path: root/include/linux/proc_fs.h
2013-05-01proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.hDavid Howells
Move non-public declarations and definitions from linux/proc_fs.h to fs/proc/internal.h. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Make the PROC_I() and PDE() macros internal to procfsDavid Howells
Make the PROC_I() and PDE() macros internal to procfs. This means making PDE_DATA() out of line. This could be made more optimal by storing PDE()->data into inode->i_private. Also provide a __PDE_DATA() that is inline and internal to procfs. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Supply a function to remove a proc entry by PDEDavid Howells
Supply a function (proc_remove()) to remove a proc entry (and any subtree rooted there) by proc_dir_entry pointer rather than by name and (optionally) root dir entry pointer. This allows us to eliminate all remaining pde->name accesses outside of procfs. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Grant Likely <grant.likely@linaro.or> cc: linux-acpi@vger.kernel.org cc: openipmi-developer@lists.sourceforge.net cc: devicetree-discuss@lists.ozlabs.org cc: linux-pci@vger.kernel.org cc: netdev@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Supply an accessor for getting the data from a PDE's parentDavid Howells
Supply an accessor function for getting the private data from the parent proc_dir_entry struct of the proc_dir_entry struct associated with an inode. ReiserFS, for instance, stores the super_block pointer in the proc directory it makes for that super_block, and a pointer to the respective seq_file show function in each of the proc files in that directory. This allows a reduction in the number of file_operations structs, open functions and seq_operations structs required. The problem otherwise is that each show function requires two pieces of data but only has storage for one per PDE (and this has no release function). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Jerry Chuang <jerry-chuang@realtek.com> cc: Maxim Mikityanskiy <maxtram95@gmail.com> cc: YAMANE Toshiaki <yamanetoshi@gmail.com> cc: linux-wireless@vger.kernel.org cc: linux-scsi@vger.kernel.org cc: devel@driverdev.osuosl.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Add proc_mkdir_data()David Howells
Add proc_mkdir_data() to allow procfs directories to be created that are annotated at the time of creation with private data rather than doing this post-creation. This means no access is then required to the proc_dir_entry struct to set this. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Neela Syam Kolli <megaraidlinux@lsi.com> cc: Jerry Chuang <jerry-chuang@realtek.com> cc: linux-scsi@vger.kernel.org cc: devel@driverdev.osuosl.org cc: linux-wireless@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}David Howells
Move some bits from linux/proc_fs.h to linux/of.h, signal.h and tty.h. Also move proc_tty_init() and proc_device_tree_init() to fs/proc/internal.h as they're internal to procfs. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> cc: devicetree-discuss@lists.ozlabs.org cc: linux-arch@vger.kernel.org cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Jri Slaby <jslaby@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Move PDE_NET() to fs/proc/proc_net.cDavid Howells
Move PDE_NET() to fs/proc/proc_net.c as that's where the only user is. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Split the namespace stuff out into linux/proc_ns.hDavid Howells
Split the proc namespace stuff out into linux/proc_ns.h. Signed-off-by: David Howells <dhowells@redhat.com> cc: netdev@vger.kernel.org cc: Serge E. Hallyn <serge.hallyn@ubuntu.com> cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Supply PDE attribute setting accessor functionsDavid Howells
Supply accessor functions to set attributes in proc_dir_entry structs. The following are supplied: proc_set_size() and proc_set_user(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> cc: linuxppc-dev@lists.ozlabs.org cc: linux-media@vger.kernel.org cc: netdev@vger.kernel.org cc: linux-wireless@vger.kernel.org cc: linux-pci@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29proc: Split kcore bits from linux/procfs.h into linux/kcore.hDavid Howells
Split kcore bits from linux/procfs.h into linux/kcore.h. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29proc: Delete create_proc_read_entry()David Howells
Delete create_proc_read_entry() as it no longer has any users. Also delete read_proc_t, write_proc_t, the read_proc member of the proc_dir_entry struct and the support functions that use them. This saves a pointer for every PDE allocated. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-29procfs: Mark create_proc_read_entry deprecatedDavid Howells
Mark create_proc_read_entry deprecated. proc_create[_data]() should be used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09try a saner locking for pde_opener...Al Viro
2013-04-09procfs: preparations for remove_proc_entry() race fixesAl Viro
* leave ->proc_fops alone; make ->pde_users negative instead * trim pde_opener * move relevant code in fs/proc/inode.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09proc: Kill create_proc_entry()David Howells
Kill create_proc_entry() in favour of create_proc_read_entry(), proc_create() and proc_create_data(). Signed-off-by: David Howells <dhowells@redhat.com>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09procfs: kill ->write_proc()Al Viro
2013-04-09procfs: add proc_remove_subtree()Al Viro
just what it sounds like; do that only to procfs subtrees you've created - doing that to something shared with another driver is not only antisocial, but might cause interesting races with proc_create() and its ilk. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-19net: proc: fix build failed when procfs is not configuredGao feng
commit d4beaa66add8aebf83ab16d2fde4e4de8dac36df "net: proc: change proc_net_fops_create to proc_create" uses proc_create to replace proc_net_fops_create, when CONFIG_PROC isn't configured, some build error will occurs. net/packet/af_packet.c: In function 'packet_net_init': net/packet/af_packet.c:3831:48: error: 'packet_seq_fops' undeclared (first use in this function) net/packet/af_packet.c:3831:48: note: each undeclared identifier is reported only once for each function it appears in There may be other build fails like above,this patch change proc_create from function to macros when CONFIG_PROC is not configured,just like what proc_net_fops_create did before this commit. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: remove proc_net_removeGao feng
proc_net_remove has been replaced by remove_proc_entry. we can remove it now. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: remove proc_net_fops_createGao feng
proc_net_fops_create has been replaced by proc_create, we can remove it now. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc patches from Andrew Morton: "Incoming: - lots of misc stuff - backlight tree updates - lib/ updates - Oleg's percpu-rwsem changes - checkpatch - rtc - aoe - more checkpoint/restart support I still have a pile of MM stuff pending - Pekka should be merging later today after which that is good to go. A number of other things are twiddling thumbs awaiting maintainer merges." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits) scatterlist: don't BUG when we can trivially return a proper error. docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output fs, fanotify: add @mflags field to fanotify output docs: add documentation about /proc/<pid>/fdinfo/<fd> output fs, notify: add procfs fdinfo helper fs, exportfs: add exportfs_encode_inode_fh() helper fs, exportfs: escape nil dereference if no s_export_op present fs, epoll: add procfs fdinfo helper fs, eventfd: add procfs fdinfo helper procfs: add ability to plug in auxiliary fdinfo providers tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test breakpoint selftests: print failure status instead of cause make error kcmp selftests: print fail status instead of cause make error kcmp selftests: make run_tests fix mem-hotplug selftests: print failure status instead of cause make error cpu-hotplug selftests: print failure status instead of cause make error mqueue selftests: print failure status instead of cause make error vm selftests: print failure status instead of cause make error ubifs: use prandom_bytes mtd: nandsim: use prandom_bytes ...
2012-12-17fs, epoll: add procfs fdinfo helperCyrill Gorcunov
This allows us to print out eventpoll target file descriptor, events and data, the /proc/pid/fdinfo/fd consists of | pos: 0 | flags: 02 | tfd: 5 events: 1d data: ffffffffffffffff enabled: 1 [avagin@: fix for unitialized ret variable] Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: James Bottomley <jbottomley@parallels.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Matthew Helsley <matt.helsley@gmail.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-20proc: Usable inode numbers for the namespace file descriptors.Eric W. Biederman
Assign a unique proc inode to each namespace, and use that inode number to ensure we only allocate at most one proc inode for every namespace in proc. A single proc inode per namespace allows userspace to test to see if two processes are in the same namespace. This has been a long requested feature and only blocked because a naive implementation would put the id in a global space and would ultimately require having a namespace for the names of namespaces, making migration and certain virtualization tricks impossible. We still don't have per superblock inode numbers for proc, which appears necessary for application unaware checkpoint/restart and migrations (if the application is using namespace file descriptors) but that is now allowd by the design if it becomes important. I have preallocated the ipc and uts initial proc inode numbers so their structures can be statically initialized. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-20proc: Generalize proc inode allocationEric W. Biederman
Generalize the proc inode allocation so that it can be used without having to having to create a proc_dir_entry. This will allow namespace file descriptors to remain light weight entitities but still have the same inode number when the backing namespace is the same. Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-20userns: Implent proc namespace operationsEric W. Biederman
This allows entering a user namespace, and the ability to store a reference to a user namespace with a bind mount. Addition of missing userns_ns_put in userns_install from Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-19vfs: Add setns support for the mount namespaceEric W. Biederman
setns support for the mount namespace is a little tricky as an arbitrary decision must be made about what to set fs->root and fs->pwd to, as there is no expectation of a relationship between the two mount namespaces. Therefore I arbitrarily find the root mount point, and follow every mount on top of it to find the top of the mount stack. Then I set fs->root and fs->pwd to that location. The topmost root of the mount stack seems like a reasonable place to be. Bind mount support for the mount namespace inodes has the possibility of creating circular dependencies between mount namespaces. Circular dependencies can result in loops that prevent mount namespaces from every being freed. I avoid creating those circular dependencies by adding a sequence number to the mount namespace and require all bind mounts be of a younger mount namespace into an older mount namespace. Add a helper function proc_ns_inode so it is possible to detect when we are attempting to bind mound a namespace inode. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Add setns supportEric W. Biederman
- Pid namespaces are designed to be inescapable so verify that the passed in pid namespace is a child of the currently active pid namespace or the currently active pid namespace itself. Allowing the currently active pid namespace is important so the effects of an earlier setns can be cancelled. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-15userns: Convert proc to use kuid/kgid where appropriateEric W. Biederman
2012-01-10procfs: make proc_get_link to use dentry instead of inodeCyrill Gorcunov
Prepare the ground for the next "map_files" patch which needs a name of a link file to analyse. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vasiliy Kulikov <segoon@openwall.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-03switch procfs to umode_t useAl Viro
both proc_dir_entry ->mode and populating functions Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-27proc: make struct proc_dir_entry::name a terminal array rather than a pointerDavid Howells
Since __proc_create() appends the name it is given to the end of the PDE structure that it allocates, there isn't a need to store a name pointer. Instead we can just replace the name pointer with a terminal char array of _unspecified_ length. The compiler will simply append the string to statically defined variables of PDE type overlapping any hole at the end of the structure and, unlike specifying an explicitly _zero_ length array, won't give a warning if you try to statically initialise it with a string of more than zero length. Also, whilst we're at it: (1) Move namelen to end just prior to name and reduce it to a single byte (name shouldn't be longer than NAME_MAX). (2) Move pde_unload_lock two places further on so that if it's four bytes in size on a 64-bit machine, it won't cause an unused hole in the PDE struct. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfdLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd: net: fix get_net_ns_by_fd for !CONFIG_NET_NS ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry. ns: Declare sys_setns in syscalls.h net: Allow setting the network namespace by fd ns proc: Add support for the ipc namespace ns proc: Add support for the uts namespace ns proc: Add support for the network namespace. ns: Introduce the setns syscall ns: proc files for namespace naming policy.
2011-05-25proc: make struct proc_maps_private truly privateStephen Wilson
Now that mm/mempolicy.c is no longer implementing /proc/pid/numa_maps there is no need to export struct proc_maps_private to the world. Move it to fs/proc/internal.h instead. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18procfs: add stub for proc_mkdir_mode()Randy Dunlap
Provide a stub for proc_mkdir_mode() when CONFIG_PROC_FS is not enabled, just like the stub for proc_mkdir(). Fixes this linux-next build error: drivers/net/wireless/airo.c:4504: error: implicit declaration of function 'proc_mkdir_mode' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10ns proc: Add support for the ipc namespaceEric W. Biederman
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-05-10ns proc: Add support for the uts namespaceEric W. Biederman
2011-05-10ns proc: Add support for the network namespace.Eric W. Biederman
Implementing file descriptors for the network namespace is simple and straight forward. Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-05-10ns: proc files for namespace naming policy.Eric W. Biederman
Create files under /proc/<pid>/ns/ to allow controlling the namespaces of a process. This addresses three specific problems that can make namespaces hard to work with. - Namespaces require a dedicated process to pin them in memory. - It is not possible to use a namespace unless you are the child of the original creator. - Namespaces don't have names that userspace can use to talk about them. The namespace files under /proc/<pid>/ns/ can be opened and the file descriptor can be used to talk about a specific namespace, and to keep the specified namespace alive. A namespace can be kept alive by either holding the file descriptor open or bind mounting the file someplace else. aka: mount --bind /proc/self/ns/net /some/filesystem/path mount --bind /proc/self/fd/<N> /some/filesystem/path This allows namespaces to be named with userspace policy. It requires additional support to make use of these filedescriptors and that will be comming in the following patches. Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-03-23proc: make struct proc_dir_entry::namelen unsigned intAlexey Dobriyan
1. namelen is declared "unsigned short" which hints for "maybe space savings". Indeed in 2.4 struct proc_dir_entry looked like: struct proc_dir_entry { unsigned short low_ino; unsigned short namelen; Now, low_ino is "unsigned int", all savings were gone for a long time. "struct proc_dir_entry" is not that countless to worry about it's size, anyway. 2. converting from unsigned short to int/unsigned int can only create problems, we better play it safe. Space is not really conserved, because of natural alignment for the next field. sizeof(struct proc_dir_entry) remains the same. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmemmap rangeKAMEZAWA Hiroyuki
Benjamin Herrenschmidt <benh@kernel.crashing.org> pointed out that vmemmap range is not included in KCORE_RAM, KCORE_VMALLOC .... This adds KCORE_VMEMMAP if SPARSEMEM_VMEMMAP is used. By this, vmemmap can be readable via /proc/kcore Because it's not vmalloc area, vread/vwrite cannot be used. But the range is static against the memory layout, this patch handles vmemmap area by the same scheme with physical memory. This patch assumes SPARSEMEM_VMEMMAP range is not in VMALLOC range. It's correct now. [akpm@linux-foundation.org: fix typo] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: use usual list for kclistKAMEZAWA Hiroyuki
This patchset is for /proc/kcore. With this, - many per-arch hooks are removed. - /proc/kcore will know really valid physical memory area. - /proc/kcore will be aware of memory hotplug. - /proc/kcore will be architecture independent i.e. if an arch supports CONFIG_MMU, it can use /proc/kcore. (if the arch uses usual memory layout.) This patch: /proc/kcore uses its own list handling codes. It's better to use generic list codes. No changes in logic. just clean up. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Move junk from proc_fs.h to fs/proc/internal.hAl Viro
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: remove fs/proc/proc_misc.cAlexey Dobriyan
Now that everything was moved to their more or less expected places, apply rm(1). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
