path: root/include/linux/proc_fs.h
2008-04-29proc: introduce proc_create_data to setup de->dataDenis V. Lunev
This set of patches fixes an proc ->open'less usage due to ->proc_fops flip in the most part of the kernel code. The original OOPS is described in the commit 2d3a4e3666325a9709cc8ea2e88151394e8f20fc: Typical PDE creation code looks like: pde = create_proc_entry("foo", 0, NULL); if (pde) pde->proc_fops = &foo_proc_fops; Notice that PDE is first created, only then ->proc_fops is set up to final value. This is a problem because right after creation a) PDE is fully visible in /proc , and b) ->proc_fops are proc_file_operations which do not have ->open callback. So, it's possible to ->read without ->open (see one class of oopses below). The fix is new API called proc_create() which makes sure ->proc_fops are set up before gluing PDE to main tree. Typical new code looks like: pde = proc_create("foo", 0, NULL, &foo_proc_fops); if (!pde) return -ENOMEM; Fix most networking users for a start. In the long run, create_proc_entry() for regular files will go. In addition to this, proc_create_data is introduced to fix reading from proc without PDE->data. The race is basically the same as above. create_proc_entries is replaced in the entire kernel code as new method is also simply better. This patch: The problem is the same as for de->proc_fops. Right now PDE becomes visible without data set. So, the entry could be looked up without data. This, in most cases, will simply OOPS. proc_create_data call is created to address this issue. proc_create now becomes a wrapper around it. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Chris Mason <chris.mason@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Len Brown <lenb@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Osterlund <petero2@telia.com> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Takashi Iwai <tiwai@suse.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove ->get_info infrastructureAlexey Dobriyan
Now that last dozen or so users of ->get_info were removed, ditch it too. Everyone sane shouldd have switched to seq_file interface long ago. P.S.: Co-existing 3 interfaces (->get_info/->read_proc/->proc_fops) for proc is long-standing crap, BTW, thus a) put ->read_proc/->write_proc/read_proc_entry() users on death row, b) new such users should be rejected, c) everyone is encouraged to convert his favourite ->read_proc user or I'll do it, lazy bastards. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root_driverAlexey Dobriyan
Use creation by full path: "driver/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root_fsAlexey Dobriyan
Use creation by full path instead: "fs/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29procfs task exe symlinkMatt Helsley
The kernel implements readlink of /proc/pid/exe by getting the file from the first executable VMA. Then the path to the file is reconstructed and reported as the result. Because of the VMA walk the code is slightly different on nommu systems. This patch avoids separate /proc/pid/exe code on nommu systems. Instead of walking the VMAs to find the first executable file-backed VMA we store a reference to the exec'd file in the mm_struct. That reference would prevent the filesystem holding the executable file from being unmounted even after unmapping the VMAs. So we track the number of VM_EXECUTABLE VMAs and drop the new reference when the last one is unmapped. This avoids pinning the mounted filesystem. [akpm@linux-foundation.org: improve comments] [yamamoto@valinux.co.jp: fix dup_mmap] Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com> Cc:"Eric W. Biederman" <ebiederm@xmission.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-07[NET]: Make /proc/net a symlink on /proc/self/net (v3)Pavel Emelyanov
Current /proc/net is done with so called "shadows", but current implementation is broken and has little chances to get fixed. The problem is that dentries subtree of /proc/net directory has fancy revalidation rules to make processes living in different net namespaces see different entries in /proc/net subtree, but currently, tasks see in the /proc/net subdir the contents of any other namespace, depending on who opened the file first. The proposed fix is to turn /proc/net into a symlink, which points to /proc/self/net, which in turn shows what previously was in /proc/net - the network-related info, from the net namespace the appropriate task lives in. # ls -l /proc/net lrwxrwxrwx 1 root root 8 Mar 5 15:17 /proc/net -> self/net In other words - this behaves like /proc/mounts, but unlike "mounts", "net" is not a file, but a directory. Changes from v2: * Fixed discrepancy of /proc/net nlink count and selinux labeling screwup pointed out by Stephen. To get the correct nlink count the ->getattr callback for /proc/net is overridden to read one from the net->proc_net entry. To make selinux still work the net->proc_net entry is initialized properly, i.e. with the "net" name and the proc_net parent. Selinux fixes are Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Changes from v1: * Fixed a task_struct leak in get_proc_task_net, pointed out by Paul. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14d_path: Make proc_get_link() use a struct path argumentJan Blunck
proc_get_link() is always called with a dentry and a vfsmount from a struct path. Make proc_get_link() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: fix ->open'less usage due to ->proc_fops flipAlexey Dobriyan
Typical PDE creation code looks like: pde = create_proc_entry("foo", 0, NULL); if (pde) pde->proc_fops = &foo_proc_fops; Notice that PDE is first created, only then ->proc_fops is set up to final value. This is a problem because right after creation a) PDE is fully visible in /proc , and b) ->proc_fops are proc_file_operations which do not have ->open callback. So, it's possible to ->read without ->open (see one class of oopses below). The fix is new API called proc_create() which makes sure ->proc_fops are set up before gluing PDE to main tree. Typical new code looks like: pde = proc_create("foo", 0, NULL, &foo_proc_fops); if (!pde) return -ENOMEM; Fix most networking users for a start. In the long run, create_proc_entry() for regular files will go. BUG: unable to handle kernel NULL pointer dereference at virtual address 00000024 printing eip: c1188c1b *pdpt = 000000002929e001 *pde = 0000000000000000 Oops: 0002 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/block/sda/sda1/dev Modules linked in: foo af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 24679, comm: cat Not tainted (2.6.24-rc3-mm1 #2) EIP: 0060:[<c1188c1b>] EFLAGS: 00210002 CPU: 0 EIP is at mutex_lock_nested+0x75/0x25d EAX: 000006fe EBX: fffffffb ECX: 00001000 EDX: e9340570 ESI: 00000020 EDI: 00200246 EBP: e9340570 ESP: e8ea1ef8 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 24679, ti=E8EA1000 task=E9340570 task.ti=E8EA1000) Stack: 00000000 c106f7ce e8ee05b4 00000000 00000001 458003d0 f6fb6f20 fffffffb 00000000 c106f7aa 00001000 c106f7ce 08ae9000 f6db53f0 00000020 00200246 00000000 00000002 00000000 00200246 00200246 e8ee05a0 fffffffb e8ee0550 Call Trace: [<c106f7ce>] seq_read+0x24/0x28a [<c106f7aa>] seq_read+0x0/0x28a [<c106f7ce>] seq_read+0x24/0x28a [<c106f7aa>] seq_read+0x0/0x28a [<c10818b8>] proc_reg_read+0x60/0x73 [<c1081858>] proc_reg_read+0x0/0x73 [<c105a34f>] vfs_read+0x6c/0x8b [<c105a6f3>] sys_read+0x3c/0x63 [<c10025f2>] sysenter_past_esp+0x5f/0xa5 [<c10697a7>] destroy_inode+0x24/0x33 ======================= INFO: lockdep is turned off. Code: 75 21 68 e1 1a 19 c1 68 87 00 00 00 68 b8 e8 1f c1 68 25 73 1f c1 e8 84 06 e9 ff e8 52 b8 e7 ff 83 c4 10 9c 5f fa e8 28 89 ea ff <f0> fe 4e 04 79 0a f3 90 80 7e 04 00 7e f8 eb f0 39 76 34 74 33 EIP: [<c1188c1b>] mutex_lock_nested+0x75/0x25d SS:ESP 0068:e8ea1ef8 [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: seqfile convert proc_pid_status to properly handle pid namespacesEric W. Biederman
Currently we possibly lookup the pid in the wrong pid namespace. So seq_file convert proc_pid_status which ensures the proper pid namespaces is passed in. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: s390 build fix] [akpm@linux-foundation.org: fix task_name() output] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: implement proc_single_file_operationsEric W. Biederman
Currently many /proc/pid files use a crufty precursor to the current seq_file api, and they don't have direct access to the pid_namespace or the pid of for which they are displaying data. So implement proc_single_file_operations to make the seq_file routines easy to use, and to give access to the full state of the pid of we are displaying data for. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: move clear_refs code to task_mmu.cMatt Mackall
This puts all the clear_refs code where it belongs and probably lets things compile on MMU-less systems as well. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[ATM]: Oops reading net/atm/arpDenis V. Lunev
cat /proc/net/atm/arp causes the NULL pointer dereference in the get_proc_net+0xc/0x3a. This happens as proc_get_net believes that the parent proc dir entry contains struct net. Fix this assumption for "net/atm" case. The problem is introduced by the commit c0097b07abf5f92ab135d024dd41bd2aada1512f from Eric W. Biederman/Daniel Lezcano. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-05proc: fix proc_dir_entry refcountingAlexey Dobriyan
Creating PDEs with refcount 0 and "deleted" flag has problems (see below). Switch to usual scheme: * PDE is created with refcount 1 * every de_get does +1 * every de_put() and remove_proc_entry() do -1 * once refcount reaches 0, PDE is freed. This elegantly fixes at least two following races (both observed) without introducing new locks, without abusing old locks, without spreading lock_kernel(): 1) PDE leak remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_read(&de->count) == 0) if (atomic_dec_and_test(&de->count)) if (de->deleted) /* also not taken! */ free_proc_entry(de); else de->deleted = 1; [refcount=0, deleted=1] 2) use after free remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_dec_and_test(&de->count)) if (atomic_read(&de->count) == 0) free_proc_entry(de); /* boom! */ if (de->deleted) free_proc_entry(de); BUG: unable to handle kernel paging request at virtual address 6b6b6b6b printing eip: c10acdda *pdpt = 00000000338f8001 *pde = 0000000000000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 23161, comm: cat Not tainted (2.6.24-rc2-8c0863403f109a43d7000b4646da4818220d501f #4) EIP: 0060:[<c10acdda>] EFLAGS: 00210097 CPU: 1 EIP is at strnlen+0x6/0x18 EAX: 6b6b6b6b EBX: 6b6b6b6b ECX: 6b6b6b6b EDX: fffffffe ESI: c128fa3b EDI: f380bf34 EBP: ffffffff ESP: f380be44 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 23161, ti=f380b000 task=f38f2570 task.ti=f380b000) Stack: c10ac4f0 00000278 c12ce000 f43cd2a8 00000163 00000000 7da86067 00000400 c128fa20 00896b18 f38325a8 c128fe20 ffffffff 00000000 c11f291e 00000400 f75be300 c128fa20 f769c9a0 c10ac779 f380bf34 f7bfee70 c1018e6b f380bf34 Call Trace: [<c10ac4f0>] vsnprintf+0x2ad/0x49b [<c10ac779>] vscnprintf+0x14/0x1f [<c1018e6b>] vprintk+0xc5/0x2f9 [<c10379f1>] handle_fasteoi_irq+0x0/0xab [<c1004f44>] do_IRQ+0x9f/0xb7 [<c117db3b>] preempt_schedule_irq+0x3f/0x5b [<c100264e>] need_resched+0x1f/0x21 [<c10190ba>] printk+0x1b/0x1f [<c107c8ad>] de_put+0x3d/0x50 [<c107c8f8>] proc_delete_inode+0x38/0x41 [<c107c8c0>] proc_delete_inode+0x0/0x41 [<c1066298>] generic_delete_inode+0x5e/0xc6 [<c1065aa9>] iput+0x60/0x62 [<c1063c8e>] d_kill+0x2d/0x46 [<c1063fa9>] dput+0xdc/0xe4 [<c10571a1>] __fput+0xb0/0xcd [<c1054e49>] filp_close+0x48/0x4f [<c1055ee9>] sys_close+0x67/0xa5 [<c10026b6>] sysenter_past_esp+0x5f/0x85 ======================= Code: c9 74 0c f2 ae 74 05 bf 01 00 00 00 4f 89 fa 5f 89 d0 c3 85 c9 57 89 c7 89 d0 74 05 f2 ae 75 01 4f 89 f8 5f c3 89 c1 89 c8 eb 06 <80> 38 00 74 07 40 4a 83 fa ff 75 f4 29 c8 c3 90 90 90 57 83 c9 EIP: [<c10acdda>] strnlen+0x6/0x18 SS:ESP 0068:f380be44 Also, remove broken usage of ->deleted from reiserfs: if sget() succeeds, module is already pinned and remove_proc_entry() can't happen => nobody can mark PDE deleted. Dummy proc root in netns code is not marked with refcount 1. AFAICS, we never get it, it's just for proper /proc/net removal. I double checked CLONE_NETNS continues to work. Patch survives many hours of modprobe/rmmod/cat loops without new bugs which can be attributed to refcounting. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-02[NETNS]: Fix /proc/net breakageEric W. Biederman
Well I clearly goofed when I added the initial network namespace support for /proc/net. Currently things work but there are odd details visible to user space, even when we have a single network namespace. Since we do not cache proc_dir_entry dentries at the moment we can just modify ->lookup to return a different directory inode depending on the network namespace of the process looking at /proc/net, replacing the current technique of using a magic and fragile follow_link method. To accomplish that this patch: - introduces a shadow_proc method to allow different dentries to be returned from proc_lookup. - Removes the old /proc/net follow_link magic - Fixes a weakness in our not caching of proc generic dentries. As shadow_proc uses a task struct to decided which dentry to return we can go back later and fix the proc generic caching without modifying any code that uses the shadow_proc method. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-07[NET]: Kill proc_net_create()David S. Miller
There are no more users. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19pid namespaces: initialize the namespace's proc_mntPavel Emelyanov
The namespace's proc_mnt must be kern_mount-ed to make this pointer always valid, independently of whether the user space mounted the proc or not. This solves raced in proc_flush_task, etc. with the proc_mnt switching from NULL to not-NULL. The initialization is done after the init's pid is created and hashed to make proc_get_sb() finr it and get for root inode. Sice the namespace holds the vfsmnt, vfsmnt holds the superblock and the superblock holds the namespace we must explicitly break this circle to destroy all the stuff. This is done after the init of the namespace dies. Running a few steps forward - when init exits it will kill all its children, so no proc_mnt will be needed after its death. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: make proc have multiple superblocks - one for each namespacePavel Emelyanov
Each pid namespace have to be visible through its own proc mount. Thus we need to have per-namespace proc trees with their own superblocks. We cannot easily show different pid namespace via one global proc tree, since each pid refers to different tasks in different namespaces. E.g. pid 1 refers to the init task in the initial namespace and to some other task when seeing from another namespace. Moreover - pid, exisintg in one namespace may not exist in the other. This approach has one move advantage is that the tasks from the init namespace can see what tasks live in another namespace by reading entries from another proc tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: prepare proc_flust_task() to flush entries from multiple ↵Pavel Emelyanov
proc trees The first part is trivial - we just make the proc_flush_task() to operate on arbitrary vfsmount with arbitrary ids and pass the pid and global proc_mnt to it. The other change is more tricky: I moved the proc_flush_task() call in release_task() higher to address the following problem. When flushing task from many proc trees we need to know the set of ids (not just one pid) to find the dentries' names to flush. Thus we need to pass the task's pid to proc_flush_task() as struct pid is the only object that can provide all the pid numbers. But after __exit_signal() task has detached all his pids and this information is lost. This creates a tiny gap for proc_pid_lookup() to bring some dentries back to tree and keep them in hash (since pids are still alive before __exit_signal()) till the next shrink, but since proc_flush_task() does not provide a 100% guarantee that the dentries will be flushed, this is OK to do so. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Fix race when opening a proc file while a network namespace is exiting.Eric W. Biederman
The problem: proc_net files remember which network namespace the are against but do not remember hold a reference count (as that would pin the network namespace). So we currently have a small window where the reference count on a network namespace may be incremented when opening a /proc file when it has already gone to zero. To fix this introduce maybe_get_net and get_proc_net. maybe_get_net increments the network namespace reference count only if it is greater then zero, ensuring we don't increment a reference count after it has gone to zero. get_proc_net handles all of the magic to go from a proc inode to the network namespace instance and call maybe_get_net on it. PROC_NET the old accessor is removed so that we don't get confused and use the wrong helper function. Then I fix up the callers to use get_proc_net and handle the case case where get_proc_net returns NULL. In that case I return -ENXIO because effectively the network namespace has already gone away so the files we are trying to access don't exist anymore. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-11Remove unused struct proc_dir_entry::setAlexey Dobriyan
After /proc/sys rewrite it was left unused. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Fix rmmod/read/write races in /proc entriesAlexey Dobriyan
Fix following races: =========================================== 1. Write via ->write_proc sleeps in copy_from_user(). Module disappears meanwhile. Or, more generically, system call done on /proc file, method supplied by module is called, module dissapeares meanwhile. pde = create_proc_entry() if (!pde) return -ENOMEM; pde->write_proc = ... open write copy_from_user pde = create_proc_entry(); if (!pde) { remove_proc_entry(); return -ENOMEM; /* module unloaded */ } *boom* ========================================== 2. bogo-revoke aka proc_kill_inodes() remove_proc_entry vfs_read proc_kill_inodes [check ->f_op validness] [check ->f_op->read validness] [verify_area, security permissions checks] ->f_op = NULL; if (file->f_op->read) /* ->f_op dereference, boom */ NOTE, NOTE, NOTE: file_operations are proxied for regular files only. Let's see how this scheme behaves, then extend if needed for directories. Directories creators in /proc only set ->owner for them, so proxying for directories may be unneeded. NOTE, NOTE, NOTE: methods being proxied are ->llseek, ->read, ->write, ->poll, ->unlocked_ioctl, ->ioctl, ->compat_ioctl, ->open, ->release. If your in-tree module uses something else, yell on me. Full audit pending. [akpm@linux-foundation.org: build fix] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between proc_get_inode() and remove_proc_entry()Alexey Dobriyan
proc_lookup remove_proc_entry =========== ================= lock_kernel(); spin_lock(&proc_subdir_lock); [find PDE with refcount 0] spin_unlock(&proc_subdir_lock); spin_lock(&proc_subdir_lock); [find PDE with refcount 0] [check refcount and free PDE] spin_unlock(&proc_subdir_lock); proc_get_inode: de_get(de); /* boom */ Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07smaps: add clear_refs file to clear referenceDavid Rientjes
Adds /proc/pid/clear_refs. When any non-zero number is written to this file, pte_mkold() and ClearPageReferenced() is called for each pte and its corresponding page, respectively, in that task's VMAs. This file is only writable by the user who owns the task. It is now possible to measure _approximately_ how much memory a task is using by clearing the reference bits with echo 1 > /proc/pid/clear_refs and checking the reference count for each VMA from the /proc/pid/smaps output at a measured time interval. For example, to observe the approximate change in memory footprint for a task, write a script that clears the references (echo 1 > /proc/pid/clear_refs), sleeps, and then greps for Pgs_Referenced and extracts the size in kB. Add the sizes for each VMA together for the total referenced footprint. Moments later, repeat the process and observe the difference. For example, using an efficient Mozilla: accumulated time referenced memory ---------------- ----------------- 0 s 408 kB 1 s 408 kB 2 s 556 kB 3 s 1028 kB 4 s 872 kB 5 s 1956 kB 6 s 416 kB 7 s 1560 kB 8 s 2336 kB 9 s 1044 kB 10 s 416 kB This is a valuable tool to get an approximate measurement of the memory footprint for a task. Cc: Hugh Dickins <hugh@veritas.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> [akpm@linux-foundation.org: build fixes] [mpm@selenic.com: rename for_each_pmd] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: reimplement the sysctl proc supportEric W. Biederman
With this change the sysctl inodes can be cached and nothing needs to be done when removing a sysctl table. For a cost of 2K code we will save about 4K of static tables (when we remove de from ctl_table) and 70K in proc_dir_entries that we will not allocate, or about half that on a 32bit arch. The speed feels about the same, even though we can now cache the sysctl dentries :( We get the core advantage that we don't need to have a 1 to 1 mapping between ctl table entries and proc files. Making it possible to have /proc/sys vary depending on the namespace you are in. The currently merged namespaces don't have an issue here but the network namespace under /proc/sys/net needs to have different directories depending on which network adapters are visible. By simply being a cache different directories being visible depending on who you are is trivial to implement. [akpm@osdl.org: fix uninitialised var] [akpm@osdl.org: fix ARM build] [bunk@stusta.de: make things static] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-10-02[PATCH] proc: modify proc_pident_lookup to be completely table drivenEric W. Biederman
Currently proc_pident_lookup gets the names and types from a table and then has a huge switch statement to get the inode and file operations it needs. That is silly and is becoming increasingly hard to maintain so I just put all of the information in the table. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] NOMMU: Implement /proc/pid/maps for NOMMUDavid Howells
Implement /proc/pid/maps for NOMMU by reading the vm_area_list attached to current->mm->context.vmlist. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-26[PATCH] proc: Use struct pid not struct task_refEric W. Biederman
Incrementally update my proc-dont-lock-task_structs-indefinitely patches so that they work with struct pid instead of struct task_ref. Mostly this is a straight 1-1 substitution. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: don't lock task_structs indefinitelyEric W. Biederman
Every inode in /proc holds a reference to a struct task_struct. If a directory or file is opened and remains open after the the task exits this pinning continues. With 8K stacks on a 32bit machine the amount pinned per file descriptor is about 10K. Normally I would figure a reasonable per user process limit is about 100 processes. With 80 processes, with a 1000 file descriptors each I can trigger the 00M killer on a 32bit kernel, because I have pinned about 800MB of useless data. This patch replaces the struct task_struct pointer with a pointer to a struct task_ref which has a struct task_struct pointer. The so the pinning of dead tasks does not happen. The code now has to contend with the fact that the task may now exit at any time. Which is a little but not muh more complicated. With this change it takes about 1000 processes each opening up 1000 file descriptors before I can trigger the OOM killer. Much better. [mlp@google.com: task_mmu small fixes] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Paul Jackson <pj@sgi.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Albert Cahalan <acahalan@gmail.com> Signed-off-by: Prasanna Meda <mlp@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: Rewrite the proc dentry flush on exit optimizationEric W. Biederman
To keep the dcache from filling up with dead /proc entries we flush them on process exit. However over the years that code has gotten hairy with a dentry_pointer and a lock in task_struct and misdocumented as a correctness feature. I have rewritten this code to look and see if we have a corresponding entry in the dcache and if so flush it on process exit. This removes the extra fields in the task_struct and allows me to trivially handle the case of a /proc/<tgid>/task/<pid> entry as well as the current /proc/<pid> entries. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: Replace proc_inode.type with proc_inode.fdEric W. Biederman
The sole renaming use of proc_inode.type is to discover the file descriptor number, so just store the file descriptor number and don't wory about processing this field. This removes any /proc limits on the maximum number of file descriptors, and clears the path to make the hard coded /proc inode numbers go away. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-11[PATCH] kdump proc vmcore size oveflow fixVivek Goyal
A couple of /proc/vmcore data structures overflow with 32bit systems having memory more than 4G. This patch fixes those. Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Use loff_t for size in struct proc_dir_entryManeesh Soni
Change proc_dir_entry->size to be loff_t to represent files like /proc/vmcore for 32bit systems with more than 4G memory. Needed for seeing correct size for /proc/vmcore for 32-bit systems with > 4G RAM. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] protect remove_proc_entrySteven Rostedt
It has been discovered that the remove_proc_entry has a race in the removing of entries in the proc file system that are siblings. There's no protection around the traversing and removing of elements that belong in the same subdirectory. This subdirectory list is protected in other areas by the BKL. So the BKL was at first used to protect this area too, but unfortunately, remove_proc_entry may be called with spinlocks held. The BKL may schedule, so this was not a solution. The final solution was to add a new global spin lock to protect this list, called proc_subdir_lock. This lock now protects the list in remove_proc_entry, and I also went around looking for other areas that this list is modified and added this protection there too. Care must be taken since these locations call several functions that may also schedule. Since I don't see any location that these functions that modify the subdirectory list are called by interrupts, the irqsave/restore versions of the spin lock was _not_ used. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] powerpc: Add/remove/update properties in /proc/device-treeDave C Boutcher
Add support to the proc_device_tree file for removing and updating properties. Remove just removes the proc file, update changes the data pointer within the proc file. The remainder of the device-tree changes occur elsewhere. Signed-off-by: Dave Boutcher <sleddog@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] Fix sysctl unregistration oops (CVE-2005-2709)Al Viro
You could open the /proc/sys/net/ipv4/conf/<if>/<whatever> file, then wait for interface to go away, try to grab as much memory as possible in hope to hit the (kfreed) ctl_table. Then fill it with pointers to your function. Then do read from file you've opened and if you are lucky, you'll get it called as ->proc_handler() in kernel mode. So this is at least an Oops and possibly more. It does depend on an interface going away though, so less of a security risk than it would otherwise be. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[PATCH] ppc64: SMU partition recoveryBenjamin Herrenschmidt
This patch adds the ability to the SMU driver to recover missing calibration partitions from the SMU chip itself. It also adds some dynamic mecanism to /proc/device-tree so that new properties are visible to userland. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-25[PATCH] kdump: Access dump file in elf format (/proc/vmcore)Vivek Goyal
From: "Vivek Goyal" <vgoyal@in.ibm.com> o Support for /proc/vmcore interface. This interface exports elf core image either in ELF32 or ELF64 format, depending on the format in which elf headers have been stored by crashed kernel. o Added support for CONFIG_VMCORE config option. o Removed the dependency on /proc/kcore. From: "Eric W. Biederman" <ebiederm@xmission.com> This patch has been refactored to more closely match the prevailing style in the affected files. And to clearly indicate the dependency between /proc/kcore and proc/vmcore.c From: Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that provides an ELF format interface to the previous kernel's memory post kexec reboot. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
