path: root/include/linux/ptrace.h
2011-07-17ptrace: dont send SIGSTOP on auto-attach if PT_SEIZEDOleg Nesterov
The fake SIGSTOP during attach has numerous problems. PTRACE_SEIZE is already fine, but we have basically the same problems is SIGSTOP is sent on auto-attach, the tracer can't know if this signal signal should be cancelled or not. Change ptrace_event() to set JOBCTL_TRAP_STOP if the new child is PT_SEIZED, this triggers the PTRACE_EVENT_STOP report. Thereafter a PT_SEIZED task can never report the bogus SIGSTOP. Test-case: #define PTRACE_SEIZE 0x4206 #define PTRACE_SEIZE_DEVEL 0x80000000 #define PTRACE_EVENT_STOP 7 #define WEVENT(s) ((s & 0xFF0000) >> 16) int main(void) { int child, grand_child, status; long message; child = fork(); if (!child) { kill(getpid(), SIGSTOP); fork(); assert(0); return 0x23; } assert(ptrace(PTRACE_SEIZE, child, 0,PTRACE_SEIZE_DEVEL) == 0); assert(wait(&status) == child); assert(WIFSTOPPED(status) && WSTOPSIG(status) == SIGSTOP); assert(ptrace(PTRACE_SETOPTIONS, child, 0, PTRACE_O_TRACEFORK) == 0); assert(ptrace(PTRACE_CONT, child, 0,0) == 0); assert(waitpid(child, &status, 0) == child); assert(WIFSTOPPED(status) && WSTOPSIG(status) == SIGTRAP); assert(WEVENT(status) == PTRACE_EVENT_FORK); assert(ptrace(PTRACE_GETEVENTMSG, child, 0, &message) == 0); grand_child = message; assert(waitpid(grand_child, &status, 0) == grand_child); assert(WIFSTOPPED(status) && WSTOPSIG(status) == SIGTRAP); assert(WEVENT(status) == PTRACE_EVENT_STOP); kill(child, SIGKILL); kill(grand_child, SIGKILL); return 0; } Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-07-17ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()Oleg Nesterov
If the new child is traced, do_fork() adds the pending SIGSTOP. It assumes that either it is traced because of auto-attach or the tracer attached later, in both cases sigaddset/set_thread_flag is correct even if SIGSTOP is already pending. Now that we have PTRACE_SEIZE this is no longer right in the latter case. If the tracer does PTRACE_SEIZE after copy_process() makes the child visible the queued SIGSTOP is wrong. We could check PT_SEIZED bit and change ptrace_attach() to set both PT_PTRACED and PT_SEIZED bits simultaneously but see the next patch, we need to know whether this child was auto-attached or not anyway. So this patch simply moves this code to ptrace_init_task(), this way we can never race with ptrace_attach(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-07-17ptrace_init_task: initialize child->jobctl explicitlyOleg Nesterov
new_child->jobctl is not initialized during the fork, it is copied from parent->jobctl. Currently this is harmless, the forking task is running and copy_process() can't succeed if signal_pending() is true, so only JOBCTL_STOP_DEQUEUED can be copied. Still this is a bit fragile, it would be more clean to set ->jobctl = 0 explicitly. Also, check ->ptrace != 0 instead of PT_PTRACED, move the CONFIG_HAVE_HW_BREAKPOINT code up. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-06-27ptrace: ptrace_reparented() should check same_thread_group()Oleg Nesterov
ptrace_reparented() naively does parent != real_parent, this means it returns true even if the tracer _is_ the real parent. This is per process thing, not per-thread. The only reason ->real_parent can point to the non-leader thread is that we have __WNOTHREAD. Change it to check !same_thread_group(parent, real_parent). It has two callers, and in both cases the current check does not look right. exit_notify: we should respect ->exit_signal if the exiting leader is traced by any thread from the parent thread group. It is the child of the whole group, and we are going to send the signal to the whole group. wait_task_zombie: without __WNOTHREAD do_wait() should do the same for any thread, only sys_ptrace() is "bound" to the single thread. However do_wait(WEXITED) succeeds but does not release a traced natural child unless the caller is the tracer. Test-case: void *tfunc(void *arg) { assert(ptrace(PTRACE_ATTACH, (long)arg, 0,0) == 0); pause(); return NULL; } int main(void) { pthread_t thr; pid_t pid, stat, ret; pid = fork(); if (!pid) { pause(); assert(0); } assert(pthread_create(&thr, NULL, tfunc, (void*)(long)pid) == 0); assert(waitpid(-1, &stat, 0) == pid); assert(WIFSTOPPED(stat)); kill(pid, SIGKILL); assert(waitpid(-1, &stat, 0) == pid); assert(WIFSIGNALED(stat) && WTERMSIG(stat) == SIGKILL); ret = waitpid(pid, &stat, 0); if (ret < 0) return 0; printf("WTF? %d is dead, but: wait=%d stat=%x\n", pid, ret, stat); return 1; } Note that the main thread simply does pid = fork(); kill(pid, SIGKILL); and then without the patch wait4(WEXITED) succeeds twice and reports WTERMSIG(stat) == SIGKILL. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-06-22ptrace: s/tracehook_tracer_task()/ptrace_parent()/Tejun Heo
tracehook.h is on the way out. Rename tracehook_tracer_task() to ptrace_parent() and move it from tracehook.h to ptrace.h. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: John Johansen <john.johansen@canonical.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-22ptrace: move SIGTRAP on exec(2) logic to ptrace_event()Tejun Heo
Move SIGTRAP on exec(2) logic from tracehook_report_exec() to ptrace_event(). This is part of changes to make ptrace_event() smarter and handle ptrace event related details in one place. This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-22ptrace: introduce ptrace_event_enabled() and simplify ptrace_event() and ↵Tejun Heo
tracehook_prepare_clone() This patch implements ptrace_event_enabled() which tests whether a given PTRACE_EVENT_* is enabled and use it to simplify ptrace_event() and tracehook_prepare_clone(). PT_EVENT_FLAG() macro is added which calculates PT_TRACE_* flag from PTRACE_EVENT_*. This is used to define PT_TRACE_* flags and by ptrace_event_enabled() to find the matching flag. This is used to make ptrace_event() and tracehook_prepare_clone() simpler. * ptrace_event() callers were responsible for providing mask to test whether the event was enabled. This patch implements ptrace_event_enabled() and make ptrace_event() drop @mask and determine whether the event is enabled from @event. Note that @event is constant and this conversion doesn't add runtime overhead. All conversions except tracehook_report_clone_complete() are trivial. tracehook_report_clone_complete() used to use 0 for @mask (always enabled) but now tests whether the specified event is enabled. This doesn't cause any behavior difference as it's guaranteed that the event specified by @trace is enabled. * tracehook_prepare_clone() now only determines which event is applicable and use ptrace_event_enabled() for enable test. This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-22ptrace: kill task_ptrace()Tejun Heo
task_ptrace(task) simply dereferences task->ptrace and isn't even used consistently only adding confusion. Kill it and directly access ->ptrace instead. This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-16ptrace: implement PTRACE_LISTENTejun Heo
The previous patch implemented async notification for ptrace but it only worked while trace is running. This patch introduces PTRACE_LISTEN which is suggested by Oleg Nestrov. It's allowed iff tracee is in STOP trap and puts tracee into quasi-running state - tracee never really runs but wait(2) and ptrace(2) consider it to be running. While ptracer is listening, tracee is allowed to re-enter STOP to notify an async event. Listening state is cleared on the first notification. Ptracer can also clear it by issuing INTERRUPT - tracee will re-trap into STOP with listening state cleared. This allows ptracer to monitor group stop state without running tracee - use INTERRUPT to put tracee into STOP trap, issue LISTEN and then wait(2) to wait for the next group stop event. When it happens, PTRACE_GETSIGINFO provides information to determine the current state. Test program follows. #define PTRACE_SEIZE 0x4206 #define PTRACE_INTERRUPT 0x4207 #define PTRACE_LISTEN 0x4208 #define PTRACE_SEIZE_DEVEL 0x80000000 static const struct timespec ts1s = { .tv_sec = 1 }; int main(int argc, char **argv) { pid_t tracee, tracer; int i; tracee = fork(); if (!tracee) while (1) pause(); tracer = fork(); if (!tracer) { siginfo_t si; ptrace(PTRACE_SEIZE, tracee, NULL, (void *)(unsigned long)PTRACE_SEIZE_DEVEL); ptrace(PTRACE_INTERRUPT, tracee, NULL, NULL); repeat: waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_GETSIGINFO, tracee, NULL, &si); if (!si.si_code) { printf("tracer: SIG %d\n", si.si_signo); ptrace(PTRACE_CONT, tracee, NULL, (void *)(unsigned long)si.si_signo); goto repeat; } printf("tracer: stopped=%d signo=%d\n", si.si_signo != SIGTRAP, si.si_signo); if (si.si_signo != SIGTRAP) ptrace(PTRACE_LISTEN, tracee, NULL, NULL); else ptrace(PTRACE_CONT, tracee, NULL, NULL); goto repeat; } for (i = 0; i < 3; i++) { nanosleep(&ts1s, NULL); printf("mother: SIGSTOP\n"); kill(tracee, SIGSTOP); nanosleep(&ts1s, NULL); printf("mother: SIGCONT\n"); kill(tracee, SIGCONT); } nanosleep(&ts1s, NULL); kill(tracer, SIGKILL); kill(tracee, SIGKILL); return 0; } This is identical to the program to test TRAP_NOTIFY except that tracee is PTRACE_LISTEN'd instead of PTRACE_CONT'd when group stopped. This allows ptracer to monitor when group stop ends without running tracee. # ./test-listen tracer: stopped=0 signo=5 mother: SIGSTOP tracer: SIG 19 tracer: stopped=1 signo=19 mother: SIGCONT tracer: stopped=0 signo=5 tracer: SIG 18 mother: SIGSTOP tracer: SIG 19 tracer: stopped=1 signo=19 mother: SIGCONT tracer: stopped=0 signo=5 tracer: SIG 18 mother: SIGSTOP tracer: SIG 19 tracer: stopped=1 signo=19 mother: SIGCONT tracer: stopped=0 signo=5 tracer: SIG 18 -v2: Moved JOBCTL_LISTENING check in wait_task_stopped() into task_stopped_code() as suggested by Oleg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-16ptrace: implement PTRACE_INTERRUPTTejun Heo
Currently, there's no way to trap a running ptracee short of sending a signal which has various side effects. This patch implements PTRACE_INTERRUPT which traps ptracee without any signal or job control related side effect. The implementation is almost trivial. It uses the group stop trap - SIGTRAP | PTRACE_EVENT_STOP << 8. A new trap flag JOBCTL_TRAP_INTERRUPT is added, which is set on PTRACE_INTERRUPT and cleared when any trap happens. As INTERRUPT should be useable regardless of the current state of tracee, task_is_traced() test in ptrace_check_attach() is skipped for INTERRUPT. PTRACE_INTERRUPT is available iff tracee is attached with PTRACE_SEIZE. Test program follows. #define PTRACE_SEIZE 0x4206 #define PTRACE_INTERRUPT 0x4207 #define PTRACE_SEIZE_DEVEL 0x80000000 static const struct timespec ts100ms = { .tv_nsec = 100000000 }; static const struct timespec ts1s = { .tv_sec = 1 }; static const struct timespec ts3s = { .tv_sec = 3 }; int main(int argc, char **argv) { pid_t tracee; tracee = fork(); if (tracee == 0) { nanosleep(&ts100ms, NULL); while (1) { printf("tracee: alive pid=%d\n", getpid()); nanosleep(&ts1s, NULL); } } if (argc > 1) kill(tracee, SIGSTOP); nanosleep(&ts100ms, NULL); ptrace(PTRACE_SEIZE, tracee, NULL, (void *)(unsigned long)PTRACE_SEIZE_DEVEL); if (argc > 1) { waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_CONT, tracee, NULL, NULL); } nanosleep(&ts3s, NULL); printf("tracer: INTERRUPT and DETACH\n"); ptrace(PTRACE_INTERRUPT, tracee, NULL, NULL); waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_DETACH, tracee, NULL, NULL); nanosleep(&ts3s, NULL); printf("tracer: exiting\n"); kill(tracee, SIGKILL); return 0; } When called without argument, tracee is seized from running state, interrupted and then detached back to running state. # ./test-interrupt tracee: alive pid=4546 tracee: alive pid=4546 tracee: alive pid=4546 tracer: INTERRUPT and DETACH tracee: alive pid=4546 tracee: alive pid=4546 tracee: alive pid=4546 tracer: exiting When called with argument, tracee is seized from stopped state, continued, interrupted and then detached back to stopped state. # ./test-interrupt 1 tracee: alive pid=4548 tracee: alive pid=4548 tracee: alive pid=4548 tracer: INTERRUPT and DETACH tracer: exiting Before PTRACE_INTERRUPT, once the tracee was running, there was no way to trap tracee and do PTRACE_DETACH without causing side effect. -v2: Updated to use task_set_jobctl_pending() so that it doesn't end up scheduling TRAP_STOP if child is dying which may make the child unkillable. Spotted by Oleg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-16ptrace: implement PTRACE_SEIZETejun Heo
PTRACE_ATTACH implicitly issues SIGSTOP on attach which has side effects on tracee signal and job control states. This patch implements a new ptrace request PTRACE_SEIZE which attaches a tracee without trapping it or affecting its signal and job control states. The usage is the same with PTRACE_ATTACH but it takes PTRACE_SEIZE_* flags in @data. Currently, the only defined flag is PTRACE_SEIZE_DEVEL which is a temporary flag to enable PTRACE_SEIZE. PTRACE_SEIZE will change ptrace behaviors outside of attach itself. The changes will be implemented gradually and the DEVEL flag is to prevent programs which expect full SEIZE behavior from using it before all the behavior modifications are complete while allowing unit testing. The flag will be removed once SEIZE behaviors are completely implemented. * PTRACE_SEIZE, unlike ATTACH, doesn't force tracee to trap. After attaching tracee continues to run unless a trap condition occurs. * PTRACE_SEIZE doesn't affect signal or group stop state. * If PTRACE_SEIZE'd, group stop uses PTRACE_EVENT_STOP trap which uses exit_code of (signr | PTRACE_EVENT_STOP << 8) where signr is one of the stopping signals if group stop is in effect or SIGTRAP otherwise, and returns usual trap siginfo on PTRACE_GETSIGINFO instead of NULL. Seizing sets PT_SEIZED in ->ptrace of the tracee. This flag will be used to determine whether new SEIZE behaviors should be enabled. Test program follows. #define PTRACE_SEIZE 0x4206 #define PTRACE_SEIZE_DEVEL 0x80000000 static const struct timespec ts100ms = { .tv_nsec = 100000000 }; static const struct timespec ts1s = { .tv_sec = 1 }; static const struct timespec ts3s = { .tv_sec = 3 }; int main(int argc, char **argv) { pid_t tracee; tracee = fork(); if (tracee == 0) { nanosleep(&ts100ms, NULL); while (1) { printf("tracee: alive\n"); nanosleep(&ts1s, NULL); } } if (argc > 1) kill(tracee, SIGSTOP); nanosleep(&ts100ms, NULL); ptrace(PTRACE_SEIZE, tracee, NULL, (void *)(unsigned long)PTRACE_SEIZE_DEVEL); if (argc > 1) { waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_CONT, tracee, NULL, NULL); } nanosleep(&ts3s, NULL); printf("tracer: exiting\n"); return 0; } When the above program is called w/o argument, tracee is seized while running and remains running. When tracer exits, tracee continues to run and print out messages. # ./test-seize-simple tracee: alive tracee: alive tracee: alive tracer: exiting tracee: alive tracee: alive When called with an argument, tracee is seized from stopped state and continued, and returns to stopped state when tracer exits. # ./test-seize tracee: alive tracee: alive tracee: alive tracer: exiting # ps -el|grep test-seize 1 T 0 4720 1 0 80 0 - 941 signal ttyS0 00:00:00 test-seize -v2: SEIZE doesn't schedule TRAP_STOP and leaves tracee running as Jan suggested. -v3: PTRACE_EVENT_STOP traps now report group stop state by signr. If group stop is in effect the stop signal number is returned as part of exit_code; otherwise, SIGTRAP. This was suggested by Denys and Oleg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-04ptrace: ptrace_check_attach(): rename @kill to @ignore_state and add commentsTejun Heo
PTRACE_INTERRUPT is going to be added which should also skip task_is_traced() check in ptrace_check_attach(). Rename @kill to @ignore_state and make it bool. Add function comment while at it. This patch doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-04-25ptrace: Prepare to fix racy accesses on task breakpointsFrederic Weisbecker
When a task is traced and is in a stopped state, the tracer may execute a ptrace request to examine the tracee state and get its task struct. Right after, the tracee can be killed and thus its breakpoints released. This can happen concurrently when the tracer is in the middle of reading or modifying these breakpoints, leading to dereferencing a freed pointer. Hence, to prepare the fix, create a generic breakpoint reference holding API. When a reference on the breakpoints of a task is held, the breakpoints won't be released until the last reference is dropped. After that, no more ptrace request on the task's breakpoints can be serviced for the tracer. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Will Deacon <will.deacon@arm.com> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: v2.6.33.. <stable@kernel.org> Link: http://lkml.kernel.org/r/1302284067-7860-2-git-send-email-fweisbec@gmail.com
2011-03-04Mark ptrace_{traceme,attach,detach} staticLinus Torvalds
They are only used inside kernel/ptrace.c, and have been for a long time. We don't want to go back to the bad-old-days when architectures did things on their own, so make them static and private. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of sys_ptrace() and friendsNamhyung Kim
Since userspace API of ptrace syscall defines @addr and @data as void pointers, it would be more appropriate to define them as unsigned long in kernel. Therefore related functions are changed also. 'unsigned long' is typically used in other places in kernel as an opaque data type and that using this helps cleaning up a lot of warnings from sparse. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-26x86, perf, bts, mm: Delete the never used BTS-ptrace codePeter Zijlstra
Support for the PMU's BTS features has been upstreamed in v2.6.32, but we still have the old and disabled ptrace-BTS, as Linus noticed it not so long ago. It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without regard for other uses (perf) and doesn't provide the flexibility needed for perf either. Its users are ptrace-block-step and ptrace-bts, since ptrace-bts was never used and ptrace-block-step can be implemented using a much simpler approach. So axe all 3000 lines of it. That includes the *locked_memory*() APIs in mm/mlock.c as well. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Markus Metzger <markus.t.metzger@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <20100325135413.938004390@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-12ptrace: move user_enable_single_step & co prototypes to linux/ptrace.hChristoph Hellwig
While in theory user_enable_single_step/user_disable_single_step/ user_enable_blockstep could also be provided as an inline or macro there's no good reason to do so, and having the prototype in one places keeps code size and confusion down. Roland said: The original thought there was that user_enable_single_step() et al might well be only an instruction or three on a sane machine (as if we have any of those!), and since there is only one call site inlining would be beneficial. But I agree that there is no strong reason to care about inlining it. As to the arch changes, there is only one thought I'd add to the record. It was always my thinking that for an arch where PTRACE_SINGLESTEP does text-modifying breakpoint insertion, user_enable_single_step() should not be provided. That is, arch_has_single_step()=>true means that there is an arch facility with "pure" semantics that does not have any unexpected side effects. Inserting a breakpoint might do very unexpected strange things in multi-threaded situations. Aside from that, it is a peculiar side effect that user_{enable,disable}_single_step() should cause COW de-sharing of text pages and so forth. For PTRACE_SINGLESTEP, all these peculiarities are the status quo ante for that arch, so having arch_ptrace() itself do those is one thing. But for building other things in the future, it is nicer to have a uniform "pure" semantics that arch-independent code can expect. OTOH, all such arch issues are really up to the arch maintainer. As of today, there is nothing but ptrace using user_enable_single_step() et al so it's a distinction without a practical difference. If/when there are other facilities that use user_enable_single_step() and might care, the affected arch's can revisit the question when someone cares about the quality of the arch support for said new facility. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-23ptrace: Fix ptrace_regset() comments and diagnose errors specificallySuresh Siddha
Return -EINVAL for the bad size and for unrecognized NT_* type in ptrace_regset() instead of -EIO. Also update the comments for this ptrace interface with more clarifications. Requested-by: Roland McGrath <roland@redhat.com> Requested-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20100222225240.397523600@sbs-t61.sc.intel.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-11ptrace: Add support for generic PTRACE_GETREGSET/PTRACE_SETREGSETSuresh Siddha
Generic support for PTRACE_GETREGSET/PTRACE_SETREGSET commands which export the regsets supported by each architecture using the correponding NT_* types. These NT_* types are already part of the userland ABI, used in representing the architecture specific register sets as different NOTES in an ELF core file. 'addr' parameter for the ptrace system call encode the REGSET type (using the corresppnding NT_* type) and the 'data' parameter points to the struct iovec having the user buffer and the length of that buffer. struct iovec iov = { buf, len}; ret = ptrace(PTRACE_GETREGSET/PTRACE_SETREGSET, pid, NT_XXX_TYPE, &iov); On successful completion, iov.len will be updated by the kernel specifying how much the kernel has written/read to/from the user's iov.buf. x86 extended state registers are primarily exported using this interface. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20100211195614.886724710@sbs-t61.sc.intel.com> Acked-by: Hongjiu Lu <hjl.tools@gmail.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-16ptrace: introduce user_single_step_siginfo() helperOleg Nesterov
Suggested by Roland. Currently there is no way to synthesize a single-stepping trap in the arch-independent manner. This patch adds the default helper which fills siginfo_t, arch/ can can override it. Architetures which implement user_enable_single_step() should add user_single_step_siginfo() also. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16ptrace: cleanup ptrace_init_task()->ptrace_link() pathOleg Nesterov
No functional changes. ptrace_init_task() looks confusing, as if we always auto-attach when "bool ptrace" argument is true, while in fact we attach only if current is traced. Make the code more explicit and kill now unused ptrace_link(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ptrace_get_task_struct: s/tasklist/rcu/, make it staticOleg Nesterov
- Use rcu_read_lock() instead of tasklist_lock to find/get the task in ptrace_get_task_struct(). - Make it static, it has no callers outside of ptrace.c. - The comment doesn't match the reality, this helper does not do any checks. Beacuse it is really trivial and static I removed the whole comment. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07x86, ptrace: add bts context unconditionallyMarkus Metzger
Add the ptrace bts context field to task_struct unconditionally. Initialize the field directly in copy_process(). Remove all the unneeded functionality used to initialize that field. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Cc: roland@redhat.com Cc: eranian@googlemail.com Cc: oleg@redhat.com Cc: juan.villacis@intel.com Cc: ak@linux.jf.intel.com LKML-Reference: <20090403144603.292754000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02forget_original_parent: split out the un-ptrace partOleg Nesterov
By discussion with Roland. - Rename ptrace_exit() to exit_ptrace(), and change it to do all the necessary work with ->ptraced list by its own. - Move this code from exit.c to ptrace.c - Update the comment in ptrace_detach() to explain the rechecking of the child->ptrace. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Metzger, Markus T" <markus.t.metzger@intel.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02ptrace: fix possible zombie leak on PTRACE_DETACHOleg Nesterov
When ptrace_detach() takes tasklist, the tracee can be SIGKILL'ed. If it has already passed exit_notify() we can leak a zombie, because a) ptracing disables the auto-reaping logic, and b) ->real_parent was not notified about the child's death. ptrace_detach() should follow the ptrace_exit's logic, change the code accordingly. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Roland McGrath <roland@redhat.com> Tested-by: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-20x86, bts: add fork and exit handlingMarkus Metzger
Impact: introduce new ptrace facility Add arch_ptrace_untrace() function that is called when the tracer detaches (either voluntarily or when the tracing task dies); ptrace_disable() is only called on a voluntary detach. Add ptrace_fork() and arch_ptrace_fork(). They are called when a traced task is forked. Clear DS and BTS related fields on fork. Release DS resources and reclaim memory in ptrace_untrace(). This releases resources already when the tracing task dies. We used to do that when the traced task dies. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20make ptrace_untrace() staticAdrian Bunk
ptrace_untrace() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07tracehook: fix CLONE_PTRACERoland McGrath
In the change in commit 09a05394fe2448a4139b014936330af23fa7ec83, I overlooked two nits in the logic and this broke using CLONE_PTRACE when PTRACE_O_TRACE* are not being used. A parent that is itself traced at all but not using PTRACE_O_TRACE*, using CLONE_PTRACE would have its new child fail to be traced. A parent that is not itself traced at all that uses CLONE_PTRACE (which should be a no-op in this case) would confuse the bookkeeping and lead to a crash at exit time. This restores the missing checks and fixes both failure modes. Reported-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Roland McGrath <roland@redhat.com>
2008-07-26task_current_syscallRoland McGrath
This adds the new function task_current_syscall() on machines where the asm/syscall.h interface is supported (CONFIG_HAVE_ARCH_TRACEHOOK). It's exported for modules to use in the future. This function safely samples the state of a blocked thread to collect what system call it is blocked in, and the six system call argument registers. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: release_taskRoland McGrath
This moves the ptrace-related logic from release_task into tracehook.h and ptrace.h inlines. It provides clean hooks both before and after locking tasklist_lock, for future tracing logic to do more cleanup without the lock. This also changes release_task() itself in the rare "zap_leader" case to set the leader to EXIT_DEAD before iterating. This maintains the invariant that release_task() only ever handles a task in EXIT_DEAD. This is a common-sense invariant that is already always true except in this one arcane case of zombie leader whose parent ignores SIGCHLD. This change is harmless and only costs one store in this one rare case. It keeps the expected state more consisently sane, which is nicer when debugging weirdness in release_task(). It also lets some future code in the tracehook entry points rely on this invariant for bookkeeping. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: cloneRoland McGrath
This moves all the ptrace initialization and tracing logic for task creation into tracehook.h and ptrace.h inlines. It reorganizes the code slightly, but should not change any behavior. There are four tracehook entry points, at each important stage of task creation. This keeps the interface from the core fork.c code fairly clean, while supporting the complex setup required for ptrace or something like it. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: add linux/tracehook.hRoland McGrath
This patch series introduces the "tracehook" interface layer of inlines in <linux/tracehook.h>. There are more details in the log entry for patch 01/23 and in the header file comments inside that patch. Most of these changes move code around with little or no change, and they should not break anything or change any behavior. This sets a new standard for uniform arch support to enable clean arch-independent implementations of new debugging and tracing stuff, denoted by CONFIG_HAVE_ARCH_TRACEHOOK. Patch 20/23 adds that symbol to arch/Kconfig, with comments listing everything an arch has to do before setting "select HAVE_ARCH_TRACEHOOK". These are elaborted a bit at: http://sourceware.org/systemtap/wiki/utrace/arch/HowTo The new inlines that arch code must define or call have detailed kerneldoc comments in the generic header files that say what is required. No arch is obligated to do any work, and no arch's build should be broken by these changes. There are several steps that each arch should take so it can set HAVE_ARCH_TRACEHOOK. Most of these are simple. Providing this support will let new things people add for doing debugging and tracing of user-level threads "just work" for your arch in the future. For an arch that does not provide HAVE_ARCH_TRACEHOOK, some new options for such features will not be available for config. I have done some arch work and will submit this to the arch maintainers after the generic tracehook series settles in. For now, that work is available in my GIT repositories, and in patch and mbox-of-patches form at http://people.redhat.com/roland/utrace/2.6-current/ This paves the way for my "utrace" work, to be submitted later. But it is not innately tied to that. I hope that the tracehook series can go in soon regardless of what eventually does or doesn't go on top of it. For anyone implementing any kind of new tracing/debugging plan, or just understanding all the context of the existing ptrace implementation, having tracehook.h makes things much easier to find and understand. This patch: This adds the new kernel-internal header file <linux/tracehook.h>. This is not yet used at all. The comments in the header introduce what the following series of patches is about. The aim is to formalize and consolidate all the places that the core kernel code and the arch code now ties into the ptrace implementation. These patches mostly don't cause any functional change. They just move the details of ptrace logic out of core code into tracehook.h inlines, where they are mostly compiled away to the same as before. All that changes is that everything is thoroughly documented and any future reworking of ptrace, or addition of something new, would not have to touch core code all over, just change the tracehook.h inlines. The new linux/ptrace.h inlines are used by the following patches in the new tracehook_*() inlines. Using these helpers for the ptrace event stops makes it simple to change or disable the old ptrace implementation of these stops conditionally later. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14Security: split proc ptrace checking into read vs. attachStephen Smalley
Enable security modules to distinguish reading of process state via proc from full ptrace access by renaming ptrace_may_attach to ptrace_may_access and adding a mode argument indicating whether only read access or full attach access is requested. This allows security modules to permit access to reading process state without granting full ptrace access. The base DAC/capability checking remains unchanged. Read access to /proc/pid/mem continues to apply a full ptrace attach check since check_mem_permission() already requires the current task to already be ptracing the target. The other ptrace checks within proc for elements like environ, maps, and fds are changed to pass the read mode instead of attach. In the SELinux case, we model such reading of process state as a reading of a proc file labeled with the target process' label. This enables SELinux policy to permit such reading of process state without permitting control or manipulation of the target process, as there are a number of cases where programs probe for such information via proc but do not need to be able to control the target (e.g. procps, lsof, PolicyKit, ConsoleKit). At present we have to choose between allowing full ptrace in policy (more permissive than required/desired) or breaking functionality (or in some cases just silencing the denials via dontaudit rules but this can hide genuine attacks). This version of the patch incorporates comments from Casey Schaufler (change/replace existing ptrace_may_attach interface, pass access mode), and Chris Wright (provide greater consistency in the checking). Note that like their predecessors __ptrace_may_attach and ptrace_may_attach, the __ptrace_may_access and ptrace_may_access interfaces use different return value conventions from each other (0 or -errno vs. 1 or 0). I retained this difference to avoid any changes to the caller logic but made the difference clearer by changing the latter interface to return a bool rather than an int and by adding a comment about it to ptrace.h for any future callers. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-30ptrace: introduce ptrace_reparented() helperOleg Nesterov
Add another trivial helper for the sake of grep. It also auto-documents the fact that ->parent != real_parent implies ->ptrace. No functional changes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kill PT_ATTACHEDOleg Nesterov
Since the patch "Fix ptrace_attach()/ptrace_traceme()/de_thread() race" commit f5b40e363ad6041a96e3da32281d8faa191597b9 we set PT_ATTACHED and change child->parent "atomically" wrt task_list lock. This means we can remove the checks like "PT_ATTACHED && ->parent != ptracer" which were needed to catch the "ptrace attach is in progress" case. We can also remove the flag itself since nobody else uses it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Add arch_ptrace_stopRoland McGrath
This adds support to allow asm/ptrace.h to define two new macros, arch_ptrace_stop_needed and arch_ptrace_stop. These control special machine-specific actions to be done before a ptrace stop. The new code compiles away to nothing when the new macros are not defined. This is the case on all machines to begin with. On ia64, these macros will be defined to solve the long-standing issue of ptrace vs register backing store. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30ptrace: generic PTRACE_SINGLEBLOCKRoland McGrath
This makes ptrace_request handle PTRACE_SINGLEBLOCK along with PTRACE_CONT et al. The new generic code makes use of the arch_has_block_step macro and generic entry points on machines that define them. [ mingo@elte.hu: bugfix ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30ptrace: arch_has_block_stepRoland McGrath
This defines the new macro arch_has_block_step() in linux/ptrace.h, a default for when asm/ptrace.h does not define it. This is the analog of arch_has_single_step() for step-until-branch on machines that have it. It declares the new user_enable_block_step function, which goes with the existing user_enable_single_step and user_disable_single_step. This is not used yet, but paves the way to harmonize on this interface for the arch-specific calls on all machines. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30ptrace: arch_has_single_stepRoland McGrath
This defines the new macro arch_has_single_step() in linux/ptrace.h, a default for when asm/ptrace.h does not define it. It declares the new user_enable_single_step and user_disable_single_step functions. This is not used yet, but paves the way to harmonize on this interface for the arch-specific calls on all machines. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-02restrict reading from /proc/<pid>/maps to those who share ->mm or can ptrace pidAl Viro
Contents of /proc/*/maps is sensitive and may become sensitive after open() (e.g. if target originally shares our ->mm and later does exec on suid-root binary). Check at read() (actually, ->start() of iterator) time that mm_struct we'd grabbed and locked is - still the ->mm of target - equal to reader's ->mm or the target is ptracable by reader. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_POKEDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata() function. AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless return EPERM. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_PEEKDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata() function. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Use decimal for PTRACE_ATTACH and PTRACE_DETACH.Roland McGrath
It is sure confusing that linux/ptrace.h has: #define PTRACE_SINGLESTEP 9 #define PTRACE_ATTACH 0x10 #define PTRACE_DETACH 0x11 #define PTRACE_SYSCALL 24 All the low-numbered constants are in decimal, but the last two in hex. It sure makes it likely that someone will look at this and think that 9, 10, 11 are used, and that 16 and 17 are not used. How about we use the same notation for all the numbers [0,24] in the same short list? Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] coredump: kill ptrace related stuffOleg Nesterov
With this patch zap_process() sets SIGNAL_GROUP_EXIT while sending SIGKILL to the thread group. This means that a TASK_TRACED task 1. Will be awakened by signal_wake_up(1) 2. Can't sleep again via ptrace_notify() 3. Can't go to do_signal_stop() after return from ptrace_stop() in get_signal_to_deliver() So we can remove all ptrace related stuff from coredump path. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] ptrace: document the locking rulesEric W. Biederman
After a lot of reading the code and thinking about how it behaves I have managed to figure out what the current ptrace locking rules are. The current code is in much better that it appears at first glance. The troublesome code paths are actually the code paths that violate the current rules. ptrace uses simple exclusive access as it's locking. You can only touch task->ptrace if the task is stopped and you are the ptracer, or if the task is running and are the task itself. Very simple, very easy to maintain. It just needs to be documented so people know not to touch ptrace from elsewhere. Currently we do have a few pieces of code that are in violation of this rule. Particularly the core dump code, and ptrace_attach. But so far the code looks fixable. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] fix zap_thread's ptrace related problemsOleg Nesterov
1. The tracee can go from ptrace_stop() to do_signal_stop() after __ptrace_unlink(p). 2. It is unsafe to __ptrace_unlink(p) while p->parent may wait for tasklist_lock in ptrace_detach(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@lst.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] PTRACE_SYSEMU is only for i386 and clashes with other ptrace codes ↵Paolo 'Blaisorblade' Giarrusso
of other archs PTRACE_SYSEMU{,_SINGLESTEP} is actually arch specific, for now, and the current allocated number clashes with a ptrace code of frv, i.e. PTRACE_GETFDPIC. I should have submitted this much earlier, anyway we get no breakage for this. CC: Daniel Jacobowitz <dan@debian.org> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] use ptrace_get_task_struct in various placesChristoph Hellwig
The ptrace_get_task_struct() helper that I added as part of the ptrace consolidation is useful in variety of places that currently opencode it. Switch them to the common helpers. Add a ptrace_traceme() helper that needs to be explicitly called, and simplify the ptrace_get_task_struct() interface. We don't need the request argument now, and we return the task_struct directly, using ERR_PTR() for error returns. It's a bit more code in the callers, but we have two sane routines that do one thing well now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
