path: root/include/linux/qnx4_fs.h
2009-06-11fs/qnx4: sanitize includesAl Viro
fs-internal parts of qnx4_fs.h taken to fs/qnx4/qnx4.h, includes adjusted, qnx4_fs.h doesn't need unifdef anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Sanitize qnx4 fsync handlingAl Viro
* have directory operations use mark_buffer_dirty_inode(), so that sync_mapping_buffers() would get those. * make qnx4_write_inode() honour its last argument. * get rid of insane copies of very ancient "walk the indirect blocks" in qnx4/fsync - they never matched the actual fs layout and, fortunately, never'd been called. Again, all this junk is not needed; ->fsync() should just do sync_mapping_buffers + sync_inode (and if we implement block allocation for qnx4, we'll need to use mark_buffer_dirty_inode() for extent blocks) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-07qnx: include <linux/types.h> for definitions of __[us]{8,16,32,64} typesAnders Larsen
On 2008-12-30 11:32:33, Sam Ravnborg wrote: > We have added a few additional validation checks of the userspace headers: ... > 3) We should include <linux/types.h> and not <asm/types.h> > 4) If we use a __[us]{8,16,32,64} type then we must include <linux/types.h> Satisfy these requirements for the linux/qnx*.h headers. Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-07iget: stop QNX4 from using iget() and read_inode()David Howells
Stop the QNX4 filesystem from using iget() and read_inode(). Replace qnx4_read_inode() with qnx4_iget(), and call that instead of iget(). qnx4_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. qnx4_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Anders Larsen <al@alarsen.net> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] fs/qnx4/*: fix sparse warningsAlexey Dobriyan
This patch fixes sparse warnings in the qnx4fs (and might even make qnx4fs work on big-endian boxes) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
