commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream.
Otherwise, ext4 file systems with the quota featured enable will get a
very confusing "No such process" error message if the quota code is
built as a module and the quota_v2 module has not been loaded.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
Quota tools need to know whether quota is stored in a system file or in
classical aquota.{user|group} files. So pass this information as a flag
in GETINFO quotactl.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
There is no point in declaring quotactl() syscall prototype in kernel header and
'make headers_check' complains about it. So just remove those lines.
As Al Viro pointed out path resolution during Q_QUOTAON calls to quotactl
is prone to deadlocks. We hold s_umount semaphore for reading during the
path resolution and resolution itself may need to acquire the semaphore
for writing when e. g. autofs mountpoint is passed.
Solve the problem by performing the resolution before we get hold of the
superblock (and thus s_umount semaphore). The whole thing is complicated
by the fact that some filesystems (OCFS2) ignore the path argument. So to
distinguish between filesystem which want the path and which do not we
introduce new .quota_on_meta callback which does not get the path. OCFS2
then uses this callback instead of old .quota_on.
CC: Al Viro <viro@ZenIV.linux.org.uk>
CC: Christoph Hellwig <hch@lst.de>
CC: Ted Ts'o <tytso@mit.edu>
CC: Joel Becker <joel.becker@oracle.com>
Generic per-cpu counter has some memory overhead but it is negligible for
modern systems and embedded systems compile without quota support. And code
reuse is a good thing. This patch should fix complain from preemptive kernels
which was introduced by dde9588853b1bde.
[Jan Kara: Fixed patch to work on 32-bit archs as well]
Reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Remount handling has fully moved into the filesystem, so all this is
superflous now.
Pass the larger struct fs_disk_quota to the ->set_dqblk operation so
that the Q_SETQUOTA and Q_XSETQUOTA operations can be implemented
with a single filesystem operation and we can retire the ->set_xquota
operation. The additional information (RT-subvolume accounting and
warn counts) are left zero for the VFS quota implementation.
Add new fieldmask values for setting the numer of blocks and inodes
values which is required for the VFS quota, but wasn't for XFS.
Pass the larger struct fs_disk_quota to the ->get_dqblk operation so
that the Q_GETQUOTA and Q_XGETQUOTA operations can be implemented
with a single filesystem operation and we can retire the ->get_xquota
Quota stats is mostly writable data structure. Let's alloc percpu
bucket for each value.
NOTE: dqstats_read() function is racy against dqstats_{inc,dec}
and may return inconsistent value. But this is ok since absolute
accuracy is not required.
Just use 0 / -EDQUOT directly - that's what it translates to anyway.
Get rid of the initialize dquot operation - it is now always called from
the filesystem and if a filesystem really needs it's own (which none
currently does) it can just call into it's own routine directly.
Rename the now static low-level dquot_initialize helper to __dquot_initialize
and vfs_dq_init to dquot_initialize to have a consistent namespace.
Get rid of the drop dquot operation - it is now always called from
Rename the now static low-level dquot_drop helper to __dquot_drop
and vfs_dq_drop to dquot_drop to have a consistent namespace.
Get rid of the transfer dquot operation - it is now always called from
Rename the now static low-level dquot_transfer helper to __dquot_transfer
and vfs_dq_transfer to dquot_transfer to have a consistent namespace,
and make the new dquot_transfer return a normal negative errno value
which all callers expect.
Get rid of the alloc_inode and free_inode dquot operations - they are
always called from the filesystem and if a filesystem really needs
their own (which none currently does) it can just call into it's
Also get rid of the vfs_dq_alloc/vfs_dq_free wrappers and always
call the lowlevel dquot_alloc_inode / dqout_free_inode routines
directly, which now lose the number argument which is always 1.
Get rid of the alloc_space, free_space, reserve_space, claim_space and
release_rsv dquot operations - they are always called from the filesystem
and if a filesystem really needs their own (which none currently does)
Move shared logic into the common __dquot_alloc_space,
dquot_claim_space_nodirty and __dquot_free_space low-level methods,
and rationalize the wrappers around it to move as much as possible
code into the common block for CONFIG_QUOTA vs not. Also rename
all these helpers to be named dquot_* instead of vfs_dq_*.
Current quota transfer interface support only uid/gid.
This patch extend interface in order to support various quotas types
The goal is accomplished without changes in most frequently used
vfs_dq_transfer() func.
- remove hardcoded USRQUOTA/GRPQUOTA flags
- convert int to bool for appropriate functions
Currenly sync_quota_sb does a lot of sync and truncate action that only
applies to "VFS" style quotas and is actively harmful for the sync
performance in XFS. Move it into vfs_quota_sync and add a wait parameter
to ->quota_sync to tell if we need it or not.
My audit of the GFS2 code says it's also not needed given the way GFS2
implements quotas, but I'd be happy if this can get a detailed review.
Currently inode_reservation is managed by fs itself and this
reservation is transfered on dquot_transfer(). This means what
inode_reservation must always be in sync with
dquot->dq_dqb.dqb_rsvspace. Otherwise dquot_transfer() will result
in incorrect quota(WARN_ON in dquot_claim_reserved_space() will be
triggered)
This is not easy because of complex locking order issues
for example http://bugzilla.kernel.org/show_bug.cgi?id=14739
The patch introduce quota reservation field for each fs-inode
(fs specific inode is used in order to prevent bloating generic
vfs inode). This reservation is managed by quota code internally
similar to i_blocks/i_bytes and may not be always in sync with
internal fs reservation.
Also perform some code rearrangement:
- Unify dquot_reserve_space() and dquot_reserve_space()
- Unify dquot_release_reserved_space() and dquot_free_space()
- Also this patch add missing warning update to release_rsv()
dquot_release_reserved_space() must call flush_warnings() as
dquot_free_space() does.
So far the maximum quota space limit was 4TB. Apparently this isn't enough
for Lustre guys anymore. So implement new quota format which raises block
limits to 2^64 bytes. Also store number of inodes and inode limits in
64-bit variables as 2^32 files isn't that insanely high anymore.
The first version of the patch has been developed by Andrew Perepechko
<Andrew.Perepechko@Sun.COM>.
CC: Andrew.Perepechko@Sun.COM
Move definition of this constant to linux/quota.h so that it
cannot clash with other format IDs.
Sending a message to userspace in a generic format to warn
of events (e.g. quota exceeded) in the quota subsystem is
a generically useful feature. This patch makes some minor
changes to the send_message function from dquot.c renaming
it quota_send_message, moving it to quota.c and exporting it
for use by filesystems which do not use the dquot code.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Remove this macro which is just a definition of NULL. Fix a few coding style
issues along the way.
Reserved quota will be claimed at the block allocation time. Over-booked
quota could be returned back with the release callback function.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Delayed allocation defers the block allocation at the dirty pages
flush-out time, doing quota charge/check at that time is too late.
But we can't charge the quota blocks until blocks are really allocated,
otherwise users could get overcharged after reboot from system crash.
This patch adds quota reservation for delayed allocation. Quota blocks
are reserved in memory, inode and quota won't gets dirtied until later
Unexport header files dqblk_v[12].h since except for quota format ID they
don't contain information userspace should be interested in. Move ID
definitions to quota.h.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
Increase reported version number of quota support since quota core has changed
significantly. Also remove __DQUOT_NUM_VERSION__ since nobody uses it.
Quota in a clustered environment needs to synchronize quota information
among cluster nodes. This means we have to occasionally update some
information in dquot from disk / network. On the other hand we have to
be careful not to overwrite changes administrator did via SETQUOTA.
So indicate in dquot->dq_flags which entries have been set by SETQUOTA
and quota format can clear these flags when it properly propagated
the changes.
For clustered filesystems, it can happen that space / inode usage goes
negative temporarily (because some node is allocating another node
is freeing and they are not completely in sync). So let quota code
allow this and change qsize_t so a signed type so that we don't
underflow the variables.
Coming quota support for OCFS2 is going to need quite a bit
of additional per-sb quota information. Moreover having fs.h
include all the types needed for this structure would be a
pain in the a**. So remove the union from mem_dqinfo and add
a private pointer for filesystem's use.
If filesystem can handle quota files as system files hidden from users, we can
skip a lot of cache invalidation, syncing, inode flags setting etc. when
turning quotas on, off and quota_sync. Allow filesystem to indicate that it is
hiding quota files from users by DQUOT_QUOTA_SYS_FILE flag.
Split DQUOT_USR_ENABLED (and DQUOT_GRP_ENABLED) into DQUOT_USR_USAGE_ENABLED
and DQUOT_USR_LIMITS_ENABLED. This way we are able to separately enable /
disable whether we should:
1) ignore quotas completely
2) just keep uptodate information about usage
3) actually enforce quota limits
This is going to be useful when quota is treated as filesystem metadata - we
then want to keep quota information uptodate all the time and just enable /
disable limits enforcement.
So far quota was fine with quota block limits and inode limits/numbers in
a 32-bit type. Now with rapid increase in storage sizes there are coming
requests to be able to handle quota limits above 4TB / more that 2^32 inodes.
So bump up sizes of types in mem_dqblk structure to 64-bits to be able to
handle this. Also update inode allocation / checking functions to use qsize_t
and make global structure keep quota limits in bytes so that things are
consistent.
Some filesystems would like to keep private information together with each
dquot. Add callbacks alloc_dquot and destroy_dquot allowing filesystem to
allocate larger dquots from their private slab in a similar fashion we
currently allocate inodes.
Remove CVS keywords that weren't updated for a long time from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Sometimes it may be useful for userspace to know (e.g. for some hosting
guys) that some user stopped exceeding his hardlimit or softlimit in
quotas. Implement sending of such events to userspace via quota netlink
protocol so that they don't have to poll for such events. Based on idea
and initial implementation by Vladislav Bogdanov.
Cc: Vladislav Bogdanov <slava@nsys.by>
Move declarations of some macros, which should be in fact functions to
quotaops.h. This way they can be later converted to inline functions
because we can now use declarations from quota.h. Also add necessary
includes of quotaops.h to a few files.
[akpm@linux-foundation.org: fix JFS build]
[akpm@linux-foundation.org: fix UFS build]
[vegard.nossum@gmail.com: fix QUOTA=n build]
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Arjen Pool <arjenpool@gmail.com>
Make loop in sync_dquots() checking whether there's something to write
more readable, remove useless variable and macro info_any_dirty() which
is used only in this place.
Cc: "Vegard Nossum" <vegard.nossum@gmail.com>
Note that it cannot be an inline function because we don't have struct
super_block prototype...
Currently, we just turn quotas off on remount of filesystem to read-only
state. The patch below adds necessary framework so that we can turn quotas
off on remount RO but we are able to automatically reenable them again when
filesystem is remounted to RW state. All we need to do is to keep references
to inodes of quota files when remounting RO and using these references to
reenable quotas when remounting RW.
Cleanups in quota code:
Change __inline__ to inline.
Change some macros to inline functions.
Remove vfs_quota_off_mount() macro.
DQUOT_OFF() should be (0) is CONFIG_QUOTA is disabled.
Move declaration of mark_dquot_dirty and dirty_dquot from quota.h to dquot.c
We should check whether quota limits set via Q_SETQUOTA are not exceeding
limits which quota format is able to handle.
Signed-off-by: Andrew Perepechko <andrew.perepechko@sun.com>
quota.h currently relies on asm/semaphore.h (through some chain; it
doesn't actually include semaphore.h itself) to include wait.h. As
well as being bad practice to rely on an implicit include, subsequent
patches will break this. While I'm in this file, add atomic.h and
list.h, and sort the list of includes.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Implement sending of quota messages via netlink interface. The advantage
is that in userspace we can better decide what to do with the message - for
example display a dialogue in your X session or just write the message to
the console. As a bonus, we can get rid of problems with console locking
deep inside filesystem code once we remove the old printing mechanism.
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Acked-by: Jan Kara <jack@ucw.cz>
Since quota.h declares a R/W semaphore, it should include rwsem.h
explicitly.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
