path: root/include/linux/ramoops.h
2011-07-26ramoops: make record_size a module parameterSergiu Iordache
The size of the dump is currently set using the RECORD_SIZE macro which is set to a page size. This patch makes the record size a module parameter and allows it to be set through platform data as well to allow larger dumps if needed. Signed-off-by: Sergiu Iordache <sergiu@chromium.org> Acked-by: Marco Stornelli <marco.stornelli@gmail.com> Cc: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ramoops: move dump_oops into platform dataSergiu Iordache
The platform driver currently allows setting the mem_size and mem_address. ince dump_oops is also a module parameter it would be more consistent if it could be set through platform data as well. Signed-off-by: Sergiu Iordache <sergiu@chromium.org> Acked-by: Marco Stornelli <marco.stornelli@gmail.com> Cc: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ramoops: use the platform data structure instead of module paramsKyungmin Park
As each board and system has different memory for ramoops. It's better to define the platform data instead of module params. [akpm@linux-foundation.org: fix ramoops_remove() return type] Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
