path: root/include/linux/range.h
2010-02-10x86/pci: Add cap_resource()Yinghai Lu
Prepare for 32bit pci root bus -v2: hpa said we should compare with (resource_size_t)~0 -v3: according to Linus to use MAX_RESOURCE instead. also need need to put related patches together -v4: according to Andrew, use min in cap_resource() Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-8-git-send-email-yinghai@kernel.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-10x86: Move range related operation to one fileYinghai Lu
We have almost the same code for mtrr cleanup and amd_bus checkup, and this code will also be used in replacing bootmem with early_res, so try to move them together and reuse it from different parts. Also rename update_range to subtract_range as that is what the function is actually doing. -v2: update comments as Christoph requested Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-4-git-send-email-yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
