path: root/include/linux/reboot.h
2013-12-18kexec: migrate to reboot cpuVivek Goyal
Commit 1b3a5d02ee07 ("reboot: move arch/x86 reboot= handling to generic kernel") moved reboot= handling to generic code. In the process it also removed the code in native_machine_shutdown() which are moving reboot process to reboot_cpu/cpu0. I guess that thought must have been that all reboot paths are calling migrate_to_reboot_cpu(), so we don't need this special handling. But kexec reboot path (kernel_kexec()) is not calling migrate_to_reboot_cpu() so above change broke kexec. Now reboot can happen on non-boot cpu and when INIT is sent in second kerneo to bring up BP, it brings down the machine. So start calling migrate_to_reboot_cpu() in kexec reboot path to avoid this problem. Bisected by WANG Chao. Reported-by: Matthew Whitehead <mwhitehe@redhat.com> Reported-by: Dave Young <dyoung@redhat.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Tested-by: Baoquan He <bhe@redhat.com> Tested-by: WANG Chao <chaowang@redhat.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: move arch/x86 reboot= handling to generic kernelRobin Holt
Merge together the unicore32, arm, and x86 reboot= command line parameter handling. Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: unicore32: prepare reboot_mode for moving to generic kernel codeRobin Holt
Prepare for the moving the parsing of reboot= to the generic kernel code by making reboot_mode into a more generic form. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: H. Peter Anvin <hpa@zytor.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: x86: prepare reboot_mode for moving to generic kernel codeRobin Holt
Prepare for the moving the parsing of reboot= to the generic kernel code by making reboot_mode into a more generic form. Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Miguel Boton <mboton.lkml@gmail.com> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09reboot: checkpatch.pl the new kernel/reboot.c fileRobin Holt
Get the new file to pass scripts/checkpatch.pl Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2011-07-25notifiers: sys: move reboot notifiers into reboot.hAmerigo Wang
It is not necessary to share the same notifier.h. This patch already moves register_reboot_notifier() and unregister_reboot_notifier() from kernel/notifier.c to kernel/sys.c. [amwang@redhat.com: make allyesconfig succeed on ppc64] Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12sysctl extern cleanup: C_A_DDave Young
Extern declarations in sysctl.c should be moved to their own header file, and then include them in relavant .c files. Move C_A_D extern variable declaration to linux/reboot.h Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: remove duplication of kexec_restart_prepare()Huang Ying
Call kernel_restart_prepare() in kernel_kexec() instead of duplicating the code. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05make kernel_shutdown_prepare() staticAdrian Bunk
kernel_shutdown_prepare() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18Add common orderly_poweroff()Jeremy Fitzhardinge
Various pieces of code around the kernel want to be able to trigger an orderly poweroff. This pulls them together into a single implementation. By default the poweroff command is /sbin/poweroff, but it can be set via sysctl: kernel/poweroff_cmd. This is split at whitespace, so it can include command-line arguments. This patch replaces four other instances of invoking either "poweroff" or "shutdown -h now": two sbus drivers, and acpi thermal management. sparc64 has its own "powerd"; still need to determine whether it should be replaced by orderly_poweroff(). Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Acked-by: Len Brown <lenb@kernel.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <ak@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David S. Miller <davem@davemloft.net>
2006-06-25[PATCH] kernel/sys.c: cleanupsAdrian Bunk
- proper prototypes for the following functions: - ctrl_alt_del() (in include/linux/reboot.h) - getrusage() (in include/linux/resource.h) - make the following needlessly global functions static: - kernel_restart_prepare() - kernel_kexec() [akpm@osdl.org: compile fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-15[ACPI] fix reboot upon suspend-to-diskAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=4320 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2005-09-22[PATCH] reboot: comment and factor the main reboot functionsEric W. Biederman
In the lead up to 2.6.13 I fixed a large number of reboot problems by making the calling conventions consistent. Despite checking and double checking my work it appears I missed an obvious one. This first patch simply refactors the reboot routines so all of the preparation for various kinds of reboots are in their own functions. Making it very hard to get the various kinds of reboot out of sync. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Add emergency_restart()Eric W. Biederman
When the kernel is working well and we want to restart cleanly kernel_restart is the function to use. But in many instances the kernel wants to reboot when thing are expected to be working very badly such as from panic or a software watchdog handler. This patch adds the function emergency_restart() so that callers can be clear what semantics they expect when calling restart. emergency_restart() is expected to be callable from interrupt context and possibly reliable in even more trying circumstances. This is an initial generic implementation for all architectures. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Refactor sys_reboot into reusable partsEric W. Biederman
Because the factors of sys_reboot don't exist people calling into the reboot path duplicate the code badly, leading to inconsistent expectations of code in the reboot path. This patch should is just code motion. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Use real pt_regs from exceptionAlexander Nyberg
Makes kexec_crashdump() take a pt_regs * as an argument. This allows to get exact register state at the point of the crash. If we come from direct panic assertion NULL will be passed and the current registers saved before crashdump. This hooks into two places: die(): check the conditions under which we will panic when calling do_exit and go there directly with the pt_regs that caused the fatal fault. die_nmi(): If we receive an NMI lockup while in the kernel use the pt_regs and go directly to crash_kexec(). We're probably nested up badly at this point so this might be the only chance to escape with proper information. Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: add kexec syscallsEric W. Biederman
This patch introduces the architecture independent implementation the sys_kexec_load, the compat_sys_kexec_load system calls. Kexec on panic support has been integrated into the core patch and is relatively clean. In addition the hopefully architecture independent option crashkernel=size@location has been docuemented. It's purpose is to reserve space for the panic kernel to live, and where no DMA transfer will ever be setup to access. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
