path: root/include/linux/reiserfs_acl.h
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21reiserfs: constify xattr_handlerStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch reiserfs to inode->i_aclAl Viro
2009-06-24switch reiserfs to usual conventions for caching ACLsAl Viro
2009-03-30reiserfs: fix build breakageAlexander Beregalov
Fix this build error when REISERFS_FS_POSIX_ACL is not set: fs/reiserfs/inode.c: In function 'reiserfs_new_inode': fs/reiserfs/inode.c:1919: warning: passing argument 1 of 'reiserfs_inherit_default_acl' from incompatible pointer type fs/reiserfs/inode.c:1919: warning: passing argument 2 of 'reiserfs_inherit_default_acl' from incompatible pointer type fs/reiserfs/inode.c:1919: warning: passing argument 3 of 'reiserfs_inherit_default_acl' from incompatible pointer type fs/reiserfs/inode.c:1919: error: too many arguments to function 'reiserfs_inherit_default_acl' due to a missing transaction-handle argument in the non-acl compatibility function. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: journaled xattrsJeff Mahoney
Deadlocks are possible in the xattr code between the journal lock and the xattr sems. This patch implements journalling for xattr operations. The benefit is twofold: * It gets rid of the deadlock possibility by always ensuring that xattr write operations are initiated inside a transaction. * It corrects the problem where xattr backing files aren't considered any differently than normal files, despite the fact they are metadata. I discussed the added journal load with Chris Mason, and we decided that since xattrs (versus other journal activity) is fairly rare, the introduction of larger transactions to support journaled xattrs wouldn't be too big a deal. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use generic xattr handlersJeff Mahoney
Christoph Hellwig had asked me quite some time ago to port the reiserfs xattrs to the generic xattr interface. This patch replaces the reiserfs-specific xattr handling code with the generic struct xattr_handler. However, since reiserfs doesn't split the prefix and name when accessing xattrs, it can't leverage generic_{set,get,list,remove}xattr without needlessly reconstructing the name on the back end. Update 7/26/07: Added missing dput() to deletion path. Update 8/30/07: Added missing mark_inode_dirty when i_mode is used to represent an ACL and no previous ACL existed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] reiserfs: ifdef ACL stuff from inodeAlexey Dobriyan
Shrink reiserfs inode more (by 8 bytes) for ACL non-users: -reiser_inode_cache 344 11 +reiser_inode_cache 336 11 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] reiserfs_get_acl() build fixAndrew Morton
With CONFIG_REISERFS_FS_XATTR=y, CONFIG_REISERFS_FS_POSIX_ACL=n: fs/reiserfs/xattr.c: In function `reiserfs_check_acl': fs/reiserfs/xattr.c:1330: called object is not a function Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove <linux/xattr_acl.h>Christoph Hellwig
This file duplicates <linux/posix_acl_xattr.h>, using slightly different names. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] reiserfs endianness: annotate little-endian objectsAl Viro
little-endian objects annotated as such; again, obviously no changes of resulting code, we only replace __u16 with __le16, etc. in relevant places. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
