path: root/include/linux/reiserfs_fs.h
2011-07-25reiserfs: use proper little-endian bitopsAkinobu Mita
Using __test_and_{set,clear}_bit_le() with ignoring its return value can be replaced with __{set,clear}_bit_le(). This introduces reiserfs_{set,clear}_le_bit for __{set,clear}_bit_le and does the above change with them. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23reiserfs: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09convert reiserfs to ->evict_inode()Al Viro
2010-07-19reiserfs: typo comment fixDavidlohr Bueso
Fix trivial typo in code comment (change adn for and), also change comment style for proper coding style. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-01-02Merge branch 'reiserfs/kill-bkl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'reiserfs/kill-bkl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: reiserfs: Safely acquire i_mutex from xattr_rmdir reiserfs: Safely acquire i_mutex from reiserfs_for_each_xattr reiserfs: Fix journal mutex <-> inode mutex lock inversion reiserfs: Fix unwanted recursive reiserfs lock in reiserfs_unlink() reiserfs: Relax lock before open xattr dir in reiserfs_xattr_set_handle() reiserfs: Relax reiserfs lock while freeing the journal reiserfs: Fix reiserfs lock <-> i_mutex dependency inversion on xattr reiserfs: Warn on lock relax if taken recursively reiserfs: Fix reiserfs lock <-> i_xattr_sem dependency inversion reiserfs: Fix remaining in-reclaim-fs <-> reclaim-fs-on locking inversion reiserfs: Fix reiserfs lock <-> inode mutex dependency inversion reiserfs: Fix reiserfs lock and journal lock inversion dependency reiserfs: Fix possible recursive lock
2010-01-02reiserfs: Warn on lock relax if taken recursivelyFrederic Weisbecker
When we relax the reiserfs lock to avoid creating unwanted dependencies against others locks while grabbing these, we want to ensure it has not been taken recursively, otherwise the lock won't be really relaxed. Only its depth will be decreased. The unwanted dependency would then actually happen. To prevent from that, add a reiserfs_lock_check_recursive() call in the places that need it. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02reiserfs: Fix reiserfs lock <-> i_xattr_sem dependency inversionFrederic Weisbecker
i_xattr_sem depends on the reiserfs lock. But after we grab i_xattr_sem, we may relax/relock the reiserfs lock while waiting on a freezed filesystem, creating a dependency inversion between the two locks. In order to avoid the i_xattr_sem -> reiserfs lock dependency, let's create a reiserfs_down_read_safe() that acts like reiserfs_mutex_lock_safe(): relax the reiserfs lock while grabbing another lock to avoid undesired dependencies induced by the heivyweight reiserfs lock. This fixes the following warning: [ 990.005931] ======================================================= [ 990.012373] [ INFO: possible circular locking dependency detected ] [ 990.013233] 2.6.33-rc1 #1 [ 990.013233] ------------------------------------------------------- [ 990.013233] dbench/1891 is trying to acquire lock: [ 990.013233] (&REISERFS_SB(s)->lock){+.+.+.}, at: [<ffffffff81159505>] reiserfs_write_lock+0x35/0x50 [ 990.013233] [ 990.013233] but task is already holding lock: [ 990.013233] (&REISERFS_I(inode)->i_xattr_sem){+.+.+.}, at: [<ffffffff8115899a>] reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [ 990.013233] which lock already depends on the new lock. [ 990.013233] [ 990.013233] [ 990.013233] the existing dependency chain (in reverse order) is: [ 990.013233] [ 990.013233] -> #1 (&REISERFS_I(inode)->i_xattr_sem){+.+.+.}: [ 990.013233] [<ffffffff81063afc>] __lock_acquire+0xf9c/0x1560 [ 990.013233] [<ffffffff8106414f>] lock_acquire+0x8f/0xb0 [ 990.013233] [<ffffffff814ac194>] down_write+0x44/0x80 [ 990.013233] [<ffffffff8115899a>] reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [<ffffffff81158e30>] reiserfs_xattr_set+0xb0/0x150 [ 990.013233] [<ffffffff8115a6aa>] user_set+0x8a/0x90 [ 990.013233] [<ffffffff8115901a>] reiserfs_setxattr+0xaa/0xb0 [ 990.013233] [<ffffffff810e2596>] __vfs_setxattr_noperm+0x36/0xa0 [ 990.013233] [<ffffffff810e26bc>] vfs_setxattr+0xbc/0xc0 [ 990.013233] [<ffffffff810e2780>] setxattr+0xc0/0x150 [ 990.013233] [<ffffffff810e289d>] sys_fsetxattr+0x8d/0xa0 [ 990.013233] [<ffffffff81002dab>] system_call_fastpath+0x16/0x1b [ 990.013233] [ 990.013233] -> #0 (&REISERFS_SB(s)->lock){+.+.+.}: [ 990.013233] [<ffffffff81063e30>] __lock_acquire+0x12d0/0x1560 [ 990.013233] [<ffffffff8106414f>] lock_acquire+0x8f/0xb0 [ 990.013233] [<ffffffff814aba77>] __mutex_lock_common+0x47/0x3b0 [ 990.013233] [<ffffffff814abebe>] mutex_lock_nested+0x3e/0x50 [ 990.013233] [<ffffffff81159505>] reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff811340e5>] reiserfs_prepare_write+0x45/0x180 [ 990.013233] [<ffffffff81158bb6>] reiserfs_xattr_set_handle+0x2a6/0x470 [ 990.013233] [<ffffffff81158e30>] reiserfs_xattr_set+0xb0/0x150 [ 990.013233] [<ffffffff8115a6aa>] user_set+0x8a/0x90 [ 990.013233] [<ffffffff8115901a>] reiserfs_setxattr+0xaa/0xb0 [ 990.013233] [<ffffffff810e2596>] __vfs_setxattr_noperm+0x36/0xa0 [ 990.013233] [<ffffffff810e26bc>] vfs_setxattr+0xbc/0xc0 [ 990.013233] [<ffffffff810e2780>] setxattr+0xc0/0x150 [ 990.013233] [<ffffffff810e289d>] sys_fsetxattr+0x8d/0xa0 [ 990.013233] [<ffffffff81002dab>] system_call_fastpath+0x16/0x1b [ 990.013233] [ 990.013233] other info that might help us debug this: [ 990.013233] [ 990.013233] 2 locks held by dbench/1891: [ 990.013233] #0: (&sb->s_type->i_mutex_key#12){+.+.+.}, at: [<ffffffff810e2678>] vfs_setxattr+0x78/0xc0 [ 990.013233] #1: (&REISERFS_I(inode)->i_xattr_sem){+.+.+.}, at: [<ffffffff8115899a>] reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [ 990.013233] stack backtrace: [ 990.013233] Pid: 1891, comm: dbench Not tainted 2.6.33-rc1 #1 [ 990.013233] Call Trace: [ 990.013233] [<ffffffff81061639>] print_circular_bug+0xe9/0xf0 [ 990.013233] [<ffffffff81063e30>] __lock_acquire+0x12d0/0x1560 [ 990.013233] [<ffffffff8115899a>] ? reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [<ffffffff8106414f>] lock_acquire+0x8f/0xb0 [ 990.013233] [<ffffffff81159505>] ? reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff8115899a>] ? reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [<ffffffff814aba77>] __mutex_lock_common+0x47/0x3b0 [ 990.013233] [<ffffffff81159505>] ? reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff81159505>] ? reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff81062592>] ? mark_held_locks+0x72/0xa0 [ 990.013233] [<ffffffff814ab81d>] ? __mutex_unlock_slowpath+0xbd/0x140 [ 990.013233] [<ffffffff810628ad>] ? trace_hardirqs_on_caller+0x14d/0x1a0 [ 990.013233] [<ffffffff814abebe>] mutex_lock_nested+0x3e/0x50 [ 990.013233] [<ffffffff81159505>] reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff811340e5>] reiserfs_prepare_write+0x45/0x180 [ 990.013233] [<ffffffff81158bb6>] reiserfs_xattr_set_handle+0x2a6/0x470 [ 990.013233] [<ffffffff81158e30>] reiserfs_xattr_set+0xb0/0x150 [ 990.013233] [<ffffffff814abcb4>] ? __mutex_lock_common+0x284/0x3b0 [ 990.013233] [<ffffffff8115a6aa>] user_set+0x8a/0x90 [ 990.013233] [<ffffffff8115901a>] reiserfs_setxattr+0xaa/0xb0 [ 990.013233] [<ffffffff810e2596>] __vfs_setxattr_noperm+0x36/0xa0 [ 990.013233] [<ffffffff810e26bc>] vfs_setxattr+0xbc/0xc0 [ 990.013233] [<ffffffff810e2780>] setxattr+0xc0/0x150 [ 990.013233] [<ffffffff81056018>] ? sched_clock_cpu+0xb8/0x100 [ 990.013233] [<ffffffff8105eded>] ? trace_hardirqs_off+0xd/0x10 [ 990.013233] [<ffffffff810560a3>] ? cpu_clock+0x43/0x50 [ 990.013233] [<ffffffff810c6820>] ? fget+0xb0/0x110 [ 990.013233] [<ffffffff810c6770>] ? fget+0x0/0x110 [ 990.013233] [<ffffffff81002ddc>] ? sysret_check+0x27/0x62 [ 990.013233] [<ffffffff810e289d>] sys_fsetxattr+0x8d/0xa0 [ 990.013233] [<ffffffff81002dab>] system_call_fastpath+0x16/0x1b Reported-and-tested-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2009-12-16reiserfs: Fix reiserfs lock <-> inode mutex dependency inversionFrederic Weisbecker
The reiserfs lock -> inode mutex dependency gets inverted when we relax the lock while walking to the tree. To fix this, use a specialized version of reiserfs_mutex_lock_safe that takes care of mutex subclasses. Then we can grab the inode mutex with I_MUTEX_XATTR subclass without any reiserfs lock dependency. This fixes the following report: [ INFO: possible circular locking dependency detected ] 2.6.32-06793-gf405425-dirty #2 ------------------------------------------------------- mv/18566 is trying to acquire lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<c1110708>] reiserfs_write_lock+0x28= /0x40 but task is already holding lock: (&sb->s_type->i_mutex_key#5/3){+.+.+.}, at: [<c111033c>] reiserfs_for_each_xattr+0x10c/0x380 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#5/3){+.+.+.}: [<c104f723>] validate_chain+0xa23/0xf70 [<c1050155>] __lock_acquire+0x4e5/0xa70 [<c105075a>] lock_acquire+0x7a/0xa0 [<c134c76f>] mutex_lock_nested+0x5f/0x2b0 [<c11102b4>] reiserfs_for_each_xattr+0x84/0x380 [<c1110615>] reiserfs_delete_xattrs+0x15/0x50 [<c10ef57f>] reiserfs_delete_inode+0x8f/0x140 [<c10a565c>] generic_delete_inode+0x9c/0x150 [<c10a574d>] generic_drop_inode+0x3d/0x60 [<c10a4667>] iput+0x47/0x50 [<c109cc0b>] do_unlinkat+0xdb/0x160 [<c109cca0>] sys_unlink+0x10/0x20 [<c1002c50>] sysenter_do_call+0x12/0x36 -> #0 (&REISERFS_SB(s)->lock){+.+.+.}: [<c104fc68>] validate_chain+0xf68/0xf70 [<c1050155>] __lock_acquire+0x4e5/0xa70 [<c105075a>] lock_acquire+0x7a/0xa0 [<c134c76f>] mutex_lock_nested+0x5f/0x2b0 [<c1110708>] reiserfs_write_lock+0x28/0x40 [<c1103d6b>] search_by_key+0x1f7b/0x21b0 [<c10e73ef>] search_by_entry_key+0x1f/0x3b0 [<c10e77f7>] reiserfs_find_entry+0x77/0x400 [<c10e81e5>] reiserfs_lookup+0x85/0x130 [<c109a144>] __lookup_hash+0xb4/0x110 [<c109b763>] lookup_one_len+0xb3/0x100 [<c1110350>] reiserfs_for_each_xattr+0x120/0x380 [<c1110615>] reiserfs_delete_xattrs+0x15/0x50 [<c10ef57f>] reiserfs_delete_inode+0x8f/0x140 [<c10a565c>] generic_delete_inode+0x9c/0x150 [<c10a574d>] generic_drop_inode+0x3d/0x60 [<c10a4667>] iput+0x47/0x50 [<c10a1c4f>] dentry_iput+0x6f/0xf0 [<c10a1d74>] d_kill+0x24/0x50 [<c10a396b>] dput+0x5b/0x120 [<c109ca89>] sys_renameat+0x1b9/0x230 [<c109cb28>] sys_rename+0x28/0x30 [<c1002c50>] sysenter_do_call+0x12/0x36 other info that might help us debug this: 2 locks held by mv/18566: #0: (&sb->s_type->i_mutex_key#5/1){+.+.+.}, at: [<c109b6ac>] lock_rename+0xcc/0xd0 #1: (&sb->s_type->i_mutex_key#5/3){+.+.+.}, at: [<c111033c>] reiserfs_for_each_xattr+0x10c/0x380 stack backtrace: Pid: 18566, comm: mv Tainted: G C 2.6.32-06793-gf405425-dirty #2 Call Trace: [<c134b252>] ? printk+0x18/0x1e [<c104e790>] print_circular_bug+0xc0/0xd0 [<c104fc68>] validate_chain+0xf68/0xf70 [<c104c8cb>] ? trace_hardirqs_off+0xb/0x10 [<c1050155>] __lock_acquire+0x4e5/0xa70 [<c105075a>] lock_acquire+0x7a/0xa0 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c134c76f>] mutex_lock_nested+0x5f/0x2b0 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c134b60a>] ? schedule+0x27a/0x440 [<c1110708>] reiserfs_write_lock+0x28/0x40 [<c1103d6b>] search_by_key+0x1f7b/0x21b0 [<c1050176>] ? __lock_acquire+0x506/0xa70 [<c1051267>] ? lock_release_non_nested+0x1e7/0x340 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c104e354>] ? trace_hardirqs_on_caller+0x124/0x170 [<c104e3ab>] ? trace_hardirqs_on+0xb/0x10 [<c1042a55>] ? T.316+0x15/0x1a0 [<c1042d2d>] ? sched_clock_cpu+0x9d/0x100 [<c10e73ef>] search_by_entry_key+0x1f/0x3b0 [<c134bf2a>] ? __mutex_unlock_slowpath+0x9a/0x120 [<c104e354>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10e77f7>] reiserfs_find_entry+0x77/0x400 [<c10e81e5>] reiserfs_lookup+0x85/0x130 [<c1042d2d>] ? sched_clock_cpu+0x9d/0x100 [<c109a144>] __lookup_hash+0xb4/0x110 [<c109b763>] lookup_one_len+0xb3/0x100 [<c1110350>] reiserfs_for_each_xattr+0x120/0x380 [<c110ffe0>] ? delete_one_xattr+0x0/0x1c0 [<c1003342>] ? math_error+0x22/0x150 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c1110615>] reiserfs_delete_xattrs+0x15/0x50 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c10ef57f>] reiserfs_delete_inode+0x8f/0x140 [<c10a561f>] ? generic_delete_inode+0x5f/0x150 [<c10ef4f0>] ? reiserfs_delete_inode+0x0/0x140 [<c10a565c>] generic_delete_inode+0x9c/0x150 [<c10a574d>] generic_drop_inode+0x3d/0x60 [<c10a4667>] iput+0x47/0x50 [<c10a1c4f>] dentry_iput+0x6f/0xf0 [<c10a1d74>] d_kill+0x24/0x50 [<c10a396b>] dput+0x5b/0x120 [<c109ca89>] sys_renameat+0x1b9/0x230 [<c1042d2d>] ? sched_clock_cpu+0x9d/0x100 [<c104c8cb>] ? trace_hardirqs_off+0xb/0x10 [<c1042dde>] ? cpu_clock+0x4e/0x60 [<c1350825>] ? do_page_fault+0x155/0x370 [<c1041816>] ? up_read+0x16/0x30 [<c1350825>] ? do_page_fault+0x155/0x370 [<c109cb28>] sys_rename+0x28/0x30 [<c1002c50>] sysenter_do_call+0x12/0x36 Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de>
2009-12-16reiserfs: don't compile procfs.o at all if no supportAlexey Dobriyan
* small define cleanup in header * fix #ifdeffery in procfs.c via Kconfig Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16reiserfs: remove /proc/fs/reiserfs/versionAlexey Dobriyan
/proc/fs/reiserfs/version is on the way of removing ->read_proc interface. It's empty however, so simply remove it instead of doing dummy conversion. It's hard to see what information userspace can extract from empty file. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-14kill-the-bkl/reiserfs: definitely drop the bkl from reiserfs_ioctl()Frederic Weisbecker
The reiserfs ioctl path doesn't need the big kernel lock anymore , now that the filesystem synchronizes through its own lock. We can then turn reiserfs_ioctl() into an unlocked_ioctl callback. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Laurent Riffard <laurent.riffard@free.fr> Cc: Thomas Gleixner <tglx@linutronix.de>
2009-09-14kill-the-bkl/reiserfs: acquire the inode mutex safelyFrederic Weisbecker
While searching a pathname, an inode mutex can be acquired in do_lookup() which calls reiserfs_lookup() which in turn acquires the write lock. On the other side reiserfs_fill_super() can acquire the write_lock and then call reiserfs_lookup_privroot() which can acquire an inode mutex (the root of the mount point). So we theoretically risk an AB - BA lock inversion that could lead to a deadlock. As for other lock dependencies found since the bkl to mutex conversion, the fix is to use reiserfs_mutex_lock_safe() which drops the lock dependency to the write lock. [ Impact: fix a possible deadlock with reiserfs ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-14kill-the-bkl/reiserfs: conditionaly release the write lock on fs_changed()Frederic Weisbecker
The goal of fs_changed() is to check whether the tree changed during a schedule(). This is a BKL legacy. A recent patch added an explicit unconditional release/reacquire of the write lock around the cond_resched() called inside fs_changed. But it's wasteful to unconditionally do that, we are creating superfluous lock contention in !TIF_NEED_RESCHED case. This patch manage that by calling reiserfs_cond_resched() from fs_changed() which only releases the lock if we are going to reschedule. [ Impact: inject less lock contention and tree job retries ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-14kill-the-BKL/reiserfs: add reiserfs_cond_resched()Frederic Weisbecker
Usually, when we call cond_resched(), we want the write lock to be released and then reacquired once we return from scheduling. Not only does it follow the previous bkl based locking scheme, but it also let other waiters to get the lock. But if we aren't going to reschedule(), such as in !TIF_NEED_RESCHED case, it's useless to release the lock. Worse, if we release and reacquire the lock whereas it is not needed, we create useless contentions. Also if someone takes the lock while we are modifying or reading the tree, there are good chances we'll have to retry our operation, eg if the block we were seeeking has moved. So this patch introduces a helper which only unlock the write lock if we are going to schedule. [ Impact: prepare to inject less lock contention and less tree operation attempts ] Reported-by: Andi Kleen <andi@firstfloor.org> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-14kill-the-BKL/reiserfs: release write lock on fs_changed()Frederic Weisbecker
fs_changed() is a macro used by reiserfs to check whether its tree has been rebalanced. It has been designed to check parallel changes on the tree after calling a sleeping function, which released the Bkl. fs_changed() also calls cond_resched(), so that if rescheduling is needed, we are in the best place to do that, since we check if the tree has changed just after (because of the bkl release on schedule()). Even if we are not anymore using the Bkl, we still want to release the lock while we reschedule, so that other waiters for the lock can acquire it safely, because of the following __fs_changed() check. [ Impact: release the reiserfs write lock when it is not needed ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-14kill-the-BKL/reiserfs: provide a tool to lock only once the write lockFrederic Weisbecker
Sometimes we don't want to recursively hold the per superblock write lock because we want to be sure it is actually released when we come to sleep. This patch introduces the necessary tools for that. reiserfs_write_lock_once() does the same job than reiserfs_write_lock() except that it won't try to acquire recursively the lock if the current task already owns it. Also the lock_depth before the call of this function is returned. reiserfs_write_unlock_once() unlock only if reiserfs_write_lock_once() returned a depth equal to -1, ie: only if it actually locked. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alessio Igor Bogani <abogani@texware.it> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> LKML-Reference: <1239680065-25013-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-14reiserfs: kill-the-BKLFrederic Weisbecker
This patch is an attempt to remove the Bkl based locking scheme from reiserfs and is intended. It is a bit inspired from an old attempt by Peter Zijlstra: http://lkml.indiana.edu/hypermail/linux/kernel/0704.2/2174.html The bkl is heavily used in this filesystem to prevent from concurrent write accesses on the filesystem. Reiserfs makes a deep use of the specific properties of the Bkl: - It can be acqquired recursively by a same task - It is released on the schedule() calls and reacquired when schedule() returns The two properties above are a roadmap for the reiserfs write locking so it's very hard to simply replace it with a common mutex. - We need a recursive-able locking unless we want to restructure several blocks of the code. - We need to identify the sites where the bkl was implictly relaxed (schedule, wait, sync, etc...) so that we can in turn release and reacquire our new lock explicitly. Such implicit releases of the lock are often required to let other resources producer/consumer do their job or we can suffer unexpected starvations or deadlocks. So the new lock that replaces the bkl here is a per superblock mutex with a specific property: it can be acquired recursively by a same task, like the bkl. For such purpose, we integrate a lock owner and a lock depth field on the superblock information structure. The first axis on this patch is to turn reiserfs_write_(un)lock() function into a wrapper to manage this mutex. Also some explicit calls to lock_kernel() have been converted to reiserfs_write_lock() helpers. The second axis is to find the important blocking sites (schedule...(), wait_on_buffer(), sync_dirty_buffer(), etc...) and then apply an explicit release of the write lock on these locations before blocking. Then we can safely wait for those who can give us resources or those who need some. Typically this is a fight between the current writer, the reiserfs workqueue (aka the async commiter) and the pdflush threads. The third axis is a consequence of the second. The write lock is usually on top of a lock dependency chain which can include the journal lock, the flush lock or the commit lock. So it's dangerous to release and trying to reacquire the write lock while we still hold other locks. This is fine with the bkl: T1 T2 lock_kernel() mutex_lock(A) unlock_kernel() // do something lock_kernel() mutex_lock(A) -> already locked by T1 schedule() (and then unlock_kernel()) lock_kernel() mutex_unlock(A) .... This is not fine with a mutex: T1 T2 mutex_lock(write) mutex_lock(A) mutex_unlock(write) // do something mutex_lock(write) mutex_lock(A) -> already locked by T1 schedule() mutex_lock(write) -> already locked by T2 deadlock The solution in this patch is to provide a helper which releases the write lock and sleep a bit if we can't lock a mutex that depend on it. It's another simulation of the bkl behaviour. The last axis is to locate the fs callbacks that are called with the bkl held, according to Documentation/filesystem/Locking. Those are: - reiserfs_remount - reiserfs_fill_super - reiserfs_put_super Reiserfs didn't need to explicitly lock because of the context of these callbacks. But now we must take care of that with the new locking. After this patch, reiserfs suffers from a slight performance regression (for now). On UP, a high volume write with dd reports an average of 27 MB/s instead of 30 MB/s without the patch applied. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Ingo Molnar <mingo@elte.hu> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Bron Gondwana <brong@fastmail.fm> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> LKML-Reference: <1239070789-13354-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-18reiserfs: fix warnings with gcc 4.4Jeff Mahoney
Several code paths in reiserfs have a construct like: if (is_direntry_le_ih(ih = B_N_PITEM_HEAD(src, item_num))) ... which, in addition to being ugly, end up causing compiler warnings with gcc 4.4.0. Previous compilers didn't issue a warning. fs/reiserfs/do_balan.c:1273: warning: operation on `aux_ih' may be undefined fs/reiserfs/lbalance.c:393: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:421: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:777: warning: operation on `ih' may be undefined I believe this is due to the ih being passed to macros which evaluate the argument more than once. This is old code and we haven't seen any problems with it, but this patch eliminates the warnings. It converts the multiple evaluation macros to static inlines and does a preassignment for the cases that were causing the warnings because that code is just ugly. Reported-by: Chris Mason <mason@oracle.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Merge branch 'reiserfs-updates' from Jeff MahoneyLinus Torvalds
* reiserfs-updates: (35 commits) reiserfs: rename [cn]_* variables reiserfs: rename p_._ variables reiserfs: rename p_s_tb to tb reiserfs: rename p_s_inode to inode reiserfs: rename p_s_bh to bh reiserfs: rename p_s_sb to sb reiserfs: strip trailing whitespace reiserfs: cleanup path functions reiserfs: factor out buffer_info initialization reiserfs: add atomic addition of selinux attributes during inode creation reiserfs: use generic readdir for operations across all xattrs reiserfs: journaled xattrs reiserfs: use generic xattr handlers reiserfs: remove i_has_xattr_dir reiserfs: make per-inode xattr locking more fine grained reiserfs: eliminate per-super xattr lock reiserfs: simplify xattr internal file lookups/opens reiserfs: Clean up xattrs when REISERFS_FS_XATTR is unset reiserfs: remove IS_PRIVATE helpers reiserfs: remove link detection code ... Fixed up conflicts manually due to: - quota name cleanups vs variable naming changes: fs/reiserfs/inode.c fs/reiserfs/namei.c fs/reiserfs/stree.c fs/reiserfs/xattr.c - exported include header cleanups include/linux/reiserfs_fs.h
2009-03-30reiserfs: rename p_._ variablesJeff Mahoney
This patch is a simple s/p_._//g to the reiserfs code. This is the fifth in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_tb to tbJeff Mahoney
This patch is a simple s/p_s_tb/tb/g to the reiserfs code. This is the fourth in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_inode to inodeJeff Mahoney
This patch is a simple s/p_s_inode/inode/g to the reiserfs code. This is the third in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_bh to bhJeff Mahoney
This patch is a simple s/p_s_bh/bh/g to the reiserfs code. This is the second in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_sb to sbJeff Mahoney
This patch is a simple s/p_s_sb/sb/g to the reiserfs code. This is the first in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: add atomic addition of selinux attributes during inode creationJeff Mahoney
Some time ago, some changes were made to make security inode attributes be atomically written during inode creation. ReiserFS fell behind in this area, but with the reworking of the xattr code, it's now fairly easy to add. The following patch adds the ability for security attributes to be added automatically during inode creation. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use generic readdir for operations across all xattrsJeff Mahoney
The current reiserfs xattr implementation open codes reiserfs_readdir and frees the path before calling the filldir function. Typically, the filldir function is something that modifies the file system, such as a chown or an inode deletion that also require reading of an inode associated with each direntry. Since the file system is modified, the path retained becomes invalid for the next run. In addition, it runs backwards in attempt to minimize activity. This is clearly suboptimal from a code cleanliness perspective as well as performance-wise. This patch implements a generic reiserfs_for_each_xattr that uses the generic readdir and a specific filldir routine that simply populates an array of dentries and then performs a specific operation on them. When all files have been operated on, it then calls the operation on the directory itself. The result is a noticable code reduction and better performance. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: journaled xattrsJeff Mahoney
Deadlocks are possible in the xattr code between the journal lock and the xattr sems. This patch implements journalling for xattr operations. The benefit is twofold: * It gets rid of the deadlock possibility by always ensuring that xattr write operations are initiated inside a transaction. * It corrects the problem where xattr backing files aren't considered any differently than normal files, despite the fact they are metadata. I discussed the added journal load with Chris Mason, and we decided that since xattrs (versus other journal activity) is fairly rare, the introduction of larger transactions to support journaled xattrs wouldn't be too big a deal. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: eliminate per-super xattr lockJeff Mahoney
With the switch to using inode->i_mutex locking during lookups/creation in the xattr root, the per-super xattr lock is no longer needed. This patch removes it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: introduce reiserfs_error()Jeff Mahoney
Although reiserfs can currently handle severe errors such as journal failure, it cannot handle less severe errors like metadata i/o failure. The following patch adds a reiserfs_error() function akin to the one in ext3. Subsequent patches will use this new error handler to handle errors more gracefully in general. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rearrange journal abortJeff Mahoney
This patch kills off reiserfs_journal_abort as it is never called, and combines __reiserfs_journal_abort_{soft,hard} into one function called reiserfs_abort_journal, which performs the same work. It is silent as opposed to the old version, since the message was always issued after a regular 'abort' message. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_panicJeff Mahoney
ReiserFS panics can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: eliminate reiserfs_warning from uniqueness functionsJeff Mahoney
uniqueness2type and type2uniquness issue a warning when the value is unknown. When called from reiserfs_warning, this causes a re-entrancy problem and deadlocks on the error buffer lock. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_warningJeff Mahoney
ReiserFS warnings can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use buffer_info for leaf_paste_entriesJeff Mahoney
This patch makes leaf_paste_entries more consistent with respect to the other leaf operations. Using buffer_info instead of buffer_head directly allows us to get a superblock pointer for use in error handling. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: audit transaction ids to always be unsigned intsJeff Mahoney
This patch fixes up the reiserfs code such that transaction ids are always unsigned ints. In places they can currently be signed ints or unsigned longs. The former just causes an annoying clm-2200 warning and may join a transaction when it should wait. The latter is just for correctness since the disk format uses a 32-bit transaction id. There aren't any runtime problems that result from it not wrapping at the correct location since the value is truncated correctly even on big endian systems. The 0 value might make it to disk, but the mount-time checks will bump it to 10 itself. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: add support for mount count incrementingJeff Mahoney
The following patch adds the fields for tracking mount counts and last fsck timestamps to the superblock. It also increments the mount count on every read-write mount. Reiserfsprogs 3.6.21 added support for these fields. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-03headers_check fix cleanup: linux/reiserfs_fs.hJaswinder Singh Rajput
Only REISERFS_IOC_* definitions are required for user space rest should be in #ifdef __KERNEL__ as pointed by Arnd Bergmann. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-02-02headers_check fix: linux/reinserfs_fs.hJaswinder Singh Rajput
fix the following 'make headers_check' warnings: usr/include/linux/reiserfs_fs.h:687: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:995: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:997: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1467: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1760: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1764: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1766: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1769: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1771: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1805: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1948: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1949: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1950: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1951: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1962: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1963: extern's make no sense in userspace usr/include/linux/reiserfs_fs.h:1964: extern's make no sense in userspace Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-10-16include: replace __FUNCTION__ with __func__Harvey Harrison
2008-07-25include: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28reiserfs: unpack tails on quota filesJan Kara
Quota files cannot have tails because quota_write and quota_read functions do not support them. So far when quota files did have tail, we just refused to turn quotas on it. Sadly this check has been wrong and so there are now plenty installations where quota files don't have NOTAIL flag set and so now after fixing the check, they suddently fail to turn quotas on. Since it's easy to unpack the tail from kernel, do this from reiserfs_quota_on() which solves the problem and is generally nicer to users anyway. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: <urhausen@urifabi.net> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08use __u32 in linux/reiserfs_fs.hMike Frysinger
Since this header is exported to userspace and all the other types in the header have been scrubbed, this brings the last straggler in line. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22reiserfs: new export opsChristoph Hellwig
Another nice little cleanup by using the new methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: ignore on disk s_bmap_nr valueJeff Mahoney
Implement support for file systems larger than 8 TiB. The reiserfs superblock contains a 16 bit value for counting the number of bitmap blocks. The rest of the disk format supports file systems up to 2^32 blocks, but the bitmap block limitation artificially limits this to 8 TiB with a 4KiB block size. Rather than trust the superblock's 16-bit bitmap block count, we calculate it dynamically based on the number of blocks in the file system. When an incorrect value is observed in the superblock, it is zeroed out, ensuring that older kernels will not be able to mount the file system. Userspace support has already been implemented and shipped in reiserfsprogs 3.6.20. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
