path: root/include/linux/reservation.h
2014-07-08reservation: add suppport for read-only access using rcuMaarten Lankhorst
This adds some extra functions to deal with rcu. reservation_object_get_fences_rcu() will obtain the list of shared and exclusive fences without obtaining the ww_mutex. reservation_object_wait_timeout_rcu() will wait on all fences of the reservation_object, without obtaining the ww_mutex. reservation_object_test_signaled_rcu() will test if all fences of the reservation_object are signaled without using the ww_mutex. reservation_object_get_excl and reservation_object_get_list require the reservation object to be held, updating requires write_seqcount_begin/end. If only the exclusive fence is needed, rcu_dereference followed by fence_get_rcu can be used, if the shared fences are needed it's recommended to use the supplied functions. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Sumit Semwal <sumit.semwal@linaro.org> Acked-by: Daniel Vetter <daniel@ffwll.ch> Reviewed-By: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-08reservation: update api and add some helpersMaarten Lankhorst
Move the list of shared fences to a struct, and return it in reservation_object_get_list(). Add reservation_object_get_excl to get the exclusive fence. Add reservation_object_reserve_shared(), which reserves space in the reservation_object for 1 more shared fence. reservation_object_add_shared_fence() and reservation_object_add_excl_fence() are used to assign a new fence to a reservation_object pointer, to complete a reservation. Changes since v1: - Add reservation_object_get_excl, reorder code a bit. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Sumit Semwal <sumit.semwal@linaro.org> Acked-by: Daniel Vetter <daniel@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-08reservation: add support for fences to enable cross-device synchronisationMaarten Lankhorst
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Sumit Semwal <sumit.semwal@linaro.org> Acked-by: Daniel Vetter <daniel@ffwll.ch> Reviewed-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-12mutex: Move ww_mutex definitions to ww_mutex.hMaarten Lankhorst
Move the definitions for wound/wait mutexes out to a separate header, ww_mutex.h. This reduces clutter in mutex.h, and increases readability. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Cc: Dave Airlie <airlied@gmail.com> Link: http://lkml.kernel.org/r/51D675DC.3000907@canonical.com [ Tidied up the code a bit. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-28reservation: cross-device reservation support, v4Maarten Lankhorst
This adds support for a generic reservations framework that can be hooked up to ttm and dma-buf and allows easy sharing of reservations across devices. The idea is that a dma-buf and ttm object both will get a pointer to a struct reservation_object, which has to be reserved before anything is done with the contents of the dma-buf. Changes since v1: - Fix locking issue in ticket_reserve, which could cause mutex_unlock to be called too many times. Changes since v2: - All fence related calls and members have been taken out for now, what's left is the bare minimum to be useful for ttm locking conversion. Changes since v3: - Removed helper functions too. The documentation has an example implementation for locking. With the move to ww_mutex there is no need to have much logic any more. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
