path: root/include/linux/resource.h
2010-11-12include/linux/resource.h needs types.hJean Delvare
Fix the following warning: usr/include/linux/resource.h:49: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-16rlimits: redo do_setrlimit to more generic do_prlimitJiri Slaby
It now allows also reading of limits. I.e. all read and writes will later use this function. It takes two parameters, new and old limits which can be both NULL. If new is non-NULL, the value in it is set to rlimits. If old is non-NULL, current rlimits are stored there. If both are non-NULL, old are stored prior to setting the new ones, atomically. (Similar to sigaction.) Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: add rlimit64 structureJiri Slaby
Add a platform independent structure for resource limits to use with a new prlimit64 syscall. This structure is the same which uses glibc for 64-bit limits. Also add corresponding infinity which is a 64-bit full of bit-ones. Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-07-16rlimits: split sys_setrlimitJiri Slaby
Create do_setrlimit from sys_setrlimit and declare do_setrlimit in the resource header. This is the first phase to have generic do_prlimit which allows to be called from read, write and compat rlimits code. The new do_setrlimit also accepts a task pointer to change the limits of. Currently, it cannot be other than current, but this will change with locking later. Also pass tsk->group_leader to security_task_setrlimit to check whether current is allowed to change rlimits of the process and not its arbitrary thread because it makes more sense given that rlimit are per process and not per-thread. Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2010-01-04resource: move kernel function inside __KERNEL__Jiri Slaby
It is an internal function. Move it inside __KERNEL__ ifdef, along with task_struct declaration. Then we get: --- /usr/include/linux/resource.h 2009-09-14 15:09:29.000000000 +0200 +++ usr/include/linux/resource.h 2010-01-04 11:30:54.000000000 +0100 @@ -3,8 +3,6 @@ #include <linux/time.h> -struct task_struct; - /* * Resource control/accounting header file for linux */ @@ -70,6 +68,5 @@ */ #include <asm/resource.h> -int getrusage(struct task_struct *p, int who, struct rusage *ru); #endif *********** include/linux/Kbuild is untouched, since unifdef is run even on headers-y nowadays. Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2008-10-30mm: increase the default mlock limit from 32k to 64kKurt Garloff
By default, non-privileged tasks can only mlock() a small amount of memory to avoid a DoS attack by ordinary users. The Linux kernel defaulted to 32k (on a 4k page size system) to accommodate the needs of gpg. However, newer gpg2 needs 64k in various circumstances and otherwise fails miserably, see bnc#329675. Change the default to 64k, and make it more agnostic to PAGE_SIZE. Signed-off-by: Kurt Garloff <garloff@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29add RUSAGE_THREADSripathi Kodi
Add the RUSAGE_THREAD option for the getrusage system call. This is essentially Roland's patch from http://lkml.org/lkml/2008/1/18/589, but the line about RUSAGE_LWP line has been removed, as suggested by Ulrich and Christoph. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-25[PATCH] kernel/sys.c: cleanupsAdrian Bunk
- proper prototypes for the following functions: - ctrl_alt_del() (in include/linux/reboot.h) - getrusage() (in include/linux/resource.h) - make the following needlessly global functions static: - kernel_restart_prepare() - kernel_kexec() [akpm@osdl.org: compile fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
