path: root/include/linux/resume-trace.h
2010-10-17PM: Add sysfs attr for rechecking dev hash from PM traceJames Hogan
If the device which fails to resume is part of a loadable kernel module it won't be checked at startup against the magic number stored in the RTC. Add a read-only sysfs attribute /sys/power/pm_trace_dev_match which contains a list of newline separated devices (usually just the one) which currently match the last magic number. This allows the device which is failing to resume to be found after the modules are loaded again. Signed-off-by: James Hogan <james@albanarts.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM: Asynchronous suspend and resume of devicesRafael J. Wysocki
Theoretically, the total time of system sleep transitions (suspend to RAM, hibernation) can be reduced by running suspend and resume callbacks of device drivers in parallel with each other. However, there are dependencies between devices such that we're not allowed to suspend the parent of a device before suspending the device itself. Analogously, we're not allowed to resume a device before resuming its parent. The most straightforward way to take these dependencies into accout is to start the async threads used for suspending and resuming devices at the core level, so that async_schedule() is called for each suspend and resume callback supposed to be executed asynchronously. For this purpose, introduce a new device flag, power.async_suspend, used to mark the devices whose suspend and resume callbacks are to be executed asynchronously (ie. in parallel with the main suspend/resume thread and possibly in parallel with each other) and helper function device_enable_async_suspend() allowing one to set power.async_suspend for given device (power.async_suspend is unset by default for all devices). For each device with the power.async_suspend flag set the PM core will use async_schedule() to execute its suspend and resume callbacks. The async threads started for different devices as a result of calling async_schedule() are synchronized with each other and with the main suspend/resume thread with the help of completions, in the following way: (1) There is a completion, power.completion, for each device object. (2) Each device's completion is reset before calling async_schedule() for the device or, in the case of devices with the power.async_suspend flags unset, before executing the device's suspend and resume callbacks. (3) During suspend, right before running the bus type, device type and device class suspend callbacks for the device, the PM core waits for the completions of all the device's children to be completed. (4) During resume, right before running the bus type, device type and device class resume callbacks for the device, the PM core waits for the completion of the device's parent to be completed. (5) The PM core completes power.completion for each device right after the bus type, device type and device class suspend (or resume) callbacks executed for the device have returned. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2008-05-25x86: move tracedata to RODATAJan Beulich
.. allowing it to be write-protected just as other read-only data under CONFIG_DEBUG_RODATA. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-21x86: PM_TRACE supportNigel Cunningham
Signed-off-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] PM: Add pm_trace switchRafael J. Wysocki
Add the pm_trace attribute in /sys/power which has to be explicitly set to one to really enable the "PM tracing" code compiled in when CONFIG_PM_TRACE is set (which modifies the machine's CMOS clock in unpredictable ways). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Add some basic resume trace facilitiesLinus Torvalds
Considering that there isn't a lot of hw we can depend on during resume, this is about as good as it gets. This is x86-only for now, although the basic concept (and most of the code) will certainly work on almost any platform. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
