path: root/include/linux/rio_ids.h
2011-11-02RapidIO: add mport driver for Tsi721 bridgeAlexandre Bounine
Add RapidIO mport driver for IDT TSI721 PCI Express-to-SRIO bridge device. The driver provides full set of callback functions defined for mport devices in RapidIO subsystem. It also is compatible with current version of RIONET driver (Ethernet over RapidIO messaging services). This patch is applicable to kernel versions starting from 2.6.39. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Chul Kim <chul.kim@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14RapidIO: add IDT CPS-1432 switch definitionsAlexandre Bounine
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: add new idt sRIO switchesAlexandre Bounine
Add new sRIO switch device IDs and enable a basic support for them. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add support for IDT CPS Gen2 switchesAlexandre Bounine
Add the RIO switch driver and definitions for IDT CPS-1848 and CPS-1616 Gen2 devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add IDT CPS/TSI switchesAlexandre Bounine
Extentions to RapidIO switch support: 1. modify switch route operation declarations to allow using single switch-specific file for family of switches that share the same route table operations. 2. add standard route table operations for switches that that support route table manipulation registers as defined in the Rev.1.3 of RapidIO specification. 3. add clear-route-table operation for switches 4. add CPSxx and TSIxxx families of RapidIO switches Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-11-07[PATCH] RapidIO support: core includesMatt Porter
Add RapidIO core include files. The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
