Rather than have architectures #define ARCH_HAS_SG_CHAIN in an
architecture specific scatterlist.h, make it a proper Kconfig option and
use that instead. At same time, remove the header files are are now
mostly useless and just include asm-generic/scatterlist.h.
[sfr@canb.auug.org.au: powerpc files now need asm/dma.h]
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Acked-by: Thomas Gleixner <tglx@linutronix.de> [x86]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc]
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Blk-mq drivers usually preallocate their S/G list as part of the request,
but if we want to support the very large S/G lists currently supported by
the SCSI code that would tie up a lot of memory in the preallocated request
pool. Add support to the scatterlist code so that it can initialize a
S/G list that uses a preallocated first chunks and dynamically allocated
additional chunks. That way the scsi-mq code can preallocate a first
page worth of S/G entries as part of the request, and dynamically extend
the S/G list when needed.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Webb Scales <webbnh@hp.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
Tested-by: Bart Van Assche <bvanassche@acm.org>
Tested-by: Robert Elliott <elliott@hp.com>
sg_copy_buffer() can't meet demand for some drrivers(such usb
mass storage), so we have to use the sg_miter_* APIs to access
sg buffer, then need export sg_miter_skip() for these drivers.
The API is needed for converting to sg_miter_* APIs in USB storage
driver for accessing sg buffer.
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
The only difference between sg_pcopy_{from,to}_buffer() and
sg_copy_{from,to}_buffer() is an additional argument that specifies the
number of bytes to skip the SG list before copying.
Cc: Douglas Gilbert <dgilbert@interlog.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Horia Geanta <horia.geanta@freescale.com>
Cc: Imre Deak <imre.deak@intel.com>
Acked-by: Tejun Heo <tj@kernel.org>
Add a check behind CONFIG_DEBUG_SG to verify this.
Pull drm updates from Dave Airlie:
"This is the main drm pull request for 3.10.
Wierd bits:
- OMAP drm changes required OMAP dss changes, in drivers/video, so I
took them in here.
- one more fbcon fix for font handover
- VT switch avoidance in pm code
- scatterlist helpers for gpu drivers - have acks from akpm
Highlights:
- qxl kms driver - driver for the spice qxl virtual GPU
Nouveau:
- fermi/kepler VRAM compression
- GK110/nvf0 modesetting support.
Tegra:
- host1x core merged with 2D engine support
i915:
- vt switchless resume
- more valleyview support
- vblank fixes
- modesetting pipe config rework
radeon:
- UVD engine support
- SI chip tiling support
- GPU registers initialisation from golden values.
exynos:
- device tree changes
- fimc block support
Otherwise:
- bunches of fixes all over the place."
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (513 commits)
qxl: update to new idr interfaces.
drm/nouveau: fix build with nv50->nvc0
drm/radeon: fix handling of v6 power tables
drm/radeon: clarify family checks in pm table parsing
drm/radeon: consolidate UVD clock programming
drm/radeon: fix UPLL_REF_DIV_MASK definition
radeon: add bo tracking debugfs
drm/radeon: add new richland pci ids
drm/radeon: add some new SI PCI ids
drm/radeon: fix scratch reg handling for UVD fence
drm/radeon: allocate SA bo in the requested domain
drm/radeon: fix possible segfault when parsing pm tables
drm/radeon: fix endian bugs in atom_allocate_fb_scratch()
OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found
OMAPDSS: VENC: Add error handling for venc_probe_pdata
OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata
OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata
OMAPDSS: DSI: Add error handling for dsi_probe_pdata
OMAPDSS: SDI: Add error handling for sdi_probe_pdata
OMAPDSS: DPI: Add error handling for dpi_probe_pdata
The i915 driver uses sg lists for memory without backing 'struct page'
pages, similarly to other IO memory regions, setting only the DMA
address for these. It does this, so that it can program the HW MMU
tables in a uniform way both for sg lists with and without backing pages.
Without a valid page pointer we can't call nth_page to get the current
page in __sg_page_iter_next, so add a helper that relevant users can
call separately. Also add a helper to get the DMA address of the current
page (idea from Daniel).
Convert all places in i915, to use the new API.
Signed-off-by: Imre Deak <imre.deak@intel.com>
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This is useful in places that recycle the same scatterlist multiple
times, and do not want to incur the cost of sg_init_table every
time in hot paths.
For better code reuse use the newly added page iterator to iterate
through the pages. The offset, length within the page is still
calculated by the mapping iterator as well as the actual mapping. Idea
from Tejun Heo.
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Add an iterator to walk through a scatter list a page at a time starting
at a specific page offset. As opposed to the mapping iterator this is
meant to be small, performing well even in simple loops like collecting
all pages on the scatterlist into an array or setting up an iommu table
based on the pages' DMA address.
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Useful helper to know the number of entries in scatterlist.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: Alex Dubov <oakad@yahoo.com>
This patch adds a new constructor for an sg table. The table is constructed
from an array of struct pages. All contiguous chunks of the pages are merged
into a single sg nodes. A user may provide an offset and a size of a buffer if
the buffer is not page-aligned.
The function is dedicated for DMABUF exporters which often perform conversion
from an page array to a scatterlist. Moreover the scatterlist should be
squashed in order to save memory and to speed-up the process of DMA mapping
using dma_map_sg.
The code is based on the patch 'v4l: vb2-dma-contig: add support for
scatterlist in userptr mode' and hints from Laurent Pinchart.
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
CC: Andrew Morton <akpm@linux-foundation.org>
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
sg_miter_start() is currently unaware of the direction of the copy
process (to or from the scatter list). It is important to know the
direction because the page has to be flushed in case the data written
is seen on a different mapping in user land on cache incoherent
architectures.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
This is alternative implementation of sg content iterator introduced
by commit 83e7d317... from Pierre Ossman in next-20080716. As there's
already an sg iterator which iterates over sg entries themselves, name
this sg_mapping_iterator.
Slightly edited description from the original implementation follows.
Iteration over a sg list is not that trivial when you take into
account that memory pages might have to be mapped before being used.
Unfortunately, that means that some parts of the kernel restrict
themselves to directly accesible memory just to not have to deal with
the mess.
This patch adds a simple iterator system that allows any code to
easily traverse an sg list and not have to deal with all the details.
The user can decide to consume part of the iteration. Also, iteration
can be stopped and resumed later if releasing the kmap between
iteration steps is necessary. These features are useful to implement
piecemeal sg copying for interrupt drive PIO for example.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
This patch adds new three helper functions to copy data between an SG
list and a linear buffer.
- sg_copy_from_buffer copies data from linear buffer to an SG list
- sg_copy_to_buffer copies data from an SG list to a linear buffer
When the APIs copy data from a linear buffer to an SG list,
flush_kernel_dcache_page is called. It's not necessary for everyone
but it's a no-op on most architectures and in general the API is not
used in performance critical path.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
SCSI sg table allocation has a maximum size (of SCSI_MAX_SG_SEGMENTS,
currently 128) and this will cause a BUG_ON() in SCSI if something
tries an allocation over it. This patch adds a size limit to the
chaining allocator to allow the specification of the maximum
allocation size for chaining, so we always chain in units of the
maximum SCSI allocation size.
Manually doing chained sg lists is not trivial, so add some helpers
to make sure that drivers get it right.
I realize that sg chaining is a ploy to make the rest of the kernel
devs feel the pain of the SCSI subsystem. But this was a little
unsubtle.
Acked-by: Tejun Heo <htejun@gmail.com>
Add more safeguards to protect against misinterpreting a chain entry
as a normal scatterlist and vice-versa.
* Make sure the entry isn't a chain when assigning and reading a
normal sg.
* Clear offset and length when chaining.
Signed-off-by: Tejun Heo <htejun@gmail.com>
sg_mark_end() overwrites the page_link information, but all users want
__sg_mark_end() behaviour where we just set the end bit. That is the most
natural way to use the sg list, since you'll fill it in and then mark the
end point.
So change sg_mark_end() to only set the termination bit. Add a sg_magic
debug check as well, and clear a chain pointer if it is set.
Don't open code sg_init_one(), make it reuse sg_init_table().
Clean up: fix a mixed sign comparison in sg_init_table() accidentally
introduced by commit d6ec0842. The sign of the loop index variable
should match the sign of the "nents" argument.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
Clean up: fix a mixed sign comparison in sg_last() accidentally
introduced by commit 70eb8040. The sign of the loop index variable
Since we are using the last entry in the list, clear any possible
termination bit that may have already been set. Pointed out by Rusty.
x86_32 CONFIG_HIGHMEM64G with 5GB RAM hung when booting, after issuing
some "request_module: runaway loop modprobe binfmt-0000" messages in
trying to exec /sbin/init.
The binprm buf doesn't see the right ".ELF" header because sg_phys()
is providing the wrong physical addresses for high pages: a 32-bit
unsigned long is too small in this case, we need to use dma_addr_t.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Most drivers need to set length and offset as well, so may as well fold
those three lines into one.
Add sg_assign_page() for those two locations that only needed to set
the page, where the offset/length is set outside of the function context.
Suggested by Boaz Harrosh <bharrosh@panasas.com>
Add a Kconfig entry which will toggle some sanity checks on the sg
entry and tables.
Change the page member of the scatterlist structure to be an unsigned
long, and encode more stuff in the lower bits:
- Bits 0 and 1 zero: this is a normal sg entry. Next sg entry is located
at sg + 1.
- Bit 0 set: this is a chain entry, the next real entry is at ->page_link
with the two low bits masked off.
- Bit 1 set: this is the final entry in the sg entry. sg_next() will return
NULL when passed such an entry.
It's thus important that sg table users use the proper accessors to get
and set the page member.
We can then transition drivers without changing the generated code.
The core of the patch - allow the last sg element in a scatterlist
table to point to the start of a new table. We overload the LSB of
the page pointer to indicate whether this is a valid sg entry, or
merely a link to the next list.
Includes a fix from Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
correcting the ifdef ARCH_HAS_SG_CHAIN guarding sg_last().
First step to being able to change the scatterlist setup without
having to modify drivers (a lot :-)
This patch adds a const modifier to the buf argument of sg_set_buf and
sg_init_one. This lets people call it with pointers that are const.
sg_init_one is a nice tool for the block layer. However, users
of struct scatterlist in other subsystems don't usually need the
DMA attributes. For them it's a waste of time and space to
initialise the whole struct scatterlist structure.
Therefore this patch adds a new function sg_set_buf to initialise
a scatterlist without zeroing the DMA attributes.
infrastructure for it.
Let it rip!
