[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ]
Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we
can now trace init processes. init is initially protected with
SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but
there are a number of paths during tracing where SIGNAL_UNKILLABLE can
be implicitly cleared.
This can result in init becoming stoppable/killable after tracing. For
example, running:
while true; do kill -STOP 1; done &
strace -p 1
and then stopping strace and the kill loop will result in init being
left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but
init will now respond to future SIGSTOP signals rather than ignoring
them.
Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED
that we don't clear SIGNAL_UNKILLABLE.
Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
[ Upstream commit 7d7efec368d537226142cbe559f45797f18672f9 ]
threadgroup_change_begin/end() are used to mark the beginning and end
of threadgroup modifying operations to allow code paths which require
a threadgroup to stay stable across blocking operations to synchronize
against those sections using threadgroup_lock/unlock().
It's currently implemented as a general mechanism in sched.h using
per-signal_struct rwsem; however, this never grew non-cgroup use cases
and becomes noop if !CONFIG_CGROUPS. It turns out that cgroups is
gonna be better served with a different sycnrhonization scheme and is
a bit silly to keep cgroups specific details as a general mechanism.
What's general here is identifying the places where threadgroups are
modified. This patch restructures threadgroup locking so that
threadgroup_change_begin/end() become a place where subsystems which
need to sycnhronize against threadgroup changes can hook into.
cgroup_threadgroup_change_begin/end() which operate on the
per-signal_struct rwsem are created and threadgroup_lock/unlock() are
moved to cgroup.c and made static.
This is pure reorganization which doesn't cause any functional
changes.
[ Upstream commit 64b875f7ac8a5d60a4e191479299e931ee949b67 ]
When the flag PT_PTRACE_CAP was added the PTRACE_TRACEME path was
overlooked. This can result in incorrect behavior when an application
like strace traces an exec of a setuid executable.
Further PT_PTRACE_CAP does not have enough information for making good
security decisions as it does not report which user namespace the
capability is in. This has already allowed one mistake through
insufficient granulariy.
I found this issue when I was testing another corner case of exec and
discovered that I could not get strace to set PT_PTRACE_CAP even when
running strace as root with a full set of caps.
This change fixes the above issue with strace allowing stracing as
root a setuid executable without disabling setuid. More fundamentaly
this change allows what is allowable at all times, by using the correct
information in it's decision.
Cc: stable@vger.kernel.org
Fixes: 4214e42f96d4 ("v2.4.9.11 -> v2.4.9.12")
[ Upstream commit 759c01142a5d0f364a462346168a56de28a80f52 ]
On no-so-small systems, it is possible for a single process to cause an
OOM condition by filling large pipes with data that are never read. A
typical process filling 4000 pipes with 1 MB of data will use 4 GB of
memory. On small systems it may be tricky to set the pipe max size to
prevent this from happening.
This patch makes it possible to enforce a per-user soft limit above
which new pipes will be limited to a single page, effectively limiting
them to 4 kB each, as well as a hard limit above which no new pipes may
be created for this user. This has the effect of protecting the system
against memory abuse without hurting other users, and still allowing
pipes to work correctly though with less data at once.
The limit are controlled by two new sysctls : pipe-user-pages-soft, and
pipe-user-pages-hard. Both may be disabled by setting them to zero. The
default soft limit allows the default number of FDs per process (1024)
to create pipes of the default size (64kB), thus reaching a limit of 64MB
before starting to create only smaller pipes. With 256 processes limited
to 1024 FDs each, this results in 1024*64kB + (256*1024 - 1024) * 4kB =
1084 MB of memory allocated for a user. The hard limit is disabled by
default to avoid breaking existing applications that make intensive use
of pipes (eg: for splicing).
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
[ Upstream commit 712f4aad406bb1ed67f3f98d04c044191f0ff593 ]
It is possible for a process to allocate and accumulate far more FDs than
the process' limit by sending them over a unix socket then closing them
to keep the process' fd count low.
This change addresses this problem by keeping track of the number of FDs
in flight per user and preventing non-privileged processes from having
more FDs in flight than their configured FD limit.
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit fe32d3cd5e8eb0f82e459763374aa80797023403 upstream.
These functions check should_resched() before unlocking spinlock/bh-enable:
preempt_count always non-zero => should_resched() always returns false.
cond_resched_lock() worked iff spin_needbreak is set.
This patch adds argument "preempt_offset" to should_resched().
preempt_count offset constants for that:
PREEMPT_DISABLE_OFFSET - offset after preempt_disable()
PREEMPT_LOCK_OFFSET - offset after spin_lock()
SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable()
SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Alexander Graf <agraf@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers")
Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz
Signed-off-by: Mike Galbraith <efault@gmx.de>
This reverts commits 0a4e6be9ca17c54817cf814b4b5aa60478c6df27
and 80f7fdb1c7f0f9266421f823964fd1962681f6ce.
The task migration notifier was originally introduced in order to support
the pvclock vsyscall with non-synchronized TSC, but KVM only supports it
with synchronized TSC. Hence, on KVM the race condition is only needed
due to a bad implementation on the host side, and even then it's so rare
that it's mostly theoretical.
As far as KVM is concerned it's possible to fix the host, avoiding the
additional complexity in the vDSO and the (re)introduction of the task
migration notifier.
Xen, on the other hand, hasn't yet implemented vsyscall support at
all, so we do not care about its plans for non-synchronized TSC.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Suggested-by: Marcelo Tosatti <mtosatti@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"Nothing too interesting. Rik made cpuset cooperate better with
isolcpus and there are several other cleanup patches"
* 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cpuset, isolcpus: document relationship between cpusets & isolcpus
cpusets, isolcpus: exclude isolcpus from load balancing in cpusets
sched, isolcpu: make cpu_isolated_map visible outside scheduler
cpuset: initialize cpuset a bit early
cgroup: Use kvfree in pidlist_free()
cgroup: call cgroup_subsys->bind on cgroup subsys initialization
Pull scheduler changes from Ingo Molnar:
"Major changes:
- Reworked CPU capacity code, for better SMP load balancing on
systems with assymetric CPUs. (Vincent Guittot, Morten Rasmussen)
- Reworked RT task SMP balancing to be push based instead of pull
based, to reduce latencies on large CPU count systems. (Steven
Rostedt)
- SCHED_DEADLINE support updates and fixes. (Juri Lelli)
- SCHED_DEADLINE task migration support during CPU hotplug. (Wanpeng Li)
- x86 mwait-idle optimizations and fixes. (Mike Galbraith, Len Brown)
- sched/numa improvements. (Rik van Riel)
- various cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (28 commits)
sched/core: Drop debugging leftover trace_printk call
sched/deadline: Support DL task migration during CPU hotplug
sched/core: Check for available DL bandwidth in cpuset_cpu_inactive()
sched/deadline: Always enqueue on previous rq when dl_task_timer() fires
sched/core: Remove unused argument from init_[rt|dl]_rq()
sched/deadline: Fix rt runtime corruption when dl fails its global constraints
sched/deadline: Avoid a superfluous check
sched: Improve load balancing in the presence of idle CPUs
sched: Optimize freq invariant accounting
sched: Move CFS tasks to CPUs with higher capacity
sched: Add SD_PREFER_SIBLING for SMT level
sched: Remove unused struct sched_group_capacity::capacity_orig
sched: Replace capacity_factor by usage
sched: Calculate CPU's usage statistic and put it into struct sg_lb_stats::group_usage
sched: Add struct rq::cpu_capacity_orig
sched: Make scale_rt invariant with frequency
sched: Make sched entity usage tracking scale-invariant
sched: Remove frequency scaling from cpu_capacity
sched: Track group sched_entity usage contributions
sched: Add sched_avg::utilization_avg_contrib
Pull KVM updates from Paolo Bonzini:
"First batch of KVM changes for 4.1
The most interesting bit here is irqfd/ioeventfd support for ARM and
ARM64.
Summary:
ARM/ARM64:
fixes for live migration, irqfd and ioeventfd support (enabling
vhost, too), page aging
s390:
interrupt handling rework, allowing to inject all local interrupts
via new ioctl and to get/set the full local irq state for migration
and introspection. New ioctls to access memory by virtual address,
and to get/set the guest storage keys. SIMD support.
MIPS:
FPU and MIPS SIMD Architecture (MSA) support. Includes some
patches from Ralf Baechle's MIPS tree.
x86:
bugfixes (notably for pvclock, the others are small) and cleanups.
Another small latency improvement for the TSC deadline timer"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
KVM: use slowpath for cross page cached accesses
kvm: mmu: lazy collapse small sptes into large sptes
KVM: x86: Clear CR2 on VCPU reset
KVM: x86: DR0-DR3 are not clear on reset
KVM: x86: BSP in MSR_IA32_APICBASE is writable
KVM: x86: simplify kvm_apic_map
KVM: x86: avoid logical_map when it is invalid
KVM: x86: fix mixed APIC mode broadcast
KVM: x86: use MDA for interrupt matching
kvm/ppc/mpic: drop unused IRQ_testbit
KVM: nVMX: remove unnecessary double caching of MAXPHYADDR
KVM: nVMX: checks for address bits beyond MAXPHYADDR on VM-entry
KVM: x86: cache maxphyaddr CPUID leaf in struct kvm_vcpu
KVM: vmx: pass error code with internal error #2
x86: vdso: fix pvclock races with task migration
KVM: remove kvm_read_hva and kvm_read_hva_atomic
KVM: x86: optimize delivery of TSC deadline timer interrupt
KVM: x86: extract blocking logic from __vcpu_run
kvm: x86: fix x86 eflags fixed bit
KVM: s390: migrate vcpu interrupt state
It is gone from all archs, now we can remove
the final bits.
Signed-off-by: Richard Weinberger <richard@nod.at>
Add new statistics which reflect the average time a task is running on the CPU
and the sum of these running time of the tasks on a runqueue. The latter is
named utilization_load_avg.
This patch is based on the usage metric that was proposed in the 1st
versions of the per-entity load tracking patchset by Paul Turner
<pjt@google.com> but that has be removed afterwards. This version differs from
the original one in the sense that it's not linked to task_group.
The rq's utilization_load_avg will be used to check if a rq is overloaded or
not instead of trying to compute how many tasks a group of CPUs can handle.
Rename runnable_avg_period into avg_period as it is now used with both
runnable_avg_sum and running_avg_sum.
Add some descriptions of the variables to explain their differences.
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Acked-by: Morten Rasmussen <morten.rasmussen@arm.com>
Cc: Paul Turner <pjt@google.com>
Cc: Ben Segall <bsegall@google.com>
Cc: Morten.Rasmussen@arm.com
Cc: dietmar.eggemann@arm.com
Cc: efault@gmx.de
Cc: kamalesh@linux.vnet.ibm.com
Cc: linaro-kernel@lists.linaro.org
Cc: nicolas.pitre@linaro.org
Cc: preeti@linux.vnet.ibm.com
Cc: riel@redhat.com
Link: http://lkml.kernel.org/r/1425052454-25797-2-git-send-email-vincent.guittot@linaro.org
Dave Chinner reported the following on https://lkml.org/lkml/2015/3/1/226
Across the board the 4.0-rc1 numbers are much slower, and the degradation
is far worse when using the large memory footprint configs. Perf points
straight at the cause - this is from 4.0-rc1 on the "-o bhash=101073" config:
- 56.07% 56.07% [kernel] [k] default_send_IPI_mask_sequence_phys
- default_send_IPI_mask_sequence_phys
- 99.99% physflat_send_IPI_mask
- 99.37% native_send_call_func_ipi
smp_call_function_many
- native_flush_tlb_others
- 99.85% flush_tlb_page
ptep_clear_flush
try_to_unmap_one
rmap_walk
try_to_unmap
migrate_pages
migrate_misplaced_page
- handle_mm_fault
- 99.73% __do_page_fault
trace_do_page_fault
do_async_page_fault
+ async_page_fault
0.63% native_send_call_func_single_ipi
generic_exec_single
smp_call_function_single
This is showing excessive migration activity even though excessive
migrations are meant to get throttled. Normally, the scan rate is tuned
on a per-task basis depending on the locality of faults. However, if
migrations fail for any reason then the PTE scanner may scan faster if
the faults continue to be remote. This means there is higher system CPU
overhead and fault trapping at exactly the time we know that migrations
cannot happen. This patch tracks when migration failures occur and
slows the PTE scanner.
Reported-by: Dave Chinner <david@fromorbit.com>
Tested-by: Dave Chinner <david@fromorbit.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
The following point:
2. per-CPU pvclock time info is updated if the
underlying CPU changes.
Is not true anymore since "KVM: x86: update pvclock area conditionally,
on cpu migration".
Add task migration notification back.
Problem noticed by Andy Lutomirski.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
CC: stable@kernel.org # 3.11+
Needed by the next patch. Also makes cpu_isolated_map present
when compiled without SMP and/or with CONFIG_NR_CPUS=1, like
the other cpu masks.
At some point we may want to clean things up so cpumasks do
not exist in UP kernels. Maybe something for the CONFIG_TINY
crowd.
Cc: Clark Williams <williams@redhat.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: cgroups@vger.kernel.org
Signed-off-by: Rik van Riel <riel@redhat.com>
Acked-by: Zefan Li <lizefan@huawei.com>
Pull scheduler fixes from Ingo Molnar:
"Thiscontains misc fixes: preempt_schedule_common() and io_schedule()
recursion fixes, sched/dl fixes, a completion_done() revert, two
sched/rt fixes and a comment update patch"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/rt: Avoid obvious configuration fail
sched/autogroup: Fix failure to set cpu.rt_runtime_us
sched/dl: Do update_rq_clock() in yield_task_dl()
sched: Prevent recursion in io_schedule()
sched/completion: Serialize completion_done() with complete()
sched: Fix preempt_schedule_common() triggering tracing recursion
sched/dl: Prevent enqueue of a sleeping task in dl_task_timer()
sched: Make dl_task_time() use task_rq_lock()
sched: Clarify ordering between task_rq_lock() and move_queued_task()
io_schedule() calls blk_flush_plug() which, depending on the
contents of current->plug, can initiate arbitrary blk-io requests.
Note that this contrasts with blk_schedule_flush_plug() which requires
all non-trivial work to be handed off to a separate thread.
This makes it possible for io_schedule() to recurse, and initiating
block requests could possibly call mempool_alloc() which, in times of
memory pressure, uses io_schedule().
Apart from any stack usage issues, io_schedule() will not behave
correctly when called recursively as delayacct_blkio_start() does
not allow for repeated calls.
So:
- use ->in_iowait to detect recursion. Set it earlier, and restore
it to the old value.
- move the call to "raw_rq" after the call to blk_flush_plug().
As this is some sort of per-cpu thing, we want some chance that
we are on the right CPU
- When io_schedule() is called recurively, use blk_schedule_flush_plug()
which cannot further recurse.
- as this makes io_schedule() a lot more complex and as io_schedule()
must match io_schedule_timeout(), but all the changes in io_schedule_timeout()
and make io_schedule a simple wrapper for that.
Signed-off-by: NeilBrown <neilb@suse.de>
[ Moved the now rudimentary io_schedule() into sched.h. ]
Cc: Tony Battersby <tonyb@cybernetics.com>
Link: http://lkml.kernel.org/r/20150213162600.059fffb2@notabene.brown
Kernel Address sanitizer (KASan) is a dynamic memory error detector. It
provides fast and comprehensive solution for finding use-after-free and
out-of-bounds bugs.
KASAN uses compile-time instrumentation for checking every memory access,
therefore GCC > v4.9.2 required. v4.9.2 almost works, but has issues with
putting symbol aliases into the wrong section, which breaks kasan
instrumentation of globals.
This patch only adds infrastructure for kernel address sanitizer. It's
not available for use yet. The idea and some code was borrowed from [1].
Basic idea:
The main idea of KASAN is to use shadow memory to record whether each byte
of memory is safe to access or not, and use compiler's instrumentation to
check the shadow memory on each memory access.
Address sanitizer uses 1/8 of the memory addressable in kernel for shadow
memory and uses direct mapping with a scale and offset to translate a
memory address to its corresponding shadow address.
Here is function to translate address to corresponding shadow address:
unsigned long kasan_mem_to_shadow(unsigned long addr)
return (addr >> KASAN_SHADOW_SCALE_SHIFT) + KASAN_SHADOW_OFFSET;
where KASAN_SHADOW_SCALE_SHIFT = 3.
So for every 8 bytes there is one corresponding byte of shadow memory.
The following encoding used for each shadow byte: 0 means that all 8 bytes
of the corresponding memory region are valid for access; k (1 <= k <= 7)
means that the first k bytes are valid for access, and other (8 - k) bytes
are not; Any negative value indicates that the entire 8-bytes are
inaccessible. Different negative values used to distinguish between
different kinds of inaccessible memory (redzones, freed memory) (see
mm/kasan/kasan.h).
To be able to detect accesses to bad memory we need a special compiler.
Such compiler inserts a specific function calls (__asan_load*(addr),
__asan_store*(addr)) before each memory access of size 1, 2, 4, 8 or 16.
These functions check whether memory region is valid to access or not by
checking corresponding shadow memory. If access is not valid an error
printed.
Historical background of the address sanitizer from Dmitry Vyukov:
"We've developed the set of tools, AddressSanitizer (Asan),
ThreadSanitizer and MemorySanitizer, for user space. We actively use
them for testing inside of Google (continuous testing, fuzzing,
running prod services). To date the tools have found more than 10'000
scary bugs in Chromium, Google internal codebase and various
open-source projects (Firefox, OpenSSL, gcc, clang, ffmpeg, MySQL and
lots of others): [2] [3] [4].
The tools are part of both gcc and clang compilers.
We have not yet done massive testing under the Kernel AddressSanitizer
(it's kind of chicken and egg problem, you need it to be upstream to
start applying it extensively). To date it has found about 50 bugs.
Bugs that we've found in upstream kernel are listed in [5].
We've also found ~20 bugs in out internal version of the kernel. Also
people from Samsung and Oracle have found some.
As others noted, the main feature of AddressSanitizer is its
performance due to inline compiler instrumentation and simple linear
shadow memory. User-space Asan has ~2x slowdown on computational
programs and ~2x memory consumption increase. Taking into account that
kernel usually consumes only small fraction of CPU and memory when
running real user-space programs, I would expect that kernel Asan will
have ~10-30% slowdown and similar memory consumption increase (when we
finish all tuning).
I agree that Asan can well replace kmemcheck. We have plans to start
working on Kernel MemorySanitizer that finds uses of unitialized
memory. Asan+Msan will provide feature-parity with kmemcheck. As
others noted, Asan will unlikely replace debug slab and pagealloc that
can be enabled at runtime. Asan uses compiler instrumentation, so even
if it is disabled, it still incurs visible overheads.
Asan technology is easily portable to other architectures. Compiler
instrumentation is fully portable. Runtime has some arch-dependent
parts like shadow mapping and atomic operation interception. They are
relatively easy to port."
Comparison with other debugging features:
KMEMCHECK:
- KASan can do almost everything that kmemcheck can. KASan uses
compile-time instrumentation, which makes it significantly faster than
kmemcheck. The only advantage of kmemcheck over KASan is detection of
uninitialized memory reads.
Some brief performance testing showed that kasan could be
x500-x600 times faster than kmemcheck:
$ netperf -l 30
MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost (127.0.0.1) port 0 AF_INET
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
no debug: 87380 16384 16384 30.00 41624.72
kasan inline: 87380 16384 16384 30.00 12870.54
kasan outline: 87380 16384 16384 30.00 10586.39
kmemcheck: 87380 16384 16384 30.03 20.23
- Also kmemcheck couldn't work on several CPUs. It always sets
number of CPUs to 1. KASan doesn't have such limitation.
DEBUG_PAGEALLOC:
- KASan is slower than DEBUG_PAGEALLOC, but KASan works on sub-page
granularity level, so it able to find more bugs.
SLUB_DEBUG (poisoning, redzones):
- SLUB_DEBUG has lower overhead than KASan.
- SLUB_DEBUG in most cases are not able to detect bad reads,
KASan able to detect both reads and writes.
- In some cases (e.g. redzone overwritten) SLUB_DEBUG detect
bugs only on allocation/freeing of object. KASan catch
bugs right before it will happen, so we always know exact
place of first bad read/write.
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
[2] https://code.google.com/p/address-sanitizer/wiki/FoundBugs
[3] https://code.google.com/p/thread-sanitizer/wiki/FoundBugs
[4] https://code.google.com/p/memory-sanitizer/wiki/FoundBugs
[5] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel#Trophies
Based on work by Andrey Konovalov.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Acked-by: Michal Marek <mmarek@suse.cz>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
When the hypervisor pauses a virtualised kernel the kernel will observe a
jump in timebase, this can cause spurious messages from the softlockup
detector.
Whilst these messages are harmless, they are accompanied with a stack
trace which causes undue concern and more problematically the stack trace
in the guest has nothing to do with the observed problem and can only be
misleading.
Futhermore, on POWER8 this is completely avoidable with the introduction
of the Virtual Time Base (VTB) register.
This patch (of 2):
This permits the use of arch specific clocks for which virtualised kernels
can use their notion of 'running' time, not the elpased wall time which
will include host execution time.
Signed-off-by: Cyril Bur <cyrilbur@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Andrew Jones <drjones@redhat.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
Cc: chai wen <chaiw.fnst@cn.fujitsu.com>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Ben Zhang <benzh@chromium.org>
Cc: John Stultz <john.stultz@linaro.org>
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
This patchset adds execveat(2) for x86, and is derived from Meredydd
Luff's patch from Sept 2012 (https://lkml.org/lkml/2012/9/11/528).
The primary aim of adding an execveat syscall is to allow an
implementation of fexecve(3) that does not rely on the /proc filesystem,
at least for executables (rather than scripts). The current glibc version
of fexecve(3) is implemented via /proc, which causes problems in sandboxed
or otherwise restricted environments.
Given the desire for a /proc-free fexecve() implementation, HPA suggested
(https://lkml.org/lkml/2006/7/11/556) that an execveat(2) syscall would be
an appropriate generalization.
Also, having a new syscall means that it can take a flags argument without
back-compatibility concerns. The current implementation just defines the
AT_EMPTY_PATH and AT_SYMLINK_NOFOLLOW flags, but other flags could be
added in future -- for example, flags for new namespaces (as suggested at
https://lkml.org/lkml/2006/7/11/474).
Related history:
- https://lkml.org/lkml/2006/12/27/123 is an example of someone
realizing that fexecve() is likely to fail in a chroot environment.
- http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=514043 covered
documenting the /proc requirement of fexecve(3) in its manpage, to
"prevent other people from wasting their time".
- https://bugzilla.redhat.com/show_bug.cgi?id=241609 described a
problem where a process that did setuid() could not fexecve()
because it no longer had access to /proc/self/fd; this has since
been fixed.
This patch (of 4):
Add a new execveat(2) system call. execveat() is to execve() as openat()
is to open(): it takes a file descriptor that refers to a directory, and
resolves the filename relative to that.
In addition, if the filename is empty and AT_EMPTY_PATH is specified,
execveat() executes the file to which the file descriptor refers. This
replicates the functionality of fexecve(), which is a system call in other
UNIXen, but in Linux glibc it depends on opening "/proc/self/fd/<fd>" (and
so relies on /proc being mounted).
The filename fed to the executed program as argv[0] (or the name of the
script fed to a script interpreter) will be of the form "/dev/fd/<fd>"
(for an empty filename) or "/dev/fd/<fd>/<filename>", effectively
reflecting how the executable was found. This does however mean that
execution of a script in a /proc-less environment won't work; also, script
execution via an O_CLOEXEC file descriptor fails (as the file will not be
accessible after exec).
Based on patches by Meredydd Luff.
Signed-off-by: David Drysdale <drysdale@google.com>
Cc: Meredydd Luff <meredydd@senatehouse.org>
Cc: Shuah Khan <shuah.kh@samsung.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Rich Felker <dalias@aerifal.cx>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
It isn't supposed to stack, so turn it into a bit-field to save 4 bytes on
the task_struct.
Also, remove the memcg_stop/resume_kmem_account helpers - it is clearer to
set/clear the flag inline. Regarding the overwhelming comment to the
helpers, which is removed by this patch too, we already have a compact yet
accurate explanation in memcg_schedule_cache_create, no need in yet
another one.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle are:
- 'Nested Sleep Debugging', activated when CONFIG_DEBUG_ATOMIC_SLEEP=y.
This instruments might_sleep() checks to catch places that nest
blocking primitives - such as mutex usage in a wait loop. Such
bugs can result in hard to debug races/hangs.
Another category of invalid nesting that this facility will detect
is the calling of blocking functions from within schedule() ->
sched_submit_work() -> blk_schedule_flush_plug().
There's some potential for false positives (if secondary blocking
primitives themselves are not ready yet for this facility), but the
kernel will warn once about such bugs per bootup, so the warning
isn't much of a nuisance.
This feature comes with a number of fixes, for problems uncovered
with it, so no messages are expected normally.
- Another round of sched/numa optimizations and refinements, for
CONFIG_NUMA_BALANCING=y.
- Another round of sched/dl fixes and refinements.
Plus various smaller fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits)
sched: Add missing rcu protection to wake_up_all_idle_cpus
sched/deadline: Introduce start_hrtick_dl() for !CONFIG_SCHED_HRTICK
sched/numa: Init numa balancing fields of init_task
sched/deadline: Remove unnecessary definitions in cpudeadline.h
sched/cpupri: Remove unnecessary definitions in cpupri.h
sched/deadline: Fix rq->dl.pushable_tasks bug in push_dl_task()
sched/fair: Fix stale overloaded status in the busiest group finding logic
sched: Move p->nr_cpus_allowed check to select_task_rq()
sched/completion: Document when to use wait_for_completion_io_*()
sched: Update comments about CLONE_NEWUTS and CLONE_NEWIPC
sched/fair: Kill task_struct::numa_entry and numa_group::task_list
sched: Refactor task_struct to use numa_faults instead of numa_* pointers
sched/deadline: Don't check CONFIG_SMP in switched_from_dl()
sched/deadline: Reschedule from switched_from_dl() after a successful pull
sched/deadline: Push task away if the deadline is equal to curr during wakeup
sched/deadline: Add deadline rq status print
sched/deadline: Fix artificial overrun introduced by yield_task_dl()
sched/rt: Clean up check_preempt_equal_prio()
sched/core: Use dl_bw_of() under rcu_read_lock_sched()
sched: Check if we got a shallowest_idle_cpu before searching for least_loaded_cpu
This patch simplifies task_struct by removing the four numa_* pointers
in the same array and replacing them with the array pointer. By doing this,
on x86_64, the size of task_struct is reduced by 3 ulong pointers (24 bytes on
x86_64).
A new parameter is added to the task_faults_idx function so that it can return
an index to the correct offset, corresponding with the old precalculated
pointers.
All of the code in sched/ that depended on task_faults_idx and numa_* was
changed in order to match the new logic.
Signed-off-by: Iulia Manda <iulia.manda21@gmail.com>
Cc: mgorman@suse.de
Cc: dave@stgolabs.net
Cc: riel@redhat.com
Link: http://lkml.kernel.org/r/20141031001331.GA30662@winterfell
PREEMPT_RCU and TREE_PREEMPT_RCU serve the same function after
TINY_PREEMPT_RCU has been removed. This patch removes TREE_PREEMPT_RCU
and uses PREEMPT_RCU config option in its place.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
cond_resched() is a preemption point, not strictly a blocking
primitive, so exclude it from the ->state test.
In particular, preemption preserves task_struct::state.
Cc: tglx@linutronix.de
Cc: ilya.dryomov@inktank.com
Cc: umgwanakikbuti@gmail.com
Cc: oleg@redhat.com
Cc: Alex Elder <alex.elder@linaro.org>
Cc: Axel Lin <axel.lin@ingics.com>
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Jason Baron <jbaron@akamai.com>
Link: http://lkml.kernel.org/r/20140924082242.656559952@infradead.org
Validate we call might_sleep() with TASK_RUNNING, which catches places
where we nest blocking primitives, eg. mutex usage in a wait loop.
Since all blocking is arranged through task_struct::state, nesting
this will cause the inner primitive to set TASK_RUNNING and the outer
will thus not block.
Another observed problem is calling a blocking function from
schedule()->sched_submit_work()->blk_schedule_flush_plug() which will
then destroy the task state for the actual __schedule() call that
comes after it.
Cc: oleg@redhat.com
Link: http://lkml.kernel.org/r/20140924082242.591637616@infradead.org
How we deal with updates to exclusive cpusets is currently broken.
As an example, suppose we have an exclusive cpuset composed of
two cpus: A[cpu0,cpu1]. We can assign SCHED_DEADLINE task to it
up to the allowed bandwidth. If we want now to modify cpusetA's
cpumask, we have to check that removing a cpu's amount of
bandwidth doesn't break AC guarantees. This thing isn't checked
in the current code.
This patch fixes the problem above, denying an update if the
new cpumask won't have enough bandwidth for SCHED_DEADLINE tasks
that are currently active.
Signed-off-by: Juri Lelli <juri.lelli@arm.com>
Link: http://lkml.kernel.org/r/5433E6AF.5080105@arm.com
exclusive cpusets
Exclusive cpusets are the only way users can restrict SCHED_DEADLINE tasks
affinity (performing what is commonly called clustered scheduling).
Unfortunately, such thing is currently broken for two reasons:
- No check is performed when the user tries to attach a task to
an exlusive cpuset (recall that exclusive cpusets have an
associated maximum allowed bandwidth).
- Bandwidths of source and destination cpusets are not correctly
updated after a task is migrated between them.
This patch fixes both things at once, as they are opposite faces
of the same coin.
The check is performed in cpuset_can_attach(), as there aren't any
points of failure after that function. The updated is split in two
halves. We first reserve bandwidth in the destination cpuset, after
we pass the check in cpuset_can_attach(). And we then release
bandwidth from the source cpuset when the task's affinity is
actually changed. Even if there can be time windows when sched_setattr()
may erroneously fail in the source cpuset, we are fine with it, as
we can't perfom an atomic update of both cpusets at once.
Reported-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Reported-by: Vincent Legout <vincent@legout.info>
Cc: Dario Faggioli <raistlin@linux.it>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Cc: Fabio Checconi <fchecconi@gmail.com>
Cc: michael@amarulasolutions.com
Cc: luca.abeni@unitn.it
Link: http://lkml.kernel.org/r/1411118561-26323-3-git-send-email-juri.lelli@arm.com
"The main changes in this cycle were:
- Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave
Hansen)
- Various sched/idle refinements for better idle handling (Nicolas
Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot)
- sched/numa updates and optimizations (Rik van Riel)
- sysbench speedup (Vincent Guittot)
- capacity calculation cleanups/refactoring (Vincent Guittot)
- Various cleanups to thread group iteration (Oleg Nesterov)
- Double-rq-lock removal optimization and various refactorings
(Kirill Tkhai)
- various sched/deadline fixes
... and lots of other changes"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits)
sched/dl: Use dl_bw_of() under rcu_read_lock_sched()
sched/fair: Delete resched_cpu() from idle_balance()
sched, time: Fix build error with 64 bit cputime_t on 32 bit systems
sched: Improve sysbench performance by fixing spurious active migration
sched/x86: Fix up typo in topology detection
x86, sched: Add new topology for multi-NUMA-node CPUs
sched/rt: Use resched_curr() in task_tick_rt()
sched: Use rq->rd in sched_setaffinity() under RCU read lock
sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask'
sched: Use dl_bw_of() under RCU read lock
sched/fair: Remove duplicate code from can_migrate_task()
sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW
sched: print_rq(): Don't use tasklist_lock
sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock()
sched: Fix the task-group check in tg_has_rt_tasks()
sched/fair: Leverage the idle state info when choosing the "idlest" cpu
sched: Let the scheduler see CPU idle states
sched/deadline: Fix inter- exclusive cpusets migrations
sched/deadline: Clear dl_entity params when setscheduling to different class
sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault()
Pull RCU updates from Ingo Molnar:
- changes related to No-CBs CPUs and NO_HZ_FULL
- RCU-tasks implementation
- torture-test updates
- miscellaneous fixes
- locktorture updates
- RCU documentation updates"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (81 commits)
workqueue: Use cond_resched_rcu_qs macro
workqueue: Add quiescent state between work items
locktorture: Cleanup header usage
locktorture: Cannot hold read and write lock
locktorture: Fix __acquire annotation for spinlock irq
locktorture: Support rwlocks
rcu: Eliminate deadlock between CPU hotplug and expedited grace periods
locktorture: Document boot/module parameters
rcutorture: Rename rcutorture_runnable parameter
locktorture: Add test scenario for rwsem_lock
locktorture: Add test scenario for mutex_lock
locktorture: Make torture scripting account for new _runnable name
locktorture: Introduce torture context
locktorture: Support rwsems
locktorture: Add infrastructure for torturing read locks
torture: Address race in module cleanup
locktorture: Make statistics generic
locktorture: Teach about lock debugging
locktorture: Support mutexes
locktorture: Add documentation
commit 21caf2fc1931 ("mm: teach mm by current context info to not do I/O
during memory allocation") introduces PF_MEMALLOC_NOIO flag to avoid doing
I/O inside memory allocation, __GFP_IO is cleared when this flag is set,
but __GFP_FS implies __GFP_IO, it should also be cleared. Or it may still
run into I/O, like in superblock shrinker. And this will make the kernel
run into the deadlock case described in that commit.
See Dave Chinner's comment about io in superblock shrinker:
Filesystem shrinkers do indeed perform IO from the superblock shrinker and
have for years. Even clean inodes can require IO before they can be freed
- e.g. on an orphan list, need truncation of post-eof blocks, need to
wait for ordered operations to complete before it can be freed, etc.
IOWs, Ext4, btrfs and XFS all can issue and/or block on arbitrary amounts
of IO in the superblock shrinker context. XFS, in particular, has been
doing transactions and IO from the VFS inode cache shrinker since it was
first introduced....
Fix this by clearing __GFP_FS in memalloc_noio_flags(), this function has
masked all the gfp_mask that will be passed into fs for the processes
setting PF_MEMALLOC_NOIO in the direct reclaim path.
v1 thread at: https://lkml.org/lkml/2014/9/3/32
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Cc: joyce.xue <xuejiufei@huawei.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: <stable@vger.kernel.org>
Pull crypto update from Herbert Xu:
- add multibuffer infrastructure (single_task_running scheduler helper,
OKed by Peter on lkml.
- add SHA1 multibuffer implementation for AVX2.
- reenable "by8" AVX CTR optimisation after fixing counter overflow.
- add APM X-Gene SoC RNG support.
- SHA256/SHA512 now handles unaligned input correctly.
- set lz4 decompressed length correctly.
- fix algif socket buffer allocation failure for 64K page machines.
- misc fixes
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (47 commits)
crypto: sha - Handle unaligned input data in generic sha256 and sha512.
Revert "crypto: aesni - disable "by8" AVX CTR optimization"
crypto: aesni - remove unused defines in "by8" variant
crypto: aesni - fix counter overflow handling in "by8" variant
hwrng: printk replacement
crypto: qat - Removed unneeded partial state
crypto: qat - Fix typo in name of tasklet_struct
crypto: caam - Dynamic allocation of addresses for various memory blocks in CAAM.
crypto: mcryptd - Fix typos in CRYPTO_MCRYPTD description
crypto: algif - avoid excessive use of socket buffer in skcipher
arm64: dts: add random number generator dts node to APM X-Gene platform.
Documentation: rng: Add X-Gene SoC RNG driver documentation
hwrng: xgene - add support for APM X-Gene SoC RNG support
crypto: mv_cesa - Add missing #define
crypto: testmgr - add test for lz4 and lz4hc
crypto: lz4,lz4hc - fix decompression
crypto: qat - Use pci_enable_msix_exact() instead of pci_enable_msix()
crypto: drbg - fix maximum value checks on 32 bit systems
crypto: drbg - fix sparse warning for cpu_to_be[32|64]
crypto: sha-mb - sha1_mb_alg_state can be static
Pull cgroup fixes from Tejun Heo:
"This is quite late but these need to be backported anyway.
This is the fix for a long-standing cpuset bug which existed from
2009. cpuset makes use of PF_SPREAD_{PAGE|SLAB} flags to modify the
task's memory allocation behavior according to the settings of the
cpuset it belongs to; unfortunately, when those flags have to be
changed, cpuset did so directly even whlie the target task is running,
which is obviously racy as task->flags may be modified by the task
itself at any time. This obscure bug manifested as corrupt
PF_USED_MATH flag leading to a weird crash.
The bug is fixed by moving the flag to task->atomic_flags. The first
two are prepatory ones to help defining atomic_flags accessors and the
third one is the actual fix"
* 'for-3.17-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cpuset: PF_SPREAD_PAGE and PF_SPREAD_SLAB should be atomic flags
sched: add macros to define bitops for task atomic flags
sched: fix confusing PFA_NO_NEW_PRIVS constant
When we change cpuset.memory_spread_{page,slab}, cpuset will flip
PF_SPREAD_{PAGE,SLAB} bit of tsk->flags for each task in that cpuset.
This should be done using atomic bitops, but currently we don't,
which is broken.
Tetsuo reported a hard-to-reproduce kernel crash on RHEL6, which happened
when one thread tried to clear PF_USED_MATH while at the same time another
thread tried to flip PF_SPREAD_PAGE/PF_SPREAD_SLAB. They both operate on
the same task.
Here's the full report:
https://lkml.org/lkml/2014/9/19/230
To fix this, we make PF_SPREAD_PAGE and PF_SPREAD_SLAB atomic flags.
v4:
- updated mm/slab.c. (Fengguang Wu)
- updated Documentation.
Cc: Miao Xie <miaox@cn.fujitsu.com>
Fixes: 950592f7b991 ("cpusets: update tasks' page/slab spread flags in time")
Cc: <stable@vger.kernel.org> # 2.6.31+
Signed-off-by: Zefan Li <lizefan@huawei.com>
This will simplify code when we add new flags.
v3:
- Kees pointed out that no_new_privs should never be cleared, so we
shouldn't define task_clear_no_new_privs(). we define 3 macros instead
of a single one.
v2:
- updated scripts/tags.sh, suggested by Peter
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Commit 1d4457f99928 ("sched: move no_new_privs into new atomic flags")
defined PFA_NO_NEW_PRIVS as hexadecimal value, but it is confusing
because it is used as bit number. Redefine it as decimal bit number.
Note this changes the bit position of PFA_NOW_NEW_PRIVS from 1 to 0.
[ lizf: slightly modified subject and changelog ]
using CONFIG_STACK_GROWSUP
Aaron Tomlin recently posted patches [1] to enable checking the
stack canary on every task switch. Looking at the canary code, I
realized that every arch (except ia64, which adds some space for
register spill above the stack) shares a definition of
end_of_stack() that makes it the first long after the
threadinfo.
For stacks that grow down, this low address is correct because
the stack starts at the end of the thread area and grows toward
lower addresses. However, for stacks that grow up, toward higher
addresses, this is wrong. (The stack actually grows away from
the canary.) On these archs end_of_stack() should return the
address of the last long, at the highest possible address for the stack.
[1] http://lkml.org/lkml/2014/9/12/293
Signed-off-by: Chuck Ebbert <cebbert.lkml@gmail.com>
Link: http://lkml.kernel.org/r/20140920101751.6c5166b6@as
Tested-by: James Hogan <james.hogan@imgtec.com> [metag]
Acked-by: James Hogan <james.hogan@imgtec.com>
Acked-by: Aaron Tomlin <atomlin@redhat.com>
This facility is used in a few places so let's introduce
a helper function to improve code readability.
Signed-off-by: Aaron Tomlin <atomlin@redhat.com>
Cc: aneesh.kumar@linux.vnet.ibm.com
Cc: dzickus@redhat.com
Cc: bmr@redhat.com
Cc: jcastillo@redhat.com
Cc: oleg@redhat.com
Cc: riel@redhat.com
Cc: prarit@redhat.com
Cc: jgh@redhat.com
Cc: minchan@kernel.org
Cc: mpe@ellerman.id.au
Cc: hannes@cmpxchg.org
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/1410527779-8133-3-git-send-email-atomlin@redhat.com
Tasks get their end of stack set to STACK_END_MAGIC with the
aim to catch stack overruns. Currently this feature does not
apply to init_task. This patch removes this restriction.
Note that a similar patch was posted by Prarit Bhargava
some time ago but was never merged:
http://marc.info/?l=linux-kernel&m=127144305403241&w=2
Cc: bmr@redhat.com
Cc: jgh@redhat.com
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Daeseok Youn <daeseok.youn@gmail.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Link: http://lkml.kernel.org/r/1410527779-8133-2-git-send-email-atomlin@redhat.com
Implementing one new API wake_up_if_idle(), which is used to
wake up the idle CPU.
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com>
Cc: daniel.lezcano@linaro.org
Cc: rjw@rjwysocki.net
Cc: linux-pm@vger.kernel.org
Cc: changcheng.liu@intel.com
Cc: xiaoming.wang@intel.com
Cc: souvik.k.chakravarty@intel.com
Cc: chuansheng.liu@intel.com
Link: http://lkml.kernel.org/r/1409815075-4180-1-git-send-email-chuansheng.liu@intel.com
Both times() and clock_gettime(CLOCK_PROCESS_CPUTIME_ID) have scalability
issues on large systems, due to both functions being serialized with a
lock.
The lock protects against reporting a wrong value, due to a thread in the
task group exiting, its statistics reporting up to the signal struct, and
that exited task's statistics being counted twice (or not at all).
Protecting that with a lock results in times() and clock_gettime() being
completely serialized on large systems.
This can be fixed by using a seqlock around the events that gather and
propagate statistics. As an additional benefit, the protection code can
be moved into thread_group_cputime(), slightly simplifying the calling
functions.
In the case of posix_cpu_clock_get_task() things can be simplified a
lot, because the calling function already ensures that the task sticks
around, and the rest is now taken care of in thread_group_cputime().
This way the statistics reporting code can run lockless.
Cc: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Cc: Guillaume Morin <guillaume@morinfr.org>
Cc: Ionut Alexa <ionut.m.alexa@gmail.com>
Cc: Michal Schmidt <mschmidt@redhat.com>
Cc: fweisbec@gmail.com
Cc: srao@redhat.com
Cc: lwoodman@redhat.com
Cc: atheurer@redhat.com
Link: http://lkml.kernel.org/r/20140816134010.26a9b572@annuminas.surriel.com
The rcu_preempt_note_context_switch() function is on a scheduling fast
path, so it would be good to avoid disabling irqs. The reason that irqs
are disabled is to synchronize process-level and irq-handler access to
the task_struct ->rcu_read_unlock_special bitmask. This commit therefore
makes ->rcu_read_unlock_special instead be a union of bools with a short
allowing single-access checks in RCU's __rcu_read_unlock(). This results
in the process-level and irq-handler accesses being simple loads and
stores, so that irqs need no longer be disabled. This commit therefore
removes the irq disabling from rcu_preempt_note_context_switch().
Currently TASKS_RCU would ignore a CPU running a task in nohz_full=
usermode execution. There would be neither a context switch nor a
scheduling-clock interrupt to tell TASKS_RCU that the task in question
had passed through a quiescent state. The grace period would therefore
extend indefinitely. This commit therefore makes RCU's dyntick-idle
subsystem record the task_struct structure of the task that is running
in dyntick-idle mode on each CPU. The TASKS_RCU grace period can
then access this information and record a quiescent state on
behalf of any CPU running in dyntick-idle usermode.
This commit adds a new RCU-tasks flavor of RCU, which provides
call_rcu_tasks(). This RCU flavor's quiescent states are voluntary
context switch (not preemption!) and userspace execution (not the idle
loop -- use some sort of schedule_on_each_cpu() if you need to handle the
idle tasks. Note that unlike other RCU flavors, these quiescent states
occur in tasks, not necessarily CPUs. Includes fixes from Steven Rostedt.
This RCU flavor is assumed to have very infrequent latency-tolerant
updaters. This assumption permits significant simplifications, including
a single global callback list protected by a single global lock, along
with a single task-private linked list containing all tasks that have not
yet passed through a quiescent state. If experience shows this assumption
to be incorrect, the required additional complexity will be added.
Suggested-by: Steven Rostedt <rostedt@goodmis.org>
only task running on a cpu
This function will help an async task processing batched jobs from
workqueue decide if it wants to keep processing on more chunks of batched
work that can be delayed, or to accumulate more work for more efficient
batched processing later.
If no other tasks are running on the cpu, the batching process can take
advantgae of the available cpu cycles to a make decision to continue
processing the existing accumulated work to minimize delay,
otherwise it will yield.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Pull more ACPI and power management updates from Rafael Wysocki:
"These are a couple of regression fixes, cpuidle menu governor
optimizations, fixes for ACPI proccessor and battery drivers,
hibernation fix to avoid problems related to the e820 memory map,
fixes for a few cpufreq drivers and a new version of the suspend
profiling tool analyze_suspend.py.
Specifics:
- Fix for an ACPI-based device hotplug regression introduced in 3.14
that causes a kernel panic to trigger when memory hot-remove is
attempted with CONFIG_ACPI_HOTPLUG_MEMORY unset from Tang Chen
- Fix for a cpufreq regression introduced in 3.16 that triggers a
"sleeping function called from invalid context" bug in
dev_pm_opp_init_cpufreq_table() from Stephen Boyd
- ACPI battery driver fix for a warning message added in 3.16 that
prints silly stuff sometimes from Mariusz Ceier
- Hibernation fix for safer handling of mismatches in the 820 memory
map between the configurations during image creation and during the
subsequent restore from Chun-Yi Lee
- ACPI processor driver fix to handle CPU hotplug notifications
correctly during system suspend/resume from Lan Tianyu
- Series of four cpuidle menu governor cleanups that also should
speed it up a bit from Mel Gorman
- Fixes for the speedstep-smi, integrator, cpu0 and arm_big_little
cpufreq drivers from Hans Wennborg, Himangi Saraogi, Markus
Pargmann and Uwe Kleine-König
- Version 3.0 of the analyze_suspend.py suspend profiling tool from
Todd E Brandt"
* tag 'pm+acpi-3.17-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / battery: Fix warning message in acpi_battery_get_state()
PM / tools: analyze_suspend.py: update to v3.0
cpufreq: arm_big_little: fix module license spec
cpufreq: speedstep-smi: fix decimal printf specifiers
ACPI / hotplug: Check scan handlers in acpi_scan_hot_remove()
cpufreq: OPP: Avoid sleeping while atomic
cpufreq: cpu0: Do not print error message when deferring
cpufreq: integrator: Use set_cpus_allowed_ptr
PM / hibernate: avoid unsafe pages in e820 reserved regions
ACPI / processor: Make acpi_cpu_soft_notify() process CPU FROZEN events
cpuidle: menu: Lookup CPU runqueues less
cpuidle: menu: Call nr_iowait_cpu less times
cpuidle: menu: Use ktime_to_us instead of reinventing the wheel
cpuidle: menu: Use shifts when calculating averages where possible
* pm-sleep:
* pm-cpufreq:
* pm-cpuidle:
Pull arch signal handling cleanup from Richard Weinberger:
"This patch series moves all remaining archs to the get_signal(),
signal_setup_done() and sigsp() functions.
Currently these archs use open coded variants of the said functions.
Further, unused parameters get removed from get_signal_to_deliver(),
tracehook_signal_handler() and signal_delivered().
At the end of the day we save around 500 lines of code."
* 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits)
powerpc: Use sigsp()
openrisc: Use sigsp()
mn10300: Use sigsp()
mips: Use sigsp()
microblaze: Use sigsp()
metag: Use sigsp()
m68k: Use sigsp()
m32r: Use sigsp()
hexagon: Use sigsp()
frv: Use sigsp()
cris: Use sigsp()
c6x: Use sigsp()
blackfin: Use sigsp()
avr32: Use sigsp()
arm64: Use sigsp()
arc: Use sigsp()
sas_ss_flags: Remove nested ternary if
Rip out get_signal_to_deliver()
Clean up signal_delivered()
tracehook_signal_handler: Remove sig, info, ka and regs
