path: root/include/linux/screen_info.h
2009-11-13x86, setup: Store the boot cursor stateMatthew Garrett
Add a field to store the boot cursor state and implement this for VGA on x86. This can then be used to set the default policy for the boot console. Signed-off-by: Matthew Garrett <mjg@redhat.com> LKML-Reference: <1258142222-16092-1-git-send-email-mjg@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-11-29x86_64 EFI boot support: EFI frame buffer driverHuang, Ying
This patch adds Graphics Output Protocol support to the kernel. UEFI2.0 spec deprecates Universal Graphics Adapter (UGA) protocol and only Graphics Output Protocol (GOP) is produced. Therefore, the boot loader needs to query the UEFI firmware with appropriate Output Protocol and pass the video information to the kernel. As a result of GOP protocol, an EFI framebuffer driver is needed for displaying console messages. The patch adds a EFI framebuffer driver. The EFI frame buffer driver in this patch is based on the Intel Mac framebuffer driver. The ELILO bootloader takes care of passing the video information as appropriate for EFI firmware. The framebuffer driver has been tested in i386 kernel and x86_64 kernel on EFI platform. Signed-off-by: Chandramouli Narayanan <mouli@linux.intel.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23Make asm-x86/bootparam.h includable from userspace.Rusty Russell
To actually write a bootloader (or, say, the lguest launcher) currently requires duplication of these structures. Making them includable from userspace is much nicer. We merge the common userspace-required definitions of e820_32/64.h into e820.h for export. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-16Remove magic macros for screen_info structure membersH. Peter Anvin
Stop using magic macros for screen_info structure members. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-07-12Clean up struct screen_info (<linux/screen_info.h>)H. Peter Anvin
struct screen_info has unaligned members, it needs to be packed. In the process, fix the naming of some of the members, which don't belong in this structure but are part of it anyway. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] i386: Relocatable kernel supportEric W. Biederman
This patch modifies the i386 kernel so that if CONFIG_RELOCATABLE is selected it will be able to be loaded at any 4K aligned address below 1G. The technique used is to compile the decompressor with -fPIC and modify it so the decompressor is fully relocatable. For the main kernel relocations are generated. Resulting in a kernel that is relocatable with no runtime overhead and no need to modify the source code. A reserved 32bit word in the parameters has been assigned to serve as a stack so we figure out where are running. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-04-11[PATCH] vesafb: Fix incorrect logo colors in x86_64Antonino A. Daplas
Bugzilla Bug 6299: A pixel size of 8 bits produces wrong logo colors in x86_64. The driver has 2 methods for setting the color map, using the protected mode interface provided by the video BIOS and directly writing to the VGA registers. The former is not supported in x86_64 and the latter is enabled only in i386. Fix by enabling the latter method in x86_64 only if supported by the BIOS. If both methods are unsupported, change the visual of vesafb to STATIC_PSEUDOCOLOR. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] vesafb: Drop blank hookAntonino A. Daplas
From: Bugzilla Bug 5351 "After resuming from S3 (suspended while in X), the LCD panel stays black . However, the laptop is up again, and I can SSH into it from another machine. I can get the panel working again, when I first direct video output to the CRT output of the laptop, and then back to LCD (done by repeatedly hitting Fn+F5 buttons on the Toshiba, which directs output to either LCD, CRT or TV) None of this ever happened with older kernels." This bug is due to the recently added vesafb_blank() method in vesafb. It works with CRT displays, but has a high incidence of problems in laptop users. Since CRT users don't really get that much benefit from hardware blanking, drop support for this. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Split out screen_info from tty.hBrian Gerst
This makes it possible for boot code to use screen_info without dragging in all of tty.h. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
