commit dce05aa6eec977f1472abed95ccd71276b9a3864 upstream.
Avoid global variables (namely sel_cons) by introducing vc_is_sel. It
checks whether the parameter is the current selection console. This will
help putting sel_cons to a struct later.
Link: https://lore.kernel.org/r/20200219073951.16151-1-jslaby@suse.cz
Every user of default_red, default_grn, and default_blu treats them as
unsigned char. So make it really unsigned char.
And indent the initializers and module_param properly.
This saves ~ 100 bytes of data.
This means all ->con_set_palette have to have the second parameter
const too now.
A notifier chain is called whenever the vt code modifies a terminal
content, except for one case which is when the modification comes
through writes to /dev/vcs* devices. Let's add the missing notifier
invocation at the end of vcs_write() for that case too.
Signed-off-by: Nicolas Pitre <nicolas.pitre@canonical.com>
Cc: Alan Cox <alan@linux.intel.com>
<linux/selection.h> assumes that struct tty_struct has previously been
included. If not, this pile of warnings will result:
CC [M] drivers/video/console/newport_con.o
In file included from drivers/video/console/newport_con.c:18:
include/linux/selection.h:16: warning: 'struct tty_struct' declared inside param
eter list
include/linux/selection.h:16: warning: its scope is only this definition or decl
aration, which is probably not what you want
include/linux/selection.h:17: warning: 'struct tty_struct' declared inside param
eter list
include/linux/selection.h:20: warning: 'struct tty_struct' declared inside param
eter list
Fixed by adding a forward declaration of struct tty_struct.
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
In file included from drivers/video/console/newport_con.c:16:
include/linux/selection.h:16: warning: "struct tty_struct" declared inside parameter list
include/linux/selection.h:16: warning: its scope is only this definition or declaration, which is probably not what you want
infrastructure for it.
Let it rip!
