[ Upstream commit 34dbbcdbf63360661ff7bda6c5f52f99ac515f92 ]
A lot of seqfile users seem to be using things like %pK that uses the
credentials of the current process, but that is actually completely
wrong for filesystem interfaces.
The unix semantics for permission checking files is to check permissions
at _open_ time, not at read or write time, and that is not just a small
detail: passing off stdin/stdout/stderr to a suid application and making
the actual IO happen in privileged context is a classic exploit
technique.
So if we want to be able to look at permissions at read time, we need to
use the file open credentials, not the current ones. Normal file
accesses can just use "f_cred" (or any of the helper functions that do
that, like file_ns_capable()), but the seqfile interfaces do not have
any such options.
It turns out that seq_file _does_ save away the user_ns information of
the file, though. Since user_ns is just part of the full credential
information, replace that special case with saving off the cred pointer
instead, and suddenly seq_file has all the permission information it
needs.
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
Now that all bitmap formatting usages have been converted to
'%*pb[l]', the separate formatting functions are unnecessary. The
following functions are removed.
* bitmap_scn[list]printf()
* cpumask_scnprintf(), cpulist_scnprintf()
* [__]nodemask_scnprintf(), [__]nodelist_scnprintf()
* seq_bitmap[_list](), seq_cpumask[_list](), seq_nodemask[_list]()
* seq_buf_bitmask()
The return values of seq_printf/puts/putc are frequently misused.
Start down a path to remove all the return value uses of these
functions.
Move the seq_overflow() to a global inlined function called
seq_has_overflowed() that can be used by the users of seq_file() calls.
Update the documentation to not show return types for seq_printf
et al. Add a description of seq_has_overflowed().
Link: http://lkml.kernel.org/p/848ac7e3d1c31cddf638a8526fa3c59fa6fdeb8a.1412031505.git.joe@perches.com
[ Reworked the original patch from Joe ]
There are several users who want to know bytes written by seq_*() for
alignment purpose. Currently they are using %n format for knowing it
because seq_*() returns 0 on success.
This patch introduces seq_setwidth() and seq_pad() for allowing them to
align without using %n format.
Cc: Joe Perches <joe@perches.com>
When we convert the file_lock_list to a set of percpu lists, we'll need
a way to iterate over them in order to output /proc/locks info. Add
some seq_list_*_percpu helpers to handle that.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: J. Bruce Fields <bfields@fieldses.org>
Same as single_open(), but preallocates the buffer of given size.
Doesn't make any sense for sizes up to PAGE_SIZE and doesn't make
sense if output of show() exceeds PAGE_SIZE only rarely - seq_read()
will take care of growing the buffer and redoing show(). If you
_know_ that it will be large, it might make more sense to look into
saner iterator, rather than go with single-shot one. If that's
impossible, single_open_size() might be for you.
Again, don't use that without a good reason; occasionally that's really
the best way to go, but very often there are better solutions.
struct file already has a user namespace associated with it
in file->f_cred->user_ns, unfortunately because struct
seq_file has no struct file backpointer associated with
it, it is difficult to get at the user namespace in seq_file
context. Therefore add a helper function seq_user_ns to return
the associated user namespace and a user_ns field to struct
seq_file to be used in implementing seq_user_ns.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
The existing seq_printf function is rewritten in terms of the new
seq_vprintf which is also exported to modules. This allows GFS2
(and potentially other seq_file users) to have a vprintf based
interface and to avoid an extra copy into a temporary buffer in
some cases.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
Process accounting applications as top, ps visit some files under
/proc/<pid>. With seq_put_decimal_ull(), we can optimize /proc/<pid>/stat
and /proc/<pid>/statm files.
This patch adds
- seq_put_decimal_ll() for signed values.
- allow delimiter == 0.
- convert seq_printf() to seq_put_decimal_ull/ll in /proc/stat, statm.
Test result on a system with 2000+ procs.
Before patch:
[kamezawa@bluextal test]$ top -b -n 1 | wc -l
2223
[kamezawa@bluextal test]$ time top -b -n 1 > /dev/null
real 0m0.675s
user 0m0.044s
sys 0m0.121s
[kamezawa@bluextal test]$ time ps -elf > /dev/null
real 0m0.236s
user 0m0.056s
sys 0m0.176s
After patch:
kamezawa@bluextal ~]$ time top -b -n 1 > /dev/null
real 0m0.657s
user 0m0.052s
sys 0m0.100s
[kamezawa@bluextal ~]$ time ps -elf > /dev/null
real 0m0.198s
user 0m0.050s
sys 0m0.145s
Considering top, ps tend to scan /proc periodically, this will reduce cpu
consumption by top/ps to some extent.
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
== stat_check.py
num = 0
with open("/proc/stat") as f:
while num < 1000 :
data = f.read()
f.seek(0, 0)
num = num + 1
perf shows
20.39% stat_check.py [kernel.kallsyms] [k] format_decode
13.41% stat_check.py [kernel.kallsyms] [k] number
12.61% stat_check.py [kernel.kallsyms] [k] vsnprintf
10.85% stat_check.py [kernel.kallsyms] [k] memcpy
4.85% stat_check.py [kernel.kallsyms] [k] radix_tree_lookup
4.43% stat_check.py [kernel.kallsyms] [k] seq_printf
This patch removes most of calls to vsnprintf() by adding num_to_str()
and seq_print_decimal_ull(), which prints decimal numbers without rich
functions provided by printf().
On my 8cpu box.
== Before patch ==
[root@bluextal test]# time ./stat_check.py
real 0m0.150s
user 0m0.026s
sys 0m0.121s
== After patch ==
real 0m0.055s
user 0m0.022s
sys 0m0.030s
[akpm@linux-foundation.org: remove incorrect comment, use less statck in num_to_str(), move comment from .h to .c, simplify seq_put_decimal_ull()]
[andrea@betterlinux.com: avoid breaking the ABI in /proc/stat]
Signed-off-by: Andrea Righi <andrea@betterlinux.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Paul Turner <pjt@google.com>
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
Standardize the style for compiler based printf format verification.
Standardized the location of __printf too.
Done via script and a little typing.
$ grep -rPl --include=*.[ch] -w "__attribute__" * | \
grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \
xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }'
[akpm@linux-foundation.org: revert arch bits]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Moving the event counter into the dynamically allocated 'struc seq_file'
allows poll() support without the need to allocate its own tracking
structure.
All current users are switched over to use the new counter.
Requested-by: Andrew Morton akpm@linux-foundation.org
Acked-by: NeilBrown <neilb@suse.de>
Tested-by: Lucas De Marchi lucas.demarchi@profusion.mobi
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Many usages of seq_file use RCU protected lists, so non RCU
iterators will not work safely.
Some places in kernel need to iterate over a hlist in seq_file,
so provide some common helpers.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Add two helpers that allow access to the seq_file's own buffer, but
hide the internal details of seq_files.
This allows easier implementation of special purpose filling
functions. It also cleans up some existing functions which duplicated
the seq_file logic.
Make these inline functions in seq_file.h, as suggested by Al.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
seq_write() can be used to construct seq_files containing arbitrary data.
Required by the gcov-profiling interface to synthesize binary profiling
data files.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Li Wei <W.Li@Sun.COM>
Cc: Michael Ellerman <michaele@au1.ibm.com>
Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
1) seq_bitmap_list() should take a const.
2) All the seq_bitmap should use cpumask_bits().
Currently seq_read assumes that the offset passed to it is always the
offset it passed to user space. In the case pread this assumption is
broken and we do the wrong thing when presented with pread.
To solve this I introduce an offset cache inside of struct seq_file so we
know where our logical file position is. Then in seq_read if we try to
read from another offset we reset our data structures and attempt to go to
the offset user space wanted.
[akpm@linux-foundation.org: restore FMODE_PWRITE]
[pjt@google.com: seq_open needs its fmode opened up to take advantage of this]
Signed-off-by: Eric Biederman <ebiederm@xmission.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x]
Impact: cleanup, futureproof
nr_cpu_ids is the (badly named) runtime limit on possible CPU numbers;
ie. the variable version of NR_CPUS.
With the new cpumask operators, only bits less than this are defined.
So we should use it everywhere, rather than NR_CPUS. Eventually this
will make it possible to allocate cpumasks of the minimal length at runtime.
Signed-off-by: Mike Travis <travis@sgi.com>
Impact: cleanup
seq_bitmap just calls bitmap_scnprintf on the bits: that arg can be const.
Similarly, seq_cpumask just calls seq_bitmap.
Impact: expose new VFS API
make mangle_path() available, as per the suggestions of Christoph Hellwig
and Al Viro:
http://lkml.org/lkml/2008/11/4/338
Signed-off-by: Török Edwin <edwintorok@gmail.com>
seq_cpumask_list(), seq_nodemask_list() are very like seq_cpumask(),
seq_nodemask(), but they print human readable string.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Paul Jackson <pj@sgi.com>
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no
good reason.
This became noticed with NR_CPUS=4096 patches, when length of printed
representation of cpumask becase 1152, but cat(1) continued to read with
1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns
1023, check returns -EINVAL.
Fix it by switching to seq_file, so handler will just fill buffer and
doesn't care about offsets, length, filling EOF and all this crap.
For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and
seq_nodemask().
Reviewed-by: Paul Jackson <pj@sgi.com>
Cc: Mike Travis <travis@sgi.com>
Remove the "#ifdef __KERNEL__" tests from unexported header files in
linux/include whose entire contents are wrapped in that preprocessor
test.
Add a new function:
seq_file_root()
This is similar to seq_path(), but calculates the path relative to the
given root, instead of current->fs->root. If the path was unreachable
from root, then modify the root parameter to reflect this.
[mszeredi@suse.cz] split big patch into managable chunks
Add the following functions:
dentry_path()
seq_dentry()
These are similar to d_path() and seq_path(). But instead of
calculating the path within a mount namespace, they calculate the path
from the root of the filesystem to a given dentry, ignoring mounts
completely.
Signed-off-by: Ram Pai <linuxram@us.ibm.com>
Allow ->show() return SEQ_SKIP; that will discard all
output from that element and move on.
Signed-off-by: Denis V. Lunev <den@openvz.org>
This fix broken compilation for 'allnoconfig'. This was introduced by
Introduced by commit 1218854afa6f659be90b748cf1bc7badee954a35 ("[NET]
NETNS: Omit seq_net_private->net without CONFIG_NET_NS.")
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Without CONFIG_NET_NS, no namespace other than &init_net exists,
no need to store net in seq_net_private.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
seq_path() is always called with a dentry and a vfsmount from a struct path.
Make seq_path() take it directly as an argument.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Fix f_version type: should be u64 instead of long
There is a type inconsistency between struct inode i_version and struct file
f_version.
fs.h:
struct inode
u64 i_version;
and
struct file
unsigned long f_version;
Users do:
fs/ext3/dir.c:
if (filp->f_version != inode->i_version) {
So why isn't f_version a u64 ? It becomes a problem if versions gets
higher than 2^32 and we are on an architecture where longs are 32 bits.
This patch changes the f_version type to u64, and updates the users accordingly.
It applies to 2.6.23-rc2-mm2.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Martin Bligh <mbligh@google.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Al Viro <viro@ftp.linux.org.uk>
Cc: <linux-ext4@vger.kernel.org>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
This function allocates the zeroed chunk of memory and
call seq_open(). The __seq_open_private() helper returns
the allocated memory to make it possible for the caller
to initialize it.
Many places in kernel use seq_file API to iterate over a regular list_head.
The code for such iteration is identical in all the places, so it's worth
introducing a common helpers.
This makes code about 300 lines smaller:
The first version of this patch made the helper functions static inline
in the seq_file.h header. This patch moves them to the fs/seq_file.c as
Andrew proposed. The vmlinux .text section sizes are as follows:
2.6.22-rc1-mm1: 0x001794d5
with the previous version: 0x00179505
with this patch: 0x00179135
The config file used was make allnoconfig with the "y" inclusion of all
the possible options to make the files modified by the patch compile plus
drivers I have on the test node.
This patch:
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
- move some file_operations structs into the .rodata section
- move static strings from policy_types[] array into the .rodata section
- fix generic seq_operations usages, so that those structs may be defined
as "const" as well
[akpm@osdl.org: couple of fixes]
Signed-off-by: Helge Deller <deller@gmx.de>
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
infrastructure for it.
Let it rip!
