path: root/include/linux/seq_file.h
2013-11-15seq_file: introduce seq_setwidth() and seq_pad()Tetsuo Handa
There are several users who want to know bytes written by seq_*() for alignment purpose. Currently they are using %n format for knowing it because seq_*() returns 0 on success. This patch introduces seq_setwidth() and seq_pad() for allowing them to align without using %n format. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-08seq_file: add seq_list_*_percpu helpersJeff Layton
When we convert the file_lock_list to a set of percpu lists, we'll need a way to iterate over them in order to output /proc/locks info. Add some seq_list_*_percpu helpers to handle that. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09new helper: single_open_size()Al Viro
Same as single_open(), but preallocates the buffer of given size. Doesn't make any sense for sizes up to PAGE_SIZE and doesn't make sense if output of show() exceeds PAGE_SIZE only rarely - seq_read() will take care of growing the buffer and redoing show(). If you _know_ that it will be large, it might make more sense to look into saner iterator, rather than go with single-shot one. If that's impossible, single_open_size() might be for you. Again, don't use that without a good reason; occasionally that's really the best way to go, but very often there are better solutions. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-14userns: Make seq_file's user namespace accessibleEric W. Biederman
struct file already has a user namespace associated with it in file->f_cred->user_ns, unfortunately because struct seq_file has no struct file backpointer associated with it, it is difficult to get at the user namespace in seq_file context. Therefore add a helper function seq_user_ns to return the associated user namespace and a user_ns field to struct seq_file to be used in implementing seq_user_ns. Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-06-11seq_file: Add seq_vprintf function and export itSteven Whitehouse
The existing seq_printf function is rewritten in terms of the new seq_vprintf which is also exported to modules. This allows GFS2 (and potentially other seq_file users) to have a vprintf based interface and to avoid an extra copy into a temporary buffer in some cases. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
2012-03-24Merge tag 'bug-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/bug.h> cleanup from Paul Gortmaker: "The changes shown here are to unify linux's BUG support under the one <linux/bug.h> file. Due to historical reasons, we have some BUG code in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in linux/kernel.h predates the addition of linux/bug.h, but old code in kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h was including <asm/bug.h> to pseudo link them. This has caused confusion[1] and general yuck/WTF[2] reactions. Here is an example that violates the principle of least surprise: CC lib/string.o lib/string.c: In function 'strlcat': lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON' make[2]: *** [lib/string.o] Error 1 $ $ grep linux/bug.h lib/string.c #include <linux/bug.h> $ We've included <linux/bug.h> for the BUG infrastructure and yet we still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh - very confusing for someone who is new to kernel development. With the above in mind, the goals of this changeset are: 1) find and fix any include/*.h files that were relying on the implicit presence of BUG code. 2) find and fix any C files that were consuming kernel.h and hence relying on implicitly getting some/all BUG code. 3) Move the BUG related code living in kernel.h to <linux/bug.h> 4) remove the asm/bug.h from kernel.h to finally break the chain. During development, the order was more like 3-4, build-test, 1-2. But to ensure that git history for bisect doesn't get needless build failures introduced, the commits have been reorderd to fix the problem areas in advance. [1] https://lkml.org/lkml/2012/1/3/90 [2] https://lkml.org/lkml/2012/1/17/414" Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul and linux-next. * tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: kernel.h: doesn't explicitly use bug.h, so don't include it. bug: consolidate BUILD_BUG_ON with other bug code BUG: headers with BUG/BUG_ON etc. need linux/bug.h bug.h: add include of it to various implicit C users lib: fix implicit users of kernel.h for TAINT_WARN spinlock: macroize assert_spin_locked to avoid bug.h dependency x86: relocate get/set debugreg fcns to include/asm/debugreg.
2012-03-23procfs: speed up /proc/pid/stat, statmKAMEZAWA Hiroyuki
Process accounting applications as top, ps visit some files under /proc/<pid>. With seq_put_decimal_ull(), we can optimize /proc/<pid>/stat and /proc/<pid>/statm files. This patch adds - seq_put_decimal_ll() for signed values. - allow delimiter == 0. - convert seq_printf() to seq_put_decimal_ull/ll in /proc/stat, statm. Test result on a system with 2000+ procs. Before patch: [kamezawa@bluextal test]$ top -b -n 1 | wc -l 2223 [kamezawa@bluextal test]$ time top -b -n 1 > /dev/null real 0m0.675s user 0m0.044s sys 0m0.121s [kamezawa@bluextal test]$ time ps -elf > /dev/null real 0m0.236s user 0m0.056s sys 0m0.176s After patch: kamezawa@bluextal ~]$ time top -b -n 1 > /dev/null real 0m0.657s user 0m0.052s sys 0m0.100s [kamezawa@bluextal ~]$ time ps -elf > /dev/null real 0m0.198s user 0m0.050s sys 0m0.145s Considering top, ps tend to scan /proc periodically, this will reduce cpu consumption by top/ps to some extent. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23procfs: add num_to_str() to speed up /proc/statKAMEZAWA Hiroyuki
== stat_check.py num = 0 with open("/proc/stat") as f: while num < 1000 : data = f.read() f.seek(0, 0) num = num + 1 == perf shows 20.39% stat_check.py [kernel.kallsyms] [k] format_decode 13.41% stat_check.py [kernel.kallsyms] [k] number 12.61% stat_check.py [kernel.kallsyms] [k] vsnprintf 10.85% stat_check.py [kernel.kallsyms] [k] memcpy 4.85% stat_check.py [kernel.kallsyms] [k] radix_tree_lookup 4.43% stat_check.py [kernel.kallsyms] [k] seq_printf This patch removes most of calls to vsnprintf() by adding num_to_str() and seq_print_decimal_ull(), which prints decimal numbers without rich functions provided by printf(). On my 8cpu box. == Before patch == [root@bluextal test]# time ./stat_check.py real 0m0.150s user 0m0.026s sys 0m0.121s == After patch == [root@bluextal test]# time ./stat_check.py real 0m0.055s user 0m0.022s sys 0m0.030s [akpm@linux-foundation.org: remove incorrect comment, use less statck in num_to_str(), move comment from .h to .c, simplify seq_put_decimal_ull()] [andrea@betterlinux.com: avoid breaking the ABI in /proc/stat] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrea Righi <andrea@betterlinux.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Turner <pjt@google.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-03constify seq_file stuffAl Viro
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20fs: seq_file - add event counter to simplify poll() supportKay Sievers
Moving the event counter into the dynamically allocated 'struc seq_file' allows poll() support without the need to allocate its own tracking structure. All current users are switched over to use the new counter. Requested-by: Andrew Morton akpm@linux-foundation.org Acked-by: NeilBrown <neilb@suse.de> Tested-by: Lucas De Marchi lucas.demarchi@profusion.mobi Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-22seq_file: add RCU versions of new hlist/list iterators (v3)stephen hemminger
Many usages of seq_file use RCU protected lists, so non RCU iterators will not work safely. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-10seq_file: Add helpers for iteration over a hlistLi Zefan
Some places in kernel need to iterate over a hlist in seq_file, so provide some common helpers. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24vfs: seq_file: add helpers for data fillingMiklos Szeredi
Add two helpers that allow access to the seq_file's own buffer, but hide the internal details of seq_files. This allows easier implementation of special purpose filling functions. It also cleans up some existing functions which duplicated the seq_file logic. Make these inline functions in seq_file.h, as suggested by Al. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-18seq_file: add function to write binary dataPeter Oberparleiter
seq_write() can be used to construct seq_files containing arbitrary data. Required by the gcov-profiling interface to synthesize binary profiling data files. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Li Wei <W.Li@Sun.COM> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com> Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30cpumask: fix seq_bitmap_*() functions.Rusty Russell
1) seq_bitmap_list() should take a const. 2) All the seq_bitmap should use cpumask_bits(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-02-18seq_file: properly cope with preadEric Biederman
Currently seq_read assumes that the offset passed to it is always the offset it passed to user space. In the case pread this assumption is broken and we do the wrong thing when presented with pread. To solve this I introduce an offset cache inside of struct seq_file so we know where our logical file position is. Then in seq_read if we try to read from another offset we reset our data structures and attempt to go to the offset user space wanted. [akpm@linux-foundation.org: restore FMODE_PWRITE] [pjt@google.com: seq_open needs its fmode opened up to take advantage of this] Signed-off-by: Eric Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Paul Turner <pjt@google.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-30cpumask: Use nr_cpu_ids in seq_cpumaskRusty Russell
Impact: cleanup, futureproof nr_cpu_ids is the (badly named) runtime limit on possible CPU numbers; ie. the variable version of NR_CPUS. With the new cpumask operators, only bits less than this are defined. So we should use it everywhere, rather than NR_CPUS. Eventually this will make it possible to allocate cpumasks of the minimal length at runtime. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-12-30bitmap: fix seq_bitmap and seq_cpumask to take const pointerRusty Russell
Impact: cleanup seq_bitmap just calls bitmap_scnprintf on the bits: that arg can be const. Similarly, seq_cpumask just calls seq_bitmap. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-11-23vfs, seqfile: make mangle_path() globalTörök Edwin
Impact: expose new VFS API make mangle_path() available, as per the suggestions of Christoph Hellwig and Al Viro: http://lkml.org/lkml/2008/11/4/338 Signed-off-by: Török Edwin <edwintorok@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20seq_file: add seq_cpumask_list(), seq_nodemask_list()Lai Jiangshan
seq_cpumask_list(), seq_nodemask_list() are very like seq_cpumask(), seq_nodemask(), but they print human readable string. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12seq_file: add seq_cpumask(), seq_nodemask()Alexey Dobriyan
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no good reason. This became noticed with NR_CPUS=4096 patches, when length of printed representation of cpumask becase 1152, but cat(1) continued to read with 1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns 1023, check returns -EINVAL. Fix it by switching to seq_file, so handler will just fill buffer and doesn't care about offsets, length, filling EOF and all this crap. For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and seq_nodemask(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Cc: Mike Travis <travis@sgi.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-23[patch 2/7] vfs: mountinfo: add seq_file_root()Miklos Szeredi
Add a new function: seq_file_root() This is similar to seq_path(), but calculates the path relative to the given root, instead of current->fs->root. If the path was unreachable from root, then modify the root parameter to reflect this. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 1/7] vfs: mountinfo: add dentry_path()Ram Pai
[mszeredi@suse.cz] split big patch into managable chunks Add the following functions: dentry_path() seq_dentry() These are similar to d_path() and seq_path(). But instead of calculating the path within a mount namespace, they calculate the path from the root of the filesystem to a given dentry, ignoring mounts completely. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-21[PATCH] teach seq_file to discard entriesAl Viro
Allow ->show() return SEQ_SKIP; that will discard all output from that element and move on. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-02[NETNS]: Do not include net/net_namespace.h from seq_file.hDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27[NETNS]: Compile NET /proc support only if CONFIG_NET is set.Denis V. Lunev
This fix broken compilation for 'allnoconfig'. This was introduced by Introduced by commit 1218854afa6f659be90b748cf1bc7badee954a35 ("[NET] NETNS: Omit seq_net_private->net without CONFIG_NET_NS.") Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit seq_net_private->net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, no namespace other than &init_net exists, no need to store net in seq_net_private. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-14d_path: Make seq_path() use a struct path argumentJan Blunck
seq_path() is always called with a dentry and a vfsmount from a struct path. Make seq_path() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[NET]: Consolidate net namespace related proc files creation.Denis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17Fix f_version type: should be u64 instead of unsigned longMathieu Desnoyers
Fix f_version type: should be u64 instead of long There is a type inconsistency between struct inode i_version and struct file f_version. fs.h: struct inode u64 i_version; and struct file unsigned long f_version; Users do: fs/ext3/dir.c: if (filp->f_version != inode->i_version) { So why isn't f_version a u64 ? It becomes a problem if versions gets higher than 2^32 and we are on an architecture where longs are 32 bits. This patch changes the f_version type to u64, and updates the users accordingly. It applies to 2.6.23-rc2-mm2. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Martin Bligh <mbligh@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: <linux-ext4@vger.kernel.org> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[FS] seq_file: Introduce the seq_open_private()Pavel Emelyanov
This function allocates the zeroed chunk of memory and call seq_open(). The __seq_open_private() helper returns the allocated memory to make it possible for the caller to initialize it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10Make common helpers for seq_files that work with list_headsPavel Emelianov
Many places in kernel use seq_file API to iterate over a regular list_head. The code for such iteration is identical in all the places, so it's worth introducing a common helpers. This makes code about 300 lines smaller: The first version of this patch made the helper functions static inline in the seq_file.h header. This patch moves them to the fs/seq_file.c as Andrew proposed. The vmlinux .text section sizes are as follows: 2.6.22-rc1-mm1: 0x001794d5 with the previous version: 0x00179505 with this patch: 0x00179135 The config file used was make allnoconfig with the "y" inclusion of all the possible options to make the files modified by the patch compile plus drivers I have on the test node. This patch: Many places in kernel use seq_file API to iterate over a regular list_head. The code for such iteration is identical in all the places, so it's worth introducing a common helpers. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: fs/seq_file.cIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
