path: root/include/linux/serial_8250.h
2013-01-15serial: 8250: Add support for dmaengineHeikki Krogerus
Add support for dmaengine API. The drivers can implement the struct uart_8250_dma member in struct uart_8250_port and 8250.c can take care of the rest. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-16tty/8250_early: Turn serial_in/serial_out into weak symbols.Noam Camus
Allows overriding default methods serial_in/serial_out. In such platform specific replacement it is possible to use other regshift, biased register offset, any other manipulation that is not covered with common default methods. Overriding default methods may be useful for platforms which got serial peripheral with registers represented in big endian. In this situation and assuming that 32 bit operations / alignment is required then it may be useful to swab words before/after accessing the serial registers. Signed-off-by: Noam Camus <noamc@ezchip.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-178250: three way resolve of the 8250 diffsAlan Cox
This resolves the differences between the original 8250 patch, the revised 8250 patch and the independant clean up of the octeon driver (to use platform devices properly yay!) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-128250: use the 8250 register interface not the legacy oneAlan Cox
The old interface just copies bits over and calls the newer one. In addition we can now pass more information. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-23Merge branch 'delete-mca' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull the MCA deletion branch from Paul Gortmaker: "It was good that we could support MCA machines back in the day, but realistically, nobody is using them anymore. They were mostly limited to 386-sx 16MHz CPU and some 486 class machines and never more than 64MB of RAM. Even the enthusiast hobbyist community seems to have dried up close to ten years ago, based on what you can find searching various websites dedicated to the relatively short lived hardware. So lets remove the support relating to CONFIG_MCA. There is no point carrying this forward, wasting cycles doing routine maintenance on it; wasting allyesconfig build time on validating it, wasting I/O on git grep'ping over it, and so on." Let's see if anybody screams. It generally has compiled, and James Bottomley pointed out that there was a MCA extension from NCR that allowed for up to 4GB of memory and PPro-class machines. So in *theory* there may be users out there. But even James (technically listed as a maintainer) doesn't actually have a system, and while Alan Cox claims to have a machine in his cellar that he offered to anybody who wants to take it off his hands, he didn't argue for keeping MCA support either. So we could bring it back. But somebody had better speak up and talk about how they have actually been using said MCA hardware with modern kernels for us to do that. And David already took the patch to delete all the networking driver code (commit a5e371f61ad3: "drivers/net: delete all code/drivers depending on CONFIG_MCA"). * 'delete-mca' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: MCA: delete all remaining traces of microchannel bus support. scsi: delete the MCA specific drivers and driver code serial: delete the MCA specific 8250 support. arm: remove ability to select CONFIG_MCA
2012-05-17serial: delete the MCA specific 8250 support.Paul Gortmaker
The support for CONFIG_MCA is being removed, since the 20 year old hardware simply isn't capable of meeting today's software demands on CPU and memory resources. This commit removes the MCA specific 8250 UART code. Cc: Alan Cox <alan@linux.intel.com> Cc: linux-serial@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-02serial8250: Introduce serial8250_register_8250_port()Magnus Damm
Introduce yet another 8250 registration function. This time it is serial8250_register_8250_port() and it allows us to register 8250 hardware instances using struct uart_8250_port. The new function makes it possible to register 8250 hardware that makes use of 8250 specific callbacks such as ->dl_read() and ->dl_write(). Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18tegra, serial8250: add ->handle_break() uart_port opDan Williams
The "KT" serial port has another use case for a "received break" quirk, so before adding another special case to the 8250 core take this opportunity to push such quirks out of the core and into a uart_port op. Stephen says: "If the callback function is to no longer live in 8250.c itself, arch/arm/mach-tegra/devices.c isn't logically a good place to put it, and that file will be going away once we get rid of all the board files and move solely to device tree." ...so since 8250_pci.c houses all the quirks for pci serial devices this quirk is similarly housed in of_serial.c. Once the open firmware conversion completes the infrastructure details (include/linux/of_serial.h, and the export) can all be removed to make this self contained to of_serial.c. Cc: Nhan H Mai <nhan.h.mai@intel.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> [stephen: kill CONFIG_SERIAL_TEGRA in favor just using CONFIG_ARCH_TEGRA] Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sudhakar Mamillapalli <sudhakar@fb.com> Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-12-09serial: add irq handler for Freescale 16550 errata.Paul Gortmaker
Sending a break on the SOC UARTs found in some MPC83xx/85xx/86xx chips seems to cause a short lived IRQ storm (/proc/interrupts typically shows somewhere between 300 and 1500 events). Unfortunately this renders SysRQ over the serial console completely inoperable. The suggested workaround in the errata is to read the Rx register, wait one character period, and then read the Rx register again. We achieve this by tracking the old LSR value, and on the subsequent interrupt event after a break, we don't read LSR, instead we just read the RBR again and return immediately. The "fsl,ns16550" is used in the compatible field of the serial device to mark UARTs known to have this issue. Thanks to Scott Wood for providing the errata data which led to a much cleaner fix. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09serial: export the key functions for an 8250 IRQ handlerPaul Gortmaker
For drivers that need to construct their own IRQ handler, the three components are seen in the current handle_port -- i.e. Rx, Tx and modem_status. Make these exported symbols so that "almost" 8250 UARTs can construct their own IRQ handler with these shared components, while working around their own unique errata issues. The function names are given a serial8250 prefix, since they are now entering the global namespace. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-24Revert "tty: serial8250: add helpers for the DesignWare 8250"Greg Kroah-Hartman
This reverts commit 6b1a98d1c4851235d9b6764b3f7b7db7909fc760. It causes a build error that needs to be resolved differently. Cc: Alan Cox <alan@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23tty: serial8250: add helpers for the DesignWare 8250Jamie Iles
The Synopsys DesignWare 8250 is an 8250 that has an extra interrupt that gets raised when writing to the LCR when busy. To handle this we need special serial_out, serial_in and handle_irq methods. Add a new function serial8250_use_designware_io() that configures a uart_port with these accessors. Cc: Alan Cox <alan@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23tty: serial8250: allow platforms to override irq handlerJamie Iles
Some ports (e.g. Synopsys DesignWare 8250) have special requirements for handling the interrupts. Allow these platforms to specify their own interrupt handler that will override the default. serial8250_handle_irq() is provided so that platforms can extend the IRQ handler rather than completely replacing it. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22serial: abstraction for 8250 legacy portsAlan Cox
Not every platform that has generic legacy 8250 ports manages to have them clocked the right way or without errata. Provide a generic interface to allow platforms to override the default behaviour in a manner that dumps the complexity in *their* code not the 8250 driver. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-228250: allow platforms to override PM hook.Manuel Lauss
Add a hook for platforms to specify custom pm methods. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10U6715 16550A serial driver supportPhilippe Langlais
UART Features extract from STEricsson U6715 data-sheet (arm926 SoC for mobile phone): * Fully compatible with industry standard 16C550 and 16C450 from various manufacturers * RX and TX 64 byte FIFO reduces CPU interrupts * Full double buffering * Modem control signals include CTS, RTS, (and DSR, DTR on UART1 only) * Automatic baud rate selection * Manual or automatic RTS/CTS smart hardware flow control * Programmable serial characteristics: – Baud rate generation (50 to 3.25M baud) – 5, 6, 7 or 8-bit characters – Even, odd or no-parity bit generation and detection – 1, 1.5 or 2 stop bit generation * Independent control of transmit, receive, line status, data set interrupts and FIFOs * Full status-reporting capabilities * Separate DMA signaling for RX and TX * Timed interrupt to spread receive interrupt on known duration * DMA time-out interrupt to allow detection of end of reception * Carkit pulse coding and decoding compliant with USB carkit control interface [40] In 16550A auto-configuration, if the fifo size is 64 then it's an U6 16550A port Add set_termios hook & export serial8250_do_set_termios to change uart clock following baudrate Signed-off-by: Philippe Langlais <philippe.langlais@stericsson.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-19serial: 8250: add IRQ trigger supportVikram Pandita
There is currently no provision for passing IRQ trigger flags for serial IRQs with triggering requirements (such as GPIO IRQs) This patch adds irqflags to plat_serial8250_port that can be passed from board file to reqest_irq() of 8250 driver Changes are backward compatible with boards passing UPF_SHARE_IRQ flag Tested on Zoom2 board that has IRQF_TRIGGER_RISING requirement for 8250 irq [Moved new flag to end to fix bugs in the original with the old_serial array -- Alan] Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-02Serial: Allow port type to be specified when calling serial8250_register_port.David Daney
Add flag value UPF_FIXED_TYPE which specifies that the UART type is known and should not be probed. For this case the UARTs properties are just copied out of the uart_config entry. This allows us to keep SOC specific 8250 probe code out of 8250.c. In this case we know the serial hardware will not be changing as it is on the same silicon as the CPU, and we can specify it with certainty in the board/cpu setup code. The alternative is to load up 8250.c with a bunch of OCTEON specific special cases in the probing code. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-028250: Serial driver changes to support future Cavium OCTEON serial patches.David Daney
In order to use Cavium OCTEON specific serial i/o drivers, we first patch the 8250 driver to use replaceable I/O functions. Compatible I/O functions are added for existing iotypeS. An added benefit of this change is that it makes it easy to factor some of the existing special cases out to board/SOC specific support code. The alternative is to load up 8250.c with a bunch of OCTEON specific iotype code and bug work-arounds. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28sm501: add uart supportMagnus Damm
This patch extends the sm501 mfd with 8250 uart support. We're currently doing this in the board specific r2d-1 code already, but it would be nice to do move things into the mfd since it's more chip specific than board specific. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-058250.c: support specifying DW APB UARTs in device platform_dataWill Newton
Allow the private_data field to be specified in platform_data for the standard 8250/16550 UART. This field is used by DW APB type UARTs and without this patch it's only possible to set this field when registering the port by hand. If private_data is not set then the driver will potentially oops with a NULL pointer dereference. Signed-off-by: Will Newton <will.newton@gmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24Use resource_size_t for serial port IO addressesJosh Boyer
At present, various parts of the serial code use unsigned long to define resource addresses. This is a problem, because some 32-bit platforms have physical addresses larger than 32-bits, and have mmio serial uarts located above the 4GB point. This patch changes the type of mapbase in both struct uart_port and struct plat_serial8250_port to resource_size_t, which can be configured to be 64 bits on such platforms. The mapbase in serial_struct can't safely be changed, because that structure is user visible. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16serial: convert early_uart to earlycon for 8250Yinghai Lu
Beacuse SERIAL_PORT_DFNS is removed from include/asm-i386/serial.h and include/asm-x86_64/serial.h. the serial8250_ports need to be probed late in serial initializing stage. the console_init=>serial8250_console_init=> register_console=>serial8250_console_setup will return -ENDEV, and console ttyS0 can not be enabled at that time. need to wait till uart_add_one_port in drivers/serial/serial_core.c to call register_console to get console ttyS0. that is too late. Make early_uart to use early_param, so uart console can be used earlier. Make it to be bootconsole with CON_BOOT flag, so can use console handover feature. and it will switch to corresponding normal serial console automatically. new command line will be: console=uart8250,io,0x3f8,9600n8 console=uart8250,mmio,0xff5e0000,115200n8 or earlycon=uart8250,io,0x3f8,9600n8 earlycon=uart8250,mmio,0xff5e0000,115200n8 it will print in very early stage: Early serial console at I/O port 0x3f8 (options '9600n8') console [uart0] enabled later for console it will print: console handover: boot [uart0] -> real [ttyS0] Signed-off-by: <yinghai.lu@sun.com> Cc: Andi Kleen <ak@suse.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Exar quad port serialPaul B Schroeder
This is on our "Envoy" boxes which we have, according to the documentation, an "Exar ST16C554/554D Quad UART with 16-byte Fifo's". The box also has two other "on-board" serial ports and a modem chip. The two on-board serial UARTs were being detected along with the first two Exar UARTs. The last two Exar UARTs were not showing up and neither was the modem. This patch was the only way I could the kernel to see beyond the standard four serial ports and get all four of the Exar UARTs to show up. [akpm@osdl.org: build fix] Signed-off-by: Paul B Schroeder <pschroeder@uplogix.com> Cc: Lennart Sorensen <lsorense@csclub.uwaterloo.ca> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[ARM] 3383/3: ixp2000: ixdp2x01 platform serial conversionLennert Buytenhek
Patch from Lennert Buytenhek Add a PLAT8250_DEV_PLATFORM2, and convert the two ixdp2x01 CPLD serial ports to use platform serial devices with ids PLAT8250_DEV_PLATFORM[12]. (The on-chip xscale UART is PLAT8250_DEV_PLATFORM, id #0.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-21[SERIAL] Make uart_port flags a bitwise typeRussell King
Same reasoning as commit 747c8a55946ed037bf7d62454c3c599c02af2262 but this time we're making uart_port flags a bitwise type - not all of these flags correspond with the old ASYNC_ flags, so there is the possibility for bugs if the wrong ASYNC_* constants are used. Always use UPF_* constants for uart_port->flags. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-06[SERIAL] Support Au1x00 8250 UARTs using the generic 8250 driver.Pantelis Antoniou
The offsets of the registers are in a different place, and some parts cannot handle a full set of modem control signals. Signed-off-by: Pantelis Antoniou <pantelis@embeddedalley.ocm> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-01[SERIAL] Move serial8250_*_port prototypes to linux/serial_8250.hRussell King
2005-06-27[PATCH] Serial: Split 8250 port tableRussell King
Add separate files for the different 8250 ISA-based serial boards. Looking across all the various architectures, it seems reasonable that we can key the availability of the configuration options for these beasts to the bus-related symbols (iow, CONFIG_ISA). We also standardise the base baud/uart clock rate for these boards - I'm sure that isn't architecture specific, but is solely dependent on the crystal fitted on the board (which should be the same no matter what type of machine its fitted into.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
