path: root/include/linux/serial_sci.h
2011-12-02serial: sh-sci: Handle GPIO function requests.Paul Mundt
This adds initial support for requesting the various GPIO functions necessary for certain ports. This just plugs in dumb request/free logic, but serves as a building block for migrating off of the ->init_pins mess to a wholly gpiolib backed solution (primarily parts with external RTS/CTS pins, but will also allow us to clean up RXD pin testing). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-12-02serial: sh-sci: per-port modem control.Paul Mundt
The bulk of the ports do not support any sort of modem control, so blindly twiddling the MCE bit doesn't accomplish much. We now require ports to manually specify which line supports modem control signals. While at it, tidy up the RTS/CTSIO handling in SCSPTR parts so it's a bit more obvious what's going on (and without clobbering other configurations in the process). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-11-11Merge branches 'sh/pm-runtime' and 'common/clkfwk' into sh-fixes-for-linusPaul Mundt
2011-11-04serial: sh-sci: Fix up SH-2A SCIF support.Phil Edworthy
This fixes up support for SH-2(A) SCIFs by introducing a new regtype. As expected, it's close to the SH-4A SCIF with fifodata, but still different enough to warrant its own type. Fixes up a number of FIFO overflows and similar for both SH7203/SH7264. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Tested-by: Federico Fuga <fuga@studiofuga.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-09-19serial: sh-sci: don't filter on DMA device, use only channel IDGuennadi Liakhovetski
On some sh-mobile systems there are more than one DMA controllers, that can be used for serial ports. Specifying a DMA device in sh-sci platform data unnecessarily restricts the driver to only use one DMA controller. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> [Fixed the trivial conflict in include/linux/serial_sci.h] Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-06-28serial: sh-sci: Fix up pretty name printing for port IRQs.Paul Mundt
Presently these were all using the same static string with no regard to dev_name() and the like. This implements a bit of rework to name the IRQ dynamically, as it should have been doing all along anyways. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14serial: sh-sci: Abstract register maps.Paul Mundt
This takes a bit of a sledgehammer to the horribly CPU subtype ifdef-ridden header and abstracts all of the different register layouts in to distinct types which in turn can be overriden on a per-port basis, or permitted to default to the map matching the port type at probe time. In the process this ultimately fixes up inumerable bugs with mismatches on various CPU types (particularly the legacy ones that were obviously broken years ago and no one noticed) and provides a more tightly coupled and consolidated platform for extending and implementing generic features. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-08serial: sh-sci: Consolidate RXD pin handling.Paul Mundt
Non-SCI parts do not have the special port reg necessary for cases where the RX and SCI pins are muxed and need to be manually polled, so these like always fall back on the normal FIFO processing paths. SH7760 is in a class in and of itself with regards to mapping its SIM card interface via the SCI port class despite not having any of the RXD lines wired up and so implicitly behaving more like a SCIF in this regard. Out of the other CPUs, some support the port check via the same block while others do it through an external SuperI/O, so it's not even possible to perform the check relative to the ioremapped cookie offset, so the separate read semantics are preserved here, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-08serial: sh-sci: Generalize overrun handling.Paul Mundt
This consolidates all of the broken out overrun handling and ensures that we have sensible defaults per-port type, in addition to making sure that overruns are flagged appropriately in the error mask for parts that haven't explicitly disabled support for it. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Kill off some DMA ifdeffery.Paul Mundt
There's nothing worth hiding under the ifdef in the platform DMA definitions, and we certainly don't want board code adding this in to their platform data definitions, so we always expose the slave rx/tx and device pointer members instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Provide a helper for muxed IRQs.Paul Mundt
All of the muxed IRQs presently populate the IRQ array verbosely, this simply provides a trivial helper to do it for them. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Kill off unused membase kludge.Paul Mundt
All users of the platform port data specify a mapbase where the driver later derives the membase from. Now that UPF flags are taken in to account for generic ioremapping we can kill off the port-specific membase clobbering and simply use the generic paths. This derives from a time when sh64 was not capable of using the generic ioremap implementation and had employed early bolted DTLB mappings for port access, which is no longer an issue. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-19serial: sh-sci: Kill off unused clock string.Paul Mundt
Now that the clock string isn't used by the driver anymore, kill it off from the platform structure. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-13Merge branch 'master' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into common/serial-rework Conflicts: arch/sh/kernel/cpu/sh2/setup-sh7619.c arch/sh/kernel/cpu/sh2a/setup-mxg.c arch/sh/kernel/cpu/sh2a/setup-sh7201.c arch/sh/kernel/cpu/sh2a/setup-sh7203.c arch/sh/kernel/cpu/sh2a/setup-sh7206.c arch/sh/kernel/cpu/sh3/setup-sh7705.c arch/sh/kernel/cpu/sh3/setup-sh770x.c arch/sh/kernel/cpu/sh3/setup-sh7710.c arch/sh/kernel/cpu/sh3/setup-sh7720.c arch/sh/kernel/cpu/sh4/setup-sh4-202.c arch/sh/kernel/cpu/sh4/setup-sh7750.c arch/sh/kernel/cpu/sh4/setup-sh7760.c arch/sh/kernel/cpu/sh4a/setup-sh7343.c arch/sh/kernel/cpu/sh4a/setup-sh7366.c arch/sh/kernel/cpu/sh4a/setup-sh7722.c arch/sh/kernel/cpu/sh4a/setup-sh7723.c arch/sh/kernel/cpu/sh4a/setup-sh7724.c arch/sh/kernel/cpu/sh4a/setup-sh7763.c arch/sh/kernel/cpu/sh4a/setup-sh7770.c arch/sh/kernel/cpu/sh4a/setup-sh7780.c arch/sh/kernel/cpu/sh4a/setup-sh7785.c arch/sh/kernel/cpu/sh4a/setup-sh7786.c arch/sh/kernel/cpu/sh4a/setup-shx3.c arch/sh/kernel/cpu/sh5/setup-sh5.c drivers/serial/sh-sci.c drivers/serial/sh-sci.h include/linux/serial_sci.h
2010-05-25serial: sh-sci: fix up serial DMA build.Paul Mundt
asm/dmaengine.h no longer exists, update for the shared linux/sh_dma.h header. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-23dmaengine: shdma: Remove sh_dmae_slave_chan_id enumMagnus Damm
This patch replaces the sh_dmae_slave_chan_id enum with an unsigned int. The purpose of this chainge is to make it possible to separate the slave id enums from the dmaengine header. The slave id enums varies with processor model, so in the future it makes sense to put these in the processor specific headers together with the pinmux enums. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-10serial: sh-sci: Fix build failure for non-sh architectures.Peter Huewe
This patch fixes a build failure for various arm based defconfigs [1][2][3] and maybe other architectures/configs. The build failure was introduced by the sh specific patch [4] "serial: sh-sci: Add DMA support" by Guennadi Liakhovetski Patch against linux-next of 20100309 References: [1] http://kisskb.ellerman.id.au/kisskb/buildresult/2248992/ [2] http://kisskb.ellerman.id.au/kisskb/buildresult/2248996/ [3] http://kisskb.ellerman.id.au/kisskb/buildresult/2248998/ [4] http://git.kernel.org/?p=linux/kernel/git/sfr/linux-next.git;a=commit;h=73a19e4c0301908ce6346715fd08a74308451f5a Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-03-02serial: sh-sci: Add DMA support.Guennadi Liakhovetski
Support using DMA for sending and receiving data over SCI(F) interfaces of various SH SoCs. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-24serial: sh-sci: Move SCBRR calculation algo in to platform data.Paul Mundt
This permits each port to select its own SCBRR calculation algorithm, rather than having it all ifdef'ed in the header. There are presently only 5 different variations that all parts fall under. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-24serial: sh-sci: Move SCSCR_INIT in to platform data.Paul Mundt
This moves all of the SCSCR_INIT definitions in to the platform data, for future consolidation. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh-sci: improve clock framework supportMagnus Damm
Use enable/disable hooks for clock framework integration. Make sure we control the clock for the serial console as well. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh-sci: remove early_sci_setup()Magnus Damm
Remove unused early_sci_setup() function from sh-sci. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-02-26serial: Move asm-sh/sci.h to linux/serial_sci.h.Paul Mundt
This header is needed on other architectures as well (namely h8300), which currently fails to build without this in place. Rather than duplicating the port definition completely there, just move this to a common location instead. This should get h8300 working again for 2.6.25, in addition to the changes already pushed by Sato-san in -rc2. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
