The callback in otg driver is not a standard way of controlling
USB VBUS. Remove the callback and use regulator to control.
Bug 997805
Change-Id: I6d7fd01f9346e037515901ac6fe6d349a140d13e
Signed-off-by: Chander Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/112896
GVS: Gerrit_Virtual_Submit
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Update correct status to fuel-gauge driver
when charger cable is disconnected.
Bug 960318
Change-Id: I4c3ad2030ada7c06825e80a3eb4697b669fe7cb6
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/98719
bug 949219
Change-Id: I5942ba86bd1cbe1f1bd06a7c9f51a10d83e6cabb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92819
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Addition of reglator interface to detect the usb cable
plug/unplug detection.
Bug 961166
Bug 966874
Change-Id: Ida297bc39df9aca8cffe60c29bc24f2d32819f56
Signed-off-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/96440
Allows OTG enable/disable only while USB OTG state
swithes between SUSPEND and HOST
Bug 937188
Change-Id: If651dfb19db37f8822e6d1473aa573246aca8d45
Reviewed-on: http://git-master/r/89111
Add update_charger_status() function callback to fix unknown
charging status at start up issue.
Bug 951750
Change-Id: Ib264479b0a251a07d136c245afa85c3444754ee0
Reviewed-on: http://git-master/r/89436
Addition of OTG support in smb349 charger driver
Change-Id: Ib38c9f4c06285ae07d93cfa3c6f5e1637aaa9460
Reviewed-on: http://git-master/r/86936
-Addition of interrupt support to update charger
properties to fuel-gauge driver.
Change-Id: If6384921247b6534f2d8142ad5fd079c5f6e0890
Reviewed-on: http://git-master/r/83507
Smb349 battery charger driver for kai platform.
Reviewed-on: http://git-master/r/78211
(cherry picked from commit f059c9db2735a6e0088dd9cd61a623b13b5d717e)
Change-Id: Ifa401713928d29bb4235353e50b66e632c7625ba
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/79980
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
