Introduce a new socket ioctl, SIOCKILLADDR, that nukes all sockets
bound to the same local address. This is useful in situations with
dynamic IPs, to kill stuck connections.
Signed-off-by: Brian Swetland <swetland@google.com>
net: fix tcp_v4_nuke_addr
Signed-off-by: Dima Zavin <dima@android.com>
net: ipv4: Fix a spinlock recursion bug in tcp_v4_nuke.
We can't hold the lock while calling to tcp_done(), so we drop
it before calling. We then have to start at the top of the chain again.
net: ipv4: Fix race in tcp_v4_nuke_addr().
To fix a recursive deadlock in 2.6.29, we stopped holding the hash table lock
across tcp_done() calls. This fixed the deadlock, but introduced a race where
the socket could die or change state.
Fix: Before unlocking the hash table, we grab a reference to the socket. We
can then unlock the hash table without risk of the socket going away. We then
lock the socket, which is safe because it is pinned. We can then call
tcp_done() without recursive deadlock and without race. Upon return, we unlock
the socket and then unpin it, killing it.
Change-Id: Idcdae072b48238b01bdbc8823b60310f1976e045
Signed-off-by: Robert Love <rlove@google.com>
Acked-by: Dima Zavin <dima@android.com>
ipv4: disable bottom halves around call to tcp_done().
Signed-off-by: Colin Cross <ccross@android.com>
ipv4: Move sk_error_report inside bh_lock_sock in tcp_v4_nuke_addr
When sk_error_report is called, it wakes up the user-space thread, which then
calls tcp_close. When the tcp_close is interrupted by the tcp_v4_nuke_addr
ioctl thread running tcp_done, it leaks 392 bytes and triggers a WARN_ON.
This patch moves the call to sk_error_report inside the bh_lock_sock, which
matches the locking used in tcp_v4_err.
In contrast to SIOCOUTQ which returns the amount of data sent
but not yet acknowledged plus data not yet sent this patch only
returns the data not sent.
For various methods of live streaming bitrate control it may
be helpful to know how much data are in the tcp outqueue are
not sent yet.
Signed-off-by: Mario Schuknecht <m.schuknecht@dresearch.de>
Signed-off-by: Steffen Sledz <sledz@dresearch.de>
User space can request hardware and/or software time stamping.
Reporting of the result(s) via a new control message is enabled
separately for each field in the message because some of the
fields may require additional computation and thus cause overhead.
User space can tell the different kinds of time stamps apart
and choose what suits its needs.
When a TX timestamp operation is requested, the TX skb will be cloned
and the clone will be time stamped (in hardware or software) and added
to the socket error queue of the skb, if the skb has a socket
associated with it.
The actual TX timestamp will reach userspace as a RX timestamp on the
cloned packet. If timestamping is requested and no timestamping is
done in the device driver (potentially this may use hardware
timestamping), it will be done in software after the device's
start_hard_xmit routine.
Signed-off-by: Patrick Ohly <patrick.ohly@intel.com>
This patch contains the scheduled removal of the frame diverter.
Ross moved. Remove the bad email address so people will find the correct
one in ./CREDITS.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
infrastructure for it.
Let it rip!
