path: root/include/linux/spi/mmc_spi.h
2008-12-31mmc_spi: Add support for OpenFirmware bindingsAnton Vorontsov
The support is implemented via platform data accessors, new module (of_mmc_spi) will be created automatically when the driver compiles on OpenFirmware platforms. Link-time dependency will load the module automatically. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-07-15mmc_spi: add support for card-detection pollingAnton Vorontsov
This patch adds new platform data variable "caps", so platforms could pass theirs capabilities into MMC core (for example, platforms without interrupt on the CD line will most probably want to pass MMC_CAP_NEEDS_POLL). New platform get_cd() callback provided to optimize polling. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-06-02mmc_spi: mmc_spi.h should include linux/interrupts.hAnton Vorontsov
Since mmc_spi.h uses irqreturn_t type, it should include appropriate header, otherwise build will break if users didn't include it (some of them do not use interrupts). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-23mmc_spi host driverDavid Brownell
This is the latest version of the MMC-over-SPI support. It works on 2.6.23-rc2 plus git-mmc (from rc1-mm2), along with the preceding patches which teach the rest of the MMC stack about SPI. The main issue of note is that sometimes cards need to be power cycled to recover after certain faults. Also, it may sometimes be necessary to disable CRCs. ("modprobe mmc_core use_spi_crc=n") Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: mikael.starvik@axis.com, Cc: Hans-Peter Nilsson <hp@axis.com> Cc: Jan Nikitenko <jan.nikitenko@gmail.com> Cc: Mike Lavender <mike@steroidmicros.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
