path: root/include/linux/spi
2012-03-28Merge tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More device tree support updates" from Olof Johansson: "This branch contains a number of updates for device tree support on several ARM platforms, in particular: * AT91 continues the device tree conversion adding support for a number of on-chip drivers and other functionality * ux500 adds probing of some of the core SoC blocks through device tree * Initial device tree support for ST SPEAr600 platforms * kirkwood continues the conversion to device-tree probing" Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and drivers/usb/gadget/at91_udc.c due to header file include cleanups. Also do an "evil merge" for the MACH_U8500 config option rename that the affected RMI4 touchscreen driver in staging. It's called MACH_MOP500 now, and it was missed during previous merges. * tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: SPEAr600: Add device-tree support to SPEAr600 boards ARM: ux500: Provide local timer support for Device Tree ARM: ux500: Enable PL022 SSP Controller in Device Tree ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree ARM: ux500: db8500: list most devices in the snowball device tree ARM: ux500: split dts file for snowball into generic part ARM: ux500: combine the board init functions for DT boot ARM: ux500: Initial Device Tree support for Snowball ARM: ux500: CONFIG: Enable Device Tree support for future endeavours ARM: kirkwood: use devicetree for rtc-mv ARM: kirkwood: rtc-mv devicetree bindings ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0 ARM: kirkwood: fdt: facilitate new boards during fdt migration ARM: kirkwood: fdt: absorb kirkwood_init() ARM: kirkwood: fdt: use mrvl ticker symbol ARM: orion: wdt: use resource vice direct access ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data. ARM: orion: spi: remove enable_clock_fix which is not used ...
2012-03-27Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: global cleanups" from Arnd Bergmann: "Quite a bit of code gets removed, and some stuff moved around, mostly the old samsung s3c24xx stuff. There should be no functional changes in this series otherwise. Some cleanups have dependencies on other arm-soc branches and will be sent in the second round. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial conflicts mainly due to #include's being changes on both sides. * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits) ep93xx: Remove unnecessary includes of ep93xx-regs.h ep93xx: Move EP93XX_SYSCON defines to SoC private header ep93xx: Move crunch code to mach-ep93xx directory ep93xx: Make syscon access functions private to SoC ep93xx: Configure GPIO ports in core code ep93xx: Move peripheral defines to local SoC header ep93xx: Convert the watchdog driver into a platform device. ep93xx: Use ioremap for backlight driver ep93xx: Move GPIO defines to gpio-ep93xx.h ep93xx: Don't use system controller defines in audio drivers ep93xx: Move PHYS_BASE defines to local SoC header file ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver ARM: EXYNOS: add clock registers for exynos4x12-cpufreq PM / devfreq: update the name of EXYNOS clock registers that were omitted PM / devfreq: update the name of EXYNOS clock register ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock ARM: EXYNOS: use static declaration on regarding clock ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs ARM: OMAP2+: Fix build error after merge ARM: S3C24XX: remove call to s3c24xx_setup_clocks ...
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-16device.h: audit and cleanup users in main include dirPaul Gortmaker
The <linux/device.h> header includes a lot of stuff, and it in turn gets a lot of use just for the basic "struct device" which appears so often. Clean up the users as follows: 1) For those headers only needing "struct device" as a pointer in fcn args, replace the include with exactly that. 2) For headers not really using anything from device.h, simply delete the include altogether. 3) For headers relying on getting device.h implicitly before being included themselves, now explicitly include device.h 4) For files in which doing #1 or #2 uncovers an implicit dependency on some other header, fix by explicitly adding the required header(s). Any C files that were implicitly relying on device.h to be present have already been dealt with in advance. Total removals from #1 and #2: 51. Total additions coming from #3: 9. Total other implicit dependencies from #4: 7. As of 3.3-rc1, there were 110, so a net removal of 42 gives about a 38% reduction in device.h presence in include/* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-16ARM: orion: spi: remove enable_clock_fix which is not usedAndrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-15spi: sh-hspi: control spi clock more correctlyKuninori Morimoto
Current sh-hspi had used platform-specific speed. This patch remove it, and use spi_transfer specific speed. It removes unnecessary flags from struct sh_hspi_info, but struct sh_hspi_info is still exist, since sh-hspi needs platform info in the future. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-09spi: Trivial warning fixShubhrajyoti D
The loop count i traverses for ntrans which is unsigned so make the loop count i also unsigned. Fix the below warning In file included from drivers/spi/spi-omap2-mcspi.c:38: include/linux/spi/spi.h: In function 'spi_message_alloc': include/linux/spi/spi.h:556: warning: comparison between signed and unsigned integer expressions Cc: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-09spi: Add SuperH HSPI prototype driverKuninori Morimoto
This patch adds SuperH HSPI driver. It is still prototype driver, but has enough function at this point. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-07spi: create a message queueing infrastructureLinus Walleij
This rips the message queue in the PL022 driver out and pushes it into (optional) common infrastructure. Drivers that want to use the message pumping thread will need to define the new per-messags transfer methods and leave the deprecated transfer() method as NULL. Most of the design is described in the documentation changes that are included in this patch. Since there is a queue that need to be stopped when the system is suspending/resuming, two new calls are implemented for the device drivers to call in their suspend()/resume() functions: spi_master_suspend() and spi_master_resume(). ChangeLog v1->v2: - Remove Kconfig entry and do not make the queue support optional at all, instead be more agressive and have it as part of the compulsory infrastructure. - If the .transfer() method is implemented, delete print a small deprecation notice and do not start the transfer pump. - Fix a bitrotted comment. ChangeLog v2->v3: - Fix up a problematic sequence courtesy of Chris Blair. - Stop rather than destroy the queue on suspend() courtesy of Chris Blair. Signed-off-by: Chris Blair <chris.blair@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-01-31ARM: S3C24XX: move spi-s3c24xx platdata out of machHeiko Stuebner
spi.h now only contains the definition of the platform data structure for the driver in spi-s3c24xx.c . Therefore it does not need to stay in include/mach but can instead live in linux/spi/s3c24xx.h . Signed-off-by: Heiko Stuebner <heiko@sntech.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-11-17SPI: Add helper macro for spi_driver boilerplateLars-Peter Clausen
This patch introduces the module_spi_driver macro which is a convenience macro for SPI driver modules similar to module_platform_driver. It is intended to be used by drivers which init/exit section does nothing but register/unregister the SPI driver. By using this macro it is possible to eliminate a few lines of boilerplate code per SPI driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-31backlight: fix broken regulator API usage in l4f00242t03Mark Brown
The regulator support in the l4f00242t03 is very non-idiomatic. Rather than requesting the regulators based on the device name and the supply names used by the device the driver requires boards to pass system specific supply names around through platform data. The driver also conditionally requests the regulators based on this platform data, adding unneeded conditional code to the driver. Fix this by removing the platform data and converting to the standard idiom, also updating all in tree users of the driver. As no datasheet appears to be available for the LCD I'm guessing the names for the supplies based on the existing users and I've no ability to do anything more than compile test. The use of regulator_set_voltage() in the driver is also problematic, since fixed voltages are required the expectation would be that the voltages would be fixed in the constraints set by the machines rather than manually configured by the driver, but is less problematic. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-15mcp23s08: get rid of setup/teardown callbacksPeter Korsgaard
There's no in-tree users, and bus notifiers are more generic anyway. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-03gpio/74x164: remove unnecessary defines and prototypeH Hartley Sweeten
Remove the #define GEN_74X164_GPIO_COUNT since it's only used in one place and it's meaning is obvious. Also remove the #define GEN_74X164_DRIVER_NAME and use spi->modalias to set the gpio chip's label and the string "74x164" for the driver name. Reorder the code slightly to remove the need to prototype gen_74x164_set_value. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe fails spi/spi_s3c24xx: Use spi_bitbang_stop instead of spi_unregister_master in s3c24xx_spi_remove spi/spi_nuc900: Use spi_bitbang_stop instead of spi_unregister_master in nuc900_spi_remove spi/spi_tegra: use spi_unregister_master() instead of spi_master_put() spi/spi_sh: use spi_unregister_master instead of spi_master_put in remove path spi: Use void pointers for data in simple SPI I/O operations spi/pl022: use cpu_relax in the busy loop spi/pl022: mark driver non-experimental spi/pl022: timeout on polled transfer v2 spi/dw_spi: improve the interrupt mode with the batch ops spi/dw_spi: change poll mode transfer from byte ops to batch ops spi/dw_spi: remove the un-necessary flush() spi/dw_spi: unify the low level read/write routines
2011-05-20spi: Use void pointers for data in simple SPI I/O operationsMark Brown
Currently the simple SPI I/O operations all take pointers to u8 * buffers to operate on. This creates needless type compatibility issues and the underlying spi_transfer structure uses void pointers anyway so convert the API over to take void pointers too. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-12Input: ads7846 - add possibility to use external vref on ads7846Alexander Stein
Just set vref_mv in your platform config to use external vref. Otherwise the internal one is used. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits) Input: tsc2005 - remove 'disable' sysfs attribute Input: tsc2005 - add open/close Input: tsc2005 - handle read errors from SPI layer Input: tsc2005 - do not rearm timer in hardirq handler Input: tsc2005 - don't use work for 'pen up' handling Input: tsc2005 - do not use 0 in place of NULL Input: tsc2005 - use true/false for boolean variables Input: tsc2005 - hide selftest attribute if we can't reset Input: tsc2005 - rework driver initialization code Input: tsc2005 - set up bus type in input device Input: tsc2005 - set up parent device Input: tsc2005 - clear driver data after unbinding Input: tsc2005 - add module description Input: tsc2005 - remove driver banner message Input: tsc2005 - remove incorrect module alias Input: tsc2005 - convert to using dev_pm_ops Input: tsc2005 - use spi_get/set_drvdata() Input: introduce tsc2005 driver Input: xen-kbdfront - move to drivers/input/misc Input: xen-kbdfront - add grant reference for shared page ...
2011-03-18spi/dw_spi: move dw_spi.h into drivers/spiGrant Likely
include/linux/dw_spi.h only includes driver internal data. It doesn't expose a platform_data configuration structure or similar (at least nothing in-tree). This patch moves the header into drivers/spi so that the scope is limited to only the dw_spi_*.c driver files Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Feng Tang <feng.tang@intel.com> Cc: spi-devel-general@lists.sourceforge.net
2011-03-18spi/dw_spi: Fix missing headerJiri Slaby
Currently, build on PPC dies with: In file included from drivers/spi/dw_spi_mmio.c:16: include/linux/spi/dw_spi.h:147: error: field ‘tx_sgl’ has incomplete type include/linux/spi/dw_spi.h:149: error: field ‘rx_sgl’ has incomplete type Add linux/scatterlist.h include to dw_spi.h, because we need to know the contents of the structure. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17Merge remote-tracking branch 'origin' into spi/nextGrant Likely
Pull in Linus' tree to pick up changes required for the langwell gpio fixes
2011-03-16Merge branch 'tsc2005' into nextDmitry Torokhov
2011-03-16Input: introduce tsc2005 driverLauri Leukkunen
Discussions: http://www.mail-archive.com/linux-omap@vger.kernel.org/msg26748.html Introduce a driver for the Texas Instruments TSC2005 touchscreen controller (http://focus.ti.com/docs/prod/folders/print/tsc2005.html). The patch is based on a driver by Lauri Leukkunen, with modifications by David Brownell, Phil Carmody, Imre Deak, Hiroshi DOYU, Ari Kauppi, Tony Lindgren, Jarkko Nikula, Eero Nurkkala and Roman Tereshonkov. Signed-off-by: Lauri Leukkunen <lauri.leukkunen@nokia.com> [aaro.koskinen@nokia.com: patch description, rebasing & cleanup] Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> [ext-srikar.1.bhavanarayana@nokia.com: various fixes] Signed-off-by: Srikar <ext-srikar.1.bhavanarayana@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-12gpio/mcp23s08: support mcp23s17 variantPeter Korsgaard
mpc23s17 is very similar to the mcp23s08, except that registers are 16bit wide, so extend the interface to work with both variants. The s17 variant also has an additional address pin, so adjust platform data structure to support up to 8 devices per SPI chipselect. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-22spi: add OpenCores tiny SPI driverThomas Chou
This patch adds support of OpenCores tiny SPI driver. http://opencores.org/project,tiny_spi Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-03serial: ifx6x60: expanded info available from platform dataRuss Gorby
Some platform attributes (e.g. max_hz, use_dma) were being intuited from the modem type. These things should be specified by the platform data. Added max_hz, use_dma to ifx_modem_platform_data definition, replaced is_6160 w/ modem_type, and changed clients accordingly Signed-off-by: Russ Gorby <russ.gorby@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (77 commits) spi/omap: Fix DMA API usage in OMAP MCSPI driver spi/imx: correct the test on platform_get_irq() return value spi/topcliff: Typo fix threhold to threshold spi/dw_spi Typo change diable to disable. spi/fsl_espi: change the read behaviour of the SPIRF spi/mpc52xx-psc-spi: move probe/remove to proper sections spi/dw_spi: add DMA support spi/dw_spi: change to EXPORT_SYMBOL_GPL for exported APIs spi/dw_spi: Fix too short timeout in spi polling loop spi/pl022: convert running variable spi/pl022: convert busy flag to a bool spi/pl022: pass the returned sglen to the DMA engine spi/pl022: map the buffers on the DMA engine spi/topcliff_pch: Fix data transfer issue spi/imx: remove autodetection spi/pxa2xx: pass of_node to spi device and set a parent device spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes. spi/pxa2xx: Add chipselect support for Sodaville spi/pxa2xx: Consider CE4100's FIFO depth spi/pxa2xx: Add CE4100 support ...
2010-12-29Merge branch 'spi' of git://git.linutronix.de/users/bigeasy/soda into spi/nextGrant Likely
* 'spi' of git://git.linutronix.de/users/bigeasy/soda into spi/next spi/pxa2xx: register driver properly spi/pxa2xx: add support for shared IRQ handler spi/pxa2xx: Use define for SSSR_TFL_MASK instead of plain numbers arm/pxa2xx: reorgazine SSP and SPI header files spi/pxa2xx: Add CE4100 support spi/pxa2xx: Consider CE4100's FIFO depth spi/pxa2xx: Add chipselect support for Sodaville spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes. spi/pxa2xx: pass of_node to spi device and set a parent device
2010-12-24spi/dw_spi: add DMA supportFeng Tang
dw_spi driver in upstream only supports PIO mode, and this patch will support it to cowork with the Designware dma controller used on Intel Moorestown platform, at the same time it provides a general framework to support dw_spi core to cowork with dma controllers on other platforms It has been tested with a Option GTM501L 3G modem and Infenion 60x60 modem. To use DMA mode, DMA controller 2 of Moorestown has to be enabled Also change the dma interface suggested by Linus Walleij. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Feng Tang <feng.tang@intel.com> [Typo fix and renames to match intel_mid_dma renaming] Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-01spi/pxa2xx: Add CE4100 supportSebastian Andrzej Siewior
Sodaville's SPI controller is very much the same as in PXA25x. The difference: - The RX/TX FIFO is only 4 words deep instead of 16 - No DMA support - The SPI controller offers a CS functionality Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-11-11ifx6x60: SPI protocol driver for Infineon 6x60 modemRuss Gorby
Prototype driver for the IFX6x60 series of SPI attached modems by Jim Stanley and Russ Gorby Signed-off-by: Russ Gorby <richardx.r.gorby@intel.com> [Some reworking and a major cleanup] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-01Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: spi/pl022: fix erroneous platform data in U300 spi: fixed odd static string conventions in core code spi/bfin_spi: only request GPIO on first load spi/bfin_spi: handle error/status changes after data interrupts spi: enable spi_board_info to be registered after spi_master
2010-10-27gpio: add support for 74x164 serial-in/parallel-out 8-bit shift registerMiguel Gaio
Add support for generic 74x164 serial-in/parallel-out 8-bits shift register. This driver can be used as a GPIO output expander. [akpm@linux-foundation.org: remove unused local `refresh'] Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com> Signed-off-by: Juhos Gabor <juhosg@openwrt.org> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21spi: enable spi_board_info to be registered after spi_masterFeng Tang
Currently spi_register_board_info() has to be called before its related spi_master be registered, otherwise these board info will be just ignored. This patch will remove this order limit, it adds a global spi master list like the existing global board info listr. Whenever a board info or a spi_master is registered, the spi master list or board info list will be scanned, and a new spi device will be created if there is a master-board info match. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/pcmcia/pcnet_cs.c net/caif/caif_socket.c
2010-09-21Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: arch/arm/mach-omap2/board-omap3pandora.c drivers/net/wireless/ath/ath5k/base.c
2010-09-21wl12xx: make wl12xx.h common to both spi and sdioOhad Ben-Cohen
Move wl12xx.h outside of the spi-specific location, so it can be shared with both spi and sdio solutions. Update all users of spi/wl12xx.h accordingly Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-08spi/dw_spi: clean the cs_control codeFeng Tang
commit 052dc7c45i "spi/dw_spi: conditional transfer mode change" introduced cs_control code, which has a bug by using bit offset for spi mode to set transfer mode in control register. Also it forces devices who don't need cs_control to re-configure the control registers for each spi transfer. This patch will fix them Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-02Merge branch 'master' of ↵John W. Linville
2010-08-25wl12xx: change contact person for the include fileKalle Valo
Luciano should be the contact person for the include/linux/spi/wl12xx.h file. Signed-off-by: Kalle Valo <kvalo@adurom.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-17spi.h: missing kernel-doc notation, please fixErnst Schwab
Added comments in kernel-doc notation for previously added struct fields. Signed-off-by: Ernst Schwab <eschwab@online.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-14Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: spi/amba_pl022: Fix probe and remove hook section annotations. spi/mpc5121: change annotations for probe and remove functions spi/bitbang: reinitialize transfer parameters for every message spi/spi-gpio: add support for controllers without MISO or MOSI pin spi/bitbang: add support for SPI_MASTER_NO_{TX, RX} modes SPI100k: Fix 8-bit and RX-only transfers spi/mmc_spi: mmc_spi adaptations for SPI bus locking API spi/mmc_spi: SPI bus locking API, using mutex Fix trivial conflict in drivers/spi/mpc512x_psc_spi.c due to 'struct of_device' => 'struct platform_device' rename and __init/__exit to __devinit/__devexit fix.
2010-08-11gpio: max730x: make pullups configurable via platformdataMarc Kleine-Budde
The gpios on the max730x chips have support for internal pullups while in input mode. This patch adds support for configuring these pullups via platform data. A new member ("input_pullup_active") to the platform data struct is introduced. A set bit in this variable activates the pullups while the respective port is in input mode. This is a compatible enhancement since unset bits lead to disables pullups which was the default in the original driver. _Note_: the 4 lowest bits in "input_pullup_active" are unused because the first 4 ports of the controller are not used, too. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-03spi/spi-gpio: add support for controllers without MISO or MOSI pinMarek Szyprowski
There are some boards that do not strictly follow SPI standard and use only 3 wires (SCLK, MOSI or MISO, SS) for connecting some simple auxiliary chips and controls them with GPIO based 'spi controller'. In this configuration the MISO or MOSI line is missing (it is not required if the chip does not transfer any data back to host or host only reads data from chip). This patch adds support for such non-standard configuration in GPIO-based SPI controller. It has been tested in configuration without MISO pin. Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-03Input: ads7846 - do not allow altering platform dataDmitry Torokhov
Tested-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-06-28spi/mmc_spi: SPI bus locking API, using mutexErnst Schwab
SPI bus locking API to allow exclusive access to the SPI bus, especially, but not limited to, for the mmc_spi driver. Coded according to an outline from Grant Likely; here is his specification (accidentally swapped function names corrected): It requires 3 things to be added to struct spi_master. - 1 Mutex - 1 spin lock - 1 flag. The mutex protects spi_sync, and provides sleeping "for free" The spinlock protects the atomic spi_async call. The flag is set when the lock is obtained, and checked while holding the spinlock in spi_async(). If the flag is checked, then spi_async() must fail immediately. The current runtime API looks like this: spi_async(struct spi_device*, struct spi_message*); spi_sync(struct spi_device*, struct spi_message*); The API needs to be extended to this: spi_async(struct spi_device*, struct spi_message*) spi_sync(struct spi_device*, struct spi_message*) spi_bus_lock(struct spi_master*) /* although struct spi_device* might be easier */ spi_bus_unlock(struct spi_master*) spi_async_locked(struct spi_device*, struct spi_message*) spi_sync_locked(struct spi_device*, struct spi_message*) Drivers can only call the last two if they already hold the spi_master_lock(). spi_bus_lock() obtains the mutex, obtains the spin lock, sets the flag, and releases the spin lock before returning. It doesn't even need to sleep while waiting for "in-flight" spi_transactions to complete because its purpose is to guarantee no additional transactions are added. It does not guarantee that the bus is idle. spi_bus_unlock() clears the flag and releases the mutex, which will wake up any waiters. The difference between spi_async() and spi_async_locked() is that the locked version bypasses the check of the lock flag. Both versions need to obtain the spinlock. The difference between spi_sync() and spi_sync_locked() is that spi_sync() must hold the mutex while enqueuing a new transfer. spi_sync_locked() doesn't because the mutex is already held. Note however that spi_sync must *not* continue to hold the mutex while waiting for the transfer to complete, otherwise only one transfer could be queued up at a time! Almost no code needs to be written. The current spi_async() and spi_sync() can probably be renamed to __spi_async() and __spi_sync() so that spi_async(), spi_sync(), spi_async_locked() and spi_sync_locked() can just become wrappers around the common code. spi_sync() is protected by a mutex because it can sleep spi_async() needs to be protected with a flag and a spinlock because it can be called atomically and must not sleep Signed-off-by: Ernst Schwab <eschwab@online.de> [grant.likely@secretlab.ca: use spin_lock_irqsave()] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Matt Fleming <matt@console-pimps.org> Tested-by: Antonio Ospite <ospite@studenti.unina.it>
2010-06-28Input: ads7846 - allow specifying irq trigger type in platform dataAnatolij Gustschin
On some platforms, for example with GPIO interrupts on mpc5121, it is not possible to configure falling edge interrupts. Specifying irq trigger type in platform data structure allows using ads7846 driver on such platforms. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
