path: root/include/linux/spinlock_api_up.h
2015-01-03spinlock: Add spin_lock_bh_nested()Thomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13locking: Optimize lock_bh functionsPeter Zijlstra
Currently all _bh_ lock functions do two preempt_count operations: local_bh_disable(); preempt_disable(); and for the unlock: preempt_enable_no_resched(); local_bh_enable(); Since its a waste of perfectly good cycles to modify the same variable twice when you can do it in one go; use the new __local_bh_{dis,en}able_ip() functions that allow us to provide a preempt_count value to add/sub. So define SOFTIRQ_LOCK_OFFSET as the offset a _bh_ lock needs to add/sub to be done in one go. As a bonus it gets rid of the preempt_enable_no_resched() usage. This reduces a 1000 loops of: spin_lock_bh(&bh_lock); spin_unlock_bh(&bh_lock); from 53596 cycles to 51995 cycles. I didn't do enough measurements to say for absolute sure that the result is significant but the the few runs I did for each suggest it is so. Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: jacob.jun.pan@linux.intel.com Cc: Mike Galbraith <bitbucket@online.de> Cc: hpa@zytor.com Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: lenb@kernel.org Cc: rjw@rjwysocki.net Cc: rui.zhang@intel.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20131119151338.GF3694@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2009-12-14locking: Cleanup the name space completelyThomas Gleixner
Make the name space hierarchy of locking functions consistent: raw_spin* -> _raw_spin* -> __raw_spin* No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14locking: Implement new raw_spinlockThomas Gleixner
Now that the raw_spin name space is freed up, we can implement raw_spinlock and the related functions which are used to annotate the locks which are not converted to sleeping spinlocks in preempt-rt. A side effect is that only such locks can be used with the low level lock fsunctions which circumvent lockdep. For !rt spin_* functions are mapped to the raw_spin* implementations. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-02-03include/linux/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-07-03[PATCH] lockdep: prove spinlock rwlock locking correctnessIngo Molnar
Use the lock validator framework to prove spinlock and rwlock locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
