commit 46fc4c909339f5a84d1679045297d9d2fb596987 upstream.
And make use of it in b43. This fixes a regression introduced with
49d55cef5b1925a5c1efb6aaddaa40fc7c693335
b43: N-PHY: implement spurious tone avoidance
This commit made BCM4322 use only MCS 0 on channel 13, which of course
resulted in performance drop (down to 0.7Mb/s).
Reported-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
This patch extends the sprom struct to contain all sprom attributes
found in sprom version 1 to 9. This was done accordingly to the open
source part of the Broadcom SDK.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This member contains the country code encoded with two chars
On sprom version 4 and 5 there are 4 values for pa_2g, pa_5gl, pa_5g
and pa_5gh, for sprom version 8 and 9 there are only 3. Make the per
path sprom store also work for older sprom versions.
There is no 2.4 GHz or 5GHz antenna gain stored in sprom. The sprom
just stores the gain values for antenna 1 and 2 or 1 to 4 for more
recent sprom versions. On old devices antenna 2 was used for 5 GHz wifi.
Some parts of the sprom struct are bigger than needed.
The leddc and maxpwr values are just 8 bit long and not 16.
rxpo2g and rxpo5g are signed
I got these information for the open source part of the Broadcom SDK
covering sprom version 1 to 9. rxpo2g contained a negative number on my
bcm5354 based device, this cased an error and Broadcom SDK says this is
signed.
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
We already extract some basic info but it's incomplete, reads info
about the first core only. Used data structure doesn't allow easy
adding of more cores.
This patch adds new struct and array for storing power info. The plan
is to: switch all extractors (including the ones using NVRAM) to new
struct, switch drivers, then deprecate and finally drop old SSB fields.
The original implementations reference THIS_MODULE in an inline.
We could include <linux/export.h>, but it is better to avoid chaining.
Fortunately someone else already thought of this, and made a similar
inline into a #define in <linux/device.h> for device_schedule_callback(),
[see commit 523ded71de0] so follow that precedent here.
Also bubble up any __must_check that were used on the prev. wrapper inline
functions up one to the real __register functions, to preserve any prev.
sanity checks that were used in those instances.
Specs say about size 2 (u16) and my 14e4:4727 has board rev 0x1211.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
They are SPROM specific, so all should be defined in ssb code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Signed-off-by: Michael Buesch <m@bues.ch>
The SSB code reads PCI revision ID register as 16-bit entity while the register
is actually 8-bit only (the next 8 bits are the programming interface register).
Fix the read and make the 'rev' field of 'struct ssb_boardinfo' 8-bit as well,
to match the register size.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
Some embedded devices like the Netgear WNDR3300 have two SSB based cards
without an own sprom on the pci bus. We have to provide two different
fallback sproms for these and this was not possible with the old solution.
In the bcm47xx architecture the sprom data is stored in the nvram in the
main flash storage. The architecture code will be able to fill the sprom
with the stored data based on the bus where the device was found.
The bcm63xx code should do the same thing as before, just using the new
API.
Acked-by: Michael Buesch <mb@bu3sch.de>
Cc: netdev@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: Florian Fainelli <florian@openwrt.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2362/
Commiting settings is possible on devices without PCI core (but with CC
core). Export it for usage in drivers supporting other cores.
My 14e4:4315 is SSB_IDLOW_SSBREV_26:
read32 0xfaafcff8 -> 0x600422d5
My 14e4:4328 is SSB_IDLOW_SSBREV_24:
read32 0xfaafcff8 -> 0x400422c5
My 14e4:432b is SSB_IDLOW_SSBREV_26 again:
For all of them wl driver is using 0x2 reject bit:
write32(0xf98) <- 0x00010002
So it seems SSB 2.3 is the exception using another bit.
We probably got false positive results for checking PLL being down.
It was incorrectly introduced in d2730b2a6a019d14455556019d744ab051e6554b. We
have already fixed function to use correct define, but forgot remove old one.
Cc: Gábor Stefanik <netrolller.3d@gmail.com>
net/ipv4/fib_frontend.c
The nvram_get function was never in the mainline kernel, it only existed in
an external OpenWrt patch. Use nvram_getenv function, which is in mainline
and use an include instead of an extra function declaration. et0macaddr
contains the mac address in text from like 00:11:22:33:44:55. We have to
parse it before adding it into macaddr.
nvram_parse_macaddr will be merged into asm/mach-bcm47xx/nvram.h through
the MIPS git tree and will be available soon. It will not build now without
nvram_parse_macaddr, but it hasn't before either.
To: linux-mips@linux-mips.org
Cc: mb@bu3sch.de
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Patchwork: https://patchwork.linux-mips.org/patch/1849/
Signed-off-by: Gábor Stefanik <netrolller.3d@gmail.com>
Now they are unnecessary. We can use the generic DMA API with any bus.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Michael Buesch <mb@bu3sch.de>
Cc: Gary Zambrano <zambrano@broadcom.com>
Cc: Stefano Brivio <stefano.brivio@polimi.it>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: John W. Linville <linville@tuxdriver.com>
Add dma_dev, a pointer to struct device, to struct ssb_device. We pass it
to the generic DMA API with SSB_BUSTYPE_PCI and SSB_BUSTYPE_SSB.
ssb_devices_register() sets up it properly.
This is preparation for replacing the ssb bus specific DMA API (ssb_dma_*)
with the generic DMA API.
Our offset handling becomes even a little more hackish now. For some reason I
do not understand all offsets as inrelative. It assumes base offset is 0x1000
but it will work for now as we make offsets relative anyway by removing base
0x1000. Should be cleaner however.
Attempting to read registers that don't exist on the SSB bus can cause
hangs on some boxes. At least some b43 devices are 'in the wild' that
don't have SPROMs at all. When the SSB bus support loads, it attempts
to read these (non-existant) SPROMs and causes hard hangs on the box --
no console output, etc.
This patch adds some intelligence to determine whether or not the SPROM
is present before attempting to read it. This avoids those hard hangs
on those devices with no SPROM attached to their SSB bus. The
SSB-attached devices (e.g. b43, et al.) won't work, but at least the box
will survive to test further patches. :-)
This slightly shrinks the structure.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Add support for communicating with a Sonics Silicon Backplane through a
SDIO interface, as found in the Nintendo Wii WLAN daughter card.
The Nintendo Wii WLAN card includes a custom Broadcom 4318 chip with
a SDIO host interface.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
Implement the "PMU LDO set voltage" and "PMU LDO PA ref enable"
functions, and use them during LP-PHY baseband init in b43.
Also add a "SPEX32" macro for extracting 32-bit SPROM variables.
This adds SSB functionality to register a fallback SPROM image from the
architecture setup code.
Weird architectures exist that have half-assed SSB devices without SPROM attached to
their PCI busses. The architecture can register a fallback SPROM image that is
used if no SPROM is found on the SSB device.
This adds support for the SSB PMU.
A PMU is found on Low-Power devices.
This adds detection code for the LP-PHY and SPROM
extraction code for version 8, which is needed by the LP-PHY and
newer N-PHY.
This fixes compilation of the SSB DMA-API code on non-PCI platforms.
Only rev 1 and 2 ssb SPROMs have fields named et0mac and et1mac;
however, all of the extraction routines extract pseudo data for these
fields from regions that are all 1's resulting in a hardware address
of FF:FF:FF:FF:FF:FF. This patch forces such a fill at the beginning of
the data extraction process, and only does the formal extraction if the
SPROM rev is 1 or 2.
Although a revision 5 SPROM has not been seen in the wild, the
open-source portion of the MIPS driver 4.150.10.5 describes its
layout, which is mostly inherited from revision 4. This patch
implements the differences.
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER
architecture does:
This enables us to cleanly fix the Calgary IOMMU issue that some devices
are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423).
I think that per-device dma_mapping_ops support would be also helpful for
KVM people to support PCI passthrough but Andi thinks that this makes it
difficult to support the PCI passthrough (see the above thread). So I
CC'ed this to KVM camp. Comments are appreciated.
A pointer to dma_mapping_ops to struct dev_archdata is added. If the
pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's
NULL, the system-wide dma_ops pointer is used as before.
If it's useful for KVM people, I plan to implement a mechanism to register
a hook called when a new pci (or dma capable) device is created (it works
with hot plugging). It enables IOMMUs to set up an appropriate
dma_mapping_ops per device.
The major obstacle is that dma_mapping_error doesn't take a pointer to the
device unlike other DMA operations. So x86 can't have dma_mapping_ops per
device. Note all the POWER IOMMUs use the same dma_mapping_error function
so this is not a problem for POWER but x86 IOMMUs use different
dma_mapping_error functions.
The first patch adds the device argument to dma_mapping_error. The patch
is trivial but large since it touches lots of drivers and dma-mapping.h in
all the architecture.
This patch:
dma_mapping_error() doesn't take a pointer to the device unlike other DMA
operations. So we can't have dma_mapping_ops per device.
Note that POWER already has dma_mapping_ops per device but all the POWER
IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device
argument.
[akpm@linux-foundation.org: fix sge]
[akpm@linux-foundation.org: fix svc_rdma]
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: fix bnx2x]
[akpm@linux-foundation.org: fix s2io]
[akpm@linux-foundation.org: fix pasemi_mac]
[akpm@linux-foundation.org: fix sdhci]
[akpm@linux-foundation.org: fix sparc]
[akpm@linux-foundation.org: fix ibmvscsi]
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
Cc: Avi Kivity <avi@qumranet.com>
ssb.h implements DMA mapping functions, so it should
include dma-mapping.h. This fixes compile failures on certain architectures.
This is a rewrite of the DMA API for SSB devices.
This is needed, because the old (non-existing) "API" made too many bad
assumptions on the API of the host-bus (PCI).
This introduces an almost complete SSB-DMA-API that maps to the lowlevel
bus-API based on the bustype.
