path: root/include/linux/string.h
2014-11-14random: add and use memzero_explicit() for clearing dataDaniel Borkmann
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream. zatimend has reported that in his environment (3.16/gcc4.8.3/corei7) memset() calls which clear out sensitive data in extract_{buf,entropy, entropy_user}() in random driver are being optimized away by gcc. Add a helper memzero_explicit() (similarly as explicit_bzero() variants) that can be used in such cases where a variable with sensitive data is being cleared out in the end. Other use cases might also be in crypto code. [ I have put this into lib/string.c though, as it's always built-in and doesn't need any dependencies then. ] Fixes kernel bugzilla: 82041 Reported-by: zatimend@hotmail.co.uk Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17string: introduce helper to get base file name from given pathAndy Shevchenko
There are several places in the kernel that use functionality like basename(3) with the exception: in case of '/foo/bar/' we expect to get an empty string. Let's do it common helper for them. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Cc: YAMANE Toshiaki <yamanetoshi@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-08-21string: do not export memweight() to userspaceWANG Cong
Fix the following warning: usr/include/linux/string.h:8: userspace cannot reference function or variable defined in the kernel Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30string: introduce memweight()Akinobu Mita
memweight() is the function that counts the total number of bits set in memory area. Unlike bitmap_weight(), memweight() takes pointer and size in bytes to specify a memory area which does not need to be aligned to long-word boundary. [akpm@linux-foundation.org: rename `w' to `ret'] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Anders Larsen <al@alarsen.net> Cc: Alasdair Kergon <agk@redhat.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Jan Kara <jack@suse.cz> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Tony Luck <tony.luck@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lib/string.c: introduce memchr_inv()Akinobu Mita
memchr_inv() is mainly used to check whether the whole buffer is filled with just a specified byte. The function name and prototype are stolen from logfs and the implementation is from SLUB. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Joern Engel <joern@logfs.org> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19Add a strtobool function matching semantics of existing in kernel equivalentsJonathan Cameron
This is a rename of the usr_strtobool proposal, which was a renamed, relocated and fixed version of previous kstrtobool RFC Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-01-14lib: Introduce strnstr()Li Zefan
It differs strstr() in that it limits the length to be searched in the first string. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4B4E8743.6030805@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-15Subject: Re: [PATCH] strstrip incorrectly marked __must_checkKOSAKI Motohiro
Recently, We marked strstrip() as must_check. because it was frequently misused and it should be checked. However, we found one exception. scsi/ipr.c intentionally ignore return value of strstrip. Because it wishes to keep the whitespace at the beginning. Thus we need to keep with and without checked whitespace trim function. This patch adds a new strim() and changes ipr.c to use it. [akpm@linux-foundation.org: coding-style fixes] Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15string: factorize skip_spaces and export it to be generally availableAndré Goddard Rosa
On the following sentence: while (*s && isspace(*s)) s++; If *s == 0, isspace() evaluates to ((_ctype[*s] & 0x20) != 0), which evaluates to ((0x08 & 0x20) != 0) which equals to 0 as well. If *s == 1, we depend on isspace() result anyway. In other words, "a char equals zero is never a space", so remove this check. Also, *s != 0 is most common case (non-null string). Fixed const return as noticed by Jan Engelhardt and James Bottomley. Fixed unnecessary extra cast on strstrip() as noticed by Jan Engelhardt. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29strstrip(): mark as as must_checkKOSAKI Motohiro
strstrip() can return a modified value of its input argument, when removing elading whitesapce. So it is surely bug for this function's return value to be ignored. The caller is probably going to use the incorrect original pointer. So mark it __must_check to prevent this frm happening (as it has before). Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-05Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param: module: use strstarts() strstarts: helper function for !strncmp(str, prefix, strlen(prefix)) arm: allow usage of string functions in linux/string.h module: don't use stop_machine on module load module: create a request_module_nowait() module: include other structures in module version check module: remove the SHF_ALLOC flag on the __versions section. module: clarify the force-loading taint message. module: Export symbols needed for Ksplice Ksplice: Add functions for walking kallsyms symbols module: remove module_text_address() module: __module_address module: Make find_symbol return a struct kernel_symbol kernel/module.c: fix an unused goto label param: fix charp parameters set via sysfs Fix trivial conflicts in kernel/extable.c manually.
2009-04-05Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: printk: correct the behavior of printk_timed_ratelimit() vsprintf: unify the format decoding layer for its 3 users, cleanup fix regression from "vsprintf: unify the format decoding layer for its 3 users" vsprintf: fix bug in negative value printing vsprintf: unify the format decoding layer for its 3 users vsprintf: add binary printf printk: introduce printk_once() Fix trivial conflicts (printk_once vs log_buf_kexec_setup() added near each other) in include/linux/kernel.h.
2009-04-01memdup_user(): introduceLi Zefan
I notice there are many places doing copy_from_user() which follows kmalloc(): dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; if (copy_from_user(dst, src, len)) { kfree(dst); return -EFAULT } memdup_user() is a wrapper of the above code. With this new function, we don't have to write 'len' twice, which can lead to typos/mistakes. It also produces smaller code and kernel text. A quick grep shows 250+ places where memdup_user() *may* be used. I'll prepare a patchset to do this conversion. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31strstarts: helper function for !strncmp(str, prefix, strlen(prefix))Rusty Russell
Impact: minor new API ksplice added a "starts_with" function, which seems like a common need. When people open-code it they seem to use fixed numbers rather than strlen, so it's quite a readability win (also, strncmp() almost always wants != 0 on it). So here's strstarts(). Cc: Anders Kaseorg <andersk@mit.edu> Cc: Jeff Arnold <jbarnold@mit.edu> Cc: Tim Abbott <tabbott@mit.edu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-06vsprintf: add binary printfLai Jiangshan
Impact: add new APIs for binary trace printk infrastructure vbin_printf(): write args to binary buffer, string is copied when "%s" is occurred. bstr_printf(): read from binary buffer for args and format a string [fweisbec@gmail.com: rebase] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <1236356510-8381-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-02linux/string.h: fix comment typoJeff Garzik
s/user/used/ Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24move memory_read_from_buffer() from fs.h to string.hAkinobu Mita
James Bottomley warns that inclusion of linux/fs.h in a low level driver was always a danger signal. This patch moves memory_read_from_buffer() from fs.h to string.h and fixes includes in existing memory_read_from_buffer() users. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01Add a new sysfs_streq() string comparison functionDavid Brownell
Add a new sysfs_streq() string comparison function, which ignores the trailing newlines found in sysfs inputs. By example: sysfs_streq("a", "b") ==> false sysfs_streq("a", "a") ==> true sysfs_streq("a", "a\n") ==> true sysfs_streq("a\n", "a") ==> true This is intended to simplify parsing of sysfs inputs, letting them avoid the need to manually strip off newlines from inputs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30[TIPC]: Fix headercheck wrt. tipc_config.hDavid S. Miller
It wants string functions like memcpy() for inline routines, and these define userland interfaces. The only clean way to deal with this is to simply put linux/string.h into unifdef-y and have it include <string.h> when not-__KERNEL__. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-18add argv_split()Jeremy Fitzhardinge
argv_split() is a helper function which takes a string, splits it at whitespace, and returns a NULL-terminated argv vector. This is deliberately simple - it does no quote processing of any kind. [ Seems to me that this is something which is already being done in the kernel, but I couldn't find any other implementations, either to steal or replace. Keep an eye out. ] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com>
2007-07-18add kstrndupJeremy Fitzhardinge
Add a kstrndup function, modelled on strndup. Like strndup this returns a string copied into its own allocated memory, but it copies no more than the specified number of bytes from the source. Remove private strndup() from irda code. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@mandriva.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Panagiotis Issaris <takis@issaris.org> Cc: Rene Scharfe <rene.scharfe@lsrfire.ath.cx>
2007-04-26[STRING]: Move strcasecmp/strncasecmp to lib/string.cDavid S. Miller
We have several platforms using local copies of identical code. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-01[PATCH] kmemdup: introduceAlexey Dobriyan
One of idiomatic ways to duplicate a region of memory is dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; memcpy(dst, src, len); which is neat code except a programmer needs to write size twice. Which sometimes leads to mistakes. If len passed to kmalloc is smaller that len passed to memcpy, it's straight overwrite-beyond-end. If len passed to memcpy is smaller than len passed to kmalloc, it's either a) legit behaviour ;-), or b) cloned buffer will contain garbage in second half. Slight trolling of commit lists shows several duplications bugs done exactly because of diverged lenghts: Linux: [CRYPTO]: Fix memcpy/memset args. [PATCH] memcpy/memset fixes OpenBSD: kerberosV/src/lib/asn1: der_copy.c:1.4 If programmer is given only one place to play with lengths, I believe, such mistakes could be avoided. With kmemdup, the snippet above will be rewritten as: dst = kmemdup(src, len, GFP_KERNEL); if (!dst) return -ENOMEM; This also leads to smaller code (kzalloc effect). Quick grep shows 200+ places where kmemdup() can be used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] strstrip() APIPekka Enberg
Add a new strstrip() function to lib/string.c for removing leading and trailing whitespace from a string. Cc: Michael Holzheu <holzheu@de.ibm.com> Acked-by: Ingo Oeser <ioe-lkml@rameria.de> Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Clean up arch-overrides in linux/string.hKyle McMartin
Some string functions were safely overrideable in lib/string.c, but their corresponding declarations in linux/string.h were not. Correct this, and make strcspn overrideable. Odds of someone wanting to do optimized assembly of these are small, but for the sake of cleanliness, might as well bring them into line with the rest of the file. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] strndup_user()Davi Arnaut
This patch series creates a strndup_user() function to easy copying C strings from userspace. Also we avoid common pitfalls like userspace modifying the final \0 after the strlen_user(). Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] propagate __nocast annotationsAlexey Dobriyan
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
