The server and client maximum are architecturally independent.
Allow changing one without affecting the other.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
At the 2015 LSF/MM, it was requested that memory allocation
call sites that request GFP_KERNEL allocations in a loop should be
annotated with __GFP_NOFAIL.
Fields in struct rpcrdma_msg are __be32. Don't byte-swap these
fields when decoding RPC calls and then swap them back for the
reply. For the most part, they can be left alone.
svc_rdma_xdr_decode_deferred_req() indexes an array with an
un-byte-swapped value off the wire. Fortunately this function
isn't used anywhere, so simply remove it.
Pull nfsd updates from Bruce Fields:
"The main change is the pNFS block server support from Christoph, which
allows an NFS client connected to shared disk to do block IO to the
shared disk in place of NFS reads and writes. This also requires xfs
patches, which should arrive soon through the xfs tree, barring
unexpected problems. Support for other filesystems is also possible
if there's interest.
Thanks also to Chuck Lever for continuing work to get NFS/RDMA into
shape"
* 'for-3.20' of git://linux-nfs.org/~bfields/linux: (32 commits)
nfsd: default NFSv4.2 to on
nfsd: pNFS block layout driver
exportfs: add methods for block layout exports
nfsd: add trace events
nfsd: update documentation for pNFS support
nfsd: implement pNFS layout recalls
nfsd: implement pNFS operations
nfsd: make find_any_file available outside nfs4state.c
nfsd: make find/get/put file available outside nfs4state.c
nfsd: make lookup/alloc/unhash_stid available outside nfs4state.c
nfsd: add fh_fsid_match helper
nfsd: move nfsd_fh_match to nfsfh.h
fs: add FL_LAYOUT lease type
fs: track fl_owner for leases
nfs: add LAYOUT_TYPE_MAX enum value
nfsd: factor out a helper to decode nfstime4 values
sunrpc/lockd: fix references to the BKL
nfsd: fix year-2038 nfs4 state problem
svcrdma: Handle additional inline content
svcrdma: Move read list XDR round-up logic
Clean up: Replace htonl and ntohl with the be32 equivalents.
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
Currently the Linux server can not decode RDMA_NOMSG type requests.
Operations whose length exceeds the fixed size of RDMA SEND buffers,
like large NFSv4 CREATE(NF4LNK) operations, must be conveyed via
RDMA_NOMSG.
For an RDMA_MSG type request, the client sends the RPC/RDMA, RPC
headers, and some or all of the NFS arguments via RDMA SEND.
For an RDMA_NOMSG type request, the client sends just the RPC/RDMA
header via RDMA SEND. The request's read list contains elements for
the entire RPC message, including the RPC header.
NFSD expects the RPC/RMDA header and RPC header to be contiguous in
page zero of the XDR buffer. Add logic in the RDMA READ path to make
the read list contents land where the server prefers, when the
incoming message is a type RDMA_NOMSG message.
The RDMA reader function doesn't change once an svcxprt_rdma is
instantiated. Instead of checking sc_devcap during every incoming
RPC, set the reader function once when the connection is accepted.
The byte_count argument is not used, and the function is called
only from one place.
The RDMA credit limit controls how many concurrent RPCs are allowed
per connection.
An NFS/RDMA client and server exchange their credit limits in the
RPC/RDMA headers. The Linux client and the Solaris client and server
allow 32 credits. The Linux server allows only 16, which limits its
performance.
Set the server's default credit limit to 32, like the other well-
known implementations, so the out-of-the-shrinkwrap performance of
the Linux server is better.
This patch refactors the NFSRDMA server marshalling logic to
remove the intermediary map structures. It also fixes an existing bug
where the NFSRDMA server was not minding the device fast register page
list length limitations.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Sparse complains that the definition function definition and the
implementation aren't anotated the same way.
Acked-by: Tom Tucker <tom@opengridcomputing.com>
The svcrdma transport was un-marshalling requests in-place. This resulted
in sparse warnings due to __beXX data containing both NBO and HBO data.
The code has been restructured to do byte-swapping as the header is
parsed instead of when the header is validated immediately after receipt.
Also moved extern declarations for the workqueue and memory pools to the
private header file.
Signed-off-by: Tom Tucker <tom@ogc.us>
RPCRDMA requests that specify a read-list are fetched with RDMA_READ. Using
an FRMR to map the data sink improves NFSRDMA security on transports that
place the RDMA_READ data sink LKEY on the wire because the valid lifetime
of the MR is only the duration of the RDMA_READ. The LKEY is invalidated
when the last RDMA_READ WR completes.
Mapping the data sink also allows for very large amounts to data to be
fetched with a single WR, so if the client is also using FRMR, the entire
RPC read-list can be fetched with a single WR.
Fast Reg MR introduces a new WR type. Add a service to register the
region with the adapter and update the completion handling to support
completions with a NULL WR context.
Add services for the allocating, freeing, and unmapping Fast Reg MR. These
services will be used by the transport connection setup, send and receive
routines.
Add data types to track Fast Reg Memory Regions. The core data type is
svc_rdma_fastreg_mr that associates a device MR with a host kva and page
list. A field is added to the WR context to keep track of the FRMR
used to map the local memory for an RPC.
An FRMR list and spin lock are added to the transport instance to keep
track of all FRMR allocated for the transport. Also added are device
capability flags to indicate what the memory registration
capabilities are for the underlying device and whether or not fast
memory registration is supported.
RDMA_READ completions are kept on a separate queue from the general
I/O request queue. Since a separate lock is used to protect the RDMA_READ
completion queue, a race exists between the dto_tasklet and the
svc_rdma_recvfrom thread where the dto_tasklet sets the XPT_DATA
bit and adds I/O to the read-completion queue. Concurrently, the
recvfrom thread checks the generic queue, finds it empty and resets
the XPT_DATA bit. A subsequent svc_xprt_enqueue will fail to enqueue
the transport for I/O and cause the transport to "stall".
The fix is to protect both lists with the same lock and set the XPT_DATA
bit with this lock held.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Change the WR context pool to be shared across mount points. This
reduces the RDMA transport memory footprint significantly since
idle mounts don't consume WR context memory.
The sc_read_wait queue head is no longer used. Remove it.
Add a dma map count in order to verify that all DMA mapping resources
have been freed when the transport is closed.
Modify the RDMA_READ processing to use the reply and chunk list mapping data
types. Also add a special purpose 'hdr_count' field in in the context to hold
the header page count instead of overloading the SGE length field and
corrupting the DMA map length.
Create a new data structure to hold the remote client address space
to local server address space mapping.
The svc_rdma_send_error function is called when an RPCRDMA protocol
error is detected. This function attempts to post an error reply message.
Since an error posting to a transport in error is ignored, change
the return type to void.
Some providers may wait while destroying adapter resources.
Since it is possible that the last reference is put on the
dto_tasklet, the actual destroy must be scheduled as a work item.
Replace the one-off linked list implementation used to implement the
context cache with the standard Linux list_head lists. Add a context
counter to catch resource leaks. A WARN_ON will be added later to
ensure that we've freed all contexts.
An NFS_WRITE requires a set of RDMA_READ requests to fetch the write
data from the client. There are two principal pieces of data that
need to be tracked: the list of pages that comprise the completed RPC
and the SGE of dma mapped pages to refer to this list of pages. Previously
this whole bit was managed as a linked list of contexts with the
context containing the page list buried in this list. This patch
simplifies this processing by not keeping a linked list, but rather only
a pionter from the last submitted RDMA_READ's context to the context
that maps the set of pages that describe the RPC. This significantly
simplifies this code path. SGE contexts are cleaned up inline in the DTO
path instead of at read completion time.
The RDMACTXT_F_READ_DONE bit is not longer used. Remove it.
This file defines the data types used by the SVCRDMA transport module.
The principle data structure is the transport specific extension to
the svcxprt structure.
Acked-by: Neil Brown <neilb@suse.de>
