commit 18ab4d4ced0817421e6db6940374cc39d28d65da upstream.
Originally get_swap_page() started iterating through the singly-linked
list of swap_info_structs using swap_list.next or highest_priority_index,
which both were intended to point to the highest priority active swap
target that was not full. The first patch in this series changed the
singly-linked list to a doubly-linked list, and removed the logic to start
at the highest priority non-full entry; it starts scanning at the highest
priority entry each time, even if the entry is full.
Replace the manually ordered swap_list_head with a plist, swap_active_head.
Add a new plist, swap_avail_head. The original swap_active_head plist
contains all active swap_info_structs, as before, while the new
swap_avail_head plist contains only swap_info_structs that are active and
available, i.e. not full. Add a new spinlock, swap_avail_lock, to protect
the swap_avail_head list.
Mel Gorman suggested using plists since they internally handle ordering
the list entries based on priority, which is exactly what swap was doing
manually. All the ordering code is now removed, and swap_info_struct
entries and simply added to their corresponding plist and automatically
ordered correctly.
Using a new plist for available swap_info_structs simplifies and
optimizes get_swap_page(), which no longer has to iterate over full
swap_info_structs. Using a new spinlock for swap_avail_head plist
allows each swap_info_struct to add or remove themselves from the
plist when they become full or not-full; previously they could not
do so because the swap_info_struct->lock is held when they change
from full<->not-full, and the swap_lock protecting the main
swap_active_head must be ordered before any swap_info_struct->lock.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Cc: Shaohua Li <shli@fusionio.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
Cc: Weijie Yang <weijieut@gmail.com>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit adfab836f4908deb049a5128082719e689eed964 upstream.
The logic controlling the singly-linked list of swap_info_struct entries
for all active, i.e. swapon'ed, swap targets is rather complex, because:
- it stores the entries in priority order
- there is a pointer to the highest priority entry
- there is a pointer to the highest priority not-full entry
- there is a highest_priority_index variable set outside the swap_lock
- swap entries of equal priority should be used equally
this complexity leads to bugs such as: https://lkml.org/lkml/2014/2/13/181
where different priority swap targets are incorrectly used equally.
That bug probably could be solved with the existing singly-linked lists,
but I think it would only add more complexity to the already difficult to
understand get_swap_page() swap_list iteration logic.
The first patch changes from a singly-linked list to a doubly-linked list
using list_heads; the highest_priority_index and related code are removed
and get_swap_page() starts each iteration at the highest priority
swap_info entry, even if it's full. While this does introduce unnecessary
list iteration (i.e. Schlemiel the painter's algorithm) in the case where
one or more of the highest priority entries are full, the iteration and
manipulation code is much simpler and behaves correctly re: the above bug;
and the fourth patch removes the unnecessary iteration.
The second patch adds some minor plist helper functions; nothing new
really, just functions to match existing regular list functions. These
are used by the next two patches.
The third patch adds plist_requeue(), which is used by get_swap_page() in
the next patch - it performs the requeueing of same-priority entries
(which moves the entry to the end of its priority in the plist), so that
all equal-priority swap_info_structs get used equally.
The fourth patch converts the main list into a plist, and adds a new plist
that contains only swap_info entries that are both active and not full.
As Mel suggested using plists allows removing all the ordering code from
swap - plists handle ordering automatically. The list naming is also
clarified now that there are two lists, with the original list changed
from swap_list_head to swap_active_head and the new list named
swap_avail_head. A new spinlock is also added for the new list, so
swap_info entries can be added or removed from the new list immediately as
they become full or not full.
This patch (of 4):
Replace the singly-linked list tracking active, i.e. swapon'ed,
swap_info_struct entries with a doubly-linked list using struct
list_heads. Simplify the logic iterating and manipulating the list of
entries, especially get_swap_page(), by using standard list_head
functions, and removing the highest priority iteration logic.
The change fixes the bug:
in which different priority swap entries after the highest priority entry
are incorrectly used equally in pairs. The swap behavior is now as
advertised, i.e. different priority swap entries are used in order, and
equal priority swap targets are used concurrently.
This patch, 2of4, contains the changes to the core swap subsystem.
This includes:
(1) makes available core swap data structures (swap_lock, swap_list and
swap_info) that are needed by frontswap.c but we don't need to expose them
to the dozens of files that include swap.h so we create a new swapfile.h
just to extern-ify these and modify their declarations to non-static
(2) adds frontswap-related elements to swap_info_struct. Frontswap_map
points to vzalloc'ed one-bit-per-swap-page metadata that indicates
whether the swap page is in frontswap or in the device and frontswap_pages
counts how many pages are in frontswap.
(3) adds hooks in the swap subsystem and extends try_to_unuse so that
frontswap_shrink can do a "partial swapoff".
Note that a failed frontswap_map allocation is safe... failure is noted
by lack of "FS" in the subsequent printk.
[v14: rebase to 3.4-rc2]
[v10: no change]
[v9: akpm@linux-foundation.org: mark some statics __read_mostly]
[v9: akpm@linux-foundation.org: add clarifying comments]
[v9: akpm@linux-foundation.org: no need to loop repeating try_to_unuse]
[v9: error27@gmail.com: remove superfluous check for NULL]
[v8: rebase to 3.0-rc4]
[v8: kamezawa.hiroyu@jp.fujitsu.com: change counter to atomic_t to avoid races]
[v8: kamezawa.hiroyu@jp.fujitsu.com: comment to clarify informational counters]
[v7: rebase to 3.0-rc3]
[v7: JBeulich@novell.com: add new swap struct elements only if config'd]
[v6: rebase to 3.0-rc1]
[v6: lliubbo@gmail.com: fix null pointer deref if vzalloc fails]
[v6: konrad.wilk@oracl.com: various checks and code clarifications/comments]
[v5: no change from v4]
[v4: rebase to 2.6.39]
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Jan Beulich <JBeulich@novell.com>
Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Rik Riel <riel@redhat.com>
[v11: Rebased, fixed mm/swapfile.c context change]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
