path: root/include/linux/taskstats_kern.h
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12copy_signal() cleanup: kill taskstats_tgid_init() and acct_init_pacct()Veaceslav Falico
Kill unused functions taskstats_tgid_init() and acct_init_pacct() because we don't use them anywhere after using kmem_cache_zalloc() in copy_signal(). Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18headers: taskstats_kern.h trimAlexey Dobriyan
Remove net/genetlink.h inclusion, now sched.c won't be recompiled because of some networking changes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] taskstats: cleanup ->signal->stats allocationOleg Nesterov
Allocate ->signal->stats on demand in taskstats_exit(), this allows us to remove taskstats_tgid_alloc() (the last non-trivial inline) from taskstat's public interface. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] taskstats: cleanup do_exit() pathOleg Nesterov
do_exit: taskstats_exit_alloc() ... taskstats_exit_send() taskstats_exit_free() I think this is not good, let it be a single function exported to the core kernel, taskstats_exit(), which does alloc + send + free itself. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats: kill ->taskstats_lock in favor of ->siglockOleg Nesterov
signal_struct is (mostly) protected by ->sighand->siglock, I think we don't need ->taskstats_lock to protect ->stats. This also allows us to simplify the locking in fill_tgid(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats_tgid_alloc: optimizationOleg Nesterov
Every subthread (except first) does unneeded kmem_cache_alloc/kmem_cache_free. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats_tgid_free: fix usageOleg Nesterov
taskstats_tgid_free() is called on copy_process's error path. This is wrong. IF (clone_flags & CLONE_THREAD) We should not clear ->signal->taskstats, current uses it, it probably has a valid accumulated info. ELSE taskstats_tgid_init() set ->signal->taskstats = NULL, there is nothing to free. Move the callsite to __exit_signal(). We don't need any locking, entire thread group is exiting, nobody should have a reference to soon to be released ->signal. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task delay accounting taskstats interface: control exit data ↵Shailabh Nagar
through cpumasks On systems with a large number of cpus, with even a modest rate of tasks exiting per cpu, the volume of taskstats data sent on thread exit can overflow a userspace listener's buffers. One approach to avoiding overflow is to allow listeners to get data for a limited and specific set of cpus. By scaling the number of listeners and/or the cpus they monitor, userspace can handle the statistical data overload more gracefully. In this patch, each listener registers to listen to a specific set of cpus by specifying a cpumask. The interest is recorded per-cpu. When a task exits on a cpu, its taskstats data is unicast to each listener interested in that cpu. Thanks to Andrew Morton for pointing out the various scalability and general concerns of previous attempts and for suggesting this design. [akpm@osdl.org: build fix] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task delay accounting: avoid send without listenersShailabh Nagar
Don't send taskstats (per-pid or per-tgid) on thread exit when no one is listening for such data. Currently the taskstats interface allocates a structure, fills it in and calls netlink to send out per-pid and per-tgid stats regardless of whether a userspace listener for the data exists (netlink layer would check for that and avoid the multicast). As a result of this patch, the check for the no-listener case is performed early, avoiding the redundant allocation and filling up of the taskstats structures. Signed-off-by: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] delay accounting taskstats interface send tgid onceShailabh Nagar
Send per-tgid data only once during exit of a thread group instead of once with each member thread exit. Currently, when a thread exits, besides its per-tid data, the per-tgid data of its thread group is also sent out, if its thread group is non-empty. The per-tgid data sent consists of the sum of per-tid stats for all *remaining* threads of the thread group. This patch modifies this sending in two ways: - the per-tgid data is sent only when the last thread of a thread group exits. This cuts down heavily on the overhead of sending/receiving per-tgid data, especially when other exploiters of the taskstats interface aren't interested in per-tgid stats - the semantics of the per-tgid data sent are changed. Instead of being the sum of per-tid data for remaining threads, the value now sent is the true total accumalated statistics for all threads that are/were part of the thread group. The patch also addresses a minor issue where failure of one accounting subsystem to fill in the taskstats structure was causing the send of taskstats to not be sent at all. The patch has been tested for stability and run cerberus for over 4 hours on an SMP. [akpm@osdl.org: bugfixes] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: delay accounting usage of taskstats interfaceShailabh Nagar
Usage of taskstats interface by delay accounting. Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: taskstats interfaceShailabh Nagar
Create a "taskstats" interface based on generic netlink (NETLINK_GENERIC family), for getting statistics of tasks and thread groups during their lifetime and when they exit. The interface is intended for use by multiple accounting packages though it is being created in the context of delay accounting. This patch creates the interface without populating the fields of the data that is sent to the user in response to a command or upon the exit of a task. Each accounting package interested in using taskstats has to provide an additional patch to add its stats to the common structure. [akpm@osdl.org: cleanups, Kconfig fix] Signed-off-by: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
