Taking socket spinlock in tcp_get_info() can deadlock, as
inet_diag_dump_icsk() holds the &hashinfo->ehash_locks[i],
while packet processing can use the reverse locking order.
We could avoid this locking for TCP_LISTEN states, but lockdep would
certainly get confused as all TCP sockets share same lockdep classes.
[ 523.722504] ======================================================
[ 523.728706] [ INFO: possible circular locking dependency detected ]
[ 523.734990] 4.1.0-dbg-DEV #1676 Not tainted
[ 523.739202] -------------------------------------------------------
[ 523.745474] ss/18032 is trying to acquire lock:
[ 523.750002] (slock-AF_INET){+.-...}, at: [<ffffffff81669d44>] tcp_get_info+0x2c4/0x360
[ 523.758129]
[ 523.758129] but task is already holding lock:
[ 523.763968] (&(&hashinfo->ehash_locks[i])->rlock){+.-...}, at: [<ffffffff816bcb75>] inet_diag_dump_icsk+0x1d5/0x6c0
[ 523.774661]
[ 523.774661] which lock already depends on the new lock.
[ 523.774661]
[ 523.782850]
[ 523.782850] the existing dependency chain (in reverse order) is:
[ 523.790326]
-> #1 (&(&hashinfo->ehash_locks[i])->rlock){+.-...}:
[ 523.796599] [<ffffffff811126bb>] lock_acquire+0xbb/0x270
[ 523.802565] [<ffffffff816f5868>] _raw_spin_lock+0x38/0x50
[ 523.808628] [<ffffffff81665af8>] __inet_hash_nolisten+0x78/0x110
[ 523.815273] [<ffffffff816819db>] tcp_v4_syn_recv_sock+0x24b/0x350
[ 523.822067] [<ffffffff81684d41>] tcp_check_req+0x3c1/0x500
[ 523.828199] [<ffffffff81682d09>] tcp_v4_do_rcv+0x239/0x3d0
[ 523.834331] [<ffffffff816842fe>] tcp_v4_rcv+0xa8e/0xc10
[ 523.840202] [<ffffffff81658fa3>] ip_local_deliver_finish+0x133/0x3e0
[ 523.847214] [<ffffffff81659a9a>] ip_local_deliver+0xaa/0xc0
[ 523.853440] [<ffffffff816593b8>] ip_rcv_finish+0x168/0x5c0
[ 523.859624] [<ffffffff81659db7>] ip_rcv+0x307/0x420
Lets use u64_sync infrastructure instead. As a bonus, 64bit
arches get optimized, as these are nop for them.
Fixes: 0df48c26d841 ("tcp: add tcpi_bytes_acked to tcp_info")
This patch tracks total number of payload bytes received on a TCP socket.
This is the sum of all changes done to tp->rcv_nxt
RFC4898 named this : tcpEStatsAppHCThruOctetsReceived
This is a 64bit field, and can be fetched both from TCP_INFO
getsockopt() if one has a handle on a TCP socket, or from inet_diag
netlink facility (iproute2/ss patch will follow)
Note that tp->bytes_received was placed near tp->rcv_nxt for
best data locality and minimal performance impact.
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Matt Mathis <mattmathis@google.com>
Cc: Eric Salo <salo@google.com>
Cc: Martin Lau <kafai@fb.com>
Cc: Chris Rapier <rapier@psc.edu>
Acked-by: Yuchung Cheng <ycheng@google.com>
This patch tracks total number of bytes acked for a TCP socket.
This is the sum of all changes done to tp->snd_una, and allows
for precise tracking of delivered data.
RFC4898 named this : tcpEStatsAppHCThruOctetsAcked
Note that tp->bytes_acked was placed near tp->snd_una for
Fast Open has been using an experimental option with a magic number
(RFC6994). This patch makes the client by default use the RFC7413
option (34) to get and send Fast Open cookies. This patch makes
the client solicit cookies from a given server first with the
RFC7413 option. If that fails to elicit a cookie, then it tries
the RFC6994 experimental option. If that also fails, it uses the
RFC7413 option on all subsequent connect attempts. If the server
returns a Fast Open cookie then the client caches the form of the
option that successfully elicited a cookie, and uses that form on
later connects when it presents that cookie.
The idea is to gradually obsolete the use of experimental options as
the servers and clients upgrade, while keeping the interoperability
meanwhile.
Signed-off-by: Daniel Lee <Longinus00@gmail.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Fast Open has been using the experimental option with a magic number
(RFC6994) to request and grant Fast Open cookies. This patch enables
the server to support the official IANA option 34 in RFC7413 in
addition.
The change has passed all existing Fast Open tests with both
old and new options at Google.
The listener field in struct tcp_request_sock is a pointer
back to the listener. We now have req->rsk_listener, so TCP
only needs one boolean and not a full pointer.
TSO relies on ability to defer sending a small amount of packets.
Heuristic is to wait for future ACKS in hope to send more packets at once.
Current algorithm uses a per socket tso_deferred field as a pseudo timer.
This pseudo timer relies on future ACK, but there is no guarantee
we receive them in time.
Fix would be to use a real timer, but cost of such timer is probably too
expensive for typical cases.
This patch changes the logic to test the time of last transmit,
because we should not add bursts of more than 1ms for any given flow.
We've used this patch for about two years at Google, before FQ/pacing
as it would reduce a fair amount of bursts.
Ensure that in state FIN_WAIT2 or TIME_WAIT, where the connection is
represented by a tcp_timewait_sock, we rate limit dupacks in response
to incoming packets (a) with TCP timestamps that fail PAWS checks, or
(b) with sequence numbers that are out of the acceptable window.
We do not send a dupack in response to out-of-window packets if it has
been less than sysctl_tcp_invalid_ratelimit (default 500ms) since we
last sent a dupack in response to an out-of-window packet.
Reported-by: Avery Fay <avery@mixpanel.com>
Ensure that in state ESTABLISHED, where the connection is represented
by a tcp_sock, we rate limit dupacks in response to incoming packets
(a) with TCP timestamps that fail PAWS checks, or (b) with sequence
numbers or ACK numbers that are out of the acceptable window.
There is already a similar (although global) rate-limiting mechanism
for "challenge ACKs". When deciding whether to send a challence ACK,
we first consult the new per-connection rate limit, and then the
global rate limit.
In the SYN_RECV state, where the TCP connection is represented by
tcp_request_sock, we now rate-limit SYNACKs in response to a client's
retransmitted SYNs: we do not send a SYNACK in response to client SYN
if it has been less than sysctl_tcp_invalid_ratelimit (default 500ms)
since we last sent a SYNACK in response to a client's retransmitted
SYN.
This allows the vast majority of legitimate client connections to
proceed unimpeded, even for the most aggressive platforms, iOS and
MacOS, which actually retransmit SYNs 1-second intervals for several
times in a row. They use SYN RTO timeouts following the progression:
1,1,1,1,1,2,4,8,16,32.
More iov_iter work for the networking from Al Viro.
Commit 95bd09eb2750 ("tcp: TSO packets automatic sizing") tried to
control TSO size, but did this at the wrong place (sendmsg() time)
At sendmsg() time, we might have a pessimistic view of flow rate,
and we end up building very small skbs (with 2 MSS per skb).
This is bad because :
- It sends small TSO packets even in Slow Start where rate quickly
increases.
- It tends to make socket write queue very big, increasing tcp_ack()
processing time, but also increasing memory needs, not necessarily
accounted for, as fast clones overhead is currently ignored.
- Lower GRO efficiency and more ACK packets.
Servers with a lot of small lived connections suffer from this.
Lets instead fill skbs as much as possible (64KB of payload), but split
them at xmit time, when we have a precise idea of the flow rate.
skb split is actually quite efficient.
Patch looks bigger than necessary, because TCP Small Queue decision now
has to take place after the eventual split.
As Neal suggested, introduce a new tcp_tso_autosize() helper, so that
tcp_tso_should_defer() can be synchronized on same goal.
Rename tp->xmit_size_goal_segs to tp->gso_segs, as this variable
contains number of mss that we can put in GSO packet, and is not
related to the autosizing goal anymore.
Tested:
40 ms rtt link
nstat >/dev/null
netperf -H remote -l -2000000 -- -s 1000000
nstat | egrep "IpInReceives|IpOutRequests|TcpOutSegs|IpExtOutOctets"
Before patch :
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/s
87380 2000000 2000000 0.36 44.22
IpInReceives 600 0.0
IpOutRequests 599 0.0
TcpOutSegs 1397 0.0
IpExtOutOctets 2033249 0.0
After patch :
Recv Send Send
bytes bytes bytes secs. 10^6bits/sec
87380 2000000 2000000 0.36 44.27
IpInReceives 221 0.0
IpOutRequests 232 0.0
TcpOutSegs 1397 0.0
IpExtOutOctets 2013953 0.0
While testing upcoming Yaogong patch (converting out of order queue
into an RB tree), I hit the max reordering level of linux TCP stack.
Reordering level was limited to 127 for no good reason, and some
network setups [1] can easily reach this limit and get limited
throughput.
Allow a new max limit of 300, and add a sysctl to allow admins to even
allow bigger (or lower) values if needed.
[1] Aggregation of links, per packet load balancing, fabrics not doing
deep packet inspections, alternative TCP congestion modules...
Cc: Yaogong Wang <wygivan@google.com>
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine updates from Dan Williams:
"Even though this has fixes marked for -stable, given the size and the
needed conflict resolutions this is 3.18-rc1/merge-window material.
These patches have been languishing in my tree for a long while. The
fact that I do not have the time to do proper/prompt maintenance of
this tree is a primary factor in the decision to step down as
dmaengine maintainer. That and the fact that the bulk of drivers/dma/
activity is going through Vinod these days.
The net_dma removal has not been in -next. It has developed simple
conflicts against mainline and net-next (for-3.18).
Continuing thanks to Vinod for staying on top of drivers/dma/.
Summary:
1/ Step down as dmaengine maintainer see commit 08223d80df38
"dmaengine maintainer update"
2/ Removal of net_dma, as it has been marked 'broken' since 3.13
(commit 77873803363c "net_dma: mark broken"), without reports of
performance regression.
3/ Miscellaneous fixes"
* tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
net: make tcp_cleanup_rbuf private
net_dma: revert 'copied_early'
net_dma: simple removal
dmatest: prevent memory leakage on error path in thread
ioat: Use time_before_jiffies()
dmaengine: fix xor sources continuation
dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup()
dma: mv_xor: Remove all callers of mv_xor_slot_cleanup()
dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call
ioat: Use pci_enable_msix_exact() instead of pci_enable_msix()
drivers: dma: Include appropriate header file in dca.c
drivers: dma: Mark functions as static in dma_v3.c
dma: mv_xor: Add DMA API error checks
ioat/dca: Use dev_is_pci() to check whether it is pci device
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: <stable@vger.kernel.org>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
Upon timeout, undo (via both timestamps/Eifel and DSACKs) was
disabled if any retransmits were still in flight. The concern was
perhaps that spurious retransmission sent in a previous recovery
episode may trigger DSACKs to falsely undo the current recovery.
However, this inadvertently misses undo opportunities (using either
TCP timestamps or DSACKs) when timeout occurs during a loss episode,
i.e. recurring timeouts or timeout during fast recovery. In these
cases some retransmissions will be in flight but we should allow
undo. Furthermore, we should only reset undo_marker and undo_retrans
upon timeout if we are starting a new recovery episode. Finally,
when we do reset our undo state, we now do so in a manner similar
to tcp_enter_recovery(), so that we require a DSACK for each of
the outstsanding retransmissions. This will achieve the original
goal by requiring that we receive the same number of DSACKs as
retransmissions.
This patch increases the undo events by 50% on Google servers.
Move the specific IPv4/IPv6 intializations to a new method in
tcp_request_sock_ops in preparation for unifying tcp_v4_conn_request
and tcp_v6_conn_request.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Experience with the recent e114a710aa50 ("tcp: fix cwnd limited
checking to improve congestion control") has shown that there are
common cases where that commit can cause cwnd to be much larger than
necessary. This leads to TSO autosizing cooking skbs that are too
large, among other things.
The main problems seemed to be:
(1) That commit attempted to predict the future behavior of the
connection by looking at the write queue (if TSO or TSQ limit
sending). That prediction sometimes overestimated future outstanding
packets.
(2) That commit always allowed cwnd to grow to twice the number of
outstanding packets (even in congestion avoidance, where this is not
needed).
This commit improves both of these, by:
(1) Switching to a measurement-based approach where we explicitly
track the largest number of packets in flight during the past window
("max_packets_out"), and remember whether we were cwnd-limited at the
moment we finished sending that flight.
(2) Only allowing cwnd to grow to twice the number of outstanding
packets ("max_packets_out") in slow start. In congestion avoidance
mode we now only allow cwnd to grow if it was fully utilized.
Consolidate various cookie checking and generation code to simplify
the fast open processing. The main goal is to reduce code duplication
in tcp_v4_conn_request() for IPv6 support.
Removes two experimental sysctl flags TFO_SERVER_ALWAYS and
TFO_SERVER_COOKIE_NOT_CHKD used primarily for developmental debugging
purposes.
Signed-off-by: Daniel Lee <longinus00@gmail.com>
Signed-off-by: Jerry Chu <hkchu@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Yuchung discovered tcp_is_cwnd_limited() was returning false in
slow start phase even if the application filled the socket write queue.
All congestion modules take into account tcp_is_cwnd_limited()
before increasing cwnd, so this behavior limits slow start from
probing the bandwidth at full speed.
The problem is that even if write queue is full (aka we are _not_
application limited), cwnd can be under utilized if TSO should auto
defer or TCP Small queues decided to hold packets.
So the in_flight can be kept to smaller value, and we can get to the
point tcp_is_cwnd_limited() returns false.
With TCP Small Queues and FQ/pacing, this issue is more visible.
We fix this by having tcp_cwnd_validate(), which is supposed to track
such things, take into account unsent_segs, the number of segs that we
are not sending at the moment due to TSO or TSQ, but intend to send
real soon. Then when we are cwnd-limited, remember this fact while we
are processing the window of ACKs that comes back.
For example, suppose we have a brand new connection with cwnd=10; we
are in slow start, and we send a flight of 9 packets. By the time we
have received ACKs for all 9 packets we want our cwnd to be 18.
We implement this by setting tp->lsnd_pending to 9, and
considering ourselves to be cwnd-limited while cwnd is less than
twice tp->lsnd_pending (2*9 -> 18).
This makes tcp_is_cwnd_limited() more understandable, by removing
the GSO/TSO kludge, that tried to work around the issue.
Note the in_flight parameter can be removed in a followup cleanup
patch.
Upcoming congestion controls for TCP require usec resolution for RTT
estimations. Millisecond resolution is simply not enough these days.
FQ/pacing in DC environments also require this change for finer control
and removal of bimodal behavior due to the current hack in
tcp_update_pacing_rate() for 'small rtt'
TCP_CONG_RTT_STAMP is no longer needed.
As Julian Anastasov pointed out, we need to keep user compatibility :
tcp_metrics used to export RTT and RTTVAR in msec resolution,
so we added RTT_US and RTTVAR_US. An iproute2 patch is needed
to use the new attributes if provided by the kernel.
In this example ss command displays a srtt of 32 usecs (10Gbit link)
lpk51:~# ./ss -i dst lpk52
Netid State Recv-Q Send-Q Local Address:Port Peer
Address:Port
tcp ESTAB 0 1 10.246.11.51:42959
10.246.11.52:64614
cubic wscale:6,6 rto:201 rtt:0.032/0.001 ato:40 mss:1448
cwnd:10 send
3620.0Mbps pacing_rate 7240.0Mbps unacked:1 rcv_rtt:993 rcv_space:29559
Updated iproute2 ip command displays :
lpk51:~# ./ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 274us rttvar 213us source
10.246.11.51
Old binary displays :
lpk51:~# ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 250us rttvar 125us source
10.246.11.51
With help from Julian Anastasov, Stephen Hemminger and Yuchung Cheng
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Larry Brakmo <brakmo@google.com>
Cc: Julian Anastasov <ja@ssi.bg>
TCP out_of_order_queue lock is not used, as queue manipulation
happens with socket lock held and we therefore use the lockless
skb queue routines (as __skb_queue_head())
We can use __skb_queue_head_init() instead of skb_queue_head_init()
to make this more consistent.
Remove declaration, 4 defines and confusing comment that are no longer used
since 1a2c6181c4 ("tcp: Remove TCPCT").
Signed-off-by: Dmitry Popov <dp@highloadlab.com>
Acked-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Idea of this patch is to add optional limitation of number of
unsent bytes in TCP sockets, to reduce usage of kernel memory.
TCP receiver might announce a big window, and TCP sender autotuning
might allow a large amount of bytes in write queue, but this has little
performance impact if a large part of this buffering is wasted :
Write queue needs to be large only to deal with large BDP, not
necessarily to cope with scheduling delays (incoming ACKS make room
for the application to queue more bytes)
For most workloads, using a value of 128 KB or less is OK to give
applications enough time to react to POLLOUT events in time
(or being awaken in a blocking sendmsg())
This patch adds two ways to set the limit :
1) Per socket option TCP_NOTSENT_LOWAT
2) A sysctl (/proc/sys/net/ipv4/tcp_notsent_lowat) for sockets
not using TCP_NOTSENT_LOWAT socket option (or setting a zero value)
Default value being UINT_MAX (0xFFFFFFFF), meaning this has no effect.
This changes poll()/select()/epoll() to report POLLOUT
only if number of unsent bytes is below tp->nosent_lowat
Note this might increase number of sendmsg()/sendfile() calls
when using non blocking sockets,
and increase number of context switches for blocking sockets.
Note this is not related to SO_SNDLOWAT (as SO_SNDLOWAT is
defined as :
Specify the minimum number of bytes in the buffer until
the socket layer will pass the data to the protocol)
Tested:
netperf sessions, and watching /proc/net/protocols "memory" column for TCP
With 200 concurrent netperf -t TCP_STREAM sessions, amount of kernel memory
used by TCP buffers shrinks by ~55 % (20567 pages instead of 45458)
lpq83:~# echo -1 >/proc/sys/net/ipv4/tcp_notsent_lowat
lpq83:~# (super_netperf 200 -t TCP_STREAM -H remote -l 90 &); sleep 60 ; grep TCP /proc/net/protocols
TCPv6 1880 2 45458 no 208 yes ipv6 y y y y y y y y y y y y y n y y y y y
TCP 1696 508 45458 no 208 yes kernel y y y y y y y y y y y y y n y y y y y
lpq83:~# echo 131072 >/proc/sys/net/ipv4/tcp_notsent_lowat
TCPv6 1880 2 20567 no 208 yes ipv6 y y y y y y y y y y y y y n y y y y y
TCP 1696 508 20567 no 208 yes kernel y y y y y y y y y y y y y n y y y y y
Using 128KB has no bad effect on the throughput or cpu usage
of a single flow, although there is an increase of context switches.
A bonus is that we hold socket lock for a shorter amount
of time and should improve latencies of ACK processing.
lpq83:~# perf stat -e context-switches ./netperf -H 7.7.7.84 -t omni -l 20 -c -i10,3
OMNI Send TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.7.84 () port 0 AF_INET : +/-2.500% @ 99% conf.
Local Remote Local Elapsed Throughput Throughput Local Local Remote Remote Local Remote Service
Send Socket Recv Socket Send Time Units CPU CPU CPU CPU Service Service Demand
Size Size Size (sec) Util Util Util Util Demand Demand Units
Final Final % Method % Method
1651584 6291456 16384 20.00 17447.90 10^6bits/s 3.13 S -1.00 U 0.353 -1.000 usec/KB
Performance counter stats for './netperf -H 7.7.7.84 -t omni -l 20 -c -i10,3':
412,514 context-switches
200.034645535 seconds time elapsed
1593240 6291456 16384 20.00 17321.16 10^6bits/s 3.35 S -1.00 U 0.381 -1.000 usec/KB
2,675,818 context-switches
200.029651391 seconds time elapsed
Cc: Neal Cardwell <ncardwell@google.com>
Acked-By: Yuchung Cheng <ycheng@google.com>
tcp_timeout_skb() was intended to trigger fast recovery on timeout,
unfortunately in reality it often causes spurious retransmission
storms during fast recovery. The particular sign is a fast retransmit
over the highest sacked sequence (SND.FACK).
Currently the RTO timer re-arming (as in RFC6298) offers a nice cushion
to avoid spurious timeout: when SND.UNA advances the sender re-arms
RTO and extends the timeout by icsk_rto. The sender does not offset
the time elapsed since the packet at SND.UNA was sent.
But if the next (DUP)ACK arrives later than ~RTTVAR and triggers
tcp_fastretrans_alert(), then tcp_timeout_skb() will mark any packet
sent before the icsk_rto interval lost, including one that's above the
highest sacked sequence. Most likely a large part of scorebard will be
marked.
If most packets are not lost then the subsequent DUPACKs with new SACK
blocks will cause the sender to continue to retransmit packets beyond
SND.FACK spuriously. Even if only one packet is lost the sender may
falsely retransmit almost the entire window.
The situation becomes common in the world of bufferbloat: the RTT
continues to grow as the queue builds up but RTTVAR remains small and
close to the minimum 200ms. If a data packet is lost and the DUPACK
triggered by the next data packet is slightly delayed, then a spurious
retransmission storm forms.
As the original comment on tcp_timeout_skb() suggests: the usefulness
of this feature is questionable. It also wastes cycles walking the
sack scoreboard and is actually harmful because of false recovery.
It's time to remove this.
Acked-by: Nandita Dukkipati <nanditad@google.com>
This patch implements F-RTO (foward RTO recovery):
When the first retransmission after timeout is acknowledged, F-RTO
sends new data instead of old data. If the next ACK acknowledges
some never-retransmitted data, then the timeout was spurious and the
congestion state is reverted. Otherwise if the next ACK selectively
acknowledges the new data, then the timeout was genuine and the
loss recovery continues. This idea applies to recurring timeouts
as well. While F-RTO sends different data during timeout recovery,
it does not (and should not) change the congestion control.
The implementaion follows the three steps of SACK enhanced algorithm
(section 3) in RFC5682. Step 1 is in tcp_enter_loss(). Step 2 and
3 are in tcp_process_loss(). The basic version is not supported
because SACK enhanced version also works for non-SACK connections.
The new implementation is functionally in parity with the old F-RTO
implementation except the one case where it increases undo events:
In addition to the RFC algorithm, a spurious timeout may be detected
without sending data in step 2, as long as the SACK confirms not
all the original data are dropped. When this happens, the sender
will undo the cwnd and perhaps enter fast recovery instead. This
additional check increases the F-RTO undo events by 5x compared
to the prior implementation on Google Web servers, since the sender
often does not have new data to send for HTTP.
Note F-RTO may detect spurious timeout before Eifel with timestamps
does so.
The patch series refactor the F-RTO feature (RFC4138/5682).
This is to simplify the loss recovery processing. Existing F-RTO
was developed during the experimental stage (RFC4138) and has
many experimental features. It takes a separate code path from
the traditional timeout processing by overloading CA_Disorder
instead of using CA_Loss state. This complicates CA_Disorder state
handling because it's also used for handling dubious ACKs and undos.
While the algorithm in the RFC does not change the congestion control,
the implementation intercepts congestion control in various places
(e.g., frto_cwnd in tcp_ack()).
The new code implements newer F-RTO RFC5682 using CA_Loss processing
path. F-RTO becomes a small extension in the timeout processing
and interfaces with congestion control and Eifel undo modules.
It lets congestion control (module) determines how many to send
independently. F-RTO only chooses what to send in order to detect
spurious retranmission. If timeout is found spurious it invokes
existing Eifel undo algorithms like DSACK or TCP timestamp based
detection.
The first patch removes all F-RTO code except the sysctl_tcp_frto is
left for the new implementation. Since CA_EVENT_FRTO is removed, TCP
westwood now computes ssthresh on regular timeout CA_EVENT_LOSS event.
TCPCT uses option-number 253, reserved for experimental use and should
not be used in production environments.
Further, TCPCT does not fully implement RFC 6013.
As a nice side-effect, removing TCPCT increases TCP's performance for
very short flows:
Doing an apache-benchmark with -c 100 -n 100000, sending HTTP-requests
for files of 1KB size.
before this patch:
average (among 7 runs) of 20845.5 Requests/Second
after:
average (among 7 runs) of 21403.6 Requests/Second
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
This is the second of the TLP patch series; it augments the basic TLP
algorithm with a loss detection scheme.
This patch implements a mechanism for loss detection when a Tail
loss probe retransmission plugs a hole thereby masking packet loss
from the sender. The loss detection algorithm relies on counting
TLP dupacks as outlined in Sec. 3 of:
http://tools.ietf.org/html/draft-dukkipati-tcpm-tcp-loss-probe-01
The basic idea is: Sender keeps track of TLP "episode" upon
retransmission of a TLP packet. An episode ends when the sender receives
an ACK above the SND.NXT (tracked by tlp_high_seq) at the time of the
episode. We want to make sure that before the episode ends the sender
receives a "TLP dupack", indicating that the TLP retransmission was
unnecessary, so there was no loss/hole that needed plugging. If the
sender gets no TLP dupack before the end of the episode, then it reduces
ssthresh and the congestion window, because the TLP packet arriving at
the receiver probably plugged a hole.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
This patch series implement the Tail loss probe (TLP) algorithm described
in http://tools.ietf.org/html/draft-dukkipati-tcpm-tcp-loss-probe-01. The
first patch implements the basic algorithm.
TLP's goal is to reduce tail latency of short transactions. It achieves
this by converting retransmission timeouts (RTOs) occuring due
to tail losses (losses at end of transactions) into fast recovery.
TLP transmits one packet in two round-trips when a connection is in
Open state and isn't receiving any ACKs. The transmitted packet, aka
loss probe, can be either new or a retransmission. When there is tail
loss, the ACK from a loss probe triggers FACK/early-retransmit based
fast recovery, thus avoiding a costly RTO. In the absence of loss,
there is no change in the connection state.
PTO stands for probe timeout. It is a timer event indicating
that an ACK is overdue and triggers a loss probe packet. The PTO value
is set to max(2*SRTT, 10ms) and is adjusted to account for delayed
ACK timer when there is only one oustanding packet.
TLP Algorithm
On transmission of new data in Open state:
-> packets_out > 1: schedule PTO in max(2*SRTT, 10ms).
-> packets_out == 1: schedule PTO in max(2*RTT, 1.5*RTT + 200ms)
-> PTO = min(PTO, RTO)
Conditions for scheduling PTO:
-> Connection is in Open state.
-> Connection is either cwnd limited or no new data to send.
-> Number of probes per tail loss episode is limited to one.
-> Connection is SACK enabled.
When PTO fires:
new_segment_exists:
-> transmit new segment.
-> packets_out++. cwnd remains same.
no_new_packet:
-> retransmit the last segment.
Its ACK triggers FACK or early retransmit based recovery.
ACK path:
-> rearm RTO at start of ACK processing.
-> reschedule PTO if need be.
In addition, the patch includes a small variation to the Early Retransmit
(ER) algorithm, such that ER and TLP together can in principle recover any
N-degree of tail loss through fast recovery. TLP is controlled by the same
sysctl as ER, tcp_early_retrans sysctl.
tcp_early_retrans==0; disables TLP and ER.
==1; enables RFC5827 ER.
==2; delayed ER.
==3; TLP and delayed ER. [DEFAULT]
==4; TLP only.
The TLP patch series have been extensively tested on Google Web servers.
It is most effective for short Web trasactions, where it reduced RTOs by 15%
and improved HTTP response time (average by 6%, 99th percentile by 10%).
The transmitted probes account for <0.5% of the overall transmissions.
tw_cookie_values is never used in the TCP-stack.
It was added by 435cf559f (TCPCT part 1d: define TCP cookie option,
extend existing struct's), but already at that time it was not used at
all, nor mentioned in the commit-message.
This functionality is used for restoring tcp sockets. A tcp timestamp
depends on how long a system has been running, so it's differ for each
host. The solution is to set a per-socket offset.
A per-socket offset for a TIME_WAIT socket is inherited from a proper
tcp socket.
tcp_request_sock doesn't have a timestamp offset, because the repair
mode for them are not implemented.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
TCP Appropriate Byte Count was added by me, but later disabled.
There is no point in maintaining it since it is a potential source
of bugs and Linux already implements other better window protection
heuristics.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
This patch adds support in the kernel for offloading in the NIC Tx and Rx
checksumming for encapsulated packets (such as VXLAN and IP GRE).
For Tx encapsulation offload, the driver will need to set the right bits
in netdev->hw_enc_features. The protocol driver will have to set the
skb->encapsulation bit and populate the inner headers, so the NIC driver will
use those inner headers to calculate the csum in hardware.
For Rx encapsulation offload, the driver will need to set again the
skb->encapsulation flag and the skb->ip_csum to CHECKSUM_UNNECESSARY.
In that case the protocol driver should push the decapsulated packet up
to the stack, again with CHECKSUM_UNNECESSARY. In ether case, the protocol
driver should set the skb->encapsulation flag back to zero. Finally the
protocol driver should have NETIF_F_RXCSUM flag set in its features.
Signed-off-by: Joseph Gasparakis <joseph.gasparakis@intel.com>
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Add a bit TCPI_OPT_SYN_DATA (32) to the socket option TCP_INFO:tcpi_options.
It's set if the data in SYN (sent or received) is acked by SYN-ACK. Server or
client application can use this information to check Fast Open success rate.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Acked-by: H.K. Jerry Chu <hkchu@google.com>
This patch adds all the necessary data structure and support
functions to implement TFO server side. It also documents a number
of flags for the sysctl_tcp_fastopen knob, and adds a few Linux
extension MIBs.
In addition, it includes the following:
1. a new TCP_FASTOPEN socket option an application must call to
supply a max backlog allowed in order to enable TFO on its listener.
2. A number of key data structures:
"fastopen_rsk" in tcp_sock - for a big socket to access its
request_sock for retransmission and ack processing purpose. It is
non-NULL iff 3WHS not completed.
"fastopenq" in request_sock_queue - points to a per Fast Open
listener data structure "fastopen_queue" to keep track of qlen (# of
outstanding Fast Open requests) and max_qlen, among other things.
"listener" in tcp_request_sock - to point to the original listener
for book-keeping purpose, i.e., to maintain qlen against max_qlen
as part of defense against IP spoofing attack.
3. various data structure and functions, many in tcp_fastopen.c, to
support server side Fast Open cookie operations, including
/proc/sys/net/ipv4/tcp_fastopen_key to allow manual rekeying.
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
Cc: Tom Herbert <therbert@google.com>
ICMP messages generated in output path if frame length is bigger than
mtu are actually lost because socket is owned by user (doing the xmit)
One example is the ipgre_tunnel_xmit() calling
icmp_send(skb, ICMP_DEST_UNREACH, ICMP_FRAG_NEEDED, htonl(mtu));
We had a similar case fixed in commit a34a101e1e6 (ipv6: disable GSO on
sockets hitting dst_allfrag).
Problem of such fix is that it relied on retransmit timers, so short tcp
sessions paid a too big latency increase price.
This patch uses the tcp_release_cb() infrastructure so that MTU
reduction messages (ICMP messages) are not lost, and no extra delay
is added in TCP transmits.
Reported-by: Maciej Żenczykowski <maze@google.com>
Diagnosed-by: Neal Cardwell <ncardwell@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Tore Anderson <tore@fud.no>
Modern TCP stack highly depends on tcp_write_timer() having a small
latency, but current implementation doesn't exactly meet the
expectations.
When a timer fires but finds the socket is owned by the user, it rearms
itself for an additional delay hoping next run will be more
successful.
tcp_write_timer() for example uses a 50ms delay for next try, and it
defeats many attempts to get predictable TCP behavior in term of
latencies.
Use the recently introduced tcp_release_cb(), so that the user owning
the socket will call various handlers right before socket release.
This will permit us to post a followup patch to address the
tcp_tso_should_defer() syndrome (some deferred packets have to wait
RTO timer to be transmitted, while cwnd should allow us to send them
sooner)
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: John Heffner <johnwheffner@gmail.com>
In trusted networks, e.g., intranet, data-center, the client does not
need to use Fast Open cookie to mitigate DoS attacks. In cookie-less
mode, sendmsg() with MSG_FASTOPEN flag will send SYN-data regardless
of cookie availability.
This patch implements sending SYN-data in tcp_connect(). The data is
from tcp_sendmsg() with flag MSG_FASTOPEN (implemented in a later patch).
The length of the cookie in tcp_fastopen_req, init'd to 0, controls the
type of the SYN. If the cookie is not cached (len==0), the host sends
data-less SYN with Fast Open cookie request option to solicit a cookie
from the remote. If cookie is not available (len > 0), the host sends
a SYN-data with Fast Open cookie option. If cookie length is negative,
the SYN will not include any Fast Open option (for fall back operations).
To deal with middleboxes that may drop SYN with data or experimental TCP
option, the SYN-data is only sent once. SYN retransmits do not include
data or Fast Open options. The connection will fall back to regular TCP
handshake.
This patch impelements the common code for both the client and server.
1. TCP Fast Open option processing. Since Fast Open does not have an
option number assigned by IANA yet, it shares the experiment option
code 254 by implementing draft-ietf-tcpm-experimental-options
with a 16 bits magic number 0xF989. This enables global experiments
without clashing the scarce(2) experimental options available for TCP.
When the draft status becomes standard (maybe), the client should
switch to the new option number assigned while the server supports
both numbers for transistion.
2. The new sysctl tcp_fastopen
3. A place holder init function
This introduce TSQ (TCP Small Queues)
TSQ goal is to reduce number of TCP packets in xmit queues (qdisc &
device queues), to reduce RTT and cwnd bias, part of the bufferbloat
problem.
sk->sk_wmem_alloc not allowed to grow above a given limit,
allowing no more than ~128KB [1] per tcp socket in qdisc/dev layers at a
given time.
TSO packets are sized/capped to half the limit, so that we have two
TSO packets in flight, allowing better bandwidth use.
As a side effect, setting the limit to 40000 automatically reduces the
standard gso max limit (65536) to 40000/2 : It can help to reduce
latencies of high prio packets, having smaller TSO packets.
This means we divert sock_wfree() to a tcp_wfree() handler, to
queue/send following frames when skb_orphan() [2] is called for the
already queued skbs.
Results on my dev machines (tg3/ixgbe nics) are really impressive,
using standard pfifo_fast, and with or without TSO/GSO.
Without reduction of nominal bandwidth, we have reduction of buffering
per bulk sender :
< 1ms on Gbit (instead of 50ms with TSO)
< 8ms on 100Mbit (instead of 132 ms)
I no longer have 4 MBytes backlogged in qdisc by a single netperf
session, and both side socket autotuning no longer use 4 Mbytes.
As skb destructor cannot restart xmit itself ( as qdisc lock might be
taken at this point ), we delegate the work to a tasklet. We use one
tasklest per cpu for performance reasons.
If tasklet finds a socket owned by the user, it sets TSQ_OWNED flag.
This flag is tested in a new protocol method called from release_sock(),
to eventually send new segments.
[1] New /proc/sys/net/ipv4/tcp_limit_output_bytes tunable
[2] skb_orphan() is usually called at TX completion time,
but some drivers call it in their start_xmit() handler.
These drivers should at least use BQL, or else a single TCP
session can still fill the whole NIC TX ring, since TSQ will
have no effect.
Cc: Dave Taht <dave.taht@bufferbloat.net>
No longer used.
MAINTAINERS
drivers/net/wireless/iwlwifi/pcie/trans.c
The iwlwifi conflict was resolved by keeping the code added
in 'net' that turns off the buggy chip feature.
The MAINTAINERS conflict was merely overlapping changes, one
change updated all the wireless web site URLs and the other
changed some GIT trees to be Johannes's instead of John's.
I originally sent this patch to <trivial@kernel.org>, but Jiri Kosina did
not feel that this is fully appropriate for the trivial tree.
Using linux/tcp.h from C++ results in:
cat t.cc
#include <linux/tcp.h>
int main() { }
g++ -c t.cc
In file included from t.cc:1:
/usr/include/linux/tcp.h:72: error: '__u32 __fswab32(__u32)' cannot appear in a constant-expression
/usr/include/linux/tcp.h:72: error: a function call cannot appear in a constant-expression
Attached trivial patch fixes this problem.
Tested:
- the t.cc above compiles with g++ and
- the following program generates the same output before/after
the patch:
#include <stdio.h>
int main ()
#define P(a) printf("%s: %08x\n", #a, (int)a)
P(TCP_FLAG_CWR);
P(TCP_FLAG_ECE);
P(TCP_FLAG_URG);
P(TCP_FLAG_ACK);
P(TCP_FLAG_PSH);
P(TCP_FLAG_RST);
P(TCP_FLAG_SYN);
P(TCP_FLAG_FIN);
P(TCP_RESERVED_BITS);
P(TCP_DATA_OFFSET);
#undef P
return 0;
Signed-off-by: Paul Pluzhnikov <ppluzhnikov@google.com>
Since it's guarenteed that we will access the inetpeer if we're trying
to do timewait recycling and TCP options were enabled on the
connection, just cache the peer in the timewait socket.
In the future, inetpeer lookups will be context dependent (per routing
realm), and this helps facilitate that as well.
