path: root/include/linux/tfrc.h
2006-12-11[DCCP] ccid3: Finer-grained resolution of sending ratesGerrit Renker
This patch * resolves a bug where packets smaller than 32/64 bytes resulted in sending rates of 0 * supports all sending rates from 1/64 bytes/second up to 4Gbyte/second * simplifies the present overflow problems in calculations Current sending rate X and the cached value X_recv of the receiver-estimated sending rate are both scaled by 64 (2^6) in order to * cope with low sending rates (minimally 1 byte/second) * allow upgrading to use a packets-per-second implementation of CCID 3 * avoid calculation errors due to integer arithmetic cut-off The patch implements a revised strategy from http://www.mail-archive.com/dccp@vger.kernel.org/msg01040.html The only difference with regard to that strategy is that t_ipi is already used in the calculation of the nofeedback timeout, which saves one division. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[NET]: Add documentation for TFRC structuresGerrit Renker
This adds documentation for the TFRC structure fields. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-18[CCID3]: Introduce include/linux/tfrc.hArnaldo Carvalho de Melo
Moving the TFRC sender and receiver variables to separate structs, so that we can copy these structs to userspace thru getsockopt, dccp_diag, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
