path: root/include/linux/ti_wilink_st.h
2012-08-16drivers/misc/ti-st: remove sparse warningsPavan Savoy
remove sparse warnings by assigning right storage specifiers to functions and also clean-up the declarations in the include/linux/ti_wilink_st.h Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-09ARM: OMAP: WiLink platform data for the PandaBoardMircea Gherzan
The "uim" deamon requires sysfs entries that are filled in using this platform data. Signed-off-by: Mircea Gherzan <mgherzan@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-08-22drivers:misc:ti-st: platform hooks for chip statesPavan Savoy
Certain platform specific or Host-WiLink Interface specific actions would be required to be taken when the chip is being enabled and after the chip is disabled such as configuration of the mux modes for the GPIO of host connected to the nshutdown of the chip or relinquishing UART after the chip is disabled. Similar actions can also be taken when the chip is in deep sleep or when the chip is awake. Performance enhancements such as configuring the host to run faster when chip is awake and slower when chip is asleep can also be made here. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22drivers:misc:ti-st: handle delayed tty receivePavan Savoy
When certain technologies shutdown their interface without waiting for the acknowledgement from the chip. The receive_buf from the TTY would be invoked a while after the relevant technology is unregistered. This patch introduces a new flag "is_registered" which maintains the state of protocols BT, FM or GPS and thereby removes the need to clear the protocol data from ST when protocols gets unregistered. This fixes corner cases when HCI RESET is sent down from bluetooth stack and the receive_buf is called from tty after 250ms before which bluetooth would have unregistered from the system. OR - when FM application decides to close down the device without sending a power-off FM command resulting in some RDS data or interrupt data coming in after the driver is unregistered. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: remove multiple gpio handlingPavan Savoy
TI shared transport driver previously intended to expose rfkill entries for each of the protocol gpio that the chip would have. However now in case such gpios exist, which requires to be enabled for a specific protocol, the responsibility lay on protocol driver. This patch removes the request/free of multiple gpios, rfkill struct references and also removes the chip_toggle function. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: firmware download optimizationPavan Savoy
To fasten the process of firmware download, the chip allows disabling of the command complete event generation from host. In these cases, only few very essential commands would have the command complete events and hence the wait associated with them. So now the driver would wait for a command complete event, only when it comes across a wait event during firmware parsing. This would also mean we need to skip not just the change baud rate command but also the wait for it. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: move from rfkill to sysfsPavan Savoy
The communication between ST KIM and UIM was interfaced over the /dev/rfkill device node. Move the interface to a simpler less abusive sysfs entry mechanism and document it in Documentation/ABI/testing/ under sysfs-platform-kim. Shared transport driver would now read the UART details originally received by bootloader or firmware as platform data. The data read will be shared over sysfs entries for the user-space UIM or other n/w manager/plugins to be read, and assist the driver by opening up the UART, setting the baud-rate and installing the line discipline. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: register with channel IDsPavan Savoy
The architecture of shared transport had begun with individual protocols like bluetooth, fm and gps telling the shared transport what sort of protocol they are and then expecting the ST driver to parse the incoming data from chip and forward data only relevant to the protocol drivers. This change would mean each protocol drivers would also send information to ST driver as to how to intrepret their protocol data coming out of the chip. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-14drivers: misc: ti-st: fix review commentsPavan Savoy
Based on comments from Jiri Slaby, drop the register storage specifier, remove the unused code, cleanup the const to non-const type casting. Also make the line discipline ops structure static, since its a singleton, unmodified structure which need not be in heap. Reported-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-05staging: ti-st: mv ti_wilink_st headerPavan Savoy
Move the header to a standard linux device driver location. This should pave the way for other drivers to be moved into the relevant directories. ti_wilink_st.h is a common header file used by the TI's shared transport device driver for WiLink chipsets. Each individual protocol drivers like bluetooth driver, FM V4L2 driver and GPS drivers will make use of this header. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
