path: root/include/linux/tsacct_kern.h
2013-01-27cputime: Use accessors to read task cputime statsFrederic Weisbecker
This is in preparation for the full dynticks feature. While remotely reading the cputime of a task running in a full dynticks CPU, we'll need to do some extra-computation. This way we can account the time it spent tickless in userspace since its last cputime snapshot. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2012-09-18userns: Convert taskstats to handle the user and pid namespaces.Eric W. Biederman
- Explicitly limit exit task stat broadcast to the initial user and pid namespaces, as it is already limited to the initial network namespace. - For broadcast task stats explicitly generate all of the idenitiers in terms of the initial user namespace and the initial pid namespace. - For request stats report them in terms of the current user namespace and the current pid namespace. Netlink messages are delivered syncrhonously to the kernel allowing us to get the user namespace and the pid namespace from the current task. - Pass the namespaces for representing pids and uids and gids into bacct_add_task. Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2006-10-01[PATCH] csa: convert CONFIG tag for extended accounting routinesJay Lan
There were a few accounting data/macros that are used in CSA but are #ifdef'ed inside CONFIG_BSD_PROCESS_ACCT. This patch is to change those ifdef's from CONFIG_BSD_PROCESS_ACCT to CONFIG_TASK_XACCT. A few defines are moved from kernel/acct.c and include/linux/acct.h to kernel/tsacct.c and include/linux/tsacct_kern.h. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: Extended system accounting over taskstatsJay Lan
Add extended system accounting handling over taskstats interface. A CONFIG_TASK_XACCT flag is created to enable the extended accounting code. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: basic accounting over taskstatsJay Lan
Add some basic accounting fields to the taskstats struct, add a new kernel/tsacct.c to handle basic accounting data handling upon exit. A handle is added to taskstats.c to invoke the basic accounting data handling. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: "Michal Piotrowski" <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
