commit fa90e1c935472281de314e6d7c9a37db9cbc2e4e upstream.
If tty_add_file fails at the point it is now, we have to revert all
the changes we did to the tty. It means either decrease all refcounts
if this was a tty reopen or delete the tty if it was newly allocated.
There was a try to fix this in v3.0-rc2 using tty_release in 0259894c7
(TTY: fix fail path in tty_open). But instead it introduced a NULL
dereference. It's because tty_release dereferences
filp->private_data, but that one is set even in our tty_add_file. And
when tty_add_file fails, it's still NULL/garbage. Hence tty_release
cannot be called there.
To circumvent the original leak (and the current NULL deref) we split
tty_add_file into two functions, making the latter non-failing. In
that case we may do the former early in open, where handling failures
is easy. The latter stays as it is now. So there is no change in
functionality.
The original bug (leak) was introduced by f573bd176 (tty: Remove
__GFP_NOFAIL from tty_add_file()). Thanks Dan for reporting this.
Later, we may split tty_release into more functions and call only some
of them in this fail path instead. (If at all possible.)
Introduced-in: v2.6.37-rc2
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Pekka Enberg <penberg@kernel.org>
tty_operations->remove is normally called like:
queue_release_one_tty
->tty_shutdown
->tty_driver_remove_tty
->tty_operations->remove
However tty_shutdown() is called from queue_release_one_tty() only if
tty_operations->shutdown is NULL. But for pty, it is not.
pty_unix98_shutdown() is used there as ->shutdown.
So tty_operations->remove of pty (i.e. pty_unix98_remove()) is never
called. This results in invalid pty_count. I.e. what can be seen in
/proc/sys/kernel/pty/nr.
I see this was already reported at:
https://lkml.org/lkml/2009/11/5/370
But it was not fixed since then.
This patch is kind of a hackish way. The problem lies in ->install. We
allocate there another tty (so-called tty->link). So ->install is
called once, but ->remove twice, for both tty and tty->link. The fix
here is to count both tty and tty->link and divide the count by 2 for
user.
And to have ->remove called, let's make tty_driver_remove_tty() global
and call that from pty_unix98_shutdown() (tty_operations->shutdown).
While at it, let's document that when ->shutdown is defined,
tty_shutdown() is not called.
Cc: Alan Cox <alan@linux.intel.com>
Cc: stable <stable@kernel.org>
Since commit (4564f9e5: consolidate line discipline number definitions)
the patch moved all line discipline number from a per-architecture termios.h
to a shared one: tty.h. However, prior to this consolidation work, the
line discipline numbers were outside of an ifdef __KERNEL__/endif block
so these numbers used to be exported to user-space.
Since such numbers are kernel ABI anyway, and tty.h is already included
for user- space header processing, just move these relevant defines
outside of the ifdef __KERNEL__/endif block in include/linux/tty.h.
CC: Maxime Bizon <mbizon@freebox.fr>
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
Acked-by: Tilman Schmidt <tilman@imap.cc>
The n_tracerouter and n_tracesink line discpline drivers use the
Linux tty line discpline framework to route trace data coming
from a tty port (say UART for example) to the trace sink line
discipline driver and to another tty port(say USB). Those
these two line discipline drivers can be used together,
independently from pti.c, they are part of the original
implementation solution of the MIPI P1149.7, compact JTAG, PTI
solution for Intel mobile platforms starting with the
Medfield platform.
Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com>
Introduce deinitialize_tty_struct which should be called after
initialize_tty_struct and before successfull tty_ldisc_setup.
It calls tty_ldisc_deinit which is opposite of tty_ldisc_init. It only
puts a reference to ldisc and assigns NULL to tty->ldisc.
It will be used to shut down ldisc when tty_release cannot be called
yet.
Cc: Julian Anastasov <ja@ssi.bg>
Using delayed-work for tty flip buffers ends up causing us to wait for
the next tick to complete some actions. That's usually not all that
noticeable, but for certain latency-critical workloads it ends up being
totally unacceptable.
As an extreme case of this, passing a token back-and-forth over a pty
will take two ticks per iteration, so even just a thousand iterations
will take 8 seconds assuming a common 250Hz configuration.
Avoiding the whole delayed work issue brings that ping-pong test-case
down to 0.009s on my machine.
In more practical terms, this latency has been a performance problem for
things like dive computer simulators (simulating the serial interface
using the ptys) and for other environments (Alan mentions a CP/M emulator).
Reported-by: Jef Driesen <jefdriesen@telenet.be>
Acked-by: Greg KH <gregkh@suse.de>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This basically encapsulates the small bit of locking knowledge needed. While
we are at it make sure we blow up on any more abusers and unsafe misuses of
ioctl for this kind of stuff.
We change the function to return an argument as at some point it needs to
honour the POSIX 'I asked for changes but got none of them' error reporting
corner case.
Signed-off-by: Alan Cox <alan@linux.intel.com>
This was caused by the previous patch to remove the file pointer
from the tty ioctl handler.
Only oddities here are a couple of drivers that bogusly called the ldisc
helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes
away.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
serial: mfd: adjust the baud rate setting
TTY: open/hangup race fixup
TTY: don't allow reopen when ldisc is changing
NET: wan/x25, fix ldisc->open retval
TTY: ldisc, fix open flag handling
serial8250: Mark console as CON_ANYTIME
Like in the "TTY: don't allow reopen when ldisc is changing" patch,
this one fixes a TTY WARNING as described in the option 1) there:
1) __tty_hangup from tty_ldisc_hangup to tty_ldisc_enable. During this
section tty_lock is held. However tty_lock is temporarily dropped in
the middle of the function by tty_ldisc_hangup.
The fix is to introduce a new flag which we set during the unlocked
window and check it in tty_reopen too. The flag is TTY_HUPPING and is
cleared after TTY_HUPPED is set.
While at it, remove duplicate TTY_HUPPED set_bit. The one after
calling ops->hangup seems to be more correct. But anyway, we hold
tty_lock, so there should be no difference.
Also document the function it does that kind of crap.
Nicely reproducible with two forked children:
static void do_work(const char *tty)
if (signal(SIGHUP, SIG_IGN) == SIG_ERR) exit(1);
setsid();
while (1) {
int fd = open(tty, O_RDWR|O_NOCTTY);
if (fd < 0) continue;
if (ioctl(fd, TIOCSCTTY)) continue;
if (vhangup()) continue;
close(fd);
exit(0);
Reported-by: <Valdis.Kletnieks@vt.edu>
Reported-by: Kyle McMartin <kyle@mcmartin.ca>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
Someone added a new ldisc number and messed up the tabbing. Fix it before
anyone else copies it.
While auditing all tasklist_lock read_lock sites I stumbled over the
following call chain:
audit_prepare_user_tty()
read_lock(&tasklist_lock);
tty_audit_push_task();
mutex_lock(&buf->mutex);
--> buf->mutex is locked with preemption disabled.
Solve this by acquiring a reference to the task struct under
rcu_read_lock and call tty_audit_push_task outside of the preempt
disabled region.
Move all code which needs to be protected by sighand lock into
tty_audit_push_task() and use lock/unlock_sighand as we do not hold
tasklist_lock.
Cc: Eric Paris <eparis@redhat.com>
This merges the staging-next tree to Linus's tree and resolves
some conflicts that were present due to changes in other trees that were
affected by files here.
This patch removes __GFP_NOFAIL use from tty_add_file() and adds proper error
handling to the call-sites of the function.
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Acked-by: David Rientjes <rientjes@google.com>
Some device drivers (mostly tty line disciplines) would like to have way
know a struct device instance corresponding to passed tty_struct. Add
a struct device pointer to struct tty_struct and populate it during
initialize_tty_struct().
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Texas Instrument's WiLink7 connectivity devices pack wireless connectivity
technologies like Bluetooth, FM Radio Receiver and Transmitter, GPS and WLAN
into a single die.
The BT, FM and GPS core on the chip are interfaced to application
processors via a single UART.
This line discipline driver allows such different technologies to be used
simultaneous and independent of each other.
Signed-off-by: Pavan Savoy <pavan_savoy@ti.com>
tty: fix fu_list abuse
tty code abuses fu_list, which causes a bug in remount,ro handling.
If a tty device node is opened on a filesystem, then the last link to the inode
removed, the filesystem will be allowed to be remounted readonly. This is
because fs_may_remount_ro does not find the 0 link tty inode on the file sb
list (because the tty code incorrectly removed it to use for its own purpose).
This can result in a filesystem with errors after it is marked "clean".
Taking idea from Christoph's initial patch, allocate a tty private struct
at file->private_data and put our required list fields in there, linking
file and tty. This makes tty nodes behave the same way as other device nodes
and avoid meddling with the vfs, and avoids this bug.
The error handling is not trivial in the tty code, so for this bugfix, I take
the simple approach of using __GFP_NOFAIL and don't worry about memory errors.
This is not a problem because our allocator doesn't fail small allocs as a rule
anyway. So proper error handling is left as an exercise for tty hackers.
[ Arguably filesystem's device inode would ideally be divorced from the
driver's pseudo inode when it is opened, but in practice it's not clear whether
that will ever be worth implementing. ]
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
fs: cleanup files_lock locking
Lock tty_files with a new spinlock, tty_files_lock; provide helpers to
manipulate the per-sb files list; unexport the files_lock spinlock.
Acked-by: Andi Kleen <ak@linux.intel.com>
The tty locking now follows the rules for mutexes, so
we can replace the BKL usage with a new subsystem
wide mutex.
Using a regular mutex here will change the behaviour
when blocked on the BTM from spinning to sleeping,
but that should not be visible to the user.
Using the mutex also means that all the BTM is now
covered by lockdep.
This changes all remaining users of tty_lock_nested
to be non-recursive, which lets us kill this function.
As a consequence, we won't need to keep the lock count
any more, which allows more simplifications later.
Calling wait_event_interruptible implicitly
releases the BKL when it sleeps, but we need
to do this explcitly when we have converted
it to a mutex.
As a preparation for replacing the big kernel lock
in the TTY layer, wrap all the callers in new
macros tty_lock, tty_lock_nested and tty_unlock.
This patch is against the 2.6.34 source.
Paraphrased from the 1989 BSD patch by David Borman @ cray.com:
These are the changes needed for the kernel to support
LINEMODE in the server.
There is a new bit in the termios local flag word, EXTPROC.
When this bit is set, several aspects of the terminal driver
are disabled. Input line editing, character echo, and mapping
of signals are all disabled. This allows the telnetd to turn
off these functions when in linemode, but still keep track of
what state the user wants the terminal to be in.
New ioctl:
TIOCSIG Generate a signal to processes in the
current process group of the pty.
There is a new mode for packet driver, the TIOCPKT_IOCTL bit.
When packet mode is turned on in the pty, and the EXTPROC bit
is set, then whenever the state of the pty is changed, the
next read on the master side of the pty will have the TIOCPKT_IOCTL
bit set. This allows the process on the server side of the pty
to know when the state of the terminal has changed; it can then
issue the appropriate ioctl to retrieve the new state.
Since the original BSD patches accompanied the source code for telnet
I've left that reference here, but obviously the feature is useful for
any remote terminal protocol, including ssh.
The corresponding feature has existed in the BSD tty driver since 1989.
For historical reference, a good copy of the relevant files can be found
here:
http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741
Signed-off-by: Howard Chu <hyc@symas.com>
Make /dev/console get initialised before any initialisation routine that
invokes modprobe because if modprobe fails, it's going to want to open
/dev/console, presumably to write an error message to.
The problem with that is that if the /dev/console driver is not yet
initialised, the chardev handler will call request_module() to invoke
modprobe, which will fail, because we never compile /dev/console as a
module.
This will lead to a modprobe loop, showing the following in the kernel
log:
request_module: runaway loop modprobe char-major-5-1
This can happen, for example, when the built in md5 module can't find
the built in cryptomgr module (because the latter fails to initialise).
The md5 module comes before the call to tty_init(), presumably because
'crypto' comes before 'drivers' alphabetically.
Fix this by calling tty_init() from chrdev_init().
Add an implementation of GSM 0710 MUX. The implementation currently supports
- Basic and advanced framing (as either end of the link)
- UI or UIH data frames
- Adaption layer 1-4 (1 and 2 via tty, 3 and 4 as skbuff lists)
- Modem and control messages including the correct retry process
- Flow control
and exposes the MUX channels as a set of virtual tty devices including modem
signals. This is an experimental driver.
Push the max ldiscs by a few number to allow ldiscs
to exist in the staging directory and elsewhere.
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
Add CAIF Serial driver. This driver is implemented as a line discipline.
caif_serial uses the following module parameters:
ser_use_stx - specifies if STart of frame eXtension is in use.
ser_loop - sets the interface in loopback mode.
Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
Commit e1108a63e10d344284011cccc06328b2cd3e5da3 ("usb_serial: Use the
shutdown() operation") breaks the ability to use a usb console
starting in 2.6.33. This was observed when using
console=ttyUSB0,115200 as a boot argument with an FTDI device. The
error is:
ftdi_sio ttyUSB0: ftdi_submit_read_urb - failed submitting read urb, error -22
The handling of the ASYNCB_INITIALIZED changed in 2.6.32 such that in
tty_port_shutdown() it always clears the flag if it is set. The fix
is to add a variable to the tty_port struct to indicate when the tty
port is a console.
CC: Alan Cox <alan@linux.intel.com>
CC: Alan Stern <stern@rowland.harvard.edu>
CC: Oliver Neukum <oliver@neukum.org>
CC: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The TTY layer takes some care to ensure that only sub-page allocations
are made with interrupts disabled. It does this by setting a goal of
"TTY_BUFFER_PAGE" to allocate. Unfortunately, while TTY_BUFFER_PAGE takes the
size of tty_buffer into account, it fails to account that tty_buffer_find()
rounds the buffer size out to the next 256 byte boundary before adding on
the size of the tty_buffer.
This patch adjusts the TTY_BUFFER_PAGE calculation to take into account the
size of the tty_buffer and the padding. Once applied, tty_buffer_alloc()
should not require high-order allocations.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
This new method can be used to init a new struct tty_ldisc_ops as the
default tty_ldisc_N_TTY struct.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Greg KH <greg@kroah.com>
Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su>
We allocate during interrupts so while our buffering is normally diced up
small anyway on some hardware at speed we can pressure the VM excessively
for page pairs. We don't really need big buffers to be linear so don't try
so hard.
In order to make this work well we will tidy up excess callers to request_room,
which cannot itself enforce this break up.
I get a few dozen of these warnings when using
gcc (GCC) 4.4.1 20090725 (Red Hat 4.4.1-2):
In file included from mmotm-2010-0113-1217/init/do_mounts.c:5:
mmotm-2010-0113-1217/include/linux/tty.h: In function 'tty_port_get':
mmotm-2010-0113-1217/include/linux/tty.h:469: warning: '______f' is static but declared in inline function 'tty_port_get' which is not static
so make the function static inline.
[akpm@linux-foundation.org: may as well convert tty_port_users() also]
The kernel offers with TIOCL_GETKMSGREDIRECT ioctl() the possibility to
redirect the kernel messages to a specific console.
However, since it's not possible to switch to the kernel message console
after a panic(), it would be nice if the kernel would print the panic
message on the current console.
This patch series adds a new interface to access the global kmsg_redirect
variable by a function to be able to use it in code where
CONFIG_VT_CONSOLE is not set (kernel/panic.c).
This patch:
Instead of using and exporting a global value kmsg_redirect, introduce a
function vt_kmsg_redirect() that both can set and return the console where
messages are printed.
Change all users of kmsg_redirect (the VT code itself and kernel/power.c)
to the new interface.
The main advantage is that vt_kmsg_redirect() can also be used when
CONFIG_VT_CONSOLE is not set.
Signed-off-by: Bernhard Walle <bernhard@bwalle.de>
Start trying to untangle the remaining BKL mess
Updated to fix missing unlock_kernel noted by Dan Carpenter
Signed-off-by: Alan "I must be out of my tree" Cox <alan@linux.intel.com>
Users of tty port need a way to refcount ports when hotplugging is
involved.
We want to be able to do this without regard for the activate/own open
method being used which causes a problem using port->mutex. Add another
mutex for now. Once everything uses port_open to do buffer allocs we can
kill it back off
For the moment this just moves the USB logic over and fixes the 'what if
we open and hangup at the same time' race noticed by Oliver Neukum.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Oliver Neukum <oliver@neukum.org>
The VT specific compat_ioctl handlers are the only ones
in common code that require the BKL. Moving them into
the vt driver lets us remove the BKL from the other handlers
and cleans up the code.
This little helper is now tty_port specific and useful generally so move it
This is used by various drivers not just serial and can be extracted
as commonality
Remove some more serial specific use
Now we are extracting out methods for shutdown and the like we can add a
proper tty_port_close method that knows all the innards of the tty closing
process and hides the lot from the caller.
At some point in the future this will be paired with a similar open()
helper and the drivers can stick to hardware management.
console_print() is an old legacy interface mostly unused in the entire
kernel tree. It's best to clean up its existing use and let developers
use their own implementation of it as they feel fit.
Signed-off-by: Anirban Sinha <asinha@zeugmasystems.com>
* topic/asoc: (226 commits)
ASoC: au1x: PSC-AC97 bugfixes
ASoC: Fix WM835x Out4 capture enumeration
ASoC: Remove unuused hw_read_t
ASoC: fix pxa2xx-ac97.c breakage
ASoC: Fully specify DC servo bits to update in wm_hubs
ASoC: Debugged improper setting of PLL fields in WM8580 driver
ASoC: new board driver to connect bfin-5xx with ad1836 codec
ASoC: OMAP: Add functionality to set CLKR and FSR sources in McBSP DAI
ASoC: davinci: i2c device creation moved into board files
ASoC: Don't reconfigure WM8350 FLL if not needed
ASoC: Fix s3c-i2s-v2 build
ASoC: Make platform data optional for TLV320AIC3x
ASoC: Add S3C24xx dependencies for Simtec machines
ASoC: SDP3430: Fix TWL GPIO6 pin mux request
ASoC: S3C platform: Fix s3c2410_dma_started() called at improper time
ARM: OMAP: McBSP: Merge two functions into omap_mcbsp_start/_stop
ASoC: OMAP: Fix setup of XCCR and RCCR registers in McBSP DAI
OMAP: McBSP: Use textual values in DMA operating mode sysfs files
ARM: OMAP: DMA: Add support for DMA channel self linking on OMAP1510
ASoC: Select core DMA when building for S3C64xx
The patch changes the line discipline name registered in include/linux/tty.h
and updates the ams-delta machine driver to use it.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
ASoC driver
This patch adds new line discipline name an number to include/linux/tty.h. The
line discipline will be used by the Amstrad E3 (Delta) sound driver that will
come next in this series of patches.
Created against linux-2.6.31-rc3.
Applies to linux-omap-2.6 commit 7c5cb7862d32cb344be7831d466535d5255e35ac as
well.
We really don't want to mark the pty as a low-latency device, because as
Alan points out, the ->write method can be called from an IRQ (ppp?),
and that means we can't use ->low_latency=1 as we take mutexes in the
low_latency case.
So rather than using low_latency to force the written data to be pushed
to the ldisc handling at 'write()' time, just make the reader side (or
the poll function) do the flush when it checks whether there is data to
be had.
This also fixes the problem with lost data in an emacs compile buffer
(bugzilla 13815), and we can thus revert the low_latency pty hack
(commit 3a54297478e6578f96fd54bf4daa1751130aca86: "pty: quickfix for the
pty ENXIO timing problems").
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[ Modified to do the tty_flush_to_ldisc() inside input_available_p() so
that it triggers for both read and poll() - Linus]
