path: root/include/linux/tty_ldisc.h
2014-04-24tty_ldisc: add more limits to the @write_wakeupHuang Shijie
In the uart_handle_cts_change(), uart_write_wakeup() is called after we call @uart_port->ops->start_tx(). The Documentation/serial/driver tells us: ----------------------------------------------- start_tx(port) Start transmitting characters. Locking: port->lock taken. Interrupts: locally disabled. ----------------------------------------------- So when the uart_write_wakeup() is called, the port->lock is taken by the upper. See the following callstack: |_ uart_write_wakeup |_ tty_wakeup |_ ld->ops->write_wakeup With the port->lock held, we call the @write_wakeup. Some implemetation of the @write_wakeup does not notice that the port->lock is held, and it still tries to send data with uart_write() which will try to grab the prot->lock. A dead lock occurs, see the following log caught in the Bluetooth by uart: -------------------------------------------------------------------- BUG: spinlock lockup suspected on CPU#0, swapper/0/0 lock: 0xdc3f4410, .magic: dead4ead, .owner: swapper/0/0, .owner_cpu: 0 CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 3.10.17-16839-ge4a1bef #1320 [<80014cbc>] (unwind_backtrace+0x0/0x138) from [<8001251c>] (show_stack+0x10/0x14) [<8001251c>] (show_stack+0x10/0x14) from [<802816ac>] (do_raw_spin_lock+0x108/0x184) [<802816ac>] (do_raw_spin_lock+0x108/0x184) from [<806a22b0>] (_raw_spin_lock_irqsave+0x54/0x60) [<806a22b0>] (_raw_spin_lock_irqsave+0x54/0x60) from [<802f5754>] (uart_write+0x38/0xe0) [<802f5754>] (uart_write+0x38/0xe0) from [<80455270>] (hci_uart_tx_wakeup+0xa4/0x168) [<80455270>] (hci_uart_tx_wakeup+0xa4/0x168) from [<802dab18>] (tty_wakeup+0x50/0x5c) [<802dab18>] (tty_wakeup+0x50/0x5c) from [<802f81a4>] (imx_rtsint+0x50/0x80) [<802f81a4>] (imx_rtsint+0x50/0x80) from [<802f88f4>] (imx_int+0x158/0x17c) [<802f88f4>] (imx_int+0x158/0x17c) from [<8007abe0>] (handle_irq_event_percpu+0x50/0x194) [<8007abe0>] (handle_irq_event_percpu+0x50/0x194) from [<8007ad60>] (handle_irq_event+0x3c/0x5c) -------------------------------------------------------------------- This patch adds more limits to the @write_wakeup, the one who wants to implemet the @write_wakeup should follow the limits which avoid the deadlock. Signed-off-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18tty: tty_ldisc.h: Remove duplicate includeSachin Kamat
linux/wait.h was included twice. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08tty: Always handle NULL flag ptrPeter Hurley
Most line disciplines already handle the undocumented NULL flag ptr in their .receive_buf method; however, several don't. Document the NULL flag ptr, and correct handling in the N_MOUSE, N_GSM0710 and N_R394 line disciplines. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Make ldisc input flow control concurrency-friendlyPeter Hurley
Although line discipline receiving is single-producer/single-consumer, using tty->receive_room to manage flow control creates unnecessary critical regions requiring additional lock use. Instead, introduce the optional .receive_buf2() ldisc method which returns the # of bytes actually received. Serialization is guaranteed by the caller. In turn, the line discipline should schedule the buffer work item whenever space becomes available; ie., when there is room to receive data and receive_room() previously returned 0 (the buffer work item stops processing if receive_buf2() returns 0). Note the 'no room' state need not be atomic despite concurrent use by two threads because only the buffer work thread can set the state and only the read() thread can clear the state. Add n_tty_receive_buf2() as the receive_buf2() method for N_TTY. Provide a public helper function, tty_ldisc_receive_buf(), to use when directly accessing the receive_buf() methods. Line disciplines not using input flow control can continue to set tty->receive_room to a fixed value and only provide the receive_buf() method. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-23tty: Replace ldisc locking with ldisc_semPeter Hurley
Line discipline locking was performed with a combination of a mutex, a status bit, a count, and a waitqueue -- basically, a rw semaphore. Replace the existing combination with an ld_semaphore. Fixes: 1) the 'reference acquire after ldisc locked' bug 2) the over-complicated halt mechanism 3) lock order wrt. tty_lock() 4) dropping locks while changing ldisc 5) previously unidentified deadlock while locking ldisc from both linked ttys concurrently 6) previously unidentified recursive deadlocks Adds much-needed lockdep diagnostics. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17n_tty: Encapsulate minimum_to_wake within N_TTYPeter Hurley
minimum_to_wake is unique to N_TTY processing, and belongs in per-ldisc data. Add the ldisc method, ldisc_ops::fasync(), to notify line disciplines when signal-driven I/O is enabled or disabled. When enabled for N_TTY (by fcntl(F_SETFL, O_ASYNC)), blocking reader/polls will be woken for any readable input. When disabled, blocking reader/polls are not woken until the read buffer is full. Canonical mode (L_ICANON(tty), n_tty_data::icanon) is not affected by the minimum_to_wake setting. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-20tty: Add timed, writer-prioritized rw semaphorePeter Hurley
The semantics of a rw semaphore are almost ideally suited for tty line discipline lifetime management; multiple active threads obtain "references" (read locks) while performing i/o to prevent the loss or change of the current line discipline (write lock). Unfortunately, the existing rw_semaphore is ill-suited in other ways; 1) TIOCSETD ioctl (change line discipline) expects to return an error if the line discipline cannot be exclusively locked within 5 secs. Lock wait timeouts are not supported by rwsem. 2) A tty hangup is expected to halt and scrap pending i/o, so exclusive locking must be prioritized. Writer priority is not supported by rwsem. Add ld_semaphore which implements these requirements in a semantically similar way to rw_semaphore. Writer priority is handled by separate wait lists for readers and writers. Pending write waits are priortized before existing read waits and prevent further read locks. Wait timeouts are trivially added, but obviously change the lock semantics as lock attempts can fail (but only due to timeout). This implementation incorporates the write-lock stealing work of Michel Lespinasse <walken@google.com>. Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-18tty: Fix checkpatch errors in tty_ldisc.hPeter Hurley
2013-02-13pps: Move timestamp read into PPS code properGeorge Spelvin
The PPS (Pulse-Per-Second) line discipline has developed a number of unhealthy attachments to core tty data and functions, ultimately leading to its breakage. The previous patches fixed the crashing. This one reduces coupling further by eliminating the timestamp parameter from the dcd_change ldisc method. This reduces header file linkage and makes the extension more generic, and the timestamp read is delayed only slightly, from just before the ldisc->ops->dcd_change method call to just after. Fix attendant build breakage in drivers/tty/n_tty.c drivers/tty/tty_buffer.c drivers/staging/speakup/selection.c drivers/staging/dgrp/dgrp_*.c Cc: William Hubbs <w.d.hubbs@gmail.com> Cc: Chris Brannon <chris@the-brannons.com> Cc: Kirk Reiser <kirk@braille.uwo.ca> Cc: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: George Spelvin <linux@horizon.com> Acked-by: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-10tty: move global ldisc idle waitqueue to the individual ldiscIvo Sieben
The global wait_queue that is used for line discipline idle handling is moved to a separate wait_queue for each line instance. This prevents unnecessary blocking on one line, because of idle handling on another line. Signed-off-by: Ivo Sieben <meltedpianoman@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13pps: timestamp is always passed to dcd_change()Alexander Gordeev
Remove the code that gatheres timestamp in pps_tty_dcd_change() in case passed ts parameter is NULL because it never happens in the current code. Fix comments as well. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13pps: unify timestamp gatheringAlexander Gordeev
Add a helper function to gather timestamps. This way clients don't have to duplicate it. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ldisc: new dcd_change() method for line disciplinesRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-04tty-ldisc: make refcount be atomic_t 'users' countLinus Torvalds
This is pure preparation of changing the ldisc reference counting to be a true refcount that defines the lifetime of the ldisc. But this is a purely syntactic change for now to make the next steps easier. This patch should make no semantic changes at all. But I wanted to make the ldisc refcount be an atomic (I will be touching it without locks soon enough), and I wanted to rename it so that there isn't quite as much confusion between 'ldo->refcount' (ldisk operations refcount) and 'ld->refcount' (ldisc refcount itself) in the same file. So it's now an atomic 'ld->users' count. It still starts at zero, despite having a reference from 'tty->ldisc', but that will change once we turn it into a _real_ refcount. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-20tty: Ldisc revampAlan Cox
Move the line disciplines towards a conventional ->ops arrangement. For the moment the actual 'tty_ldisc' struct in the tty is kept as part of the tty struct but this can then be changed if it turns out that when it all settles down we want to refcount ldiscs separately to the tty. Pull the ldisc code out of /proc and put it with our ldisc code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11tty: add compat_ioctlPaul Fulghum
Add compat_ioctl method for tty code to allow processing of 32 bit ioctl calls on 64 bit systems by tty core, tty drivers, and line disciplines. Based on patch by Arnd Bergmann: http://www.uwsg.iu.edu/hypermail/linux/kernel/0511.0/1732.html [akpm@linux-foundation.org: make things static] Signed-off-by: Paul Fulghum <paulkf@microgate.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermios and new frameworkAlan Cox
This is the core of the switch to the new framework. I've split it from the driver patches which are mostly search/replace and would encourage people to give this one a good hard stare. The references to BOTHER and ISHIFT are the termios values that must be defined by a platform once it wants to turn on "new style" ioctl support. The code patches here ensure that providing 1. The termios overlays the ktermios in memory 2. The only new kernel only fields are c_ispeed/c_ospeed (or none) the existing behaviour is retained. This is true for the patches at this point in time. Future patches will define BOTHER, ISHIFT and enable newer termios structures for each architecture, and once they are all done some of the ifdefs also vanish. [akpm@osdl.org: warning fix] [akpm@osdl.org: IRDA fix] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
