path: root/include/linux/types.h
2012-12-11mm, oom: fix race when specifying a thread as the oom originDavid Rientjes
test_set_oom_score_adj() and compare_swap_oom_score_adj() are used to specify that current should be killed first if an oom condition occurs in between the two calls. The usage is short oom_score_adj = test_set_oom_score_adj(OOM_SCORE_ADJ_MAX); ... compare_swap_oom_score_adj(OOM_SCORE_ADJ_MAX, oom_score_adj); to store the thread's oom_score_adj, temporarily change it to the maximum score possible, and then restore the old value if it is still the same. This happens to still be racy, however, if the user writes OOM_SCORE_ADJ_MAX to /proc/pid/oom_score_adj in between the two calls. The compare_swap_oom_score_adj() will then incorrectly reset the old value prior to the write of OOM_SCORE_ADJ_MAX. To fix this, introduce a new oom_flags_t member in struct signal_struct that will be used for per-thread oom killer flags. KSM and swapoff can now use a bit in this member to specify that threads should be killed first in oom conditions without playing around with oom_score_adj. This also allows the correct oom_score_adj to always be shown when reading /proc/pid/oom_score. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-07-22merge task_work and rcu_head, get rid of separate allocation for keyring caseAl Viro
task_work and rcu_head are identical now; merge them (calling the result struct callback_head, rcu_head #define'd to it), kill separate allocation in security/keys since we can just use cred->rcu now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30bury __kernel_nlink_t, make internal nlink_t consistentAl Viro
2012-04-10irq: Kill pointless irqd_to_hw exportGrant Likely
It makes no sense to export this trivial function. Make it a static inline instead. This patch also drops virq_to_hw from arch/c6x since it is unused by that architecture. v2: Move irq_hw_number_t into types.h to fix ARM build failure Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-03consolidate umode_t declarationsAl Viro
2011-12-12types.h: fix comment spelling for 'architectures'Mark Einon
Spelling change, architetures -> architectures Signed-off-by: Mark Einon <mark.einon@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-28rcu: Move rcu_head definition to types.hPaul E. McKenney
Take a first step towards untangling Linux kernel header files by placing the struct rcu_head definition into include/linux/types.h and including include/linux/types.h in include/linux/rcupdate.h where struct rcu_head used to be defined. The actual inclusion point for include/linux/types.h is with the rest of the #include directives rather than at the point where struct rcu_head used to be defined, as suggested by Mathieu Desnoyers. Once this is in place, then header files that need only rcu_head can include types.h rather than rcupdate.h. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26types.h: move misplaced commentAndrew Morton
This comment landed in the wrong place. Cc: Andi Kleen <andi@firstfloor.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Miller <davem@davemloft.net> Cc: Eric Paris <eparis@redhat.com> Cc: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-15types.h: define __aligned_u64 and expose to userspaceEric Paris
We currently have a kernel internal type called aligned_u64 which aligns __u64's on 8 bytes boundaries even on systems which would normally align them on 4 byte boundaries. This patch creates a new type __aligned_u64 which does the same thing but which is exposed to userspace rather than being kernel internal. [akpm: merge early as both the net and audit trees want this] [akpm@linux-foundation.org: enhance the comment describing the reasons for using aligned_u64. Via Andreas and Andi.] Based-on-patch-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Jan Engelhardt <jengelh@medozas.de> Cc: David Miller <davem@davemloft.net> Cc: Andi Kleen <andi@firstfloor.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-06Merge branch 'master' into for-linusChris Metcalf
2010-07-11fix #warning about using kernel headers in userpsaceJustin P. Mattock
Move the preprocessor #warning message: warning: #warning Attempt to use kernel headers from user space, see http://kernelnewbies.org/KernelHeaders from kernel.h to types.h. And also fixe the #warning message due to the preprocessor not being able to read the web address due to it thinking it was the start of a comment. also remove the extra #ifndef _KERNEL_ since it's already there. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-06Move list types from <linux/list.h> to <linux/types.h>.Chris Metcalf
This allows a list_head (or hlist_head, etc.) to be used from places that used to be impractical, in particular <asm/processor.h>, which used to cause include file recursion: <linux/list.h> includes <linux/prefetch.h>, which always includes <asm/processor.h> for the prefetch macros, as well as <asm/system.h>, which often includes <asm/processor.h> directly or indirectly. This avoids a lot of painful workaround hackery on the tile architecture, where we use a list_head in the thread_struct to chain together tasks that are activated on a particular hardwall. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
2010-05-17atomic_t: Remove volatile from atomic_t definitionAnton Blanchard
When looking at a performance problem on PowerPC, I noticed some awful code generation: c00000000051fc98: 3b 60 00 01 li r27,1 ... c00000000051fca0: 3b 80 00 00 li r28,0 ... c00000000051fcdc: 93 61 00 70 stw r27,112(r1) c00000000051fce0: 93 81 00 74 stw r28,116(r1) c00000000051fce4: 81 21 00 70 lwz r9,112(r1) c00000000051fce8: 80 01 00 74 lwz r0,116(r1) c00000000051fcec: 7d 29 07 b4 extsw r9,r9 c00000000051fcf0: 7c 00 07 b4 extsw r0,r0 c00000000051fcf4: 7c 20 04 ac lwsync c00000000051fcf8: 7d 60 f8 28 lwarx r11,0,r31 c00000000051fcfc: 7c 0b 48 00 cmpw r11,r9 c00000000051fd00: 40 c2 00 10 bne- c00000000051fd10 c00000000051fd04: 7c 00 f9 2d stwcx. r0,0,r31 c00000000051fd08: 40 c2 ff f0 bne+ c00000000051fcf8 c00000000051fd0c: 4c 00 01 2c isync We create two constants, write them out to the stack, read them straight back in and sign extend them. What a mess. It turns out this bad code is a result of us defining atomic_t as a volatile int. We removed the volatile attribute from the powerpc atomic_t definition years ago, but commit ea435467500612636f8f4fb639ff6e76b2496e4b (atomic_t: unify all arch definitions) added it back in. To dig up an old quote from Linus: > The fact is, volatile on data structures is a bug. It's a wart in the C > language. It shouldn't be used. > > Volatile accesses in *code* can be ok, and if we have "atomic_read()" > expand to a "*(volatile int *)&(x)->value", then I'd be ok with that. > > But marking data structures volatile just makes the compiler screw up > totally, and makes code for initialization sequences etc much worse. And screw up it does :) With the volatile removed, we see much more reasonable code generation: c00000000051f5b8: 3b 60 00 01 li r27,1 ... c00000000051f5c0: 3b 80 00 00 li r28,0 ... c00000000051fc7c: 7c 20 04 ac lwsync c00000000051fc80: 7c 00 f8 28 lwarx r0,0,r31 c00000000051fc84: 7c 00 d8 00 cmpw r0,r27 c00000000051fc88: 40 c2 00 10 bne- c00000000051fc98 c00000000051fc8c: 7f 80 f9 2d stwcx. r28,0,r31 c00000000051fc90: 40 c2 ff f0 bne+ c00000000051fc80 c00000000051fc94: 4c 00 01 2c isync Six instructions less. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19block: rename CONFIG_LBD to CONFIG_LBDAFBartlomiej Zolnierkiewicz
Follow-up to "block: enable by default support for large devices and files on 32-bit archs". Rename CONFIG_LBD to CONFIG_LBDAF to: - allow update of existing [def]configs for "default y" change - reflect that it is used also for large files support nowadays Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26remove __KERNEL_STRICT_NAMESArnd Bergmann
With the last used of non-strict names gone from the exported header files, we can remove the old libc5 compatibility cruft from our headers and only export strict types. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26unconditionally include asm/types.h from linux/types.hJaswinder Singh Rajput
Reported-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06make linux/types.h as assembly safeJaswinder Singh Rajput
2009-01-07linux/types.h: Don't depend on __GNUC__ for __le64/__be64Detlef Riekenberg
The typedefs for __u64 and __s64 where fixed to be available for other compiler on May 2 2008 by H. Peter Anvin (in commit edfa5cfa3dc5) Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Detlef Riekenberg <wine.dev@web.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06atomic_t: unify all arch definitionsMatthew Wilcox
The atomic_t type cannot currently be used in some header files because it would create an include loop with asm/atomic.h. Move the type definition to linux/types.h to break the loop. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29Get rid of CONFIG_LSFJens Axboe
We have two seperate config entries for large devices/files. One is CONFIG_LBD that guards just the devices, the other is CONFIG_LSF that handles large files. This doesn't make a lot of sense, you typically want both or none. So get rid of CONFIG_LSF and change CONFIG_LBD wording to indicate that it covers both. Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-09-14generic: redefine resource_size_t as phys_addr_tJeremy Fitzhardinge
There's no good reason why a resource_size_t shouldn't just be a physical address, so simply redefine it in terms of phys_addr_t. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14generic: add phys_addr_t for holding physical addressesJeremy Fitzhardinge
Add a kernel-wide "phys_addr_t" which is guaranteed to be able to hold any physical address. By default it equals the word size of the architecture, but a 32-bit architecture can set ARCH_PHYS_ADDR_T_64BIT if it needs a 64-bit phys_addr_t. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24types.h: don't expose struct ustat to userspacemaximilian attems
<linux/types.h> can't be used together with <sys/ustat.h> because they both define struct ustat: $ cat test.c #include <sys/ustat.h> #include <linux/types.h> $ gcc -c test.c In file included from test.c:2: /usr/include/linux/types.h:165: error: redefinition of 'struct ustat' has been reported a while ago to debian, but seems to have been lost in cat fighting: http://bugs.debian.org/429064 Signed-off-by: maximilian attems <max@stro.at> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Remove __STRICT_ANSI__ from linux/types.hMike Frysinger
All of the asm-*/types.h headers have been updated to no longer check __STRICT_ANSI__ for the 64bit types, so this brings linux/types.h in line. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31linux/types.h: Use __u64 for aligned_u64Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-29fix abuses of ptrdiff_tAl Viro
Use of ptrdiff_t in places like - if (!access_ok(VERIFY_WRITE, u_tmp->rx_buf, u_tmp->len)) + if (!access_ok(VERIFY_WRITE, (u8 __user *) + (ptrdiff_t) u_tmp->rx_buf, + u_tmp->len)) is wrong; for one thing, it's a bad C (it's what uintptr_t is for; in general we are not even promised that ptrdiff_t is large enough to hold a pointer, just enough to hold a difference between two pointers within the same object). For another, it confuses the fsck out of sparse. Use unsigned long or uintptr_t instead. There are several places misusing ptrdiff_t; fixed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define first set of BIT* macrosJiri Slaby
define first set of BIT* macros - move BITOP_MASK and BITOP_WORD from asm-generic/bitops/atomic.h to include/linux/bitops.h and rename it to BIT_MASK and BIT_WORD - move BITS_TO_LONGS and BITS_PER_BYTE to bitops.h too and allow easily define another BITS_TO_something (e.g. in event.c) by BITS_TO_TYPE macro Remaining (and common) BIT macro will be defined after all occurences and conflicts will be sorted out in the patches. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-04[PATCH] Centralise definitions of sector_t and blkcnt_tMatthew Wilcox
CONFIG_LBD and CONFIG_LSF are spread into asm/types.h for no particularly good reason. Centralising the definition in linux/types.h means that arch maintainers don't need to bother adding it, as well as fixing the problem with x86-64 users being asked to make a decision that has absolutely no effect. The H8/300 porters seem particularly confused since I'm not aware of any microcontrollers that need to support 2TB filesystems. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[NET]: Introduce types for checksums.Al Viro
New types - for 16bit checksums and "unfolded" 32bit variant. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: trivial annotationsAl Viro
2006-10-04[PATCH] Document bi_sector and sector_tRoger Gammans
Signed-Off-By: Roger Gammans <rgammans@computer-surgery.co.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-01[PATCH] Generic booleanRichard Knutsson
This patch defines: * a generic boolean-type, named 'bool' * aliases to 0 and 1, named 'false' and 'true' Removing colliding definitions of 'bool', 'false' and 'true'. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit Resource: finally enable 64bit resource sizesGreg Kroah-Hartman
Introduce the Kconfig entry and actually switch to a 64bit value, if wanted, for resource_size_t. Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: introduce resource_size_t for the start and end of ↵Greg Kroah-Hartman
struct resource But do not change it from what it currently is (unsigned long) Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-26[PATCH] 2TB files: add blkcnt_tTakashi Sato
Add blkcnt_t as the type of inode.i_blocks. This enables you to make the size of blkcnt_t either 4 bytes or 8 bytes on 32 bits architecture with CONFIG_LSF. - CONFIG_LSF Add new configuration parameter. - blkcnt_t On h8300, i386, mips, powerpc, s390 and sh that define sector_t, blkcnt_t is defined as u64 if CONFIG_LSF is enabled; otherwise it is defined as unsigned long. On other architectures, it is defined as unsigned long. - inode.i_blocks Change the type from sector_t to blkcnt_t. Signed-off-by: Takashi Sato <sho@tnes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] Define BITS_PER_BYTEBryan O'Sullivan
This can make the intent behind some arithmetic expressions clearer. Signed-off-by: Bryan O'Sullivan <bos@pathscale.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: infrastructureAl Viro
Beginning of gfp_t annotations: - -Wbitwise added to CHECKFLAGS - old __bitwise renamed to __bitwise__ - __bitwise defined to either __bitwise__ or nothing, depending on __CHECK_ENDIAN__ being defined - gfp_t switched from __nocast to __bitwise__ - force cast to gfp_t added to __GFP_... constants - new helper - gfp_zone(); extracts zone bits out of gfp_t value and casts the result to int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NETFILTER]: introduce and use aligned_u64 data typeHarald Welte
As proposed by Andi Kleen, this is required esp. for x86_64 architecture, where 64bit code needs 8byte aligned 64bit data types, but 32bit userspace apps will only align to 4bytes. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
