path: root/include/linux/unaligned
2011-01-13include/linux/unaligned/packed_struct.h: use __packedAndrew Morton
Cc: Will Newton <will.newton@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22include/linux/unaligned: pack the whole struct rather than just the fieldWill Newton
The current packed struct implementation of unaligned access adds the packed attribute only to the field within the unaligned struct rather than to the struct as a whole. This is not sufficient to enforce proper behaviour on architectures with a default struct alignment of more than one byte. For example, the current implementation of __get_unaligned_cpu16 when compiled for arm with gcc -O1 -mstructure-size-boundary=32 assumes the struct is on a 4 byte boundary so performs the load of the 16bit packed field as if it were on a 4 byte boundary: __get_unaligned_cpu16: ldrh r0, [r0, #0] bx lr Moving the packed attribute to the struct rather than the field causes the proper unaligned access code to be generated: __get_unaligned_cpu16: ldrb r3, [r0, #0] @ zero_extendqisi2 ldrb r0, [r0, #1] @ zero_extendqisi2 orr r0, r3, r0, asl #8 bx lr Signed-off-by: Will Newton <will.newton@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24include/linux/unaligned/{l,b}e_byteshift.h: fix usage for compressed kernelsAlbin Tonnerre
When unaligned accesses are required for uncompressing a kernel (such as for LZO decompression on ARM in a patch that follows), including <linux/kernel.h> causes issues as it brings in a lot of things that are not available in the decompression environment. linux/kernel.h brings at least: extern int console_printk[]; extern const char hex_asc[]; which causes errors at link-time as they are not available when compiling the pre-boot environement. There are also a few others: arch/arm/boot/compressed/misc.o: In function `valid_user_regs': arch/arm/include/asm/ptrace.h:158: undefined reference to `elf_hwcap' arch/arm/boot/compressed/misc.o: In function `console_silent': include/linux/kernel.h:292: undefined reference to `console_printk' arch/arm/boot/compressed/misc.o: In function `console_verbose': include/linux/kernel.h:297: undefined reference to `console_printk' arch/arm/boot/compressed/misc.o: In function `pack_hex_byte': include/linux/kernel.h:360: undefined reference to `hex_asc' arch/arm/boot/compressed/misc.o: In function `hweight_long': include/linux/bitops.h:45: undefined reference to `hweight32' arch/arm/boot/compressed/misc.o: In function `__cmpxchg_local_generic': include/asm-generic/cmpxchg-local.h:21: undefined reference to `wrong_size_cmpxchg' include/asm-generic/cmpxchg-local.h:42: undefined reference to `wrong_size_cmpxchg' arch/arm/boot/compressed/misc.o: In function `__xchg': arch/arm/include/asm/system.h:309: undefined reference to `__bad_xchg' However, those files apparently use nothing from <linux/kernel.h>, all they need is the declaration of types such as u32 or u64, so <linux/types.h> should be enough Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: add common infrastructure for unaligned accessHarvey Harrison
Create a linux/unaligned directory similar in spirit to the linux/byteorder folder to hold generic implementations collected from various arches. Currently there are five implementations: 1) packed_struct.h: C-struct based, from asm-generic/unaligned.h 2) le_byteshift.h: Open coded byte-swapping, heavily based on asm-arm 3) be_byteshift.h: Open coded byte-swapping, heavily based on asm-arm 4) memmove.h: taken from multiple implementations in tree 5) access_ok.h: taken from x86 and others, unaligned access is ok. All of the new implementations checks for sizes not equal to 1,2,4,8 and will fail to link. API additions: get_unaligned_{le16|le32|le64|be16|be32|be64}(p) which is meant to replace code of the form: le16_to_cpu(get_unaligned((__le16 *)p)); put_unaligned_{le16|le32|le64|be16|be32|be64}(val, pointer) which is meant to replace code of the form: put_unaligned(cpu_to_le16(val), (__le16 *)p); The headers that arches should include from their asm/unaligned.h: access_ok.h : Wrappers of the byteswapping functions in asm/byteorder Choose a particular implementation for little-endian access: le_byteshift.h le_memmove.h (arch must be LE) le_struct.h (arch must be LE) Choose a particular implementation for big-endian access: be_byteshift.h be_memmove.h (arch must be BE) be_struct.h (arch must be BE) After including as needed from the above, include unaligned/generic.h and define your arch's get/put_unaligned as (for LE): Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
