path: root/include/linux/usb.h
2008-04-24wusb: add link wusb-usb deviceInaky Perez-Gonzalez
We need to tie the WUSB and USB devices; the USB stack doesn't need to know the details about the WUSB device, but needs to have a link to it. This is needed so that the notify call back for Remove Device can tie both and undo the device setup (sysfs files). We connect the devices together at the Add Device notifier callback (the wusb_dev references the usb_dev and stores it, the usb_dev references the wusb_dev and stores it); then we do create the WUSB sysfs files at the usb_dev sysfs directory. At Remove Device, we undo that (thus we need the usb_dev reference). Cross reference to functions in the WUSB substack: wusb_dev_{add,rm}_ncb(). Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24wusb: add authenticathed bit to usb_devInaky Perez-Gonzalez
This bit indicates the system that the WUSB device has been crypto authenticated and thus can operate as normal. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: update comments about usb driver's headerOliver Neukum
Comments here are so outdated that they are plain wrong. We cannot expect people to write correct drivers if the headers have incorrect comments. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add extension of anchor API, usb_unlink_anchored_urbsOliver Neukum
This adds the ability to trigger asynchronous unlinks of anchored URBs. This is needed for error handling in the comntext of completion handlers, which cannot sleep. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: usb.h: reduce syslog clutter [v3]Tilman Schmidt
The the err() / info() / warn() macros in usb.h inserted __FILE__ at the beginning of the message, which expands to the complete pathname of the source file within the kernel tree, frequently taking up half of an 80 character screen line before the actual message even begins. Use the module name instead. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: convert usb.h struct usb_device to kernel-docRandy Dunlap
Convert struct usb_device to use kernel-doc notation. Please especially check the @filelist and @usb_classdev descriptions. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove CONFIG_USB_PERSIST settingAlan Stern
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling it permanently. It also prevents the power/persist attribute from being created for hub devices; there's no point in having it since USB-PERSIST is always turned on for hubs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04USB: fix comment of struct usb_interfaceLei Ming
update the comment for the removed "driver" field and being out-of-order of @cur_altsetting and @num_altsetting. Signed-off-by: Lei Ming <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-03docbook: fix usb source filesRandy Dunlap
Fix docbook problems in USB source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01USB: fix codingstyle issues in include/linux/usb.hGreg Kroah-Hartman
No logical code changes were made, but checkpatch.pl is much happier now. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Export suspend statisticsSarah Sharp
This patch exports two statistics to userspace: /sys/bus/usb/device/.../power/connected_duration /sys/bus/usb/device/.../power/active_duration connected_duration is the total time (in msec) that the device has been connected. active_duration is the total time the device has not been suspended. With these two statistics, tools like PowerTOP can calculate the percentage time that a device is active, i.e. not suspended or auto-suspended. Users can also use the active_duration to check if a device is actually autosuspended. Currently, they can set power/level to auto and power/autosuspend to a positive timeout, but there's no way to know from userspace if a device was actually autosuspended without looking at the dmesg output. These statistics will be useful in creating an automated userspace script to test autosuspend for USB devices. Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Convert from class_device to device for USB coreTony Jones
Convert from class_device to device for drivers/usb/core. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-17usb.h: fix kernel-doc warningRandy Dunlap
Fix kernel-doc warning in usb.h: Warning(linux-2.6.24-rc3-git7//include/linux/usb.h:166): No description found for parameter 'sysfs_files_created' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: keep track of whether interface sysfs files existAlan Stern
This patch (as1009) solves the problem of multiple registrations for USB sysfs files in a more satisfying way than the existing code. It simply adds a flag to keep track of whether or not the files have been created; that way the files can be created or removed as needed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
2007-10-12USB: skip autosuspended devices during system resumeAlan Stern
System suspends and hibernation are supposed to be as transparent as possible. By this reasoning, if a USB device is already autosuspended before the system sleep begins then it should remain autosuspended after the system wakes up. This patch (as1001) adds a skip_sys_resume flag to the usb_device structure and uses it to avoid waking up devices which were suspended when a system sleep began. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: Export URB statistics for powertopSarah Sharp
powertop currently tracks interrupts generated by uhci, ehci, and ohci, but it has no way of telling which USB device to blame USB bus activity on. This patch exports the number of URBs that are submitted for a given device. Cat the file 'urbnum' in /sys/bus/usb/devices/.../ Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: flush outstanding URBs when suspendingAlan Stern
This patch (as989) makes usbcore flush all outstanding URBs for each device as the device is suspended. This will be true even when CONFIG_USB_SUSPEND is not enabled. In addition, an extra can_submit flag is added to the usb_device structure. That flag will be turned off whenever a suspend request has been received for the device, even if the device isn't actually suspended because CONFIG_USB_SUSPEND isn't set. It's no longer necessary to check for the device state being equal to USB_STATE_SUSPENDED during URB submission; that check can be replaced by a check of the can_submit flag. This also permits us to remove some questionable references to the deprecated power.power_state field. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: get rid of urb->lockAlan Stern
Now that urb->status isn't used, urb->lock doesn't protect anything. This patch (as980) removes it and replaces it with a private mutex in the one remaining place it was still used: usb_kill_urb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add urb->unlinked fieldAlan Stern
This patch (as970) adds a new urb->unlinked field, which is used to store the status of unlinked URBs since we can't use urb->status for that purpose any more. To help simplify the HCDs, usbcore will check urb->unlinked before calling the completion handler; if the value is set it will automatically override the status reported by the HCD. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usb: introduce usb_device authorization bitsInaky Perez-Gonzalez
This just modifies 'struct usb_device' to contain the 'authorized' bit. It also adds a 'wusb' bit. This is needed because nonauthorized (and thus non-authenticated) wusb devices will fail certain kind of simple requests (such as string descriptors). By knowing the device is WUSB, we just avoid them. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: cleanup for previous patchesAlan Stern
This patch (as951) cleans up a few loose ends from earlier patches. Redundant checks for non-NULL urb->dev are removed, as are checks of urb->dev->bus (which can never be NULL). Conversely, a check for non-NULL urb->ep is added to the unlink paths. A homegrown round-down-to-power-of-2 loop is simplified by using the ilog2 routine. The comparison in usb_urb_dir_in() is made more transparent. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: avoid using urb->pipe in usbcoreAlan Stern
This patch (as946) eliminates many of the uses of urb->pipe in usbcore. Unfortunately there will have to be a significant API change, affecting all USB drivers, before we can remove it entirely. This patch contents itself with changing only the interface to usb_buffer_map_sg() and friends: The pipe argument is replaced with a direction flag. That can be done easily because those routines get used in only one place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add direction bit to urb->transfer_flagsAlan Stern
This patch (as945) adds a bit to urb->transfer_flags for recording the direction of the URB. The bit is set/cleared automatically in usb_submit_urb() so drivers don't have to worry about it (although as a result, it isn't valid until the URB has been submitted). Inline routines are added for easily checking an URB's direction. They replace calls to usb_pipein in the DMA-mapping parts of hcd.c. For non-control endpoints, the direction is determined directly from the endpoint descriptor. However control endpoints are bi-directional; for them the direction is determined from the bRequestType byte and the wLength value in the setup packet. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add ep->enableAlan Stern
This patch (as944) adds an explicit "enabled" field to the usb_host_endpoint structure and uses it in place of the current mechanism. This is merely a time-space tradeoff; it makes checking whether URBs may be submitted to an endpoint simpler. The existing mechanism is efficient when converting urb->pipe to an endpoint pointer, but it's not so efficient when urb->ep is used instead. As a side effect, the procedure for enabling an endpoint is now a little more complicated. The ad-hoc inline code in usb.c and hub.c for enabling ep0 is now replaced with calls to usb_enable_endpoint, which is no longer static. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add urb->epAlan Stern
This patch (as943) prepares the way for eliminating urb->pipe by introducing an endpoint pointer into struct urb. For now urb->ep is set by usb_submit_urb() from the pipe value; eventually drivers will set it themselves and we will remove urb->pipe completely. The patch also adds new inline routines to retrieve an endpoint descriptor's number and transfer type, essentially as replacements for usb_pipeendpoint and usb_pipetype. usb_submit_urb(), usb_hcd_submit_urb(), and usb_hcd_unlink_urb() are converted to use the new field and new routines. Other parts of usbcore will be converted in later patches. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: usb.h kernel-doc additionsRandy Dunlap
Add kernel-doc entries in <linux/usb.h> for: Warning(linux-2.6.22-git12//include/linux/usb.h:162): No description found for parameter 'intf_assoc' Warning(linux-2.6.22-git12//include/linux/usb.h:268): No description found for parameter 'intf_assoc[USB_MAXIADS]' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add IAD support to usbfs and sysfsCraig W. Nadler
USB_IAD: Adds support for USB Interface Association Descriptors. This patch adds support to the USB host stack for parsing, storing, and displaying Interface Association Descriptors. In /proc/bus/usb/devices lines starting with A: show the fields in an IAD. In sysfs if an interface on a USB device is referenced by an IAD the following files will be added to the sysfs directory for that interface: iad_bFirstInterface, iad_bInterfaceCount, iad_bFunctionClass, and iad_bFunctionSubClass, iad_bFunctionProtocol Signed-off-by: Craig W. Nadler <craig@nadler.us> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: Add URB_FREE_BUFFER flag and the logic behind itMarcel Holtmann
USB: Add URB_FREE_BUFFER flag for freeing the transfer buffer In some cases it is not needed that the driver keeps track of the transfer buffer of an URB. It can be simply freed along with the URB itself when the reference count goes down to zero. The new flag URB_FREE_BUFFER enables this behavior. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add power/persist device attributeAlan Stern
This patch (as920) adds an extra level of protection to the USB-Persist facility. Now it will apply by default only to hubs; for all other devices the user must enable it explicitly by setting the power/persist device attribute. The disconnect_all_children() routine in hub.c has been removed and its code placed inline. This is the way it was originally as part of hub_pre_reset(); the revised usage in hub_reset_resume() is sufficiently different that the code can no longer be shared. Likewise, mark_children_for_reset() is now inline as part of hub_reset_resume(). The end result looks much cleaner than before. The sysfs interface is updated to add the new attribute file, and there are corresponding documentation updates. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add reset_resume methodAlan Stern
This patch (as918) introduces a new USB driver method: reset_resume. It is called when a device needs to be reset as part of a resume procedure (whether because of a device quirk or because of the USB-Persist facility), thereby taking over a role formerly assigned to the post_reset method. As a consequence, post_reset no longer needs an argument indicating whether it is being called as part of a reset-resume. This separation of functions makes the code clearer. In addition, the pre_reset and post_reset method return types are changed; they now must return an error code. The return value is unused at present, but at some later time we may unbind drivers and re-probe if they encounter an error during reset handling. The existing pre_reset and post_reset methods in the usbhid, usb-storage, and hub drivers are updated to match the new requirements. For usbhid the post_reset routine is also used for reset_resume (duplicate method pointers); for the other drivers a new reset_resume routine is added. The change to hub.c looks bigger than it really is, because mark_children_for_reset_resume() gets moved down next to the new hub_reset_resume() routine. A minor change to usb-storage makes the usb_stor_report_bus_reset() routine acquire the host lock instead of requiring the caller to hold it already. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz> CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: introduce usb_anchorOliver Neukum
- introduction of usb_anchor and its methods Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add USB_DEVICE_AND_INTERFACE_INFO for device matchingDaniel Drake
Recently, the USB device matching code stopped matching generic interface matches against devices with vendor-specific device class values. Some drivers now need to explicitly match USB device ID's (in addition to generic interface info) to retain the same behaviour as before. This new macro, suggested by Alan Stern, makes the explicit device/interface matching a little simpler for those users. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add USB-Persist facilityAlan Stern
This patch (as886) adds the controversial USB-persist facility, allowing USB devices to persist across a power loss during system suspend. The facility is controlled by a new Kconfig option (with appropriate warnings about the potential dangers); when the option is off the behavior will remain the same as it is now. But when the option is on, people will be able to use suspend-to-disk and keep their USB filesystems intact -- something particularly valuable for small machines where the root filesystem is on a USB device! Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10USB: Add USB_DEVICE_INTERFACE_PROTOCOL macroJan Kratochvil
The USB_DEVICE_INTERFACE_PROTOCOL will allow to match one interface protocol of vendor specific device. This macro is used in patch adding support for xbox360 to xpad.c Signed-off-by: Jan Kratochvil <honza@jikos.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-27USB: add "last_busy" field for use in autosuspendAlan Stern
This patch (as877) adds a "last_busy" field to struct usb_device, for use by the autosuspend framework. Now if an autosuspend call comes at a time when the device isn't busy but hasn't yet been idle for long enough, the timer can be set to exactly the desired value. And we will be ready to handle things like HID drivers, which can't maintain a useful usage count and must rely on the time-of-last-use to decide when to autosuspend. The patch also makes some related minor improvements: Move the calls to the autosuspend condition-checking routine into usb_suspend_both(), which is the only place where it really matters. If the autosuspend timer is already running, don't stop and restart it. Replace immediate returns with gotos so that the optional debugging ouput won't be bypassed. If autoresume is disabled but the device is already awake, don't return an error for an autoresume call. Don't try to autoresume a device if it isn't suspended. (Yes, this undercuts the previous change -- so sue me.) Don't duplicate existing code in the autosuspend work routine. Fix the kerneldoc in usb_autopm_put_interface(): If an autoresume call fails, the usage counter is left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: make usbdevices export their device nodes instead of using a separate classKay Sievers
o The "real" usb-devices export now a device node which can populate /dev/bus/usb. o The usb_device class is optional now and can be disabled in the kernel config. Major/minor of the "real" devices and class devices are the same. o The environment of the usb-device event contains DEVNUM and BUSNUM to help udev and get rid of the ugly udev rule we need for the class devices. o The usb-devices and usb-interfaces share the same bus, so I used the new "struct device_type" to let these devices identify themselves. This also removes the current logic of using a magic platform-pointer. The name of the device_type is also added to the environment which makes it easier to distinguish the different kinds of devices on the same subsystem. It looks like this: add@/devices/pci0000:00/0000:00:1d.1/usb2/2-1 ACTION=add DEVPATH=/devices/pci0000:00/0000:00:1d.1/usb2/2-1 SUBSYSTEM=usb SEQNUM=1533 MAJOR=189 MINOR=131 DEVTYPE=usb_device PRODUCT=46d/c03e/2000 TYPE=0/0/0 BUSNUM=002 DEVNUM=004 This udev rule works as a replacement for usb_device class devices: SUBSYSTEM=="usb", ACTION=="add", ENV{DEVTYPE}=="usb_device", \ NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", MODE="0644" Updated patch, which needs the device_type patches in Greg's tree. I also got a bugzilla assigned for this. :) https://bugzilla.novell.com/show_bug.cgi?id=250659 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: add power/level sysfs attributeAlan Stern
This patch (as874) adds another piece to the user-visible part of the USB autosuspend interface. The new power/level sysfs attribute allows users to force the device on (with autosuspend off), force the device to sleep (with autoresume off), or return to normal automatic operation. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: Allow autosuspend delay to equal 0Alan Stern
This patch (as867) adds an entry for the new power/autosuspend attribute in Documentation/ABI/testing, and it changes the behavior of the delay value. Now a delay of 0 means to autosuspend as soon as possible, and negative values will prevent autosuspend. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23USB: make autosuspend delay a module parameterAlan Stern
This patch (as859) makes the default USB autosuspend delay a module parameter of usbcore. By setting the delay value at boot time, users will be able to prevent the system from autosuspending devices which for some reason can't handle it. The patch also stores the autosuspend delay as a per-device value. A later patch will allow the user to change the value, tailoring the delay for each individual device. A delay value of 0 will prevent autosuspend. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23USB: add a blacklist for devices that can't handle some things we throw at them.Oliver Neukum
This adds a blacklist to the USB core to handle some autosuspend and string issues that devices have. Originally written by Oliver, but hacked up a lot by Greg. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16USB: make usb_iso_packet_descriptor.status signedPete Zaitcev
The status in usb_iso_packet_descriptor should be signed, for the benefit of someone who casts to a long or makes other benign misstep (the principle of least surprise). Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (70 commits) USB: remove duplicate device id from zc0301 USB: remove duplicate device id from usb_storage USB: remove duplicate device id from keyspan USB: remove duplicate device id from ftdi_sio USB: remove duplicate device id from visor USB: a bit more coding style cleanup usbcore: trivial whitespace fixes usb-storage: use first bulk endpoints, not last EHCI: fix interrupt-driven remote wakeup USB: switch ehci-hcd to new polling scheme USB: autosuspend for usb printer driver USB Input: Added kernel module to support all GTCO CalComp USB InterWrite School products USB: Sierra Wireless auto set D0 USB: usb ethernet gadget recognizes HUSB2DEV USB: list atmel husb2_udc gadget controller USB: gadgetfs AIO tweaks USB: gadgetfs behaves better on userspace init bug USB: gadgetfs race fix USB: gadgetfs simplifications USB: gadgetfs cleanups ...
2007-02-07usbcore: remove unused bandwith-related codeAlan Stern
This patch (as841) removes from usbcore a couple of support routines meant to help with bandwidth allocation. With the changes to uhci-hcd in the previous patch, these routines are no longer used anywhere. Also removed is the CONFIG_USB_BANDWIDTH option; it no longer does anything and is no longer needed since the HCDs now handle bandwidth issues correctly. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: Add usb_endpoint_xfer_control to usb.hSarah Bailey
Added a function to check if an endpoint is a control endpoint. There were similar functions for bulk, interrupt, and isoc, but not for control endpoints. Signed-off-by: Sarah Bailey <saharabeara@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB serial: add dynamic id support to usb-serial coreGreg Kroah-Hartman
Thanks to Johannes Hölzl <johannes.hoelzl@gmx.de> for fixing a few things and getting it all working properly. This adds support for dynamic usb ids to the usb serial core. The file "new_id" will show up under the usb serial driver, not the usb driver associated with the usb-serial driver (yeah, it can be a bit confusing at first glance...) This patch also modifies the USB core to allow the usb-serial core to reuse much of the dynamic id logic. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de>
2007-02-07USB: <linux/usb_ch9.h> becomes <linux/usb/ch9.h>David Brownell
This moves <linux/usb_ch9.h> to <linux/usb/ch9.h> to reduce some of the clutter of usb header files. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: convert usb class devices to real devicesGreg Kroah-Hartman
2007-02-07USB: move usb_device_class class devices to be real devicesGreg Kroah-Hartman
This moves the usb class devices that control the usbfs nodes to show up in the proper place in the larger device tree. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: add the sysfs driver name to all modulesGreg Kroah-Hartman
This adds the module name to all USB drivers, if they are built into the kernel or not. It will show up in /sys/modules/MODULE_NAME/drivers/ Cc: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
