Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
(cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa)
Bug 1040642
Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/128693
GVS: Gerrit_Virtual_Submit
Bug 901367
Change-Id: I73fe7c19f5f50530f7d0a73d0a6b9ba2092c71d2
Reviewed-on: http://git-master/r/76664
Reviewed-by: Steve Lin <stlin@nvidia.com>
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Change-Id: I309eb6178a7f39714f9e5f963faf011a1a79b079
Reviewed-on: http://git-master/r/77309
Adding FLAG_RMNET to change ncm net device name
for Ericsson modem.
Bug 901367
Change-Id: I4a029cc10a02176035319ed4ac1e7b9af349cbd1
Reviewed-on: http://git-master/r/74912
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Signed-off-by: BH Hsieh <bhsieh@nvidia.com>
Reviewed-on: http://git-master/r/76459
Resubmit interrupt URB if device is open. Use a flag set in
usbnet_open() to determine this state. Also kill and free
interrupt URB in usbnet_disconnect().
[Rebased off git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git]
Signed-off-by: Paul Stewart <pstew@chromium.org>
USB tethering does not work anymore since 2.6.39-rc2, but it's okay in
-rc1. The root cause is the new added mask code 'FLAG_POINTTOPOINT'
overlaps 'FLAG_MULTI_PACKET' in include/linux/usb/usbnet.h, this
causes logic issue in rx_process(). This patch cleans up the overlap.
Reported-and-Tested-by: Gottfried Haider <gottfried.haider@gmail.com>
The documentation for the USB ethernet devices suggests that
only some devices are supposed to use usb0 as the network interface
name instead of eth0. The logic used there, and documented in
Kconfig for CDC is that eth0 will be used when the mac address
is a globally assigned one, but usb0 is used for the locally
managed range that is typically used on point-to-point links.
Unfortunately, this has caused a lot of pain on the smsc95xx
device that is used on the popular pandaboard without an
EEPROM to store the MAC address, which causes the driver to
call random_ether_address().
Obviously, there should be a proper MAC addressed assigned to
the device, and discussions are ongoing about how to solve
this, but this patch at least makes sure that the default
interface naming gets a little saner and matches what the
user can expect based on the documentation, including for
new devices.
The approach taken here is to flag whether a device might be a
point-to-point link with the new FLAG_POINTTOPOINT setting in
the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT
and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one
of the two. The usbnet framework only looks at the MAC address
for device naming if both flags are set, otherwise it trusts the
flag.
Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Tested-by: Andy Green <andy.green@linaro.org>
This adds a driver for the CDC Ethernet part of this modem. The
device's ID is blacklisted in cdc_ether.c and is white-listed in
this new driver because of the quirks needed to make it useful.
The modem's firmware exposes a CDC ACM port for modem control and a
CDC Ethernet port for network data. The descriptors look fine but
both ports actually are some sort of multiplexers requiring non-
standard headers added/removed from every packet or they get
ignored. All information is based on a usb traffic log from a
Windows machine.
On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with
this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps.
Userspace scripts are required to talk to the CDC ACM port.
Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com>
Changes:
include/linux/usb/usbnet.h:
- a new flag to indicate driver's capability to accumulate IP packets in Tx
direction and extract several packets from single skb in Rx direction.
drivers/net/usb/usbnet.c:
- the procedure of counting packets in usbnet was updated due to the
accumulating of IP packets in the driver
- no short packets are sent if indicated by the flag in driver_info
structure
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
Lots of minor formatting cleanups in includes/usb/ to make checkpatch
happier.
These macros are too similar to the dev_<level> equivalents
but take a usbnet * argument. Convert them to the recently
introduced netdev_<level> macros and remove the old macros.
The old macros had "\n" appended to the format string.
Add the "\n" to the converted uses.
Some existing uses of the dev<foo> macros in cdc_eem.c
probably mistakenly had trailing "\n". No "\n" added there.
Fix net1080 this/other log message inversion.
Using remote wakeup and delayed transmission to allow
online device to go into usb autosuspend.
Minimal alternate support for devices that don't support
remote wakeup.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Some usbnet drivers update link state while others do not due to
hardware limitations. Add a flag to distinguish those that do, and
set the link down initially for their devices.
This is intended to fix this bug: http://bugs.debian.org/444043
Add support for usbnet based devices like CDC-Ether to indicate that they
are actually mobile broadband devices. In that case use wwan%d as default
interface name.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Usbnet framework assumes USB hardware doesn't handle zero length
packets, but SMSC LAN95xx requires these to be sent for correct
operation.
This patch fixes an easily reproducible tx lockup when sending a frame
that results in exactly 512 bytes in a USB transmission (e.g. a UDP
frame with 458 data bytes, due to IP headers and our USB headers). It
adds an extra flag to usbnet for the hardware driver to indicate that
it can handle and requires the zero length packets.
This patch should not affect other usbnet users, please also consider
for -stable.
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
Add rx queue pausing to usbnet. This is needed by rndis_wlan so that it can
control rx queue and prevent received packets from being send forward before
rndis_wlan receives and handles 'media connect'-indication. Without this
establishing WPA connections is hard and fail often.
[v2] - removed unneeded use of skb_clone
Cc: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Allow rndis_wlan to see all indications. Currently rndis_host lets rndis_wlan to
know about link state changes only, but there is whole set of other
802.11-specific indications that rndis_wlan should handle properly. So rename
link_change() to indication() and convert rndis_wlan to use it.
rndis_wlan devices freeze after running usbnet_stop several times. It appears
that firmware freezes in state where it does not respond to any RNDIS commands
and device have to be physically unplugged/replugged. This patch lets
minidrivers to disable unlink_urbs on usbnet_stop through new info flag.
Allow minidriver to know that netdev has stopped. This is to let
wireless turn off radio when usbnet dev is stopped.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Now that nothing uses the private stats structure we can remove it.
because of using the same function get_ethernet_addr as cdc_ether.c
i export usbnet_get_ethernet_addr from usbnet and fixed cdc_ether
(suggested by Oliver Neukum).
Signed-off-by: Peter Holik <peter@holik.at>
Use net_device_ops for usbnet device, and export for use
by other derived drivers.
Improve usbnet's devdbg to always type-check diagnostic arguments,
like dev_dbg (device.h). This makes no change to the resulting size of
usbnet modules.
This patch also removes an #ifdef DEBUG directive from rndis_wlan so
it's devdbg statements are always type-checked at compile time.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
For the header files in include/linux/usb, add missing multiple
inclusion protection and standardize what's already there. The
apparent standards:
* macro name of __LINUX_USB_headerfile_H
* inclusion protection placed after leading comment block
* macro name added as a comment on the final #endif
* any obvious trivial whitespace cleanup associated with the above
Move headers usbnet.h and rndis_host.h to include/linux/usb and fix includes
for drivers/net/usb modules. Headers are moved because rndis_wlan will be
outside drivers/net/usb in drivers/net/wireless and yet need these headers.
