path: root/include/linux/usb
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-13USB: Add support for SuperSpeed isoc endpointsPaul Zimmerman
Use the Mult and bMaxBurst values from the endpoint companion descriptor to calculate the max length of an isoc transfer. Add USB_SS_MULT macro to access Mult field of bmAttributes, at Sarah's suggestion. This patch should be queued for the 2.6.36 and 2.6.37 stable trees, since those were the first kernels to have isochronous support for SuperSpeed devices. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-03-13USB: Remove bogus USB_PORT_STAT_SUPER_SPEED symbol.Sarah Sharp
USB_PORT_STAT_SUPER_SPEED is a made up symbol that the USB core used to track whether USB ports had a SuperSpeed device attached. This is a linux-internal symbol that was used when SuperSpeed and non-SuperSpeed devices would show up under the same xHCI roothub. This particular port status is never returned by external USB 3.0 hubs. (Instead they have a USB_PORT_STAT_SPEED_5GBPS that uses a completely different speed mask.) Now that the xHCI driver registers two roothubs, USB 3.0 devices will only show up under USB 3.0 hubs. Rip out USB_PORT_STAT_SUPER_SPEED and replace it with calls to hub_is_superspeed(). Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-03-13usb: Make core allocate resources per PCI-device.Sarah Sharp
Introduce the notion of a PCI device that may be associated with more than one USB host controller driver (struct usb_hcd). This patch is the start of the work to separate the xHCI host controller into two roothubs: a USB 3.0 roothub with SuperSpeed-only ports, and a USB 2.0 roothub with HS/FS/LS ports. One usb_hcd structure is designated to be the "primary HCD", and a pointer is added to the usb_hcd structure to keep track of that. A new function call, usb_hcd_is_primary_hcd() is added to check whether the USB hcd is marked as the primary HCD (or if it is not part of a roothub pair). To allow the USB core and xHCI driver to access either roothub in a pair, a "shared_hcd" pointer is added to the usb_hcd structure. Add a new function, usb_create_shared_hcd(), that does roothub allocation for paired roothubs. It will act just like usb_create_hcd() did if the primary_hcd pointer argument is NULL. If it is passed a non-NULL primary_hcd pointer, it sets usb_hcd->shared_hcd and usb_hcd->primary_hcd fields. It will also skip the bandwidth_mutex allocation, and set the secondary hcd's bandwidth_mutex pointer to the primary HCD's mutex. IRQs are only allocated once for the primary roothub. Introduce a new usb_hcd driver flag that indicates the host controller driver wants to create two roothubs. If the HCD_SHARED flag is set, then the USB core PCI probe methods will allocate a second roothub, and make sure that second roothub gets freed during rmmod and in initialization error paths. When usb_hc_died() is called with the primary HCD, make sure that any roothubs that share that host controller are also marked as being dead. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-03-13usb: Store bus type in usb_hcd, not in driver flags.Sarah Sharp
The xHCI driver essentially has both a USB 2.0 and a USB 3.0 roothub. So setting the HCD_USB3 bits in the hcd->driver->flags is a bit misleading. Add a new field to usb_hcd, bcdUSB. Store the result of hcd->driver->flags & HCD_MASK in it. Later, when we have the xHCI driver register the two roothubs, we'll set the usb_hcd->bcdUSB field to HCD_USB2 for the USB 2.0 roothub, and HCD_USB3 for the USB 3.0 roothub. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-03-13usb: Change usb_hcd->bandwidth_mutex to a pointer.Sarah Sharp
Change the bandwith_mutex in struct usb_hcd to a pointer. This will allow the pointer to be shared across usb_hcds for the upcoming work to split the xHCI driver roothub into a USB 2.0/1.1 and a USB 3.0 bus. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-03-13USB 3.0 Hub ChangesJohn Youn
Update the USB core to deal with USB 3.0 hubs. These hubs have a slightly different hub descriptor than USB 2.0 hubs, with a fixed (rather than variable length) size. Change the USB core's hub descriptor to have a union for the last fields that differ. Change the host controller drivers that access those last fields (DeviceRemovable and PortPowerCtrlMask) to use the union. Translate the new version of the hub port status field into the old version that khubd understands. (Note: we need to fix it to translate the roothub's port status once we stop converting it to USB 2.0 hub status internally.) Add new code to handle link state change status. Send out new control messages that are needed for USB 3.0 hubs, like Set Hub Depth. This patch is a modified version of the original patch submitted by John Youn. It's updated to reflect the removal of the "bitmap" #define, and change the hub descriptor accesses of a couple new host controller drivers. Signed-off-by: John Youn <johnyoun@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Max Vozeler <mvz@vozeler.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <dbrownell@users.sourceforge.net>
2011-03-13USB: Remove bitmap #define from hcd.hSarah Sharp
Using a #define to redefine a common variable name is a bad thing, especially when the #define is in a header. include/linux/usb/hcd.h redefined bitmap to DeviceRemovable to avoid typing a long field in the hub descriptor. This has unintended side effects for files like drivers/usb/core/devio.c that include that file, since another header included after hcd.h has different variables named bitmap. Remove the bitmap #define and replace instances of it in the host controller code. Cleanup the spaces around function calls and square brackets while we're at it. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Max Vozeler <mvz@vozeler.com> Cc: Tejun Heo <tj@kernel.org> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Lothar Wassmann <LW@KARO-electronics.de> Cc: Olav Kongas <ok@artecdesign.ee> Cc: Martin Fuzzey <mfuzzey@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: David Brownell <dbrownell@users.sourceforge.net>
2011-03-11usb: host: Add EHCI driver for NVIDIA Tegra SoCsBenoit Goby
The Tegra 2 SoC has 3 EHCI compatible USB controllers. This patch adds the necessary glue to allow the ehci-hcd driver to work on Tegra 2 SoCs. The platform data is used to configure board-specific phy settings and to configure the operating mode, as one of the ports may be used as a otg port. For additional power saving, the driver supports powering down the phy on bus suspend when it is used, for example, to connect an internal device that use an out-of-band remote wakeup mechanism (e.g. a gpio). Signed-off-by: Benoit Goby <benoit@android.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-11usb: otg: Add ulpi viewport access opsBenoit Goby
Add generic access ops for controllers with a ulpi viewport register (e.g. Chipidea/ARC based controllers). Signed-off-by: Benoit Goby <benoit@android.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07USB: Rename "msm72k_otg.c" to "msm_otg.c"Pavankumar Kondeti
This driver is used across all MSM SoCs. Hence give a generic name. All Functions and strutures are also using "msm_otg" as prefix. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-07USB: move usbcore away from hcd->stateAlan Stern
The hcd->state variable is a disaster. It's not clearly owned by either usbcore or the host controller drivers, and they both change it from time to time, potentially stepping on each other's toes. It's not protected by any locks. And there's no mechanism to prevent it from going through an invalid transition. This patch (as1451) takes a first step toward fixing these problems. As it turns out, usbcore uses hcd->state for essentially only two things: checking whether the controller's root hub is running and checking whether the controller has died. Therefore the patch adds two new atomic bitflags to the hcd structure, to store these pieces of information. The new flags are used only by usbcore, and a private spinlock prevents invalid combinations (a dead controller's root hub cannot be running). The patch does not change the places where usbcore sets hcd->state, since HCDs may depend on them. Furthermore, there is one place in usb_hcd_irq() where usbcore still must use hcd->state: An HCD's interrupt handler can implicitly indicate that the controller died by setting hcd->state to HC_STATE_HALT. Nevertheless, the new code is a big improvement over the current code. The patch makes one other change. The hcd_bus_suspend() and hcd_bus_resume() routines now check first whether the host controller has died; if it has then they return immediately without calling the HCD's bus_suspend or bus_resume methods. This fixes the major problem reported in Bugzilla #29902: The system fails to suspend after a host controller dies during system resume. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Alex Terekhov <a.terekhov@gmail.com> CC: <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-25USB: fix unsafe USB_SS_MAX_STREAMS() definitionDmitry Torokhov
Macro arguments used in expressions need to be enclosed in parenthesis to avoid unpleasant surprises. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-25USB: serial drivers need to use larger bulk-in buffersAlan Stern
When a driver doesn't know how much data a device is going to send, the buffer size should be at least as big as the endpoint's maxpacket value. The serial drivers don't follow this rule; many of them request only 256-byte bulk-in buffers. As a result, they suffer overflow errors if a high-speed device wants to send a lot of data, because high-speed bulk endpoints are required to have a maxpacket size of 512. This patch (as1450) fixes the problem by using the driver's bulk_in_size value as a minimum, always allocating buffers no smaller than the endpoint's maxpacket size. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Flynn Marquardt <flynn@flynnux.de> CC: <stable@kernel.org> [after .39-rc1 is out] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-24Merge 2.6.38-rc6 into tty-nextGreg Kroah-Hartman
This was to resolve a merge issue with drivers/char/Makefile and drivers/tty/serial/68328serial.c Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-18usb: otg: notifier: switch to atomic notifierFelipe Balbi
most of our notifications, will be called from IRQ context, so an atomic notifier suits the job better. Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-02-18usb: otg: TWL6030 Save the last event in otg_transceiverHema HK
Save the last event in the otg_transceiver so that it can used in the musb driver and gadget driver to configure the musb and enable the vbus for host mode and OTG mode, if the device is connected during boot. Signed-off-by: Hema HK <hemahk@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-02-17tty: remove filp from the USB tty ioctlsAlan Cox
We don't use it so we can trim it from here as we try and stamp the file object dependencies out of the serial code. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: usb.h: Make comment match the defines it describesPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17Merge 2.6.38-rc5 into usb-nextGreg Kroah-Hartman
This is needed to resolve some merge conflicts that were found in the USB host controller patches, and reported by Stephen Rothwell. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-10Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (21 commits) USB: cdc-acm: Adding second ACM channel support for Nokia N8 USB, Mass Storage, composite, gadget: Fix build failure and memset of a struct USB: Fix trout build failure with ci13xxx_msm gadget USB: EHCI: fix scheduling while atomic during suspend USB: usb-storage: unusual_devs entry for Coby MP3 player USB: ftdi_sio: Add VID=0x0647, PID=0x0100 for Acton Research spectrograph USB: fix race between root-hub resume and wakeup requests USB: prevent buggy hubs from crashing the USB stack usb: r8a66597-udc: Fixed bufnum of Bulk USB: ftdi_sio: add ST Micro Connect Lite uart support USB: Storage: Add unusual_devs entry for VTech Kidizoom USB SL811HS HCD: Fix memory leak in sl811h_urb_enqueue() USB: ti_usb: fix module removal USB: io_edgeport: fix the reported firmware major and minor usb: ehci-omap: Show fatal probing time errors to end user usb: musb: introduce api for dma code to check compatibility with usb request usb: musb: maintain three states for buffer mappings instead of two usb: musb: disable double buffering when it's broken usb: musb: hsdma: change back to use musb_read/writew usb: musb: core: fix IRQ check ...
2011-02-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) virtio_net: Add schedule check to napi_enable call x25: Do not reference freed memory. pch_can: fix tseg1/tseg2 setting issue isdn: hysdn: Kill (partially buggy) CVS regision log reporting. can: softing_cs needs slab.h pch_gbe: Fix the issue which a driver locks when rx offload is set by ethtool netfilter: nf_conntrack: set conntrack templates again if we return NF_REPEAT pch_can: fix module reload issue with MSI pch_can: fix rmmod issue pch_can: fix 800k comms issue net: Fix lockdep regression caused by initializing netdev queues too early. net/caif: Fix dangling list pointer in freed object on error. USB CDC NCM errata updates for cdc_ncm host driver CDC NCM errata updates for cdc.h ixgbe: update version string ixgbe: cleanup variable initialization ixgbe: limit VF access to network traffic ixgbe: fix for 82599 erratum on Header Splitting ixgbe: fix variable set but not used warnings by gcc 4.6 e1000: add support for Marvell Alaska M88E1118R PHY ...
2011-02-08CDC NCM errata updates for cdc.hAlexey Orishko
Changes are based on the following documents: - CDC NCM errata: http://www.usb.org/developers/devclass_docs/NCM10_012011.zip - CDC and WMC errata link: http://www.usb.org/developers/devclass_docs/CDC1.2_WMC1.1_012011.zip Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-04USB: Fix trout build failure with ci13xxx_msm gadgetPavankumar Kondeti
This patch fixes the below compilation errors. CC drivers/usb/gadget/ci13xxx_msm.o CC net/mac80211/led.o drivers/usb/gadget/ci13xxx_msm.c: In function 'ci13xxx_msm_notify_event': drivers/usb/gadget/ci13xxx_msm.c:42: error: 'USB_AHBBURST' undeclared (first use in this function) drivers/usb/gadget/ci13xxx_msm.c:42: error: (Each undeclared identifier is reported only once drivers/usb/gadget/ci13xxx_msm.c:42: error: for each function it appears in.) drivers/usb/gadget/ci13xxx_msm.c:43: error: 'USB_AHBMODE' undeclared (first use in this function) make[4]: *** [drivers/usb/gadget/ci13xxx_msm.o] Error 1 make[3]: *** [drivers/usb/gadget] Error 2 MSM USB driver is not supported on boards like trout (MSM7201) which has an external PHY. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04USB: gadget: export functionfs.h to the includes available for userspaceMarek Szyprowski
To compile functionfs userspace driver one needs definitions from include/linux/usb/functionfs.h. This patch add this file to the list of includes exported to userspace. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04USB: HCD: Add driver hooks for (un)?map_urb_for_dmaRobert Morell
Provide optional hooks for the host controller driver to override the default DMA mapping and unmapping routines. In general, these shouldn't be necessary unless the host controller has special DMA requirements, such as alignment contraints. If these are not specified, the general usb_hcd_(un)?map_urb_for_dma functions will be used instead. Also, pass the status to unmap_urb_for_dma so it can know whether the DMA buffer has been overwritten. Finally, add a flag to be used by these implementations if they allocated a temporary buffer so it can be freed properly when unmapping. Signed-off-by: Robert Morell <rmorell@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04USB: HCD: Add usb_hcd prefix to exported functionsRobert Morell
The convention is to prefix symbols exported from the USB HCD core with "usb_hcd". This change makes unmap_urb_setup_for_dma() and unmap_urb_for_dma() consistent with that. Signed-off-by: Robert Morell <rmorell@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-24Merge branch 'for-usb-linus' of ↵Greg Kroah-Hartman
master.kernel.org:/pub/scm/linux/kernel/git/sarah/xhci into usb-linus * 'for-usb-linus' of master.kernel.org:/pub/scm/linux/kernel/git/sarah/xhci: xhci: Remove more doorbell-related reads xHCI: fix printk_ratelimit() usage xHCI: replace dev_dbg() with xhci_dbg() xHCI: fix cycle bit set in giveback_first_trb() xHCI: remove redundant parameter in giveback_first_trb() xHCI: fix queue_trb in isoc transfer xhci: Use GFP_NOIO during device reset. usb: Realloc xHCI structures after a hub is verified. xhci: Do not run xhci_cleanup_msix with irq disabled xHCI: synchronize irq in xhci_suspend() xhci: Resume bus on any port status change.
2011-01-22USB: serial: handle Data Carrier Detect changesLibor Pechacek
Alan's commit 335f8514f200e63d689113d29cb7253a5c282967 introduced .carrier_raised function in several drivers. That also means tty_port_block_til_ready can now suspend the process trying to open the serial port when Carrier Detect is low and put it into tty_port.open_wait queue. We need to wake up the process when Carrier Detect goes high and trigger TTY hangup when CD goes low. Some of the devices do not report modem status line changes, or at least we don't understand the status message, so for those we remove .carrier_raised again. Signed-off-by: Libor Pechacek <lpechacek@suse.cz> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-14xHCI: synchronize irq in xhci_suspend()Andiry Xu
Synchronize the interrupts instead of free them in xhci_suspend(). This will prevent a double free when the host is suspended and then the card removed. Set the flag hcd->msix_enabled when using MSI-X, and check the flag in suspend_common(). MSI-X synchronization will be handled by xhci_suspend(), and MSI/INTx will be synchronized in suspend_common(). This patch should be queued for the 2.6.37 stable tree. Reported-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-01-07Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits) USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004) USB: serial: ftdi_sio: add support for TIOCSERGETLSR USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport USB: atmel_usba_udc: fix freeing irq in usba_udc_remove() usb: ehci-omap: fix tll channel enable mask usb: ohci-omap3: fix trivial typo USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096 USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's USB: gadget: update ci13xxx to work with g_ether USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers Revert "USB: musb: pm: don't rely fully on clock support" Revert "USB: musb: blackfin: pm: make it work" USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added ... Manually fix up trivial conflicts in USB Kconfig changes in: arch/arm/mach-omap2/Kconfig arch/sh/Kconfig drivers/usb/Kconfig drivers/usb/host/ehci-hcd.c and annoying chip clock data conflicts in: arch/arm/mach-omap2/clock3xxx_data.c arch/arm/mach-omap2/clock44xx_data.c
2010-12-16Merge branch 'usb-next' into musb-mergeGreg Kroah-Hartman
* usb-next: (132 commits) USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added usb: gadget: f_ncm.c added usb: gadget: u_ether: prepare for NCM usb: pch_udc: Fix setup transfers with data out usb: pch_udc: Fix compile error, warnings and checkpatch warnings usb: add ab8500 usb transceiver driver USB: gadget: Implement runtime PM for MSM bus glue driver USB: gadget: Implement runtime PM for ci13xxx gadget USB: gadget: Add USB controller driver for MSM SoC USB: gadget: Introduce ci13xxx_udc_driver struct USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc USB: gadget: Separate out PCI bus code from ci13xxx_udc ...
2010-12-15Merge branch 'musb-hw' of git://gitorious.org/usb/usb into musbGreg Kroah-Hartman
* 'musb-hw' of git://gitorious.org/usb/usb: (43 commits) usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource arm: OMAP4430: musb: Configure musb to OTG mode usb: musb: Adding musb support for OMAP4430 usb: otg: TWL6030: Add twl6030_usb file for compilation mfd: TWL6030: OMAP4: Registering the TWL6030-usb device usb: musb: TWL6030: Selecting TWL6030_USB transceiver usb: otg: Kconfig: Add Kconfig option for TWL6030 transceiver. usb: otg: Adding twl6030-usb transceiver driver for OMAP4430 mfd: TWL6030: USBOTG VBUS event generation on usb: musb: add support for ux500 platform musb: am35x: fix compile error due to control apis arm: omap4: enable usb on 4430sdp usb: musb: drop board_set_vbus usb: musb: drop musb_platform_suspend/resume usb: musb: blackfin: usb dev_pm_ops structure usb: musb: am35x: usb dev_pm_ops structure usb: musb: omap2430: use dev_pm_ops structure usb: musb: omap2430: drop the nops usb: musb: mark musb_save/restore_context static ...
2010-12-10USB: OTG: msm: Add support for power managementPavankumar Kondeti
Implement runtime and system pm ops to put hardware into low power mode (LPM). As part of LPM, USB clocks are turned off, PHY is put into suspend state and PHY comparators are turned off if VBUS/Id notifications are not required from PHY. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10USB: Add MSM OTG Controller driverPavankumar Kondeti
This driver implements PHY initialization, clock management, ULPI IO ops and simple OTG state machine to kick host/peripheral based on Id/VBUS line status. VBUS/Id lines are tied to a reference voltage on some boards. Hence provide debugfs interface to select host/peripheral mode. Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10USB: otg: fix link breakage, when the NOP USB Xceiver is a moduleGuennadi Liakhovetski
If the NOP USB OTG transceiver driver is built as a module, the otg.h header declares external functions, but if they are referenced from the kernel proper, as, e.g., in the OMAP3 case, where the omap3evm board is calling the usb_nop_xceiv_register() function, linkage breaks. This patch fixes this problem. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-10usb: musb: drop the set_clock magicFelipe Balbi
now that platform glue layer handles clock completely, that function is completely useless for us. Drop it. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: mark ->set_clock deprecatedFelipe Balbi
... we will completely drop that need by moving clock handling to platform glue layer. Marking as deprecated will allow us to catch all users easily. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: pass platform_ops via platform_dataFelipe Balbi
... then we don't need to export any symbols from glue layer to musb_core. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-10usb: musb: trivial search and replace patchFelipe Balbi
change all ocurrences of musb_hdrc to musb-hdrc. We will call glue layer drivers musb-<glue layer>, so in order to keep things somewhat standard, let's change the underscore into a dash. Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-12-06usbnet: changes for upcoming cdc_ncm driverAlexey Orishko
Changes: include/linux/usb/usbnet.h: - a new flag to indicate driver's capability to accumulate IP packets in Tx direction and extract several packets from single skb in Rx direction. drivers/net/usb/usbnet.c: - the procedure of counting packets in usbnet was updated due to the accumulating of IP packets in the driver - no short packets are sent if indicated by the flag in driver_info structure Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30usb: gadget: langwell_udc: add usb test mode supportLuo Andy
This patch adds test mode support for Langwell gadget driver. Signed-off-by: Henry Yuan <hang.yuan@intel.com> Signed-off-by: Andy Luo <yifei.luo@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11usb: USB3.0 ch11 definitionsTatyana Brokhman
Adding hub SuperSpeed usb definitions as defined by ch10 of the USB3.0 spec. Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-05USB: musb: blackfin: push clkin value to platform resourcesBob Liu
In order to not touch the driver file for different xtal usage, push the clkin value to board file and calculate the register value instead of hardcoding it. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits) USB: mct_u232: fix broken close USB: gadget: amd5536udc.c: fix error path USB: imx21-hcd - fix off by one resource size calculation usb: gadget: fix Kconfig warning usb: r8a66597-udc: Add processing when USB was removed. mxc_udc: add workaround for ENGcm09152 for i.MX35 USB: ftdi_sio: add device ids for ScienceScope USB: musb: AM35x: Workaround for fifo read issue USB: musb: add musb support for AM35x USB: AM35x: Add musb support usb: Fix linker errors with CONFIG_PM=n USB: ohci-sh - use resource_size instead of defining its own resource_len macro USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro USB: xhci: Fix compile error when CONFIG_PM=n USB: accept some invalid ep0-maxpacket values USB: xHCI: PCI power management implementation USB: xHCI: bus power management implementation USB: xHCI: port remote wakeup implementation USB: xHCI: port power management implementation ... Manually fix up (non-data) conflict: the SCSI merge gad renamed the 'hw_sector_size' member to 'physical_block_size', and the USB tree brought a new use of it.
2010-10-22usb: usb3.0 ch9 definitionsTatyana Brokhman
Adding SuperSpeed usb definitions as defined by ch9 of the USB3.0 spec. This patch is a preparation for adding SuperSpeed support to the gadget framework. Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: introduce unmap_urb_setup_for_dma()Martin Fuzzey
Split unmap_urb_for_dma() to allow just the setup buffer to be unmapped. This allows HCDs to use PIO for the setup buffer if it is not suitable for DMA. Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: Add more empty functions in otg.hGrazvydas Ignotas
Add empty functions for get/put transceiver functions too, so that drivers that optionally use them can call them without worrying that they might not exist, eliminating ifdefs. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
