path: root/include/linux/user_namespace.h
2011-01-13user_ns: improve the user_ns on-the-slab packagingPavel Emelyanov
Currently on 64-bit arch the user_namespace is 2096 and when being kmalloc-ed it resides on a 4k slab wasting 2003 bytes. If we allocate a separate cache for it and reduce the hash size from 128 to 64 chains the packaging becomes *much* better - the struct is 1072 bytes and the hole between is 98 bytes. [akpm@linux-foundation.org: s/__initcall/module_init/] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-16user_ns: Introduce user_nsmap_uid and user_ns_map_gid.Eric W. Biederman
Define what happens when a we view a uid from one user_namespace in another user_namepece. - If the user namespaces are the same no mapping is necessary. - For most cases of difference use overflowuid and overflowgid, the uid and gid currently used for 16bit apis when we have a 32bit uid that does fit in 16bits. Effectively the situation is the same, we want to return a uid or gid that is not assigned to any user. - For the case when we happen to be mapping the uid or gid of the creator of the target user namespace use uid 0 and gid as confusing that user with root is not a problem. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-27Fix recursive lock in free_uid()/free_user_ns()David Howells
free_uid() and free_user_ns() are corecursive when CONFIG_USER_SCHED=n, but free_user_ns() is called from free_uid() by way of uid_hash_remove(), which requires uidhash_lock to be held. free_user_ns() then calls free_uid() to complete the destruction. Fix this by deferring the destruction of the user_namespace. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-24User namespaces: set of cleanups (v2)Serge Hallyn
The user_ns is moved from nsproxy to user_struct, so that a struct cred by itself is sufficient to determine access (which it otherwise would not be). Corresponding ecryptfs fixes (by David Howells) are here as well. Fix refcounting. The following rules now apply: 1. The task pins the user struct. 2. The user struct pins its user namespace. 3. The user namespace pins the struct user which created it. User namespaces are cloned during copy_creds(). Unsharing a new user_ns is no longer possible. (We could re-add that, but it'll cause code duplication and doesn't seem useful if PAM doesn't need to clone user namespaces). When a user namespace is created, its first user (uid 0) gets empty keyrings and a clean group_info. This incorporates a previous patch by David Howells. Here is his original patch description: >I suggest adding the attached incremental patch. It makes the following >changes: > > (1) Provides a current_user_ns() macro to wrap accesses to current's user > namespace. > > (2) Fixes eCryptFS. > > (3) Renames create_new_userns() to create_user_ns() to be more consistent > with the other associated functions and because the 'new' in the name is > superfluous. > > (4) Moves the argument and permission checks made for CLONE_NEWUSER to the > beginning of do_fork() so that they're done prior to making any attempts > at allocation. > > (5) Calls create_user_ns() after prepare_creds(), and gives it the new creds > to fill in rather than have it return the new root user. I don't imagine > the new root user being used for anything other than filling in a cred > struct. > > This also permits me to get rid of a get_uid() and a free_uid(), as the > reference the creds were holding on the old user_struct can just be > transferred to the new namespace's creator pointer. > > (6) Makes create_user_ns() reset the UIDs and GIDs of the creds under > preparation rather than doing it in copy_creds(). > >David >Signed-off-by: David Howells <dhowells@redhat.com> Changelog: Oct 20: integrate dhowells comments 1. leave thread_keyring alone 2. use current_user_ns() in set_user() Signed-off-by: Serge Hallyn <serue@us.ibm.com>
2007-09-19Convert uid hash to hlistPavel Emelyanov
Surprisingly, but (spotted by Alexey Dobriyan) the uid hash still uses list_heads, thus occupying twice as much place as it could. Convert it to hlist_heads. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19user namespace: fix copy_user_ns return valueSerge E. Hallyn
When a CONFIG_USER_NS=n and a user tries to unshare some namespace other than the user namespace, the dummy copy_user_ns returns NULL rather than the old_ns. This value then gets assigned to task->nsproxy->user_ns, so that a subsequent setuid, which uses task->nsproxy->user_ns, causes a NULL pointer deref. Fix this by returning old_ns. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16user namespace: add unshareSerge E. Hallyn
This patch enables the unshare of user namespaces. It adds a new clone flag CLONE_NEWUSER and implements copy_user_ns() which resets the current user_struct and adds a new root user (uid == 0) For now, unsharing the user namespace allows a process to reset its user_struct accounting and uid 0 in the new user namespace should be contained using appropriate means, for instance selinux The plan, when the full support is complete (all uid checks covered), is to keep the original user's rights in the original namespace, and let a process become uid 0 in the new namespace, with full capabilities to the new namespace. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Andrew Morgan <agm@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16user namespace: add the frameworkCedric Le Goater
Basically, it will allow a process to unshare its user_struct table, resetting at the same time its own user_struct and all the associated accounting. A new root user (uid == 0) is added to the user namespace upon creation. Such root users have full privileges and it seems that theses privileges should be controlled through some means (process capabilities ?) The unshare is not included in this patch. Changes since [try #4]: - Updated get_user_ns and put_user_ns to accept NULL, and get_user_ns to return the namespace. Changes since [try #3]: - moved struct user_namespace to files user_namespace.{c,h} Changes since [try #2]: - removed struct user_namespace* argument from find_user() Changes since [try #1]: - removed struct user_namespace* argument from find_user() - added a root_user per user namespace Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Andrew Morgan <agm@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
