path: root/include/linux/uts.h
2011-06-15uts: make default hostname configurable, rather than always using "(none)"Josh Triplett
The "hostname" tool falls back to setting the hostname to "localhost" if /etc/hostname does not exist. Distribution init scripts have the same fallback. However, if userspace never calls sethostname, such as when booting with init=/bin/sh, or otherwise booting a minimal system without the usual init scripts, the default hostname of "(none)" remains, unhelpfully appearing in various places such as prompts ("root@(none):~#") and logs. Furthermore, "(none)" doesn't typically resolve to anything useful. Make the default hostname configurable. This removes the need for the standard fallback, provides a useful default for systems that never call sethostname, and makes minimal systems that much more useful with less configuration. Distributions could choose to use "localhost" here to avoid the fallback, while embedded systems may wish to use a specific target hostname. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: David Miller <davem@davemloft.net> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Kel Modderman <kel@otaku42.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
