path: root/include/linux/vga_switcheroo.h
2014-09-18vgaswitcheroo: add vga_switcheroo_fini_domain_pm_opsAlex Deucher
Drivers should call this on unload to unregister pmops. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=84431 Reviewed-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com>
2013-08-29gpu/vga_switcheroo: add driver control power feature. (v3)Dave Airlie
For optimus and powerxpress muxless we really want the GPU driver deciding when to power up/down the GPU, not userspace. This adds the ability for a driver to dynamically power up/down the GPU and remove the switcheroo from controlling it, the switcheroo reports the dynamic state to userspace also. It also adds 2 power domains, one for machine where the power switch is controlled outside the GPU D3 state, so the powerdown ordering is done correctly, and the second for the hdmi audio device to make sure it can resume for PCI config space accesses. v1.1: fix build with switcheroo off v2: add power domain support for radeon and v1 nvidia dsms v2.1: fix typo in off case v3: add audio power domain for hdmi audio + misc audio fixes v4: use PCI_SLOT macro, drop power reference on hdmi audio resume failure also. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-06-21vga_switcheroo: Add include guardOzan Çağlayan
Guard vga_switcheroo.h against multiple inclusion. Signed-off-by: Ozan Çağlayan <ozancag@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-06-16vga_switcheroo.h: fix pci_dev warningRandy Dunlap
Fix warnings on some architectures/configs (not on x86): include/linux/vga_switcheroo.h:28:30: warning: 'struct pci_dev' declared inside parameter list [enabled by default] include/linux/vga_switcheroo.h:28:30: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Takashi Iwai <tiwai@suse.de> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-06-08vga_switcheroo: Fix error without CONFIG_VGA_SWITCHEROOTakashi Iwai
Fix a typo that is built only when CONFIG_VGA_SWITCHEROO=n. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-08vga_switcheroo: Add a helper function to get the client stateTakashi Iwai
Add vga_switcheroo_get_client_state() to get the current state of the client. This is necessary to determine the proper initial state of audio clients in HD-audio driver. Acked-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-13vga_switcheroo: Add the support for audio clientsTakashi Iwai
Add the support for audio clients to VGA-switcheroo for handling the HDMI audio controller together with VGA switching. The id of the audio controller should be given explicitly at registration time unlike the video controller. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43155 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-13vga_switcheroo: Introduce struct vga_switcheroo_client_opsTakashi Iwai
This changes the API as a clean-up. Instead of passing multiple function pointers at each time, introduce a new struct holding the whole callback functions and pass it to the registration. The same struct will be used for the upcoming audio client registration, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-06vga_switcheroo: fix build with non switcheroo enabled path.Dave Airlie
2011-01-05vga_switcheroo: add reprobe hook for fbcon to recheck connected outputs.Dave Airlie
This adds a hook after the mux is switched for the driver to reprobe the connected outputs. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01vga_switcheroo: fix build on platforms with no ACPIDave Airlie
radeon was always including the atpx code unnecessarily, also core switcheroo was including acpi headers. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01vga_switcheroo: initial implementation (v15)Dave Airlie
Many new laptops now come with 2 gpus, one to be used for low power modes and one for gaming/on-ac applications. These GPUs are typically wired to the laptop panel and VGA ports via a multiplexer unit which is controlled via ACPI methods. 4 combinations of systems typically exist - with 2 ACPI methods. Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method ATI/ATI - some ASUS - use ATPX ACPI Method Intel/Nvidia - - use _DSM ACPI method Nvidia/Nvidia - - use _DSM ACPI method. TODO: This patch adds support for the ATPX method and initial bits for the _DSM methods that need to written by someone with access to the hardware. Add a proper non-debugfs interface - need to get some proper testing first. v2: add power up/down support for both devices on W500 puts i915/radeon into D3 and cuts power to radeon. v3: redo probing methods, no DMI list, drm devices call to register with switcheroo, it tries to find an ATPX method on any device and once there is two devices + ATPX it inits the switcher. v4: ATPX msg handling using buffers - should work on more machines v5: rearchitect after more mjg59 discussion - move ATPX handling to radeon driver. v6: add file headers + initial nouveau bits (to be filled out). v7: merge delayed switcher code. v8: avoid suspend/resume of gpu that is off v9: rearchitect - mjg59 is always right. - move all ATPX code to radeon, should allow simpler DSM also proper ATRM handling v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv v11: fix bug in resuming Intel for 2nd time. v12: start fixing up nvidia code blindly. v13: blindly guess at finishing nvidia code v14: remove radeon audio hacks - fix up intel resume more like upstream v15: clean up printks + remove unnecessary igd/dis pointers mount debugfs /sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected + 2 cards. DIS - immediate change to discrete IGD - immediate change to IGD DDIS - delayed change to discrete DIGD - delayed change to IGD ON - turn on not in use OFF - turn off not in use Tested on W500 (Intel/ATI) and T500 (Intel/ATI) Signed-off-by: Dave Airlie <airlied@redhat.com>
