path: root/include/linux/vgaarb.h
2010-08-27vgaarb: Wrap vga_(get|put) in CONFIG_VGA_ARBChris Wilson
Fix link failure without the vga arbitrator. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-12vgaarb: drop vga.h includeDave Airlie
We don't actually need this include on any platform. built on powerpc + x86, reported on m68k. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-21include/linux/vgaarb.h: add missing part of include guardDoug Goldstein
vgaarb.h was missing the #define of the #ifndef at the top for the guard to prevent multiple #include's from causing re-define errors Signed-off-by: Doug Goldstein <cardoe@gentoo.org> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-03vgaarb: use MIT licenseTiago Vignatti
Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com> Cc: Henry Zhao <Henry.Zhao@Sun.COM> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-24Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: make 32 bit NUMA node array int, not unsigned char x86/PCI: default pcibus cpumask to all cpus if it lacks affinity MAINTAINTERS: remove hotplug driver entries PCI: pciehp: remove slot capabilities definitions PCI: pciehp: remove error message definitions PCI: pciehp: remove number field PCI: pciehp: remove hpc_ops PCI: pciehp: remove pci_dev field PCI: pciehp: remove crit_sect mutex PCI: pciehp: remove slot_bus field PCI: pciehp: remove first_slot field PCI: pciehp: remove slot_device_offset field PCI: pciehp: remove hp_slot field PCI: pciehp: remove device field PCI: pciehp: remove bus field PCI: pciehp: remove slot_num_inc field PCI: pciehp: remove num_slots field PCI: pciehp: remove slot_list field PCI: fix VGA arbiter header file PCI: Disable AER with pci=nomsi ... Fixed up trivial conflicts in MAINTAINERS
2009-09-23vgaarb: make client interface config invariant.Ingo Molnar
Fixes build when VGA_ARB is off. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-17PCI: fix VGA arbiter header fileJesse Barnes
Remove reference to vgaarb.c and replace it with a comment about the arbiter itself. Reported-by: Tiago Vignatti <tiago.vignatti@nokia.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI/vgaarb: cleanup some warnings + cleanup some comments.Dave Airlie
Fix some warnings reported in linux-next + also cleanup some comment errors noticed by Pekka Paalanen. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI/GPU: implement VGA arbitration on LinuxBenjamin Herrenschmidt
Background: Graphic devices are accessed through ranges in I/O or memory space. While most modern devices allow relocation of such ranges, some "Legacy" VGA devices implemented on PCI will typically have the same "hard-decoded" addresses as they did on ISA. For more details see "PCI Bus Binding to IEEE Std 1275-1994 Standard for Boot (Initialization Configuration) Firmware Revision 2.1" Section 7, Legacy Devices. The Resource Access Control (RAC) module inside the X server currently does the task of arbitration when more than one legacy device co-exists on the same machine. But the problem happens when these devices are trying to be accessed by different userspace clients (e.g. two server in parallel). Their address assignments conflict. Therefore an arbitration scheme _outside_ of the X server is needed to control the sharing of these resources. This document introduces the operation of the VGA arbiter implemented for Linux kernel. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
