path: root/include/linux/vgaarb.h
2013-10-11Revert "i915: Update VGA arbiter support for newer devices"Dave Airlie
This reverts commit 81b5c7bc8de3e6f63419139c2fc91bf81dea8a7d. Adding drm/i915 into the vga arbiter chain means that X (in a piece of well-meant paranoia) will do a get/put on the vga decoding around _every_ accel call down into the ddx. Which results in some nice performance disasters [1]. This really breaks userspace, by disabling DRI for everyone, and stops OpenGL from working, this isn't limited to just the i915 but both the integrated and discrete GPUs on multi-gpu systems, in other words this causes untold worlds of pain, Ville tried to come up with a Great Hack to fiddle the required VGA I/O ops behind everyone's back using stop_machine, but that didn't really work out [2]. Given that we're fairly late in the -rc stage for such games let's just revert this all. One thing we might want to keep is to delay the disabling of the vga decoding until the fbdev emulation and the fbcon screen is set up. If we kill vga mem decoding beforehand fbcon can end up with a white square in the top-left corner it tried to save from the vga memory for a seamless transition. And we have bug reports on older platforms which seem to match these symptoms. But again that's something to play around with in -next. References: [1] http://lists.x.org/archives/xorg-devel/2013-September/037763.html References: [2] http://www.spinics.net/lists/intel-gfx/msg34062.html Cc: Alex Williamson <alex.williamson@redhat.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-09-03i915: Update VGA arbiter support for newer devicesAlex Williamson
This is intended to add VGA arbiter support for Intel HD graphics on Core processors. The old GMCH registers no longer exist, so even though it appears that i915 participates in VGA arbitration, it doesn't work. On Intel HD graphics we already attempt to disable VGA regions of the device. This makes registering as a VGA client unnecessary since we don't intend to operate differently depending on how many VGA devices are present. We can disable VGA memory regions by clearing the memory enable bit in the VGA MSR. That only leaves VGA IO, which we update the VGA arbiter to know that we don't participate in VGA memory arbitration. We also add a hook on unload to re-enable memory and reinstate VGA memory arbitration. v3: Use explicit LEGACY_IO | LEGACY_MEM when restoring rather than LEGACY_MASK, per Ville's comments. v2: I915_READ/WRITE accessors don't work in i915_disable_vga, use inb/outb directly. Also, on the driver unbind VGA enable path, acquire legacy IO to re-enable VGA memory. Correct comment. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> [danvet: Add patch changelog. Also squash in a fixup to have a dummy static inline for vga_set_legacy_decoding for CONFIG_VGA_ARB=n as reported by the 0-day kernel build bot.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> fixup 2
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-03vgaarb: Provide dummy default device functionsMatthew Garrett
Add some stub functions for the case where CONFIG_VGA_ARB is disabled. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-02Merge tag 'drm-intel-next-2012-04-23' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-core-next Daniel Vetter writes: A new drm-intel-next pull. Highlights: - More gmbus patches from Daniel Kurtz, I think gmbus is now ready, all known issues fixed. - Fencing cleanup and pipelined fencing removal from Chris. - rc6 residency interface from Ben, useful for powertop. - Cleanups and code reorg around the ringbuffer code (Ben&me). - Use hw semaphores in the pageflip code from Ben. - More vlv stuff from Jesse, unfortunately his vlv cpu is doa, so less merged than I've hoped for - we still have the unused function warning :( - More hsw patches from Eugeni, again, not yet enabled fully. - intel_pm.c refactoring from Eugeni. - Ironlake sprite support from Chris. - And various smaller improvements/fixes all over the place. Note that this pull request also contains a backmerge of -rc3 to sort out a few things in -next. I've also had to frob the shortlog a bit to exclude anything that -rc3 brings in with this pull. Regression wise we have a few strange bugs going on, but for all of them closer inspection revealed that they've been pre-existing, just now slightly more likely to be hit. And for most of them we have a patch already. Otherwise QA has not reported any regressions, and I'm also not aware of anything bad happening in 3.4. * tag 'drm-intel-next-2012-04-23' of git://people.freedesktop.org/~danvet/drm-intel: (420 commits) drm/i915: rc6 residency (fix the fix) drm/i915/tv: fix open-coded ARRAY_SIZE. drm/i915: invalidate render cache on gen2 drm/i915: Silence the change of LVDS sync polarity drm/i915: add generic power management initialization drm/i915: move clock gating functionality into intel_pm module drm/i915: move emon functionality into intel_pm module drm/i915: move drps, rps and rc6-related functions to intel_pm drm/i915: fix line breaks in intel_pm drm/i915: move watermarks settings into intel_pm module drm/i915: move fbc-related functionality into intel_pm module drm/i915: Refactor get_fence() to use the common fence writing routine drm/i915: Refactor fence clearing to use the common fence writing routine drm/i915: Refactor put_fence() to use the common fence writing routine drm/i915: Prepare to consolidate fence writing drm/i915: Remove the unsightly "optimisation" from flush_fence() drm/i915: Simplify fence finding drm/i915: Discard the unused obj->last_fenced_ring drm/i915: Remove unused ring->setup_seqno drm/i915: Remove fence pipelining ...
2012-04-24vgaarb: Add support for setting the default video device (v2)Matthew Garrett
The default VGA device is a somewhat fluid concept on platforms with multiple GPUs. Add support for setting it so switching code can update things appropriately, and make sure that the sysfs code returns the right device if it's changed. v2: Updated to fix builds when __ARCH_HAS_VGA_DEFAULT_DEVICE is false. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: benh@kernel.crashing.org Cc: airlied@redhat.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-04-11vgaarb.h: fix build warningsRandy Dunlap
Fix build warnings by providing a struct stub since no fields of the struct are used: include/linux/vgaarb.h:66:9: warning: 'struct pci_dev' declared inside parameter list include/linux/vgaarb.h:66:9: warning: its scope is only this definition or declaration, which is probably not what you want include/linux/vgaarb.h:99:34: warning: 'struct pci_dev' declared inside parameter list include/linux/vgaarb.h:109:6: warning: 'struct pci_dev' declared inside parameter list include/linux/vgaarb.h:121:8: warning: 'struct pci_dev' declared inside parameter list include/linux/vgaarb.h:140:37: warning: 'struct pci_dev' declared inside parameter list Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-27vgaarb: Wrap vga_(get|put) in CONFIG_VGA_ARBChris Wilson
Fix link failure without the vga arbitrator. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-12vgaarb: drop vga.h includeDave Airlie
We don't actually need this include on any platform. built on powerpc + x86, reported on m68k. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-21include/linux/vgaarb.h: add missing part of include guardDoug Goldstein
vgaarb.h was missing the #define of the #ifndef at the top for the guard to prevent multiple #include's from causing re-define errors Signed-off-by: Doug Goldstein <cardoe@gentoo.org> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-03vgaarb: use MIT licenseTiago Vignatti
Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com> Cc: Henry Zhao <Henry.Zhao@Sun.COM> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-24Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: make 32 bit NUMA node array int, not unsigned char x86/PCI: default pcibus cpumask to all cpus if it lacks affinity MAINTAINTERS: remove hotplug driver entries PCI: pciehp: remove slot capabilities definitions PCI: pciehp: remove error message definitions PCI: pciehp: remove number field PCI: pciehp: remove hpc_ops PCI: pciehp: remove pci_dev field PCI: pciehp: remove crit_sect mutex PCI: pciehp: remove slot_bus field PCI: pciehp: remove first_slot field PCI: pciehp: remove slot_device_offset field PCI: pciehp: remove hp_slot field PCI: pciehp: remove device field PCI: pciehp: remove bus field PCI: pciehp: remove slot_num_inc field PCI: pciehp: remove num_slots field PCI: pciehp: remove slot_list field PCI: fix VGA arbiter header file PCI: Disable AER with pci=nomsi ... Fixed up trivial conflicts in MAINTAINERS
2009-09-23vgaarb: make client interface config invariant.Ingo Molnar
Fixes build when VGA_ARB is off. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-17PCI: fix VGA arbiter header fileJesse Barnes
Remove reference to vgaarb.c and replace it with a comment about the arbiter itself. Reported-by: Tiago Vignatti <tiago.vignatti@nokia.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI/vgaarb: cleanup some warnings + cleanup some comments.Dave Airlie
Fix some warnings reported in linux-next + also cleanup some comment errors noticed by Pekka Paalanen. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI/GPU: implement VGA arbitration on LinuxBenjamin Herrenschmidt
Background: Graphic devices are accessed through ranges in I/O or memory space. While most modern devices allow relocation of such ranges, some "Legacy" VGA devices implemented on PCI will typically have the same "hard-decoded" addresses as they did on ISA. For more details see "PCI Bus Binding to IEEE Std 1275-1994 Standard for Boot (Initialization Configuration) Firmware Revision 2.1" Section 7, Legacy Devices. The Resource Access Control (RAC) module inside the X server currently does the task of arbitration when more than one legacy device co-exists on the same machine. But the problem happens when these devices are trying to be accessed by different userspace clients (e.g. two server in parallel). Their address assignments conflict. Therefore an arbitration scheme _outside_ of the X server is needed to control the sharing of these resources. This document introduces the operation of the VGA arbiter implemented for Linux kernel. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
