path: root/include/linux/videodev2.h
2008-10-21V4L/DVB (9320): v4l2: Add 10-bit RAW Bayer formatsSergio Aguirre
Add 10-bit raw bayer format expanded to 16 bits. Adds also definition for 10-bit raw bayer format dpcm-compressed to 8 bits. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8649): v4l2: add AAC bitrate controlHans Verkuil
If you can select AAC as audio encoder, then you should also be able to set the bitrate. Add this missing control. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8635): v4l: add AC-3 audio support to the MPEG Encoding APIHans Verkuil
Some models of the saa6752hs support AC-3. Extend the API with the necessary controls for AC-3. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8634): v4l2: extend MPEG Encoding API with AVC and AACJanne Grunau
Adds Advanced Audio Coding (AAC) and MPEG-4 Advanced Video Coding (AVC/H.264) as audio/video codecs to the extended controls API. Updates cx2341x driver to the new values. Signed-off-by: Janne Grunau <j@jannau.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8832): gspca: Bad pixelformat of vc0321 webcams.Jean-Francois Moine
Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8809): gspca: Revert commit 9a9335776548d01525141c6e8f0c12e86bbde982Hans de Goede
the previous patch (sensor upside down). Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8720): gspca: V4L2_CAP_SENSOR_UPSIDE_DOWN added as a cap for some ↵Hans de Goede
webcams. This patch adds a V4L2_CAP_SENSOR_UPSIDE_DOWN flag to the capabilities flags, and sets this flag for the Philips SPC200NC cam (which has its sensor installed upside down). The same flag is also needed and added for the Philips SPC300NC. Together with a patch to libv4l which adds flipping the image in software this fixes the upside down display with the SPC200NC cam. Signed-of-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8675): gspca: Pixmap PJPG (Pixart 73xx JPEG) added, generated by ↵Jean-Francois Moine
pac7311. The JPEG frames generated by the Pixart 73xx have: - special markers 'ff ff ff xx' every 1024/512 bytes, - unused 8 bits at end of JPEG blocks, and then ask for a new pixel format. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-08-16Fix header export of videodev2.h, ivtv.h, ivtvfb.hDavid Woodhouse
The exported copy of videodev2.h contains this line: #define #include <sys/time.h> This is because for some reason it defines __user for itself -- despite the fact that we remove all instances of __user when exporting headers. _All_ pointers in userspace are user pointers. Fix it by removing the unnecessary '#define __user' from the file. The new headers ivtv.h and ivtvfb.h would have the same problem... if whoever put them there had actually remembered to add them to the Kbuild file while he was at it. Fix those too, and export them as was presumably intended. Note that includes of <linux/compiler.h> are also stripped by the header export process, so those don't need to be conditional. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27V4L/DVB (8522): videodev2: Fix merge conflictMauro Carvalho Chehab
2008-07-27V4L/DVB (8524): videodev: copy the VID_TYPE defines to videodev.hHans Verkuil
The VID_TYPE defines are V4L1 specific, so copy them back to videodev.h. In videodev2.h ensure that they are not used in the kernel (you need to include videodev.h instead) and mark them are deprecated. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-27V4L/DVB (8518): gspca: Remove the remaining frame decoding functions from ↵Jean-Francois Moine
the subdrivers. SPCA505 and SPCA508 added in the pixel formats. Decode functions and associated resources removed in spca505, 506 and 508. The decode routines are now found in the V4L library. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-27V4L/DVB (8502): videodev2.h: CodingStyle cleanupsMauro Carvalho Chehab
2008-07-20V4L/DVB (8197): gspca: pac207 frames no more decoded in the subdriver.Hans de Goede
videodev2: New pixfmt pac207: Remove the specific decoding. main: get_buff_size operation added for the subdriver. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8194): gspca: Fix the format of the low resolution mode of spca561.Hans de Goede
The low (half) res modes of the spca561 are not spca561 compressed, but are raw bayer, this patches fixes this and adds a PIX_FMT define for the GBRG bayer format used by the spca561 in low res mode. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8157): gspca: all subdriversJean-Francois Moine
- remaning subdrivers added - remove the decoding helper and some specific frame decodings Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (7942): Hardware frequency seek ioctl interfaceTobias Lorenz
Signed-off-by: Tobias Lorenz <tobias.lorenz@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7166): [v4l] Add new user class controls and deprecate othersDavid Woodhouse
These were removed in commit 26d507fcfef7f7d0cd2eec874a87169cc121c835: > -#define V4L2_CID_HCENTER (V4L2_CID_BASE+22) > -#define V4L2_CID_VCENTER (V4L2_CID_BASE+23) > -#define V4L2_CID_LASTP1 (V4L2_CID_BASE+24) /* > last CID + 1 */ > + > +/* Deprecated, use V4L2_CID_PAN_RESET and V4L2_CID_TILT_RESET */ > +#define V4L2_CID_HCENTER_DEPRECATED (V4L2_CID_BASE+22) > +#define V4L2_CID_VCENTER_DEPRECATED (V4L2_CID_BASE+23) But there was no warning in Documentation/feature-removal-schedule.txt and I'm receiving reports that it's breaking userspace apps (the gstreamer-v4l2 plugin breaks in Fedora rawhide). You can't just pull things from the published userspace API like that. Please can we revert the addition of _DEPRECATED to these ioctl definitions. Perhaps we can add a runtime warning if they actually get used? Or a compile-time warning if we can manage that? Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7453): v4l2-api: Define a standard control for color killer ↵Frej Drejhammar
functionality Define a pre-defined control ID for color killer functionality. Signed-off-by: "Frej Drejhammar <frej.drejhammar@gmail.com>" Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7450): v4l2-api: Define a standard control for chroma AGCFrej Drejhammar
Define a pre-defined control ID for chroma automatic gain control. Signed-off-by: "Frej Drejhammar <frej.drejhammar@gmail.com>" Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7178): Add two new fourcc codes for 16bpp formatsSteven Whitehouse
This adds two new fourcc codes (as per info at fourcc.org) for 16bpp mono and 16bpp Bayer formats. Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7167): [v4l] Add camera class control definitionsBrandon Philips
Add all of the recently proposed camera class controls. These controls should appear in the next version of the v4l2spec. Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7166): [v4l] Add new user class controls and deprecate othersBrandon Philips
These changes should appear in the next update of the v4l2spec. HCENTER and VCENTER are unused in the tree so I added a _DEPRECATED postfix so applications can remove their use. Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7198): V4L, include ioctl.h in videodev headersJiri Slaby
Fix compilation of user processes which includes videodev*.h but not includes linux/ioctl.h: v4l2ext_helper.c: In function 'process_ioctl': v4l2ext_helper.c:183: warning: implicit declaration of function '_IOWR' v4l2ext_helper.c:183: error: expected expression before 'struct' v4l2ext_helper.c:183: error: case label does not reduce to an integer constant Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-22V4L/DVB (6321): Remove obsolete VIDIOC_S/G_MPEGCOMP ioctlsHans Verkuil
Remove the obsolete VIDIOC_G_MPEGCOMP and VIDIOC_S_MPEGCOMP ioctls from the V4L2 API as per the removal schedule (October 2007). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6108): videodev2.h: add new pixel formats for the cx23415 OSDHans Verkuil
The Conexant cx23415 MPEG encoder/decoder supports some unusual pixelformats for the On-Screen Display. Add new defines to videodev2.h for these formats. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-08-20V4L/DVB (5968): videodev2.h: remove superfluous FBUF GLOBAL_INV_ALPHA supportHans Verkuil
There is no need for a global inverted alpha capability since all the application has to do is to pass '255-alpha' as the global alpha value. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-20V4L/DVB (5867): videodev2.h: add missing <sys/time.h> for userspaceHans Verkuil
When videodev2.h is included by an application, it needs to include <sys/time.h> for the timeval struct. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-06-08V4L/DVB (5736): Add V4L2_FBUF_CAP/FLAG_LOCAL/GLOBAL_INV_ALPHAHans Verkuil
Michael Schimek requested the addition of inverted alpha framebuffer caps/flags to support such hardware. 'Normal' alpha uses this formula to mix the framebuffer and video: output = fb pixel * fb alpha + video pixel * (1 - fb alpha) and the 'inverted' alpha uses this formula: output = fb pixel * (1 - fb alpha) + video pixel * fb alpha Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-06-08V4L/DVB (5730): Remove unused V4L2_CAP_VIDEO_OUTPUT_POSHans Verkuil
V4L2_CAP_VIDEO_OUTPUT_POS was initially introduced for 2.6.22 but never actually used: remove it before the final 2.6.22 is made. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-22V4L/DVB (5670): Adding new fields to v4l2_pix_format broke the ABI, reverted ↵Hans Verkuil
that change Reverted the change to struct v4l2_pix_format. I completely missed that this struct was used by existing ioctls so that changing it broke the ABI. I will have to think of another way of setting the top/left coordinates but for now this change is reverted to preserve compatibility. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5306): Add support for VIDIOC_G_CHIP_IDENTHans Verkuil
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be used to detect which chips are on the board and based on that information selected register dumps can be made, making it easy to debug complicated media chips containing tens or hundreds of registers. This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5289): Add support for video output overlays.Hans Verkuil
Add V4L2_BUF_TYPE_VIDEO_OUTPUT_OVERLAY support. Also add support for local and global alpha overlays. Add new field enums V4L2_FIELD_INTERLACED_TB and V4L2_FIELD_INTERLACED_BT. These changes are needed to support the ivtv On Screen Display features. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5272): Add V4L2_CAP_VIDEO_OUTPUT_POS capabilityHans Verkuil
Add V4L2_CAP_VIDEO_OUTPUT_POS capability and x, y position coordinates to struct v4l2_pix_format. This is needed to support positioning the MPEG/YUV output of the cx23415. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5268): Add support for three new MPEG controls.Hans Verkuil
Added V4L2_CID_MPEG_AUDIO_MUTE, V4L2_CID_MPEG_VIDEO_MUTE and V4L2_CID_MPEG_CX2341X_STREAM_INSERT_NAV_PACKETS controls together with their implementation in the cx2341x module. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5305): Mark VIDIOC_DBG_S/G_REGISTER as experimentalHans Verkuil
Move VIDIOC_DBG_S/G_REGISTER from the internal ioctl list to the public ioctls, but mark it as experimental for now. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5271): Add VIDIOC_TRY_ENCODER_CMD and VIDIOC_ENCODER_CMD ioctls.Hans Verkuil
Add support for starting, stopping, pausing and resuming an MPEG (or similar compressed stream) encoder. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5270): Add VIDIOC_G_ENC_INDEX ioctlHans Verkuil
The VIDIOC_G_ENC_INDEX ioctl can obtain the MPEG index from an MPEG encoder. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5304): Improve chip matching in v4l2_registerHans Verkuil
The chip matching in struct v4l2_register for VIDIOC_DBG_G/S_REGISTER was rather primitive. It could not be extended to other busses besides i2c and it lacked a way to. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5204): Change videodev2.h licence to dual GPL/BSDMichael Schimek
videodev2.h contains just the V4L2 API structs and defines. By allowing this header file to be dual GPL/BSD will enable sharing userspace apps between Linux and *BSD systems. It will also allow developing newer BSD licensed drivers that can be shared on Linux and *BSD. It should be noticed that most of the current V4L drivers, and v4l core itself are GPL only. This won't be changed by this patch. Signed-off-by: Michael H. Schimek <mschimek@gmx.at> Signed-off-by: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Bill Dirks <bill@thedirks.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Martin Rubli <mrubli@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5182): Remove #if 0 section from videodev2.hHans Verkuil
Remove a section containing basically ideas for future sliced VBI standards. This can be resurrected should any of this be actually implemented. For now it only pollutes this header file. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5181): Sliced VBI API no longer marked experimental.Hans Verkuil
The Sliced VBI API is no longer marked experimental. Introduced in 2.6.14 and with only a single modification in 2.6.19 I think we can consider this API to be solid. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5162): Change VIDIOC_DBG_[SG]_REGISTER ioctls' reg address to 64 bitsTrent Piepho
Maybe someday there will be a device with a register address space > 32-bits, or maybe an i2c device which uses a protocol > 4 bytes long to address its registers. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5146): Make VIDIOC_INT_[SG]_REGISTER ioctls no longer internal onlyTrent Piepho
The direct register access ioctls were defined as kernel internal only, but they are very useful for debugging hardware from userspace and are used as such. Officially export them. VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER Definition of ioctl and struct v4l2_register is moved from v4l2-common.h to videodev2.h. Types used in struct v4l2_register are changed to the userspace exportable versions (u32 -> __u32, etc). Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move the check into the video_ioctl2() dispatcher so it doesn't need to be duplicated in each driver's call-back function. CAP_SYS_ADMIN check is added to pvrusb2 (which doesn't use video_ioctl2). Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5068): Fix authorship referencesMauro Carvalho Chehab
Bill Dirks asked me to update his entries at kernel files, since he change his e-mail. I've also updated a few web broken links or obsolete info to the curent sites where V4L drivers and API are being discussed currently. CC: Bill Dirks <bill@thedirks.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-01-15V4L/DVB (5023): Fix compilation on ppc32 architectureMauro Carvalho Chehab
There's a problem, pointed by Meelis Roos <mroos@linux.ee>, that, on ppc32 arch, with some gcc versions (noticed with prerelease 4.1.2 20061115), compilation fails, due the lack of __ucmpdi2 to do the required 64-bit comparision. This patch takes some sugestions made by Andrew Morton <akpm@osdl.org>, Stelian Pop <stelian@popies.net> and Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4796): A couple of V4L2 defines needed by Cafe Camara driverJonathan Corbet
Two defines for V4L2, needed by the Cafe camera driver: 1) Add the RGB444 image format 2) Add the "init" internal command which is separate from "reset". Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-14V4L/DVB (4746): HM12 is YUV 4:2:0, not YUV 4:1:1Hans Verkuil
Fix comment in videodev2.h Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4673): Mark the two newer ioctls as experimentalMauro Carvalho Chehab
VIDIOC_ENUM_FRAMESIZES and VIDIOC_ENUM_FRAMEINTERVALS ioctls are meant to be used to provide better support for webcams. Currently, it is not yet used on kernel drivers. Better to keep it marked as experimental, until we have several kernel drivers supporting those features. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4672): Frame format enumeration (1/2)Laurent Pinchart
Add VIDIOC_ENUM_FRAMESIZES and VIDIOC_ENUM_FRAMEINTERVALS ioctls to enumerate supported frame sizes and frame intervals. Signed-off-by: Martin Rubli <martin.rubli@epfl.ch> Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
