path: root/include/linux/virtio_9p.h
2010-10-27Remove duplicate includes from many filesZimny Lech
Signed-off-by: Zimny Lech <napohybelskurwysynom2010@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11virtio_9p.h: include linux/types.hRandy Dunlap
Add <linux/types.h> to <linux/virtio_9p.h> so that types are explicitly defined: linux/virtio_9p.h:15: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-02virtio_9p.h needs <linux/types.h>Fang Wenqi
Found with makes headers_check: include/linux/virtio_9p.h:15: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Fang Wenqi <antonf@turbolinux.com.cn> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-03-13net/9p: Use the tag name in the config space for identifying mount pointAneesh Kumar K.V
This patch use the tag name in the config space to identify the mount device. The the virtio device name depend on the enumeration order of the device and may not remain the same across multiple boots So we use the tag name which is set via qemu option to uniquely identify the mount device Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-03-05net/9p: Remove MAX_9P_CHAN limitAneesh Kumar K.V
Use a list to track the channel instead of statically allocated array Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-03-05net/9p: Add multi channel support.Aneesh Kumar K.V
This is needed for supporting multiple mount points. We can find out the device names to be used with mount by checking /sys/devices/virtio-pci/virtio*/device file if the device file have value 9 then the specific virtio device can be used for mounting. ex: #cat /sys/devices/virtio-pci/virtio1/device 9 now we can mount using # mount -t 9p -o trans=virtio virtio1 /mnt/ Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: clarify that ABI is usable by any implementationsRusty Russell
We want others to implement and use virtio, so it makes sense to BSD license the non-__KERNEL__ parts of the headers to make this crystal clear. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Ryan Harper <ryanh@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com> Acked-by: Anthony Liguori <aliguori@us.ibm.com>
2007-10-239p: add virtio transportEric Van Hensbergen
This adds a transport to 9p for communicating between guests and a host using a virtio based transport. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
